IDE Fehler mit CubeCellHTCC AB-01
Hallo Gemeinde
ich bin gerade am testen mit den Heltec Cube Cell Boards für LoraWAN. Leider wirft mir die IDE Fehler aus, bei dehnen ich nicht weiter komme.
Betriebssystem OSX 10.13.6
IDE 1.8.12
Heltecboard wurden über den Boardmanager installiert, und es befinden sich alle Files im Ordner :
Library/ Arduino 15/Packages/Cubezell. inklussive aller TOOLS LIBS & BEISPIELE.
Beim kompilieren eines Beisieles wirft er folgenden Fehler:
"/Users/olaf 1/Library/Arduino15/packages/CubeCell/tools/gcc-arm-none-eabi/8-2019-q3/bin/arm-none-eabi-ar" -rcs /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/core/core.a /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/core/cores/WString.cpp.o
"/Users/olaf 1/Library/Arduino15/packages/CubeCell/tools/gcc-arm-none-eabi/8-2019-q3/bin/arm-none-eabi-ar" -rcs /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/core/core.a /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/core/main.cpp.o
Gebauter Kern wird archiviert (zwischengespeichert) in: /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_cache_398423/core/core_e15d7c4c691f33afa73e3092c7718d92.a
Linking everything together...
"/Users/olaf 1/Library/Arduino15/packages/CubeCell/tools/gcc-arm-none-eabi/8-2019-q3/bin/arm-none-eabi-gcc" -Wl,--start-group -L/var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798 -mcpu=cortex-m0plus -mthumb -mthumb-interwork "-L/Users/olaf 1/Library/Arduino15/packages/CubeCell/hardware/CubeCell/1.0.0/cores/asr650x/projects/PSoC4" "-T/Users/olaf 1/Library/Arduino15/packages/CubeCell/hardware/CubeCell/1.0.0/cores/asr650x/projects/PSoC4/cm0plusgcc.ld" -lstdc++ -lm "/Users/olaf 1/Library/Arduino15/packages/CubeCell/hardware/CubeCell/1.0.0/cores/asr650x/projects/CubeCellLib.a" -Wl,-Map,/var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/LoRaWAN_BMP280.ino.map -specs=nano.specs -Wl,--gc-sections -Wl,--wrap=printf -Wl,--wrap=fflush -Wl,--wrap=sprintf -Wl,--wrap=snprintf -g -ffunction-sections -Os -ffat-lto-objects -o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/LoRaWAN_BMP280.ino.elf /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/sketch/LoRaWAN_BMP280.ino.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/LoRa/LoRaWan_APP.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/LoRa/LoRa_APP.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/Sensor_ThirdParty/BME680.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/Sensor_ThirdParty/BMP280.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/Sensor_ThirdParty/SC16IS740RK.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/Sensor_ThirdParty/SHT2x.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/Sensor_ThirdParty/VL53L1X.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/Sensor_ThirdParty/vl53l1x_class.cpp.o /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/libraries/RGB/CubeCell_NeoPixel.cpp.o -lm /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/core/core.a -Wl,--end-group
"/Users/olaf 1/Library/Arduino15/packages/CubeCell/tools/CubeCellelftool/0.0.1/CubeCellelftool" "/Users/olaf 1/Library/Arduino15/packages/CubeCell/tools/gcc-arm-none-eabi/8-2019-q3/bin/arm-none-eabi-objcopy" /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/LoRaWAN_BMP280.ino.elf /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/LoRaWAN_BMP280.ino.hex /var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/CubeCell_Board_REGION_AS923_RGB_1.cyacd
sh: /Users/olaf: No such file or directory
[20135] Failed to execute script CubeCellelftool
Traceback (most recent call last):
File "CubeCellelftool.py", line 3, in
File "elftool.py", line 26, in elftool.main
FileNotFoundError: [Errno 2] No such file or directory: '/var/folders/fm/zgs651217s56l10yx7_xbc4m0000gn/T/arduino_build_697798/LoRaWAN_BMP280.ino.hex'
Bibliothek LoRa in Version 1.0 im Ordner: /Users/olaf 1/Library/Arduino15/packages/CubeCell/hardware/CubeCell/1.0.0/libraries/LoRa wird verwendet
Bibliothek Sensor_ThirdParty in Version 1.1.0 im Ordner: /Users/olaf 1/Library/Arduino15/packages/CubeCell/hardware/CubeCell/1.0.0/libraries/Sensor_ThirdParty wird verwendet
Bibliothek RGB in Version 1.0 im Ordner: /Users/olaf 1/Library/Arduino15/packages/CubeCell/hardware/CubeCell/1.0.0/libraries/RGB wird verwendet
exit status 255
Fehler beim Kompilieren für das Board CubeCell-Board(HTCC-AB01).
Die beiden Files "CubeCellelftool.py" & "elftool.py" sind leider nicht über die Suche zu finden, damit ist auch eine Analyse der betreffenden Zeilen nicht möglich.
"CubeCellelftool" & "elftool" sind als ausführbare Dateien unter Tools vorhanden, jedoch ohne .py.
Hat jemand einen Lösungsansatz für dieses Problem?
Python ist nicht wirklich meine Sprache.
Grüße
Broemmel:
Hallo Gemeinde
Was sagt Heltec dazu?
Gruß
Gregor
Bis jetzt noch nichts,
Nur sone Idee:
Broemmel:
Ist da ein Leerzeichen drin?
Denn hier:
[/quote]
siehts so aus, als ob der Path verlorengeht.
Vielleicht kann ja mal jemand anderes mit mehr Erfahrung rund um den Compiler dauf schaun. Ich würd aber meinen, das das nicht in Ordnung ist.
Gelöst:
@ my_xy_projekt. Wir hatten beide die selbe Idee: lag diesmal an Apple selber.
Das System hat mir mal einen Benutzerordner mit Leerzeichen & 1 angelegt, als ich mein Netzwerk eingerichtet hatte & der Vorgängerrechner im Netzwerk war.
selber geben sie an, das der Benutzerordner ohne Leerzeichen sein muss.
Hat mehrere Jahre funktioniert ohne aufzufallen, bis die IDE durch das neue Board auf Python zugreift und eine Pfadstruktur erwartet.
Benutzerordener umbenannt und gut iss.
jetzt läuft es
Broemmel:
Gelöst:
jetzt läuft es
Schön wenn man auch mal Erfolge hört!
Danke für die Rückmeldung!
