IDE for Windows7/8/10
I am missing the Pin-function in Windows. Currently, if you open for example Word or a Windows program, you can see your last opened documents and pin the application on the taskbar.
In Arduino (probably because it is wrote in Java), you can only select "close window" if you press with the right mouse button on the taskbar-icon.
It would be nice to have more options, like other Windows applications.
Bye,
Adriano
In windows 8 you can right click on 'arduino.exe' and select 'Pin to Taskbar'. Although yes, the menu on the taskbar item does not have the option.
While the splash screen is showing, right-click the icon on the taskbar and select "pin to taskbar". You have to be quick, though. Or you can drag the .exe onto the taskbar.
