IDE going crazy on me can i get some tips/advise/help
Hello guys i need some help as this is my very first code i written and i got errors out of no where that i cant even understand as the IDE is not being specific enough to my understanding ill post my code below for your review
//imu's
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
//motors
#include "Servo.h"
//wireless
#include "nRF24L01.h"
#include "RF24.h"
#include "SPI.h"
const uint64_t LeftArm   = 0xF0F0F0F0D2LL;//mcu address
const uint64_t RightArm  = 0xF0F0F0F0C3LL;//mcu address
const uint64_t LeftLeg   = 0xF0F0F0F0B4LL;//mcu address
const uint64_t RightLeg  = 0xF0F0F0F0A5LL;//mcu address
const uint64_t LeftWrist = 0xF0F0F0F0E6LL;//mcu address
const uint64_t RighWrist = 0xF0F0F0F0F7LL;//mcu address
RF24 radio(9, 10);
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
struct MyData{
//Left Arm IMU ADDRESS WILL BE THE MUX CH 0
Servo AxLshoulder;
Servo AyLarm;
Servo GxLbicep;
Servo GzLelbow;
//Right Arm IMU ADDRESS WILL BE THE MUX CH 1
Servo AxRshoulder;
Servo AyRarm;
Servo GxRbicep;
Servo GzRelbow;
//both Wrist Gyro roll up/dwn roll lft/rgt
Servo GxLwrist; //ch2
Servo GzLwrist; //ch2
Servo GxRwrist; //ch3
Servo GzRwrist; //ch3
/* Left Hand
Stepper GxThumbj1;
Stepper GzThumbj2;
Stepper GxIndexj1;
Stepper GzIndexj2;
Stepper Gxvectorj1;
Stepper GzVectorj2;
Right Hand
Stepper GxThumbj1;
Stepper GzThumbj2;
Stepper GxIndexj1;
Stepper GzIndexj2;
Stepper Gxvectorj1;
Stepper GzVectorj2;
Left Leg IMU ADDRESS WILL BE THE MUX CH4
Right Leg IMU ADDRESS WILL BE THE MUX CH5
//both Ankles Gyro roll up/dwn roll lft/rgt
Servo GxLAnkle; //ch6
Servo GzLAnkle; //ch6
Servo GxRAnkle; //ch7
Servo GzRAnkle; //ch7
int AxLshoulder.attach(4);
int AyLarm.attach(3);
int GxLbicep.attach(2);
int GzLelbow.attach(1);
MyData data;
long val;
long prevVal;
  Wire.begin();
  mpu.initialize();
  radio.begin();
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.openWritingPipe(LeftArm);
    mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    val = map(ax, -17000, 17000, 0, 180);
    val = map(az, -17000, 17000, 0, 180);
    val = map(gz, -17000, 17000, 0, 180);
    val = map(gy, -17000, 17000, 0, 180);
    val = map(gx, -17000, 17000, 0, 180);
    val = map(ay, -17000, 17000, 0, 180);
  if (val != prevVal)
    radio.write(&data, val, sizeof(MyData));
    prevVal = val;
   delay(50);
Well this is the Compiling errors i got
Arduino: 1.6.1 (Windows 8.1), Board: "Arduino Nano, ATmega328"
TESTING_IMU_nRF_Servo_Tx.ino:36:1: error: expected unqualified-id before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:36:1: error: expected constructor, destructor, or type conversion before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:38:1: error: expected unqualified-id before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:38:1: error: expected constructor, destructor, or type conversion before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:35:16: error: expected constructor, destructor, or type conversion before 'LeftArm'
TESTING_IMU_nRF_Servo_Tx.ino:44:9: error: expected constructor, destructor, or type conversion before 'mpu'
TESTING_IMU_nRF_Servo_Tx.ino:49:1: error: expected unqualified-id before 'struct'
TESTING_IMU_nRF_Servo_Tx.ino:49:1: error: expected constructor, destructor, or type conversion before 'struct'
TESTING_IMU_nRF_Servo_Tx.ino:95:1: error: expected unqualified-id before 'int'
TESTING_IMU_nRF_Servo_Tx.ino:95:1: error: expected constructor, destructor, or type conversion before 'int'
TESTING_IMU_nRF_Servo_Tx.ino:96:11: error: expected initializer before '.' token
TESTING_IMU_nRF_Servo_Tx.ino:97:13: error: expected initializer before '.' token
TESTING_IMU_nRF_Servo_Tx.ino:98:13: error: expected initializer before '.' token
TESTING_IMU_nRF_Servo_Tx.ino:101:8: error: expected constructor, destructor, or type conversion before 'data'
TESTING_IMU_nRF_Servo_Tx.ino:107:1: error: expected unqualified-id before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:107:1: error: expected constructor, destructor, or type conversion before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:119:1: error: expected unqualified-id before 'void'
TESTING_IMU_nRF_Servo_Tx.ino:119:1: error: expected constructor, destructor, or type conversion before 'void'
Error compiling.
You should make small steps. Test small parts of code and try to make them work. Combine them if everything is okay.
Which Arduino board do you use ? An Arduino Nano ? You should select the board in the IDE, so the compiler know for which microcontroller is should be compiled.
64-bit unsigned integer ? I don't know if an Arduino Nano can use uint64_t, I think not. What about so many Servo and Stepper definitions in your struct. I think the Nano will run out of ram.
I hope you use the Arduino Due or Zero for your project, or else a Teensy or perhaps the Raspberry Pi.
