IDE hangs on startup after update
Hi, @ptillisch this is my first post so apologies if in the wrong place or too long.
I also have the never ending pulsing logo having just updated to 2.1
Not done any coding for a while and when I opened the IDE it prompted to update - which I did only to get stuck when relaunched after the update.
Have read numerous threads on the forum and tried a few but none have fixed the issue.
I found the log files in ..\AppData\Roaming\Arduino IDE\YYYY-MM-DD_log.log
There are some warnings but nothing that stands out, have attached the latest log file contents for you to examine.
Running Win10 22H2 CPU N3700 @ 1.60GHz 8GB Ram 1.1TB Free on HD
2023-06-03 00:20:58 Using browser-only version of superagent in non-browser environment
2023-06-03 00:20:58 Configuration directory URI: 'file:///c%3A/Users/Les/.theia'
2023-06-03 00:20:58 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-06-03 00:20:59 2023-06-02T23:20:59.126Z root INFO Backend Object.initialize: 19.5 ms [Finished 8.127 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.126Z root INFO Backend Object.configure: 14.9 ms [Finished 8.128 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.127Z root INFO Backend MessagingContribution.onStart: 7.6 ms [Finished 8.128 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.130Z root INFO Backend OSBackendApplicationContribution.configure: 1.6 ms [Finished 8.335 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.133Z root INFO Backend DefaultWorkspaceServer.onStart: 1.4 ms [Finished 8.335 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.138Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.9 ms [Finished 8.336 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.141Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 207.3 ms [Finished 8.337 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.142Z root INFO Backend TaskBackendApplicationContribution.onStart: 1.3 ms [Finished 8.337 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.146Z root INFO Backend ElectronTokenBackendContribution.configure: 3.6 ms [Finished 8.342 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.149Z config INFO >>> Initializing CLI configuration...
2023-06-03 00:20:59 2023-06-02T23:20:59.150Z root INFO Backend PluginDeployerContribution.initialize: 2.4 ms [Finished 8.343 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.151Z root INFO Backend ConfigServiceImpl.onStart: 3.7 ms [Finished 8.345 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.155Z config INFO Loading CLI configuration from c:\Users\Les\.arduinoIDE\arduino-cli.yaml...
2023-06-03 00:20:59 2023-06-02T23:20:59.158Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 1.8 ms [Finished 8.350 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.158Z root INFO Backend ArduinoDaemonImpl.onStart: 4.9 ms [Finished 8.354 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.158Z root INFO Backend NodeFileUploadService.configure: 9.4 ms [Finished 8.355 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.159Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-06-03 00:20:59 2023-06-02T23:20:59.160Z discovery-log INFO start
2023-06-03 00:20:59 2023-06-02T23:20:59.160Z discovery-log INFO start new deferred
2023-06-03 00:20:59 2023-06-02T23:20:59.160Z root INFO Backend HostedPluginLocalizationService.initialize: 2.3 ms [Finished 8.359 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.161Z root INFO Backend BoardDiscovery.onStart: 4.9 ms [Finished 8.362 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.161Z root INFO Backend FileDownloadEndpoint.configure: 3.9 ms [Finished 8.364 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.162Z root INFO Backend AuthenticationServiceImpl.onStart: 1.9 ms [Finished 8.370 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.162Z root INFO Backend PluginApiContribution.configure: 2.0 ms [Finished 8.371 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.167Z root INFO Backend HostedPluginReader.configure: 1.4 ms [Finished 8.374 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.167Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 8.375 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.167Z root INFO Backend PlotterBackendContribution.configure: 4.2 ms [Finished 8.380 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.181Z root INFO Theia app listening on http://localhost:51937.
2023-06-03 00:20:59 2023-06-02T23:20:59.183Z root INFO Finished starting backend application: 21.9 ms [Finished 8.394 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.445Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.445Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.446Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.446Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.446Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.447Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.447Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.448Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.448Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.449Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.449Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.450Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.450Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.450Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.450Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.451Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.451Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.451Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.452Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.452Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.452Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.453Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.453Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.453Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.453Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.454Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.454Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.454Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.455Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.455Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.455Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.456Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-03 00:20:59 2023-06-02T23:20:59.456Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-06-03 00:20:59 2023-06-02T23:20:59.521Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Les\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Les\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Les\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-06-03 00:20:59 2023-06-02T23:20:59.523Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-06-03 00:20:59 2023-06-02T23:20:59.524Z config INFO Loaded the CLI configuration.
2023-06-03 00:20:59 2023-06-02T23:20:59.530Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Les/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Les/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-06-03 00:20:59 2023-06-02T23:20:59.531Z config INFO Validating the CLI configuration...
2023-06-03 00:20:59 2023-06-02T23:20:59.540Z config INFO The CLI config is valid.
2023-06-03 00:20:59 2023-06-02T23:20:59.540Z config INFO <<< Initialized the CLI configuration.
2023-06-03 00:20:59 2023-06-02T23:20:59.609Z root INFO Resolve plugins list: 455.5 ms [Finished 8.820 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.628Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 18.3 ms [Finished 8.840 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.643Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 15.1 ms [Finished 8.855 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.673Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 29.7 ms [Finished 8.885 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.681Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 8.1 ms [Finished 8.893 s after backend start]
2023-06-03 00:20:59 2023-06-02T23:20:59.684Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.9 ms [Finished 8.896 s after backend start]
2023-06-03 00:21:00 2023-06-02T23:21:00.042Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 357.2 ms [Finished 9.254 s after backend start]
2023-06-03 00:21:01 2023-06-02T23:21:01.723Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 1680.7 ms [Finished 10.935 s after backend start]
2023-06-03 00:21:02 2023-06-02T23:21:02.351Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 628.0 ms [Finished 11.563 s after backend start]
2023-06-03 00:21:02 2023-06-02T23:21:02.766Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 415.4 ms [Finished 11.978 s after backend start]
2023-06-03 00:21:12 2023-06-02T23:21:12.831Z daemon INFO e[36mINFOe[0m[0000] Using config file: c:\Users\Les\.arduinoIDE\arduino-cli.yaml
e[36mINFOe[0m[0000] arduino-cli.exe version 0.32.2
e[36mINFOe[0m[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:51938
{"IP":"127.0.0.1","Port":"51938"}
2023-06-03 00:21:12 2023-06-02T23:21:12.833Z daemon INFO Daemon is running.
2023-06-03 00:21:13 2023-06-02T23:21:13.119Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 10352.8 ms [Finished 22.331 s after backend start]
2023-06-03 00:21:13 2023-06-02T23:21:13.158Z daemon INFO e[36mINFOe[0m[0010] Loading hardware from: C:\Users\Les\AppData\Local\Arduino15\packages
e[36mINFOe[0m[0010] Loading package builtin from: C:\Users\Les\AppData\Local\Arduino15\packages\builtin
2023-06-03 00:21:13 2023-06-02T23:21:13.160Z daemon INFO e[36mINFOe[0m[0010] Checking existence of 'tools' path: C:\Users\Les\AppData\Local\Arduino15\packages\builtin\tools
e[36mINFOe[0m[0010] Loading tools from dir: C:\Users\Les\AppData\Local\Arduino15\packages\builtin\tools
2023-06-03 00:21:13 2023-06-02T23:21:13.163Z daemon INFO e[36mINFOe[0m[0010] Loaded tool                                   e[36mtoole[0m="builtin:ctags@5.8-arduino11"
e[36mINFOe[0m[0010] Loaded tool                                   e[36mtoole[0m="builtin:mdns-discovery@1.0.9"
2023-06-03 00:21:13 2023-06-02T23:21:13.379Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 259.9 ms [Finished 22.591 s after backend start]
2023-06-03 00:21:13 2023-06-02T23:21:13.380Z daemon INFO e[36mINFOe[0m[0010] Loaded tool                                   e[36mtoole[0m="builtin:serial-discovery@1.4.0"
e[36mINFOe[0m[0010] Loaded tool                                   e[36mtoole[0m="builtin:serial-monitor@0.13.0"
e[36mINFOe[0m[0010] Checking signature                            e[36mindexe[0m="C:\\Users\\Les\\AppData\\Local\\Arduino15\\package_index.json" e[36msignatureFilee[0m="C:\\Users\\Les\\AppData\\Local\\Arduino15\\package_index.json.sig" e[36mtrustede[0m=true
e[36mINFOe[0m[0010] Loading libraries index file                  e[36mindexe[0m="C:\\Users\\Les\\AppData\\Local\\Arduino15\\library_index.json"
2023-06-03 00:21:13 2023-06-02T23:21:13.776Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 396.0 ms [Finished 22.988 s after backend start]
2023-06-03 00:21:14 2023-06-02T23:21:14.189Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 413.0 ms [Finished 23.401 s after backend start]
2023-06-03 00:21:14 2023-06-02T23:21:14.227Z daemon INFO e[36mINFOe[0m[0011] Adding libraries dir                          e[36mdire[0m="C:\\Users\\Les\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
e[36mINFOe[0m[0011] Adding libraries dir                          e[36mdire[0m="C:\\Users\\Les\\Documents\\Arduino\\libraries" e[36mlocatione[0m=user
2023-06-03 00:21:14 2023-06-02T23:21:14.700Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 511.5 ms [Finished 23.913 s after backend start]
2023-06-03 00:21:14 2023-06-02T23:21:14.968Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 267.3 ms [Finished 24.180 s after backend start]
2023-06-03 00:21:15 2023-06-02T23:21:15.727Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 759.1 ms [Finished 24.939 s after backend start]
2023-06-03 00:21:15 2023-06-02T23:21:15.738Z discovery-log INFO start request start watch
2023-06-03 00:21:15 2023-06-02T23:21:15.739Z discovery-log INFO start requested start watch
2023-06-03 00:21:15 2023-06-02T23:21:15.740Z discovery-log INFO start resolved watching
2023-06-03 00:21:16 2023-06-02T23:21:16.984Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 1257.1 ms [Finished 26.197 s after backend start]
2023-06-03 00:21:16 2023-06-02T23:21:16.985Z daemon INFO e[36mINFOe[0m[0013] starting discovery builtin:mdns-discovery process
e[36mINFOe[0m[0013] starting discovery builtin:serial-discovery process
e[36mINFOe[0m[0013] started discovery builtin:serial-discovery process
e[36mINFOe[0m[0013] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:serial-discovery
e[36mINFOe[0m[0014] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
e[36mINFOe[0m[0014] sending command START_SYNC to discovery builtin:serial-discovery
e[36mINFOe[0m[0014] from discovery builtin:serial-discovery received message type: start_sync, message: OK
e[36mINFOe[0m[0014] from discovery builtin:serial-discovery received message type: add, port: COM1
e[36mINFOe[0m[0014] started discovery builtin:mdns-discovery process
e[36mINFOe[0m[0014] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:mdns-discovery
e[36mINFOe[0m[0014] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
e[36mINFOe[0m[0014] sending command START_SYNC to discovery builtin:mdns-discovery
e[36mINFOe[0m[0014] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-06-03 00:21:16 2023-06-02T23:21:16.994Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-06-03 00:21:17 2023-06-02T23:21:17.920Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 935.3 ms [Finished 27.132 s after backend start]
2023-06-03 00:21:18 2023-06-02T23:21:18.692Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 772.2 ms [Finished 27.905 s after backend start]
2023-06-03 00:21:19 2023-06-02T23:21:19.434Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 742.2 ms [Finished 28.647 s after backend start]
2023-06-03 00:21:19 2023-06-02T23:21:19.768Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 286.4 ms [Finished 28.933 s after backend start]
2023-06-03 00:21:19 2023-06-02T23:21:19.769Z root INFO Deploy plugins list: 455.5 ms [Finished 28.981 s after backend start]
What I noticed is that towards the end the event order becomes different?
End of another log file
2023-06-02 23:26:31 2023-06-02T22:26:31.101Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 144.6 ms [Finished 23.588 s after backend start]
2023-06-02 23:26:31 2023-06-02T22:26:31.397Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 295.7 ms [Finished 23.884 s after backend start]
2023-06-02 23:26:31 2023-06-02T22:26:31.655Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 257.8 ms [Finished 24.142 s after backend start]
2023-06-02 23:26:31 2023-06-02T22:26:31.963Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 307.9 ms [Finished 24.450 s after backend start]
2023-06-02 23:26:31 2023-06-02T22:26:31.974Z discovery-log INFO start request start watch
2023-06-02 23:26:31 2023-06-02T22:26:31.976Z discovery-log INFO start requested start watch
2023-06-02 23:26:31 2023-06-02T22:26:31.977Z discovery-log INFO start resolved watching
2023-06-02 23:26:31 2023-06-02T22:26:31.980Z daemon INFO e[36mINFOe[0m[0012] starting discovery builtin:mdns-discovery process
2023-06-02 23:26:32 2023-06-02T22:26:32.258Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 294.2 ms [Finished 24.745 s after backend start]
2023-06-02 23:26:32 2023-06-02T22:26:32.259Z daemon INFO e[36mINFOe[0m[0012] starting discovery builtin:serial-discovery process
2023-06-02 23:26:32 2023-06-02T22:26:32.445Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 187.0 ms [Finished 24.932 s after backend start]
2023-06-02 23:26:32 2023-06-02T22:26:32.447Z daemon INFO e[36mINFOe[0m[0013] started discovery builtin:serial-discovery process
2023-06-02 23:26:32 2023-06-02T22:26:32.761Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 315.2 ms [Finished 25.247 s after backend start]
2023-06-02 23:26:32 2023-06-02T22:26:32.761Z root INFO Deploy plugins list: 431.5 ms [Finished 25.248 s after backend start]
2023-06-02 23:26:32 2023-06-02T22:26:32.763Z daemon INFO e[36mINFOe[0m[0013] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
e[36mINFOe[0m[0013] sending command START_SYNC to discovery builtin:serial-discovery
e[36mINFOe[0m[0013] from discovery builtin:serial-discovery received message type: start_sync, message: OK
e[36mINFOe[0m[0013] from discovery builtin:serial-discovery received message type: add, port: COM1
e[36mINFOe[0m[0013] started discovery builtin:mdns-discovery process
e[36mINFOe[0m[0013] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:mdns-discovery
2023-06-02 23:26:32 2023-06-02T22:26:32.807Z daemon INFO e[36mINFOe[0m[0013] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
e[36mINFOe[0m[0013] sending command START_SYNC to discovery builtin:mdns-discovery
2023-06-02 23:26:32 2023-06-02T22:26:32.810Z daemon INFO e[36mINFOe[0m[0013] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-06-02 23:26:32 2023-06-02T22:26:32.818Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
Hope this helps someone work out why the IDE will not start.
Would like to get back to writing some code :slight_smile:
Some thoughts;
IDE version number not in the log?
Is this a timing error between the different programme parts? something as simple as the GUI hadn't finished formatting before it was updated to visible?
Possibly due to differences in hardware - number of cores, CPU speed, etc. - my laptop is not the newest/fastest..... is there a minimum spec?
With the IDE pulsing there are 12 elements running under Arduino.
Would be better if there was an activity progress/status displayed - then people would be able to see/tell where/what was stuck/waiting to happen.
Regards
Hi @lesc1. I'm sorry about the problem with Arduino IDE.
It would be interesting to see if the problem also occurs if you switch back to using the previous version of Arduino IDE. Do you remember which version you were using before you did the update?
Hi @ptillisch , (This is another long post with 2 x log files)
the events went like this;
Opened V1.8. did some coding compiled downloaded to NANO 33 IoT
Edit update->may actually have been 2.0.0 but not sure.. found that I had downloaded 2.0.0 12 months ago (May 2022) but don't recall installing. There is no IDE version stamped into the user code files that I can see to confirm either way-sorry.
Next day prompted to update 2.0.4 (Think that's correct)
This partially opened showing top headers File, etc..... but with pulsing logo.
Googled issue and saw lots of posts so presumed update had gone wrong
Uninstalled IDE and downloaded 2.1.0 and then installed
Running this only gave the container and pulsing logo
Googled again and tried some of the fixes - no improvement
Found log files and posted on forum
After reading your reply I downloaded V1.8.19
Thought I'd try once more before rolling back and left it at the pulsing logo was writing this reply when a windows warning popped up for dpinst-amd64.exe with ..\Local\Arduino15.. path -- I let it run. Flipping back to the IDE found that it had opened and had the following in the Output view
Downloading packages
arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7
arduino:avrdude@6.3.0-arduino17
arduino:arduinoOTA@1.3.0
arduino:avr@1.8.6
Installing arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7
Configuring tool.
arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7 installed
Installing arduino:avrdude@6.3.0-arduino17
Configuring tool.
arduino:avrdude@6.3.0-arduino17 installed
Installing arduino:arduinoOTA@1.3.0
Configuring tool.
arduino:arduinoOTA@1.3.0 installed
Installing platform arduino:avr@1.8.6
Configuring platform.
Platform arduino:avr@1.8.6 installed
Downloading TFT@1.0.6
TFT@1.0.6
Installing TFT@1.0.6
Installed TFT@1.0.6
Downloading Stepper@1.1.3
Stepper@1.1.3
Installing Stepper@1.1.3
Installed Stepper@1.1.3
Downloading Keyboard@1.0.4
Keyboard@1.0.4
Installing Keyboard@1.0.4
Installed Keyboard@1.0.4
Downloading Ethernet@2.0.2
Ethernet@2.0.2
Installing Ethernet@2.0.2
Installed Ethernet@2.0.2
Downloading Firmata@2.5.9
Firmata@2.5.9
Installing Firmata@2.5.9
Installed Firmata@2.5.9
Downloading Mouse@1.0.1
Mouse@1.0.1
Installing Mouse@1.0.1
Installed Mouse@1.0.1
Downloading SD@1.2.4
SD@1.2.4
Installing SD@1.2.4
Installed SD@1.2.4
Downloading LiquidCrystal@1.0.7
LiquidCrystal@1.0.7
Installing LiquidCrystal@1.0.7
Installed LiquidCrystal@1.0.7
Downloading Servo@1.2.0
Servo@1.2.0
Installing Servo@1.2.0
Installed Servo@1.2.0
Downloading Arduino_BuiltIn@1.0.0
Installing Arduino_BuiltIn@1.0.0
Installed Arduino_BuiltIn@1.0.0
Plugged in UNO 33 IoT and selected in IDE - pop up appeared to install SAMD core - replied YES
System downloaded installed/configured the following
arduino:arm-none-eabi-gcc@7-2017q4
arduino:bossac@1.7.0-arduino3
arduino:openocd@0.10.0-arduino7
arduino:CMSIS@4.5.0
arduino:CMSIS-Atmel@1.2.0
arduino:arduinoOTA@1.2.1
arduino:samd@1.8.13
Installing arduino:arm-none-eabi-gcc@7-2017q4
Configuring tool.
arduino:arm-none-eabi-gcc@7-2017q4 installed
Installing arduino:bossac@1.7.0-arduino3
Configuring tool.
arduino:bossac@1.7.0-arduino3 installed
Installing arduino:openocd@0.10.0-arduino7
Configuring tool.
arduino:openocd@0.10.0-arduino7 installed
Installing arduino:CMSIS@4.5.0
Configuring tool.
arduino:CMSIS@4.5.0 installed
Installing arduino:CMSIS-Atmel@1.2.0
Configuring tool.
arduino:CMSIS-Atmel@1.2.0 installed
Installing arduino:arduinoOTA@1.2.1
Configuring tool.
arduino:arduinoOTA@1.2.1 installed
Installing platform arduino:samd@1.8.13
Platform arduino:samd@1.8.13 installed
Opened last sketch I was working on - verified/compiled/downloaded- all OK
Closed IDE
Opened again;
about 90 seconds for container to appear (Title=Arduino IDE) with pulsing logo
When IDE opened correctly before Title was Arduino IDE 2.1.0 when does this change in the startup process?
15 minutes later still have pulsing logo
Closed container and tried again - same again
So this is the log from the time when the IDE started
There are some odd error messages --- ERROR ---- !!!SLOW!!! DURATION
plus some other errors
2023-06-04_loga.log (244.4 KB)
This is the log for the second failed IDE start
2023-06-04_logb.log (24.5 KB)
Hope this all helps.
If you need anything specific trying/testing let me know.
I will leave 2.1.0 installed at the moment.
Regards
Hi @ptillisch , an update.
2.1.0 will sometimes open and run correctly.
Every time it doesn't start the container only shows 'Arduino IDE'
If it is going to start the container shows 'Arduino IDE 2.1.0'
Looks like some sort of timing issue, missed load event or one of the promise call routines stalling/not throwing an error ?
Regards
Hi @ptillisch , new quirk when 2.1.0 starts
When IDE starts - it is still intermittent - I now have a red status bar at the bottom with message CLI Daemon Offline
Can edit/verify/upload/monitor all OK - any thoughts?
Regards
