IDE hangs on startup: "connectex: A connection attempt failed because the connected party did not properly respond ..."
Continuing the discussion from IDE hangs on startup, with no error shown in logs:
I'm try over your suggestions as above it still cannot launch (it's show loading screen always).
Kindly help how can I do.
2024-05-08 10:35:43 Arduino IDE 2.3.2
2024-05-08 10:35:43 Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
2024-05-08 10:35:43 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-05-08 10:35:43 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-05-08 10:35:43 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-05-08 10:35:43 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-05-08 10:35:43 Starting backend process. PID: 16648
2024-05-08 10:35:44 Using browser-only version of superagent in non-browser environment
2024-05-08 10:35:44 Configuration directory URI: 'file:///c%3A/Users/prawech_sr/.arduinoIDE'
2024-05-08 10:35:44 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-08 10:35:44 2024-05-08T03:35:44.561Z root INFO Backend Object.initialize: 9.4 ms [Finished 1.001 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.570Z root INFO Backend Object.configure: 9.0 ms [Finished 1.002 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.570Z root INFO Backend s.onStart: 4.1 ms [Finished 1.002 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.572Z root INFO Backend s.configure: 0.9 ms [Finished 1.047 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.573Z root INFO Backend d.onStart: 0.6 ms [Finished 1.047 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.574Z root INFO Backend d.configure: 0.2 ms [Finished 1.047 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.577Z root INFO Backend d.initialize: 44.2 ms [Finished 1.047 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.577Z root INFO Backend c.onStart: 0.3 ms [Finished 1.047 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.579Z root INFO Backend a.configure: 9.7 ms [Finished 1.057 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.582Z config INFO >>> Initializing CLI configuration...
2024-05-08 10:35:44 2024-05-08T03:35:44.582Z root INFO Backend c.initialize: 1.1 ms [Finished 1.058 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.583Z root INFO Backend R.onStart: 1.8 ms [Finished 1.059 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.584Z config INFO Loading CLI configuration from c:\Users\prawech_sr\.arduinoIDE\arduino-cli.yaml...
2024-05-08 10:35:44 2024-05-08T03:35:44.585Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-08 10:35:44 2024-05-08T03:35:44.585Z root INFO Backend a.initialize: 0.7 ms [Finished 1.060 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.585Z root INFO Backend w.onStart: 2.8 ms [Finished 1.063 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend r.configure: 4.1 ms [Finished 1.063 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z discovery-log INFO start
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z discovery-log INFO start new deferred
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend d.initialize: 1.7 ms [Finished 1.065 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend y.onStart: 5.1 ms [Finished 1.068 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend r.configure: 3.7 ms [Finished 1.069 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend a.onStart: 1.0 ms [Finished 1.071 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend h.configure: 0.7 ms [Finished 1.071 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend s.configure: 0.2 ms [Finished 1.072 s after backend start]
2024-05-08 10:35:44 2024-05-08T03:35:44.586Z root INFO Backend l.configure: 0.1 ms [Finished 1.072 s after backend start]
2024-05-08 10:36:06 2024-05-08T03:36:06.894Z root INFO Theia app listening on http://127.0.0.1:63995.
2024-05-08 10:36:06 2024-05-08T03:36:06.894Z root INFO Finished starting backend application: 22307.9 ms [Finished 23.379 s after backend start]
2024-05-08 10:36:07 2024-05-08T03:36:07.272Z root WARN The local plugin referenced by local-dir:/c%3A/Users/prawech_sr/.arduinoIDE/plugins does not exist.
2024-05-08 10:36:07 2024-05-08T03:36:07.272Z root WARN The local plugin referenced by local-dir:/c%3A/Users/prawech_sr/.arduinoIDE/extensions does not exist.
2024-05-08 10:36:07 2024-05-08T03:36:07.272Z root WARN The local plugin referenced by local-dir:C:\Users\prawech_sr\.arduinoIDE\plugins does not exist.
2024-05-08 10:36:07 2024-05-08T03:36:07.285Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\prawech_sr\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-08 10:36:07 2024-05-08T03:36:07.285Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-08 10:36:07 2024-05-08T03:36:07.285Z config INFO Loaded the CLI configuration.
2024-05-08 10:36:07 2024-05-08T03:36:07.317Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/prawech_sr/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/prawech_sr/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-08 10:36:07 2024-05-08T03:36:07.317Z config INFO Validating the CLI configuration...
2024-05-08 10:36:07 2024-05-08T03:36:07.342Z config INFO The CLI config is valid.
2024-05-08 10:36:07 2024-05-08T03:36:07.343Z config INFO <<< Initialized the CLI configuration.
2024-05-08 10:36:07 2024-05-08T03:36:07.420Z root INFO Resolve plugins list: 22835.4 ms [Finished 23.904 s after backend start]
2024-05-08 10:36:07 2024-05-08T03:36:07.650Z daemon INFO time="2024-05-08T10:36:07+07:00" level=info msg="Using config file: c:\\Users\\prawech_sr\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-08T10:36:07+07:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-08T10:36:07+07:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-08 10:36:09 2024-05-08T03:36:09.153Z daemon INFO Daemon is now listening on 127.0.0.1:63999
{"IP":"127.0.0.1","Port":"63999"}
2024-05-08 10:36:09 2024-05-08T03:36:09.153Z daemon INFO Daemon is running.
2024-05-08 10:36:09 2024-05-08T03:36:09.198Z daemon INFO time="2024-05-08T10:36:09+07:00" level=info msg="Updating libraries index"
2024-05-08 10:36:09 2024-05-08T03:36:09.218Z daemon INFO time="2024-05-08T10:36:09+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-05-08 10:36:09 2024-05-08T03:36:09.776Z root INFO Deploy plugins list: 22835.4 ms [Finished 26.262 s after backend start]
2024-05-08 10:36:09 Opening channel for service path '/services/electron-window'.
2024-05-08 10:36:09 Opening channel for service path '/services/ide-updater'.
2024-05-08 10:36:10 2024-05-08T03:36:10.270Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 244.6 ms [Finished 3.113 s after frontend start]
2024-05-08 10:36:10 2024-05-08T03:36:10.270Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-08 10:37:02 2024-05-08T03:37:02.434Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 10:37:02 2024-05-08T03:37:02.436Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\prawech_sr\AppData\Local\Arduino15\package_index.json: open C:\Users\prawech_sr\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-05-08 10:37:02 2024-05-08T03:37:02.436Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Loading hardware from: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages"
2024-05-08 10:37:02 2024-05-08T03:37:02.438Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Loading libraries index file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-08 10:37:02 2024-05-08T03:37:02.440Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-05-08 10:37:02 2024-05-08T03:37:02.441Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-05-08 10:37:02 2024-05-08T03:37:02.442Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\prawech_sr\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-05-08 10:37:02 2024-05-08T03:37:02.442Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-05-08T10:37:02+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\Documents\\Arduino\\libraries" location=user
2024-05-08 10:37:02 2024-05-08T03:37:02.455Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\prawech_sr\AppData\Local\Arduino15\package_index.json: open C:\Users\prawech_sr\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\prawech_sr\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-05-08 10:37:02 2024-05-08T03:37:02.457Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Updating libraries index"
2024-05-08 10:37:02 2024-05-08T03:37:02.458Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-08 10:37:02 2024-05-08T03:37:02.462Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-08 10:37:02 2024-05-08T03:37:02.464Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-05-08 10:37:02 2024-05-08T03:37:02.469Z daemon INFO time="2024-05-08T10:37:02+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-05-08 10:37:02 2024-05-08T03:37:02.472Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-05-08 10:37:55 2024-05-08T03:37:55.704Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623733
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-05-08 10:37:55 2024-05-08T03:37:55.707Z daemon INFO time="2024-05-08T10:37:55+07:00" level=info msg="Updating libraries index"
2024-05-08 10:37:55 2024-05-08T03:37:55.715Z daemon INFO time="2024-05-08T10:37:55+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-05-08 10:38:37 2024-05-08T03:38:37.813Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 10:38:37 2024-05-08T03:38:37.816Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\prawech_sr\AppData\Local\Arduino15\package_index.json: open C:\Users\prawech_sr\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-05-08 10:38:37 2024-05-08T03:38:37.816Z daemon INFO time="2024-05-08T10:38:37+07:00" level=info msg="Loading hardware from: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages"
2024-05-08 10:38:37 2024-05-08T03:38:37.820Z daemon INFO time="2024-05-08T10:38:37+07:00" level=info msg="Loading libraries index file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-08 10:38:37 2024-05-08T03:38:37.820Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-05-08 10:38:37 2024-05-08T03:38:37.821Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-05-08 10:38:37 2024-05-08T03:38:37.822Z daemon INFO time="2024-05-08T10:38:37+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-05-08 10:38:37 2024-05-08T03:38:37.822Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\prawech_sr\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-05-08 10:38:37 2024-05-08T03:38:37.822Z daemon INFO time="2024-05-08T10:38:37+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\Documents\\Arduino\\libraries" location=user
2024-05-08 10:38:37 2024-05-08T03:38:37.828Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-08 10:38:37 2024-05-08T03:38:37.828Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
Hi @wettar.
Is your computer connected to the Internet?
If yes, is your firewall preventing the Arduino IDE application from accessing the Internet?
I'm Allowed and add new rule (on advance security) but still error
2024-05-08 11:49:10 2024-05-08T04:49:10.349Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 15:57:51 Arduino IDE 2.3.2
2024-05-08 15:57:51 Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
2024-05-08 15:57:51 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-05-08 15:57:51 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-05-08 15:57:51 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-05-08 15:57:51 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-05-08 15:57:51 Starting backend process. PID: 11764
2024-05-08 15:57:52 Using browser-only version of superagent in non-browser environment
2024-05-08 15:57:52 Configuration directory URI: 'file:///c%3A/Users/prawech_sr/.arduinoIDE'
2024-05-08 15:57:52 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-08 15:57:52 2024-05-08T08:57:52.100Z root INFO Backend Object.initialize: 3.3 ms [Finished 0.377 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.102Z root INFO Backend Object.configure: 2.8 ms [Finished 0.377 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.102Z root INFO Backend s.onStart: 1.4 ms [Finished 0.377 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.103Z root INFO Backend s.configure: 0.3 ms [Finished 0.393 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.103Z root INFO Backend d.onStart: 0.3 ms [Finished 0.393 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.104Z root INFO Backend d.configure: 0.1 ms [Finished 0.393 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.105Z root INFO Backend d.initialize: 15.9 ms [Finished 0.393 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.105Z root INFO Backend c.onStart: 0.2 ms [Finished 0.394 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.105Z root INFO Backend a.configure: 2.9 ms [Finished 0.396 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.106Z config INFO >>> Initializing CLI configuration...
2024-05-08 15:57:52 2024-05-08T08:57:52.106Z root INFO Backend c.initialize: 0.4 ms [Finished 0.397 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.106Z root INFO Backend R.onStart: 0.5 ms [Finished 0.397 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.107Z config INFO Loading CLI configuration from c:\Users\prawech_sr\.arduinoIDE\arduino-cli.yaml...
2024-05-08 15:57:52 2024-05-08T08:57:52.107Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-08 15:57:52 2024-05-08T08:57:52.107Z root INFO Backend a.initialize: 0.2 ms [Finished 0.398 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.107Z root INFO Backend w.onStart: 1.1 ms [Finished 0.398 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend r.configure: 1.5 ms [Finished 0.399 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z discovery-log INFO start
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z discovery-log INFO start new deferred
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend d.initialize: 0.5 ms [Finished 0.399 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend y.onStart: 1.6 ms [Finished 0.400 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend r.configure: 1.2 ms [Finished 0.400 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend a.onStart: 0.4 ms [Finished 0.401 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend h.configure: 0.3 ms [Finished 0.401 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend s.configure: 0.1 ms [Finished 0.401 s after backend start]
2024-05-08 15:57:52 2024-05-08T08:57:52.108Z root INFO Backend l.configure: 0.0 ms [Finished 0.402 s after backend start]
2024-05-08 15:57:55 2024-05-08T08:57:55.330Z root INFO Theia app listening on http://127.0.0.1:50438.
2024-05-08 15:57:55 2024-05-08T08:57:55.330Z root INFO Finished starting backend application: 3222.3 ms [Finished 3.624 s after backend start]
2024-05-08 15:57:55 2024-05-08T08:57:55.373Z root WARN The local plugin referenced by local-dir:/c%3A/Users/prawech_sr/.arduinoIDE/plugins does not exist.
2024-05-08 15:57:55 2024-05-08T08:57:55.373Z root WARN The local plugin referenced by local-dir:/c%3A/Users/prawech_sr/.arduinoIDE/extensions does not exist.
2024-05-08 15:57:55 2024-05-08T08:57:55.373Z root WARN The local plugin referenced by local-dir:C:\Users\prawech_sr\.arduinoIDE\plugins does not exist.
2024-05-08 15:57:55 2024-05-08T08:57:55.382Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\prawech_sr\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-08 15:57:55 2024-05-08T08:57:55.382Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-08 15:57:55 2024-05-08T08:57:55.382Z config INFO Loaded the CLI configuration.
2024-05-08 15:57:55 2024-05-08T08:57:55.387Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/prawech_sr/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/prawech_sr/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-08 15:57:55 2024-05-08T08:57:55.387Z config INFO Validating the CLI configuration...
2024-05-08 15:57:55 2024-05-08T08:57:55.389Z config INFO The CLI config is valid.
2024-05-08 15:57:55 2024-05-08T08:57:55.389Z config INFO <<< Initialized the CLI configuration.
2024-05-08 15:57:55 2024-05-08T08:57:55.416Z root INFO Resolve plugins list: 3308.8 ms [Finished 3.709 s after backend start]
2024-05-08 15:57:55 2024-05-08T08:57:55.455Z daemon INFO time="2024-05-08T15:57:55+07:00" level=info msg="Using config file: c:\\Users\\prawech_sr\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-08T15:57:55+07:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-08T15:57:55+07:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-08 15:57:55 2024-05-08T08:57:55.953Z daemon INFO Daemon is now listening on 127.0.0.1:50439
{"IP":"127.0.0.1","Port":"50439"}
2024-05-08 15:57:55 2024-05-08T08:57:55.953Z daemon INFO Daemon is running.
2024-05-08 15:57:55 2024-05-08T08:57:55.990Z daemon INFO time="2024-05-08T15:57:55+07:00" level=info msg="Missing signature file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\package_index.json"
time="2024-05-08T15:57:55+07:00" level=info msg="Loading hardware from: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages"
time="2024-05-08T15:57:55+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
2024-05-08 15:57:56 2024-05-08T08:57:56.169Z root INFO Deploy plugins list: 3308.8 ms [Finished 4.463 s after backend start]
2024-05-08 15:57:57 Opening channel for service path '/services/electron-window'.
2024-05-08 15:57:57 Opening channel for service path '/services/ide-updater'.
2024-05-08 15:57:57 2024-05-08T08:57:57.270Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 106.3 ms [Finished 1.859 s after frontend start]
2024-05-08 15:57:57 2024-05-08T08:57:57.270Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-08 15:58:38 2024-05-08T08:58:38.120Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 15:58:38 2024-05-08T08:58:38.121Z daemon INFO time="2024-05-08T15:58:38+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2024-05-08 15:59:20 2024-05-08T08:59:20.239Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 15:59:20 2024-05-08T08:59:20.240Z daemon INFO time="2024-05-08T15:59:20+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
2024-05-08 16:00:13 2024-05-08T09:00:13.460Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:00:13 2024-05-08T09:00:13.460Z daemon INFO time="2024-05-08T16:00:13+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
2024-05-08 16:00:55 2024-05-08T09:00:55.577Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:00:55 2024-05-08T09:00:55.578Z daemon INFO time="2024-05-08T16:00:55+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip"
2024-05-08 16:01:48 2024-05-08T09:01:48.781Z daemon INFO time="2024-05-08T16:01:48+07:00" level=info msg="Loading tools from dir: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-08 16:01:48 2024-05-08T09:01:48.783Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:ctags@5.8-arduino11 tool: Get "https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:01:48 2024-05-08T09:01:48.784Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: reading directory C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: open C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: The system cannot find the path specified.
2024-05-08 16:01:48 2024-05-08T09:01:48.785Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-08 16:01:48 2024-05-08T09:01:48.785Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-05-08 16:01:48 2024-05-08T09:01:48.785Z daemon INFO time="2024-05-08T16:01:48+07:00" level=info msg="Loading libraries index file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-08 16:01:48 2024-05-08T09:01:48.973Z daemon INFO time="2024-05-08T16:01:48+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-05-08 16:01:48 2024-05-08T09:01:48.973Z daemon INFO time="2024-05-08T16:01:48+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\Documents\\Arduino\\libraries" location=user
2024-05-08 16:01:48 2024-05-08T09:01:48.978Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-05-08 16:01:48 2024-05-08T09:01:48.979Z daemon INFO time="2024-05-08T16:01:48+07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-08 16:01:48 2024-05-08T09:01:48.981Z daemon INFO time="2024-05-08T16:01:48+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-08 16:01:48 2024-05-08T09:01:48.982Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-05-08 16:02:31 2024-05-08T09:02:31.123Z root ERROR Failed to update platform indexes. Error: 13 INTERNAL: Some indexes could not be updated.
for call at
2024-05-08 16:02:31 2024-05-08T09:02:31.130Z daemon INFO time="2024-05-08T16:02:31+07:00" level=info msg="Missing signature file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\package_index.json"
2024-05-08 16:02:31 2024-05-08T09:02:31.131Z daemon INFO time="2024-05-08T16:02:31+07:00" level=info msg="Loading hardware from: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages"
2024-05-08 16:02:31 2024-05-08T09:02:31.134Z daemon INFO time="2024-05-08T16:02:31+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
2024-05-08 16:03:24 2024-05-08T09:03:24.337Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:03:24 2024-05-08T09:03:24.339Z daemon INFO time="2024-05-08T16:03:24+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip"
2024-05-08 16:04:06 2024-05-08T09:04:06.471Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:ctags@5.8-arduino11 tool: Get "https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:04:06 2024-05-08T09:04:06.473Z daemon INFO time="2024-05-08T16:04:06+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
2024-05-08 16:04:59 2024-05-08T09:04:59.692Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:04:59 2024-05-08T09:04:59.693Z daemon INFO time="2024-05-08T16:04:59+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2024-05-08 16:05:41 2024-05-08T09:05:41.824Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:05:41 2024-05-08T09:05:41.824Z daemon INFO time="2024-05-08T16:05:41+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
2024-05-08 16:06:35 2024-05-08T09:06:35.013Z daemon INFO time="2024-05-08T16:06:35+07:00" level=info msg="Loading tools from dir: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-08 16:06:35 2024-05-08T09:06:35.015Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 16:06:35 2024-05-08T09:06:35.016Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: reading directory C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: open C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: The system cannot find the path specified.
2024-05-08 16:06:35 2024-05-08T09:06:35.016Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-08 16:06:35 2024-05-08T09:06:35.016Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-05-08 16:06:35 2024-05-08T09:06:35.016Z daemon INFO time="2024-05-08T16:06:35+07:00" level=info msg="Loading libraries index file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-08 16:06:35 2024-05-08T09:06:35.154Z daemon INFO time="2024-05-08T16:06:35+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-05-08T16:06:35+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\Documents\\Arduino\\libraries" location=user
2024-05-08 16:06:35 2024-05-08T09:06:35.157Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-08 16:06:35 2024-05-08T09:06:35.157Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-08 16:52:01 2024-05-08T09:52:01.409Z root ERROR Uncaught Exception:  Error: transport close
2024-05-08 16:52:01 2024-05-08T09:52:01.410Z root ERROR Error: transport close
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1095642
    at Map.forEach (<anonymous>)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1095621
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1062813
    at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1062903)
    at s.fire (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1064706)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1090506
    at Object.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1090476)
    at e.dispose (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1055872)
2024-05-08 17:04:12 Closing channel on service path '/services/electron-window'.
2024-05-08 17:04:12 Closing channel on service path '/services/ide-updater'.
2024-05-08 17:04:12 Stored workspaces roots:
2024-05-08 17:04:12 No sketches were scheduled for deletion.
2024-05-08 17:20:20 Arduino IDE 2.3.2
2024-05-08 17:20:20 Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
2024-05-08 17:20:21 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-05-08 17:20:21 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-05-08 17:20:21 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-05-08 17:20:21 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-05-08 17:20:21 Starting backend process. PID: 14320
2024-05-08 17:20:21 Using browser-only version of superagent in non-browser environment
2024-05-08 17:20:21 Configuration directory URI: 'file:///c%3A/Users/prawech_sr/.arduinoIDE'
2024-05-08 17:20:21 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-08 17:20:21 2024-05-08T10:20:21.456Z root INFO Backend Object.initialize: 2.9 ms [Finished 0.385 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.459Z root INFO Backend Object.configure: 2.4 ms [Finished 0.385 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.459Z root INFO Backend s.onStart: 1.2 ms [Finished 0.385 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.459Z root INFO Backend s.configure: 0.5 ms [Finished 0.402 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.460Z root INFO Backend d.onStart: 0.4 ms [Finished 0.402 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.460Z root INFO Backend d.configure: 0.1 ms [Finished 0.402 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.461Z root INFO Backend d.initialize: 17.6 ms [Finished 0.403 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.461Z root INFO Backend c.onStart: 0.2 ms [Finished 0.403 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.462Z root INFO Backend a.configure: 3.6 ms [Finished 0.406 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.463Z config INFO >>> Initializing CLI configuration...
2024-05-08 17:20:21 2024-05-08T10:20:21.463Z root INFO Backend c.initialize: 0.4 ms [Finished 0.406 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.463Z root INFO Backend R.onStart: 0.5 ms [Finished 0.407 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z config INFO Loading CLI configuration from c:\Users\prawech_sr\.arduinoIDE\arduino-cli.yaml...
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend a.initialize: 0.3 ms [Finished 0.407 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend w.onStart: 1.1 ms [Finished 0.408 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend r.configure: 1.6 ms [Finished 0.408 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z discovery-log INFO start
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z discovery-log INFO start new deferred
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend d.initialize: 0.7 ms [Finished 0.409 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend y.onStart: 1.7 ms [Finished 0.410 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend r.configure: 1.1 ms [Finished 0.410 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend a.onStart: 0.4 ms [Finished 0.411 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend h.configure: 0.3 ms [Finished 0.411 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend s.configure: 0.1 ms [Finished 0.411 s after backend start]
2024-05-08 17:20:21 2024-05-08T10:20:21.464Z root INFO Backend l.configure: 0.0 ms [Finished 0.412 s after backend start]
2024-05-08 17:20:24 2024-05-08T10:20:24.709Z root INFO Theia app listening on http://127.0.0.1:63365.
2024-05-08 17:20:24 2024-05-08T10:20:24.709Z root INFO Finished starting backend application: 3244.8 ms [Finished 3.656 s after backend start]
2024-05-08 17:20:24 2024-05-08T10:20:24.752Z root WARN The local plugin referenced by local-dir:/c%3A/Users/prawech_sr/.arduinoIDE/plugins does not exist.
2024-05-08 17:20:24 2024-05-08T10:20:24.752Z root WARN The local plugin referenced by local-dir:/c%3A/Users/prawech_sr/.arduinoIDE/extensions does not exist.
2024-05-08 17:20:24 2024-05-08T10:20:24.752Z root WARN The local plugin referenced by local-dir:C:\Users\prawech_sr\.arduinoIDE\plugins does not exist.
2024-05-08 17:20:24 2024-05-08T10:20:24.758Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\prawech_sr\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-08 17:20:24 2024-05-08T10:20:24.758Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-08 17:20:24 2024-05-08T10:20:24.758Z config INFO Loaded the CLI configuration.
2024-05-08 17:20:24 2024-05-08T10:20:24.765Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/prawech_sr/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/prawech_sr/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-08 17:20:24 2024-05-08T10:20:24.765Z config INFO Validating the CLI configuration...
2024-05-08 17:20:24 2024-05-08T10:20:24.771Z config INFO The CLI config is valid.
2024-05-08 17:20:24 2024-05-08T10:20:24.771Z config INFO <<< Initialized the CLI configuration.
2024-05-08 17:20:24 2024-05-08T10:20:24.799Z root INFO Resolve plugins list: 3334.7 ms [Finished 3.745 s after backend start]
2024-05-08 17:20:24 2024-05-08T10:20:24.835Z daemon INFO time="2024-05-08T17:20:24+07:00" level=info msg="Using config file: c:\\Users\\prawech_sr\\.arduinoIDE\\arduino-cli.yaml"
2024-05-08 17:20:24 2024-05-08T10:20:24.836Z daemon INFO time="2024-05-08T17:20:24+07:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-08T17:20:24+07:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-08 17:20:25 2024-05-08T10:20:25.359Z daemon INFO Daemon is now listening on 127.0.0.1:63366
{"IP":"127.0.0.1","Port":"63366"}
2024-05-08 17:20:25 2024-05-08T10:20:25.359Z daemon INFO Daemon is running.
2024-05-08 17:20:25 2024-05-08T10:20:25.388Z daemon INFO time="2024-05-08T17:20:25+07:00" level=info msg="Missing signature file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\package_index.json"
time="2024-05-08T17:20:25+07:00" level=info msg="Loading hardware from: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages"
time="2024-05-08T17:20:25+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
2024-05-08 17:20:25 2024-05-08T10:20:25.581Z root INFO Deploy plugins list: 3334.7 ms [Finished 4.529 s after backend start]
2024-05-08 17:20:26 Opening channel for service path '/services/electron-window'.
2024-05-08 17:20:26 Opening channel for service path '/services/ide-updater'.
2024-05-08 17:20:26 2024-05-08T10:20:26.654Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 106.0 ms [Finished 1.862 s after frontend start]
2024-05-08 17:20:26 2024-05-08T10:20:26.654Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-08 17:21:18 2024-05-08T10:21:18.592Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:21:18 2024-05-08T10:21:18.593Z daemon INFO time="2024-05-08T17:21:18+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2024-05-08 17:22:00 2024-05-08T10:22:00.733Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:22:00 2024-05-08T10:22:00.735Z daemon INFO time="2024-05-08T17:22:00+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
2024-05-08 17:22:53 2024-05-08T10:22:53.926Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:22:53 2024-05-08T10:22:53.927Z daemon INFO time="2024-05-08T17:22:53+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
2024-05-08 17:23:36 2024-05-08T10:23:36.033Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:23:36 2024-05-08T10:23:36.033Z daemon INFO time="2024-05-08T17:23:36+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip"
2024-05-08 17:24:29 2024-05-08T10:24:29.207Z daemon INFO time="2024-05-08T17:24:29+07:00" level=info msg="Loading tools from dir: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-08 17:24:29 2024-05-08T10:24:29.209Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:ctags@5.8-arduino11 tool: Get "https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:24:29 2024-05-08T10:24:29.211Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: reading directory C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: open C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: The system cannot find the path specified.
2024-05-08 17:24:29 2024-05-08T10:24:29.212Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-08 17:24:29 2024-05-08T10:24:29.212Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-05-08 17:24:29 2024-05-08T10:24:29.212Z daemon INFO time="2024-05-08T17:24:29+07:00" level=info msg="Loading libraries index file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-08 17:24:29 2024-05-08T10:24:29.354Z daemon INFO time="2024-05-08T17:24:29+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-05-08T17:24:29+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\Documents\\Arduino\\libraries" location=user
2024-05-08 17:24:29 2024-05-08T10:24:29.360Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-08 17:24:29 2024-05-08T10:24:29.361Z daemon INFO time="2024-05-08T17:24:29+07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-08 17:24:29 2024-05-08T10:24:29.363Z daemon INFO time="2024-05-08T17:24:29+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-08 17:24:29 2024-05-08T10:24:29.364Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-05-08 17:25:11 2024-05-08T10:25:11.459Z root ERROR Failed to update platform indexes. Error: 13 INTERNAL: Some indexes could not be updated.
for call at
2024-05-08 17:25:11 2024-05-08T10:25:11.466Z daemon INFO time="2024-05-08T17:25:11+07:00" level=info msg="Missing signature file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\package_index.json"
2024-05-08 17:25:11 2024-05-08T10:25:11.467Z daemon INFO time="2024-05-08T17:25:11+07:00" level=info msg="Loading hardware from: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages"
2024-05-08 17:25:11 2024-05-08T10:25:11.469Z daemon INFO time="2024-05-08T17:25:11+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip"
2024-05-08 17:26:04 2024-05-08T10:26:04.604Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:ctags@5.8-arduino11 tool: Get "https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:26:04 2024-05-08T10:26:04.605Z daemon INFO time="2024-05-08T17:26:04+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
2024-05-08 17:26:57 2024-05-08T10:26:57.764Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:26:57 2024-05-08T10:26:57.765Z daemon INFO time="2024-05-08T17:26:57+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2024-05-08 17:27:40 2024-05-08T10:27:40.104Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:27:40 2024-05-08T10:27:40.105Z daemon INFO time="2024-05-08T17:27:40+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
2024-05-08 17:28:22 2024-05-08T10:28:22.197Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:28:22 2024-05-08T10:28:22.198Z daemon INFO time="2024-05-08T17:28:22+07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
2024-05-08 17:29:15 2024-05-08T10:29:15.372Z daemon INFO time="2024-05-08T17:29:15+07:00" level=info msg="Loading tools from dir: C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-08 17:29:15 2024-05-08T10:29:15.374Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-05-08 17:29:15 2024-05-08T10:29:15.376Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: reading directory C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: open C:\Users\prawech_sr\AppData\Local\Arduino15\packages\builtin\tools: The system cannot find the path specified.
2024-05-08 17:29:15 2024-05-08T10:29:15.376Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-08 17:29:15 2024-05-08T10:29:15.376Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-05-08 17:29:15 2024-05-08T10:29:15.376Z daemon INFO time="2024-05-08T17:29:15+07:00" level=info msg="Loading libraries index file" index="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-08 17:29:15 2024-05-08T10:29:15.518Z daemon INFO time="2024-05-08T17:29:15+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-05-08 17:29:15 2024-05-08T10:29:15.518Z daemon INFO time="2024-05-08T17:29:15+07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\prawech_sr\\Documents\\Arduino\\libraries" location=user
2024-05-08 17:29:15 2024-05-08T10:29:15.521Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-08 17:29:15 2024-05-08T10:29:15.521Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-08 17:31:23 2024-05-08T10:31:23.406Z root ERROR Uncaught Exception:  Error: transport close
2024-05-08 17:31:23 2024-05-08T10:31:23.406Z root ERROR Error: transport close
