IDE hangs on startup: "connectex: A connection attempt failed because the connected party did not properly respond ..."
Hi, I have installed the IDE for the first time today and it hangs on startup. I get the following in the Powershell:
Thanks
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 26512
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/brgr/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-09-12T12:55:00.891Z root INFO Backend Object.initialize: 4.3 ms [Finished 0.401 s after backend start]
2024-09-12T12:55:00.892Z root INFO Backend Object.configure: 3.8 ms [Finished 0.401 s after backend start]
2024-09-12T12:55:00.892Z root INFO Backend s.onStart: 1.4 ms [Finished 0.401 s after backend start]
2024-09-12T12:55:00.892Z root INFO Backend s.configure: 0.2 ms [Finished 0.418 s after backend start]
2024-09-12T12:55:00.893Z root INFO Backend d.onStart: 0.2 ms [Finished 0.418 s after backend start]
2024-09-12T12:55:00.893Z root INFO Backend d.configure: 0.1 ms [Finished 0.418 s after backend start]
2024-09-12T12:55:00.894Z root INFO Backend d.initialize: 17.4 ms [Finished 0.419 s after backend start]
2024-09-12T12:55:00.894Z root INFO Backend c.onStart: 0.2 ms [Finished 0.419 s after backend start]
2024-09-12T12:55:00.895Z root INFO Backend a.configure: 1.1 ms [Finished 0.420 s after backend start]
2024-09-12T12:55:00.896Z config INFO >>> Initializing CLI configuration...
2024-09-12T12:55:00.896Z root INFO Backend c.initialize: 0.3 ms [Finished 0.420 s after backend start]
2024-09-12T12:55:00.896Z root INFO Backend R.onStart: 0.4 ms [Finished 0.420 s after backend start]
2024-09-12T12:55:00.897Z config INFO Loading CLI configuration from c:\Users\brgr\.arduinoIDE\arduino-cli.yaml...
2024-09-12T12:55:00.897Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-12T12:55:00.897Z root INFO Backend a.initialize: 0.2 ms [Finished 0.421 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend w.onStart: 0.9 ms [Finished 0.421 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend r.configure: 1.3 ms [Finished 0.421 s after backend start]
2024-09-12T12:55:00.897Z discovery-log INFO start
2024-09-12T12:55:00.897Z discovery-log INFO start new deferred
2024-09-12T12:55:00.897Z root INFO Backend d.initialize: 0.5 ms [Finished 0.422 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend y.onStart: 1.9 ms [Finished 0.423 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend r.configure: 1.5 ms [Finished 0.424 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend a.onStart: 0.3 ms [Finished 0.424 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend h.configure: 0.3 ms [Finished 0.424 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend s.configure: 0.1 ms [Finished 0.424 s after backend start]
2024-09-12T12:55:00.897Z root INFO Backend l.configure: 0.0 ms [Finished 0.425 s after backend start]
2024-09-12T12:55:00.899Z root INFO Theia app listening on http://127.0.0.1:53113.
2024-09-12T12:55:00.899Z root INFO Finished starting backend application: 1.8 ms [Finished 0.426 s after backend start]
2024-09-12T12:55:00.914Z root WARN The local plugin referenced by local-dir:/c%3A/Users/brgr/.arduinoIDE/plugins does not exist.
2024-09-12T12:55:00.914Z root WARN The local plugin referenced by local-dir:/c%3A/Users/brgr/.arduinoIDE/extensions does not exist.
2024-09-12T12:55:00.914Z root WARN The local plugin referenced by local-dir:C:\Users\brgr\.arduinoIDE\plugins does not exist.
2024-09-12T12:55:00.918Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\brgr\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\brgr\\AppData\\Local\\Arduino15\\staging","user":"\\\\METASFS01.AD.METAS\\HOME$\\OFFICE\\BRGR\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-09-12T12:55:00.918Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-09-12T12:55:00.918Z config INFO Loaded the CLI configuration.
2024-09-12T12:55:00.929Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/brgr/AppData/Local/Arduino15","sketchDirUri":"file://metasfs01.ad.metas/HOME%24/OFFICE/BRGR/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-09-12T12:55:00.929Z config INFO Validating the CLI configuration...
2024-09-12T12:55:00.931Z config INFO The CLI config is valid.
2024-09-12T12:55:00.931Z config INFO <<< Initialized the CLI configuration.
2024-09-12T12:55:00.946Z root INFO Resolve plugins list: 49.5 ms [Finished 0.473 s after backend start]
2024-09-12T12:55:01.045Z daemon INFO time="2024-09-12T14:55:01+02:00" level=info msg="Using config file: c:\\Users\\brgr\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-12T14:55:01+02:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-09-12T14:55:01+02:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:53115
{"IP":"127.0.0.1","Port":"53115"}
2024-09-12T12:55:01.045Z daemon INFO Daemon is running.
2024-09-12T12:55:01.098Z daemon INFO time="2024-09-12T14:55:01+02:00" level=info msg="Updating libraries index"
2024-09-12T12:55:01.103Z daemon INFO time="2024-09-12T14:55:01+02:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-12T12:55:01.662Z root INFO Deploy plugins list: 49.5 ms [Finished 1.189 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-09-12T12:55:02.256Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 106.4 ms [Finished 1.277 s after frontend start]
2024-09-12T12:55:02.256Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-09-12T12:55:43.232Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-12T12:55:43.232Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\brgr\AppData\Local\Arduino15\package_index.json: open C:\Users\brgr\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-09-12T12:55:43.233Z daemon INFO time="2024-09-12T14:55:43+02:00" level=info msg="Loading hardware from: C:\\Users\\brgr\\AppData\\Local\\Arduino15\\packages"
2024-09-12T12:55:43.234Z daemon INFO time="2024-09-12T14:55:43+02:00" level=info msg="Loading libraries index file" index="C:\\Users\\brgr\\AppData\\Local\\Arduino15\\library_index.json"
2024-09-12T12:55:43.234Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-09-12T12:55:43.234Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-09-12T12:55:43.235Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\brgr\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-09-12T12:55:43.235Z daemon INFO time="2024-09-12T14:55:43+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\brgr\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-09-12T14:55:43+02:00" level=info msg="Adding libraries dir" dir="\\\\METASFS01.AD.METAS\\HOME$\\OFFICE\\BRGR\\Arduino\\libraries" location=user
2024-09-12T12:55:43.243Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\brgr\AppData\Local\Arduino15\package_index.json: open C:\Users\brgr\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\brgr\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-09-12T12:55:43.245Z daemon INFO time="2024-09-12T14:55:43+02:00" level=info msg="Updating libraries index"
time="2024-09-12T14:55:43+02:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-09-12T12:55:43.248Z daemon INFO time="2024-09-12T14:55:43+02:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-09-12T12:55:43.251Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-09-12T12:55:43.252Z daemon INFO time="2024-09-12T14:55:43+02:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-12T12:55:43.253Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-09-12T12:56:25.341Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623733
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-09-12T12:56:25.345Z daemon INFO time="2024-09-12T14:56:25+02:00" level=info msg="Updating libraries index"
2024-09-12T12:56:25.351Z daemon INFO time="2024-09-12T14:56:25+02:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-12T12:57:07.497Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-12T12:57:07.498Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\brgr\AppData\Local\Arduino15\package_index.json: open C:\Users\brgr\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-09-12T12:57:07.508Z daemon INFO time="2024-09-12T14:57:07+02:00" level=info msg="Loading hardware from: C:\\Users\\brgr\\AppData\\Local\\Arduino15\\packages"
2024-09-12T12:57:07.508Z daemon INFO time="2024-09-12T14:57:07+02:00" level=info msg="Loading libraries index file" index="C:\\Users\\brgr\\AppData\\Local\\Arduino15\\library_index.json"
2024-09-12T12:57:07.509Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-09-12T12:57:07.509Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-09-12T12:57:07.510Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\brgr\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-09-12T12:57:07.510Z daemon INFO time="2024-09-12T14:57:07+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\brgr\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-09-12T14:57:07+02:00" level=info msg="Adding libraries dir" dir="\\\\METASFS01.AD.METAS\\HOME$\\OFFICE\\BRGR\\Arduino\\libraries" location=user
2024-09-12T12:57:07.515Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-09-12T12:57:07.516Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
I'm not a specialist but I think that this line indicates the root cause of your problem.
Are you in a corporate environment where certain applications are blocked from accessing the internet?
Did you set any firewall rules for yourself?
I don't think this is the problem, I think the download happened but it couldn't be applied - I can go to the download address and download the file directly with no problems.
First suggestion: talk to the IT department.
The IDE needs internet access on the first run to download some stuff. The work around would be to use another computer with the same operating system (windows in your case) that can access the internet and the IDE in a working state.
I'm not sure what is exactly needed, it will be at least the directory C:\Users\yourUsername\AppData\Local\Arduino15\packages and possibly C:\Users\bugge\AppData\Local\Arduino15\packages\builtin\tools (just check if it's there with a couple of subdirectories like serial-discovery.
Your company can block based on application. A browser will be allowed, some vague application might be blocked.
OK, found a topic: Issue to install tools and library due to security - #8 by ptillisch
