While trying to run Arduino IDE under proxy, IDE open with logo screen and halt on same
PS C:\Program Files\Arduino IDE> .\"Arduino IDE"
D 2025-02-07T09:37:32.671Z | index | Loading @grpc/grpc-js version 1.9.5
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 3356
D 2025-02-07T09:37:33.657Z | index | Loading @grpc/grpc-js version 1.9.5
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Lalit/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-02-07T09:37:33.819Z root INFO Backend Object.initialize: 8.1 ms [Finished 0.910 s after backend start]
2025-02-07T09:37:33.819Z root INFO Backend Object.configure: 6.2 ms [Finished 0.910 s after backend start]
2025-02-07T09:37:33.819Z root INFO Backend s.onStart: 3.6 ms [Finished 0.910 s after backend start]
2025-02-07T09:37:33.819Z root INFO Backend s.configure: 0.6 ms [Finished 0.947 s after backend start]
2025-02-07T09:37:33.821Z root INFO Backend d.onStart: 0.4 ms [Finished 0.947 s after backend start]
2025-02-07T09:37:33.823Z root INFO Backend d.configure: 0.2 ms [Finished 0.947 s after backend start]
2025-02-07T09:37:33.824Z root INFO Backend d.initialize: 36.8 ms [Finished 0.948 s after backend start]
2025-02-07T09:37:33.824Z root INFO Backend c.onStart: 0.5 ms [Finished 0.948 s after backend start]
2025-02-07T09:37:33.825Z root INFO Backend a.configure: 0.6 ms [Finished 0.948 s after backend start]
2025-02-07T09:37:33.828Z config INFO >>> Initializing CLI configuration...
2025-02-07T09:37:33.828Z root INFO Backend c.initialize: 0.7 ms [Finished 0.949 s after backend start]
2025-02-07T09:37:33.828Z root INFO Backend x.onStart: 1.2 ms [Finished 0.950 s after backend start]
2025-02-07T09:37:33.830Z config INFO Loading CLI configuration from c:\Users\Lalit\.arduinoIDE\arduino-cli.yaml...
2025-02-07T09:37:33.831Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-02-07T09:37:33.831Z root INFO Backend a.initialize: 0.7 ms [Finished 0.952 s after backend start]
2025-02-07T09:37:33.831Z root INFO Backend w.onStart: 1.9 ms [Finished 0.953 s after backend start]
2025-02-07T09:37:33.831Z root INFO Backend r.configure: 3.7 ms [Finished 0.953 s after backend start]
2025-02-07T09:37:33.832Z discovery-log INFO start
2025-02-07T09:37:33.832Z discovery-log INFO start new deferred
2025-02-07T09:37:33.832Z root INFO Backend d.initialize: 0.7 ms [Finished 0.954 s after backend start]
2025-02-07T09:37:33.832Z root INFO Backend y.onStart: 3.8 ms [Finished 0.958 s after backend start]
2025-02-07T09:37:33.832Z root INFO Backend r.configure: 3.4 ms [Finished 0.958 s after backend start]
2025-02-07T09:37:33.832Z root INFO Backend a.onStart: 1.1 ms [Finished 0.961 s after backend start]
2025-02-07T09:37:33.832Z root INFO Backend h.configure: 0.8 ms [Finished 0.961 s after backend start]
2025-02-07T09:37:33.832Z root INFO Backend s.configure: 0.3 ms [Finished 0.961 s after backend start]
2025-02-07T09:37:33.832Z root INFO Backend l.configure: 0.2 ms [Finished 0.962 s after backend start]
2025-02-07T09:37:33.837Z root INFO Theia app listening on http://127.0.0.1:56166.
2025-02-07T09:37:33.837Z root INFO Finished starting backend application: 5.3 ms [Finished 0.966 s after backend start]
2025-02-07T09:37:33.856Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Lalit/.arduinoIDE/plugins does not exist.
2025-02-07T09:37:33.856Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Lalit/.arduinoIDE/extensions does not exist.
2025-02-07T09:37:33.857Z root WARN The local plugin referenced by local-dir:C:\Users\Lalit\.arduinoIDE\plugins does not exist.
2025-02-07T09:37:33.904Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-02-07T09:37:33.904Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'2025-02-07T09:37:33.982Z root INFO Resolve plugins list: 151.8 ms [Finished 1.110 s after backend start]
2025-02-07T09:37:34.211Z daemon INFO time="2025-02-07T15:07:34+05:30" level=info msg="arduino-cli version 1.1.1"
time="2025-02-07T15:07:34+05:30" level=info msg="Using config file: c:\\Users\\Lalit\\.arduinoIDE\\arduino-cli.yaml"
time="2025-02-07T15:07:34+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56169
{"IP":"127.0.0.1","Port":"56169"}
2025-02-07T09:37:34.211Z root ERROR D 2025-02-07T09:37:34.204Z | resolving_load_balancer | dns:localhost:56169 IDLE -> IDLE
2025-02-07T09:37:34.211Z root ERROR D 2025-02-07T09:37:34.204Z | connectivity_state | (1) dns:localhost:56169 IDLE -> IDLE
2025-02-07T09:37:34.211Z root ERROR D 2025-02-07T09:37:34.204Z | dns_resolver | Resolver constructed for target dns:localhost:56169
2025-02-07T09:37:34.211Z root ERROR D 2025-02-07T09:37:34.206Z | channel | (1) dns:localhost:56169 Channel constructed with options {
"grpc.max_send_message_length": 536870912,
"grpc.max_receive_message_length": 536870912,
"grpc.primary_user_agent": "arduino-ide/2.3.4"
2025-02-07T09:37:34.213Z root ERROR D 2025-02-07T09:37:34.206Z | channel_stacktrace | (1) Channel constructed
at new t.InternalChannel (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:974883)
at new t.ChannelImplementation (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:927551)
at new t.Client (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:945055)
at new s (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013000)
at t.createArduinoCoreServiceClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:41260)
at v.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776583)
at v.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:775541)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:774437
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1221089
at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1221179)
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.207Z | channel | (1) dns:localhost:56169 createResolvingCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.207Z | resolving_call | [0] Created
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.207Z | resolving_call | [0] Deadline: Infinity
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.207Z | resolving_call | [0] start called
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.208Z | dns_resolver | Looking up DNS hostname localhost
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.208Z | resolving_load_balancer | dns:localhost:56169 IDLE -> CONNECTING
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.208Z | connectivity_state | (1) dns:localhost:56169 IDLE -> CONNECTING
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.209Z | channel | (1) dns:localhost:56169 callRefTimer.ref | configSelectionQueue.length=1 pickQueue.length=0
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.209Z | resolving_call | [0] startRead called
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.210Z | resolving_call | [0] write() called with message of length 0
2025-02-07T09:37:34.215Z root ERROR D 2025-02-07T09:37:34.210Z | resolving_call | [0] halfClose called
2025-02-07T09:37:34.215Z daemon INFO Daemon is running.
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.240Z | dns_resolver | Resolved addresses for target dns:localhost:56169: [::1:56169,127.0.0.1:56169]
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.242Z | subchannel | (2) ::1:56169 Subchannel constructed with options {
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.243Z | subchannel_refcount | (2) ::1:56169 refcount 0 -> 1
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.246Z | subchannel | (3) 127.0.0.1:56169 Subchannel constructed with options {
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.247Z | subchannel_refcount | (3) 127.0.0.1:56169 refcount 0 -> 1
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.247Z | subchannel_refcount | (2) ::1:56169 refcount 1 -> 2
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.247Z | subchannel_refcount | (3) 127.0.0.1:56169 refcount 1 -> 2
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.247Z | pick_first | Start connecting to subchannel with address ::1:56169
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.248Z | pick_first | IDLE -> CONNECTING
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.248Z | resolving_load_balancer | dns:localhost:56169 CONNECTING -> CONNECTING
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.248Z | channel | (1) dns:localhost:56169 callRefTimer.unref | configSelectionQueue.length=1 pickQueue.length=0
2025-02-07T09:37:34.248Z root ERROR D 2025-02-07T09:37:34.248Z | connectivity_state | (1) dns:localhost:56169 CONNECTING -> CONNECTING
2025-02-07T09:37:34.272Z root ERROR D 2025-02-07T09:37:34.262Z | subchannel | (2) ::1:56169 IDLE -> CONNECTING
2025-02-07T09:37:34.272Z root ERROR D 2025-02-07T09:37:34.264Z | transport | dns:localhost:56169 creating HTTP/2 session to ::1:56169
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.267Z | channel | (1) dns:localhost:56169 createRetryingCall [1] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.267Z | resolving_call | [0] Created child [1]
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.268Z | retrying_call | [1] start called
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.268Z | channel | (1) dns:localhost:56169 createLoadBalancingCall [2] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.269Z | retrying_call | [1] Created child call [2] for attempt 1
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.270Z | load_balancing_call | [2] start called
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.270Z | load_balancing_call | [2] Pick called
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.270Z | load_balancing_call | [2] Pick result: QUEUE subchannel: null status: undefined undefined
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.270Z | channel | (1) dns:localhost:56169 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.271Z | retrying_call | [1] startRead called
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.271Z | load_balancing_call | [2] startRead called
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.272Z | retrying_call | [1] write() called with message of length 5
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.272Z | load_balancing_call | [2] write() called with message of length 5
2025-02-07T09:37:34.273Z root ERROR D 2025-02-07T09:37:34.272Z | retrying_call | [1] halfClose called
2025-02-07T09:37:34.278Z root ERROR D 2025-02-07T09:37:34.276Z | transport | dns:localhost:56169 connection failed with error connect ECONNREFUSED ::1:56169
2025-02-07T09:37:34.278Z root ERROR D 2025-02-07T09:37:34.278Z | subchannel | (2) ::1:56169 CONNECTING -> TRANSIENT_FAILURE
2025-02-07T09:37:34.279Z root ERROR D 2025-02-07T09:37:34.278Z | pick_first | Start connecting to subchannel with address 127.0.0.1:56169
2025-02-07T09:37:34.279Z root ERROR D 2025-02-07T09:37:34.279Z | subchannel | (3) 127.0.0.1:56169 IDLE -> CONNECTING
2025-02-07T09:37:34.279Z root ERROR D 2025-02-07T09:37:34.279Z | transport | dns:localhost:56169 creating HTTP/2 session to 127.0.0.1:56169
2025-02-07T09:37:34.288Z root ERROR D 2025-02-07T09:37:34.282Z | subchannel | (3) 127.0.0.1:56169 CONNECTING -> READY
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.282Z | pick_first | Pick subchannel with address 127.0.0.1:56169
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.282Z | subchannel_refcount | (3) 127.0.0.1:56169 refcount 2 -> 3
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.283Z | subchannel_refcount | (2) ::1:56169 refcount 2 -> 1
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.283Z | subchannel_refcount | (3) 127.0.0.1:56169 refcount 3 -> 2
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.283Z | pick_first | CONNECTING -> READY
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.283Z | resolving_load_balancer | dns:localhost:56169 CONNECTING -> READY
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.283Z | channel | (1) dns:localhost:56169 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.283Z | load_balancing_call | [2] Pick called
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.284Z | load_balancing_call | [2] Pick result: COMPLETE subchannel: (3) 127.0.0.1:56169 status: undefined undefined
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.284Z | connectivity_state | (1) dns:localhost:56169 CONNECTING -> READY
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.286Z | transport_flowctrl | (4) 127.0.0.1:56169 local window size: 65535 remote window size: 65535
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.287Z | transport_internals | (4) 127.0.0.1:56169 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.288Z | load_balancing_call | [2] Created child call [3]
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.288Z | subchannel_call | [3] write() called with message of length 5
2025-02-07T09:37:34.289Z root ERROR D 2025-02-07T09:37:34.288Z | subchannel_call | [3] sending data chunk of length 5
2025-02-07T09:37:34.290Z root ERROR D 2025-02-07T09:37:34.290Z | load_balancing_call | [2] halfClose called
2025-02-07T09:37:34.290Z root ERROR D 2025-02-07T09:37:34.290Z | subchannel_call | [3] end() called
2025-02-07T09:37:34.290Z root ERROR D 2025-02-07T09:37:34.290Z | subchannel_call | [3] calling end() on HTTP/2 stream
2025-02-07T09:37:34.322Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\Lalit\\Documents\\Arduino","data":"C:\\Users\\Lalit\\AppData\\Local\\Arduino15"}}
2025-02-07T09:37:34.322Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\Lalit\\Documents\\Arduino","data":"C:\\Users\\Lalit\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-02-07T09:37:34.322Z config INFO Loaded the CLI configuration.
2025-02-07T09:37:34.381Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Lalit/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Lalit/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-02-07T09:37:34.383Z config INFO Validating the CLI configuration...
2025-02-07T09:37:34.396Z config INFO The CLI config is valid.
2025-02-07T09:37:34.397Z config INFO <<< Initialized the CLI configuration.
2025-02-07T09:37:34.500Z root ERROR D 2025-02-07T09:37:34.500Z | transport | (4) 127.0.0.1:56169 local settings acknowledged by remote: {"headerTableSize":4096,"enablePush":true,"initialWindowSize":65535,"maxFrameSize":16384,"maxConcurrentStreams":4294967295,"maxHeaderListSize":4294967295,"maxHeaderSize":4294967295,"enableConnectProtocol":false}
2025-02-07T09:37:34.501Z root ERROR D 2025-02-07T09:37:34.501Z | subchannel_call | [3] Received server headers:
:status: 200
content-type: application/grpc
2025-02-07T09:37:34.501Z root ERROR D 2025-02-07T09:37:34.501Z | load_balancing_call | [2] Received metadata
2025-02-07T09:37:34.501Z root ERROR D 2025-02-07T09:37:34.501Z | retrying_call | [1] Received metadata from child [2]
2025-02-07T09:37:34.501Z root ERROR D 2025-02-07T09:37:34.501Z | retrying_call | [1] Committing call [2] at index 0
2025-02-07T09:37:34.501Z root ERROR D 2025-02-07T09:37:34.501Z | resolving_call | [0] Received metadata
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.501Z | subchannel_call | [3] receive HTTP/2 data frame of length 9
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.502Z | subchannel_call | [3] parsed message of length 9
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.502Z | subchannel_call | [3] pushing to reader message of length 9
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.502Z | load_balancing_call | [2] Received message
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.502Z | retrying_call | [1] Received message from child [2]
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.502Z | resolving_call | [0] Received message
2025-02-07T09:37:34.504Z root ERROR D 2025-02-07T09:37:34.502Z | resolving_call | [0] Finished filtering received message
2025-02-07T09:37:34.505Z root ERROR D 2025-02-07T09:37:34.504Z | subchannel_call | [3] Received server trailers:
grpc-status: 0
grpc-message:
2025-02-07T09:37:34.505Z root ERROR D 2025-02-07T09:37:34.504Z | subchannel_call | [3] received status code 0 from server
2025-02-07T09:37:34.505Z root ERROR D 2025-02-07T09:37:34.504Z | subchannel_call | [3] received status details string "" from server
2025-02-07T09:37:34.505Z root ERROR D 2025-02-07T09:37:34.504Z | subchannel_call | [3] close http2 stream with code 0
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.505Z | subchannel_call | [3] ended with status: code=0 details=""
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | load_balancing_call | [2] Received status
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | load_balancing_call | [2] ended with status: code=0 details=""
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | retrying_call | [1] Received status from child [2]
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | retrying_call | [1] state=COMMITTED handling status with progress PROCESSED from child [2] in state ACTIVE
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | retrying_call | [1] ended with status: code=0 details=""
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | resolving_call | [0] Received status
2025-02-07T09:37:34.508Z root ERROR D 2025-02-07T09:37:34.506Z | resolving_call | [0] ended with status: code=0 details=""
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.506Z | subchannel_call | [3] HTTP/2 stream closed with code 0
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.507Z | channel | (1) dns:localhost:56169 createResolvingCall [4] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init", deadline=Infinity
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.507Z | resolving_call | [4] Created
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.507Z | resolving_call | [4] Deadline: Infinity
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.507Z | resolving_call | [4] start called
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.508Z | resolving_call | [4] write() called with message of length 4
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.508Z | resolving_call | [4] halfClose called
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.508Z | channel | (1) dns:localhost:56169 createRetryingCall [5] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.508Z | resolving_call | [4] Created child [5]
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.508Z | retrying_call | [5] start called
2025-02-07T09:37:34.509Z root ERROR D 2025-02-07T09:37:34.508Z | channel | (1) dns:localhost:56169 createLoadBalancingCall [6] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.508Z | retrying_call | [5] Created child call [6] for attempt 1
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.508Z | load_balancing_call | [6] start called
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.508Z | load_balancing_call | [6] Pick called
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.508Z | load_balancing_call | [6] Pick result: COMPLETE subchannel: (3) 127.0.0.1:56169 status: undefined undefined
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | transport_flowctrl | (4) 127.0.0.1:56169 local window size: 65526 remote window size: 65535
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | transport_internals | (4) 127.0.0.1:56169 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | load_balancing_call | [6] Created child call [7]
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | retrying_call | [5] write() called with message of length 9
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | load_balancing_call | [6] write() called with message of length 9
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | subchannel_call | [7] write() called with message of length 9
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | subchannel_call | [7] sending data chunk of length 9
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.509Z | retrying_call | [5] halfClose called
2025-02-07T09:37:34.510Z root ERROR D 2025-02-07T09:37:34.510Z | resolving_call | [4] startRead called
2025-02-07T09:37:34.511Z root ERROR D 2025-02-07T09:37:34.510Z | retrying_call | [5] startRead called
2025-02-07T09:37:34.511Z root ERROR D 2025-02-07T09:37:34.510Z | load_balancing_call | [6] startRead called
2025-02-07T09:37:34.511Z root ERROR D 2025-02-07T09:37:34.511Z | load_balancing_call | [6] halfClose called
2025-02-07T09:37:34.511Z root ERROR D 2025-02-07T09:37:34.511Z | subchannel_call | [7] end() called
2025-02-07T09:37:34.511Z root ERROR D 2025-02-07T09:37:34.511Z | subchannel_call | [7] calling end() on HTTP/2 stream
2025-02-07T09:37:34.616Z daemon INFO time="2025-02-07T15:07:34+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-07T09:37:34.616Z root ERROR D 2025-02-07T09:37:34.616Z | subchannel_call | [7] Received server headers:
:status: 200
2025-02-07T09:37:34.616Z root ERROR D 2025-02-07T09:37:34.616Z | load_balancing_call | [6] Received metadata
2025-02-07T09:37:34.616Z root ERROR D 2025-02-07T09:37:34.616Z | retrying_call | [5] Received metadata from child [6]
2025-02-07T09:37:34.616Z root ERROR D 2025-02-07T09:37:34.616Z | retrying_call | [5] Committing call [6] at index 0
2025-02-07T09:37:34.616Z root ERROR D 2025-02-07T09:37:34.616Z | resolving_call | [4] Received metadata
2025-02-07T09:37:34.628Z root ERROR D 2025-02-07T09:37:34.616Z | subchannel_call | [7] receive HTTP/2 data frame of length 115
2025-02-07T09:37:34.629Z root ERROR D 2025-02-07T09:37:34.616Z | subchannel_call | [7] parsed message of length 115
2025-02-07T09:37:34.629Z root ERROR D 2025-02-07T09:37:34.616Z | subchannel_call | [7] pushing to reader message of length 115
2025-02-07T09:37:34.629Z root ERROR D 2025-02-07T09:37:34.616Z | load_balancing_call | [6] Received message
2025-02-07T09:37:34.629Z root ERROR D 2025-02-07T09:37:34.616Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:37:34.629Z root ERROR D 2025-02-07T09:37:34.616Z | resolving_call | [4] Received message
2025-02-07T09:37:34.629Z root ERROR D 2025-02-07T09:37:34.616Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:37:34.630Z root ERROR D 2025-02-07T09:37:34.630Z | resolving_call | [4] startRead called
2025-02-07T09:37:34.630Z root ERROR D 2025-02-07T09:37:34.630Z | retrying_call | [5] startRead called
2025-02-07T09:37:34.630Z root ERROR D 2025-02-07T09:37:34.630Z | load_balancing_call | [6] startRead called
2025-02-07T09:37:35.287Z root ERROR D 2025-02-07T09:37:35.287Z | subchannel | (2) ::1:56169 TRANSIENT_FAILURE -> CONNECTING
2025-02-07T09:37:35.287Z root ERROR D 2025-02-07T09:37:35.287Z | transport | dns:localhost:56169 creating HTTP/2 session to ::1:56169
2025-02-07T09:37:35.288Z root ERROR D 2025-02-07T09:37:35.288Z | transport | dns:localhost:56169 connection failed with error connect ECONNREFUSED ::1:56169
2025-02-07T09:37:35.288Z root ERROR D 2025-02-07T09:37:35.288Z | subchannel | (2) ::1:56169 CONNECTING -> TRANSIENT_FAILURE
2025-02-07T09:37:35.288Z root ERROR D 2025-02-07T09:37:35.288Z | subchannel | (2) ::1:56169 TRANSIENT_FAILURE -> IDLE
2025-02-07T09:37:35.575Z root INFO Deploy plugins list: 151.8 ms [Finished 2.705 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-02-07T09:37:36.708Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 274.4 ms [Finished 2.732 s after frontend start]
2025-02-07T09:37:36.708Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-02-07T09:37:44.245Z root ERROR D 2025-02-07T09:37:44.244Z | subchannel_refcount | (2) ::1:56169 refcount 1 -> 0
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.703Z | subchannel_call | [7] receive HTTP/2 data frame of length 306
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.703Z | subchannel_call | [7] parsed message of length 306
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.703Z | subchannel_call | [7] pushing to reader message of length 306
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.703Z | load_balancing_call | [6] Received message
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.704Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.704Z | resolving_call | [4] Received message
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.704Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:38:16.705Z root ERROR D 2025-02-07T09:38:16.705Z | resolving_call | [4] startRead called
2025-02-07T09:38:16.706Z root ERROR D 2025-02-07T09:38:16.705Z | retrying_call | [5] startRead called
2025-02-07T09:38:16.706Z root ERROR D 2025-02-07T09:38:16.705Z | load_balancing_call | [6] startRead called
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | subchannel_call | [7] receive HTTP/2 data frame of length 850
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | subchannel_call | [7] parsed message of length 850
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | subchannel_call | [7] pushing to reader message of length 850
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | load_balancing_call | [6] Received message
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | resolving_call | [4] Received message
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.706Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:38:16.709Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2025-02-07T09:38:16.709Z root ERROR D 2025-02-07T09:38:16.709Z | resolving_call | [4] startRead called
2025-02-07T09:38:16.710Z root ERROR D 2025-02-07T09:38:16.709Z | retrying_call | [5] startRead called
2025-02-07T09:38:16.710Z root ERROR D 2025-02-07T09:38:16.709Z | load_balancing_call | [6] startRead called
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | subchannel_call | [7] receive HTTP/2 data frame of length 514
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | subchannel_call | [7] parsed message of length 514
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | subchannel_call | [7] pushing to reader message of length 514
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | load_balancing_call | [6] Received message
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | resolving_call | [4] Received message
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.710Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:38:16.711Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Lalit\AppData\Local\Arduino15\package_index.json: open C:\Users\Lalit\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.711Z | resolving_call | [4] startRead called
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.711Z | retrying_call | [5] startRead called
2025-02-07T09:38:16.711Z root ERROR D 2025-02-07T09:38:16.711Z | load_balancing_call | [6] startRead called
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.711Z | subchannel_call | [7] receive HTTP/2 data frame of length 160
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.711Z | subchannel_call | [7] parsed message of length 160
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.711Z | subchannel_call | [7] pushing to reader message of length 160
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.711Z | load_balancing_call | [6] Received message
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.712Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.712Z | resolving_call | [4] Received message
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.712Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:38:16.712Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.712Z | resolving_call | [4] startRead called
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.712Z | retrying_call | [5] startRead called
2025-02-07T09:38:16.712Z root ERROR D 2025-02-07T09:38:16.712Z | load_balancing_call | [6] startRead called
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | subchannel_call | [7] receive HTTP/2 data frame of length 158
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | subchannel_call | [7] parsed message of length 158
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | subchannel_call | [7] pushing to reader message of length 158
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | load_balancing_call | [6] Received message
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | resolving_call | [4] Received message
2025-02-07T09:38:16.713Z root ERROR D 2025-02-07T09:38:16.713Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:38:16.713Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.713Z | resolving_call | [4] startRead called
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.713Z | retrying_call | [5] startRead called
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.714Z | load_balancing_call | [6] startRead called
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.714Z | subchannel_call | [7] receive HTTP/2 data frame of length 167
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.714Z | subchannel_call | [7] parsed message of length 167
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.714Z | subchannel_call | [7] pushing to reader message of length 167
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.714Z | load_balancing_call | [6] Received message
2025-02-07T09:38:16.714Z root ERROR D 2025-02-07T09:38:16.714Z | retrying_call | [5] Received message from child [6]
2025-02-07T09:38:16.715Z root ERROR D 2025-02-07T09:38:16.714Z | resolving_call | [4] Received message
2025-02-07T09:38:16.715Z root ERROR D 2025-02-07T09:38:16.714Z | resolving_call | [4] Finished filtering received message
2025-02-07T09:38:16.715Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Lalit\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-07T09:38:16.715Z root ERROR D 2025-02-07T09:38:16.715Z | resolving_call | [4] startRead called
2025-02-07T09:38:16.715Z root ERROR D 2025-02-07T09:38:16.715Z | retrying_call | [5] startRead called
2025-02-07T09:38:16.715Z root ERROR D 2025-02-07T09:38:16.715Z | load_balancing_call | [6] startRead called
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | subchannel_call | [7] Received server trailers:
grpc-status: 0
grpc-message:
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | subchannel_call | [7] received status code 0 from server
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | subchannel_call | [7] received status details string "" from server
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | subchannel_call | [7] close http2 stream with code 0
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | subchannel_call | [7] ended with status: code=0 details=""
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | load_balancing_call | [6] Received status
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.715Z | load_balancing_call | [6] ended with status: code=0 details=""
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.716Z | retrying_call | [5] Received status from child [6]
2025-02-07T09:38:16.723Z root ERROR D 2025-02-07T09:38:16.716Z | retrying_call | [5] state=COMMITTED handling status with progress PROCESSED from child [6] in state ACTIVE
2025-02-07T09:38:16.724Z root ERROR D 2025-02-07T09:38:16.716Z | retrying_call | [5] ended with status: code=0 details=""
2025-02-07T09:38:16.724Z root ERROR D 2025-02-07T09:38:16.716Z | resolving_call | [4] Received status
2025-02-07T09:38:16.724Z root ERROR D 2025-02-07T09:38:16.716Z | resolving_call | [4] ended with status: code=0 details=""
2025-02-07T09:38:16.725Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\Lalit\AppData\Local\Arduino15\package_index.json: open C:\Users\Lalit\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\Lalit\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | channel | (1) dns:localhost:56169 createResolvingCall [8] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex", deadline=Infinity
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [8] Created
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [8] Deadline: Infinity
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [8] start called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [8] write() called with message of length 4
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [8] halfClose called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | channel | (1) dns:localhost:56169 createResolvingCall [9] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex", deadline=Infinity
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [9] Created
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [9] Deadline: Infinity
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.722Z | resolving_call | [9] start called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.723Z | resolving_call | [9] write() called with message of length 4
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.723Z | resolving_call | [9] halfClose called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | channel | (1) dns:localhost:56169 createRetryingCall [10] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex"
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | resolving_call | [8] Created child [10]
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | retrying_call | [10] start called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | channel | (1) dns:localhost:56169 createLoadBalancingCall [11] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateIndex"
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | retrying_call | [10] Created child call [11] for attempt 1
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [11] start called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [11] Pick called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [11] Pick result: COMPLETE subchannel: (3) 127.0.0.1:56169 status: undefined undefined
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | channel | (1) dns:localhost:56169 createRetryingCall [12] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex"
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | resolving_call | [9] Created child [12]
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | retrying_call | [12] start called
2025-02-07T09:38:16.725Z root ERROR D 2025-02-07T09:38:16.724Z | channel | (1) dns:localhost:56169 createLoadBalancingCall [13] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/UpdateLibrariesIndex"
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | retrying_call | [12] Created child call [13] for attempt 1
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [13] start called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [13] Pick called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [13] Pick result: COMPLETE subchannel: (3) 127.0.0.1:56169 status: undefined undefined
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | transport_flowctrl | (4) 127.0.0.1:56169 local window size: 63256 remote window size: 65535
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | transport_internals | (4) 127.0.0.1:56169 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.724Z | load_balancing_call | [11] Created child call [14]
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | load_balancing_call | [13] Created child call [15]
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | retrying_call | [10] write() called with message of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | load_balancing_call | [11] write() called with message of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | subchannel_call | [14] write() called with message of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | subchannel_call | [14] sending data chunk of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | retrying_call | [10] halfClose called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | retrying_call | [12] write() called with message of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | load_balancing_call | [13] write() called with message of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | subchannel_call | [15] write() called with message of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | subchannel_call | [15] sending data chunk of length 9
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.725Z | retrying_call | [12] halfClose called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.726Z | resolving_call | [8] startRead called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.726Z | retrying_call | [10] startRead called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.726Z | load_balancing_call | [11] startRead called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.726Z | resolving_call | [9] startRead called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.726Z | retrying_call | [12] startRead called
2025-02-07T09:38:16.726Z root ERROR D 2025-02-07T09:38:16.726Z | load_balancing_call | [13] startRead called
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | subchannel_call | [7] HTTP/2 stream closed with code 0
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | load_balancing_call | [11] halfClose called
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | subchannel_call | [14] end() called
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | subchannel_call | [14] calling end() on HTTP/2 stream
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | load_balancing_call | [13] halfClose called
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | subchannel_call | [15] end() called
2025-02-07T09:38:16.727Z root ERROR D 2025-02-07T09:38:16.727Z | subchannel_call | [15] calling end() on HTTP/2 stream
2025-02-07T09:38:16.727Z daemon INFO time="2025-02-07T15:08:16+05:30" level=info msg="Loading hardware from: C:\\Users\\Lalit\\AppData\\Local\\Arduino15\\packages"
time="2025-02-07T15:08:16+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\Lalit\\AppData\\Local\\Arduino15\\library_index.json"
time="2025-02-07T15:08:16+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Lalit\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-02-07T15:08:16+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Lalit\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
time="2025-02-07T15:08:16+05:30" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-02-07T09:38:16.729Z daemon INFO time="2025-02-07T15:08:16+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2025-02-07T15:08:16+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-02-07T09:38:16.729Z root ERROR D 2025-02-07T09:38:16.729Z | subchannel_call | [15] Received server headers:
:status: 200
2025-02-07T09:38:16.729Z root ERROR D 2025-02-07T09:38:16.729Z | load_balancing_call | [13] Received metadata
2025-02-07T09:38:16.729Z root ERROR D 2025-02-07T09:38:16.729Z | retrying_call | [12] Received metadata from child [13]
2025-02-07T09:38:16.729Z root ERROR D 2025-02-07T09:38:16.729Z | retrying_call | [12] Committing call [13] at index 0
2025-02-07T09:38:16.730Z root ERROR D 2025-02-07T09:38:16.729Z | resolving_call | [9] Received metadata
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | subchannel_call | [15] receive HTTP/2 data frame of length 113
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | subchannel_call | [15] parsed message of length 113
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | subchannel_call | [15] pushing to reader message of length 113
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | load_balancing_call | [13] Received message
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | retrying_call | [12] Received message from child [13]
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | resolving_call | [9] Received message
2025-02-07T09:38:16.731Z root ERROR D 2025-02-07T09:38:16.730Z | resolving_call | [9] Finished filtering received message
2025-02-07T09:38:16.731Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.731Z | resolving_call | [9] startRead called
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.731Z | retrying_call | [12] startRead called
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.731Z | load_balancing_call | [13] startRead called
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.732Z | subchannel_call | [14] Received server headers:
:status: 200
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.732Z | load_balancing_call | [11] Received metadata
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.732Z | retrying_call | [10] Received metadata from child [11]
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.732Z | retrying_call | [10] Committing call [11] at index 0
2025-02-07T09:38:16.732Z root ERROR D 2025-02-07T09:38:16.732Z | resolving_call | [8] Received metadata
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | subchannel_call | [14] receive HTTP/2 data frame of length 112
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | subchannel_call | [14] parsed message of length 112
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | subchannel_call | [14] pushing to reader message of length 112
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | load_balancing_call | [11] Received message
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | retrying_call | [10] Received message from child [11]
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | resolving_call | [8] Received message
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.732Z | resolving_call | [8] Finished filtering received message
2025-02-07T09:38:16.733Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.733Z | resolving_call | [8] startRead called
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.733Z | retrying_call | [10] startRead called
2025-02-07T09:38:16.733Z root ERROR D 2025-02-07T09:38:16.733Z | load_balancing_call | [11] startRead called
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.816Z | subchannel_call | [15] receive HTTP/2 data frame of length 303
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.816Z | subchannel_call | [15] parsed message of length 303
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.816Z | subchannel_call | [15] pushing to reader message of length 303
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | load_balancing_call | [13] Received message
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | retrying_call | [12] Received message from child [13]
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | resolving_call | [9] Received message
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | resolving_call | [9] Finished filtering received message
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | resolving_call | [9] startRead called
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | retrying_call | [12] startRead called
2025-02-07T09:38:58.817Z root ERROR D 2025-02-07T09:38:58.817Z | load_balancing_call | [13] startRead called
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | subchannel_call | [14] receive HTTP/2 data frame of length 302
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | subchannel_call | [14] parsed message of length 302
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | subchannel_call | [14] pushing to reader message of length 302
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | load_balancing_call | [11] Received message
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | retrying_call | [10] Received message from child [11]
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | resolving_call | [8] Received message
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | resolving_call | [8] Finished filtering received message
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | resolving_call | [8] startRead called
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | retrying_call | [10] startRead called
2025-02-07T09:38:58.818Z root ERROR D 2025-02-07T09:38:58.818Z | load_balancing_call | [11] startRead called
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | subchannel_call | [15] receive HTTP/2 data frame of length 73
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | subchannel_call | [15] parsed message of length 73
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | subchannel_call | [15] pushing to reader message of length 73
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | load_balancing_call | [13] Received message
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | retrying_call | [12] Received message from child [13]
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | resolving_call | [9] Received message
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.819Z | resolving_call | [9] Finished filtering received message
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.820Z | resolving_call | [9] startRead called
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.820Z | retrying_call | [12] startRead called
2025-02-07T09:38:58.820Z root ERROR D 2025-02-07T09:38:58.820Z | load_balancing_call | [13] startRead called
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | subchannel_call | [14] receive HTTP/2 data frame of length 72
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | subchannel_call | [14] parsed message of length 72
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | subchannel_call | [14] pushing to reader message of length 72
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | load_balancing_call | [11] Received message
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | retrying_call | [10] Received message from child [11]
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | resolving_call | [8] Received message
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.820Z | resolving_call | [8] Finished filtering received message
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.821Z | resolving_call | [8] startRead called
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.821Z | retrying_call | [10] startRead called
2025-02-07T09:38:58.821Z root ERROR D 2025-02-07T09:38:58.821Z | load_balancing_call | [11] startRead called
2025-02-07T09:38:58.823Z root ERROR D 2025-02-07T09:38:58.821Z | subchannel_call | [15] Received server trailers:
grpc-status: 13
grpc-message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2025-02-07T09:38:58.823Z root ERROR D 2025-02-07T09:38:58.821Z | subchannel_call | [15] received status code 13 from server
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | subchannel_call | [15] received status details string "Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond." from server
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | subchannel_call | [15] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | subchannel_call | [15] close http2 stream with code 8
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | load_balancing_call | [13] Received status
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | load_balancing_call | [13] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | retrying_call | [12] Received status from child [13]
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | retrying_call | [12] state=COMMITTED handling status with progress PROCESSED from child [13] in state ACTIVE
2025-02-07T09:38:58.824Z root ERROR D 2025-02-07T09:38:58.821Z | retrying_call | [12] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
2025-02-07T09:38:58.825Z root ERROR D 2025-02-07T09:38:58.821Z | resolving_call | [9] Received status
2025-02-07T09:38:58.825Z root ERROR D 2025-02-07T09:38:58.822Z | resolving_call | [9] ended with status: code=13 details="Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
2025-02-07T09:38:58.826Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.10.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:921712)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:949334)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:942356)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1028497
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:949101)
at s.updateLibrariesIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778557
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778750
at new Promise (<anonymous>)
at v.doUpdateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778729)
at v.updateLibraryIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:778529)
at v.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777803)
at v.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776035)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.823Z | channel | (1) dns:localhost:56169 createResolvingCall [16] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init", deadline=Infinity
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.823Z | resolving_call | [16] Created
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.823Z | resolving_call | [16] Deadline: Infinity
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.823Z | resolving_call | [16] start called
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.823Z | resolving_call | [16] write() called with message of length 4
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.823Z | resolving_call | [16] halfClose called
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | channel | (1) dns:localhost:56169 createRetryingCall [17] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | resolving_call | [16] Created child [17]
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | retrying_call | [17] start called
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | channel | (1) dns:localhost:56169 createLoadBalancingCall [18] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Init"
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | retrying_call | [17] Created child call [18] for attempt 1
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | load_balancing_call | [18] start called
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | load_balancing_call | [18] Pick called
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.825Z | load_balancing_call | [18] Pick result: COMPLETE subchannel: (3) 127.0.0.1:56169 status: undefined undefined
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.826Z | transport_flowctrl | (4) 127.0.0.1:56169 local window size: 62281 remote window size: 65535
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.826Z | transport_internals | (4) 127.0.0.1:56169 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.826Z | load_balancing_call | [18] Created child call [19]
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.826Z | retrying_call | [17] write() called with message of length 9
2025-02-07T09:38:58.826Z root ERROR D 2025-02-07T09:38:58.826Z | load_balancing_call | [18] write() called with message of length 9
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.826Z | subchannel_call | [19] write() called with message of length 9
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.826Z | subchannel_call | [19] sending data chunk of length 9
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.826Z | retrying_call | [17] halfClose called
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.827Z | resolving_call | [16] startRead called
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.827Z | retrying_call | [17] startRead called
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.827Z | load_balancing_call | [18] startRead called
2025-02-07T09:38:58.827Z root ERROR D 2025-02-07T09:38:58.827Z | subchannel_call | [15] HTTP/2 stream closed with code 8
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.827Z | subchannel_call | [14] Received server trailers:
grpc-status: 13
grpc-message: Some indexes could not be updated.
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.827Z | subchannel_call | [14] received status code 13 from server
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.827Z | subchannel_call | [14] received status details string "Some indexes could not be updated." from server
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.827Z | subchannel_call | [14] ended with status: code=13 details="Some indexes could not be updated."
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.827Z | subchannel_call | [14] close http2 stream with code 8
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | load_balancing_call | [11] Received status
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | load_balancing_call | [11] ended with status: code=13 details="Some indexes could not be updated."
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | retrying_call | [10] Received status from child [11]
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | retrying_call | [10] state=COMMITTED handling status with progress PROCESSED from child [11] in state ACTIVE
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | retrying_call | [10] ended with status: code=13 details="Some indexes could not be updated."
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | resolving_call | [8] Received status
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | resolving_call | [8] ended with status: code=13 details="Some indexes could not be updated."
2025-02-07T09:38:58.828Z root ERROR D 2025-02-07T09:38:58.828Z | subchannel_call | [14] HTTP/2 stream closed with code 8
2025-02-07T09:38:58.829Z root ERROR D 2025-02-07T09:38:58.829Z | load_balancing_call | [18] halfClose called
2025-02-07T09:38:58.829Z root ERROR D 2025-02-07T09:38:58.829Z | subchannel_call | [19] end() called
2025-02-07T09:38:58.829Z root ERROR D 2025-02-07T09:38:58.829Z | subchannel_call | [19] calling end() on HTTP/2 stream
2025-02-07T09:38:58.832Z daemon INFO time="2025-02-07T15:08:58+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-07T09:38:58.832Z root ERROR D 2025-02-07T09:38:58.832Z | subchannel_call | [19] Received server headers:
:status: 200
2025-02-07T09:38:58.832Z root ERROR D 2025-02-07T09:38:58.832Z | load_balancing_call | [18] Received metadata
2025-02-07T09:38:58.832Z root ERROR D 2025-02-07T09:38:58.832Z | retrying_call | [17] Received metadata from child [18]
2025-02-07T09:38:58.832Z root ERROR D 2025-02-07T09:38:58.832Z | retrying_call | [17] Committing call [18] at index 0
2025-02-07T09:38:58.832Z root ERROR D 2025-02-07T09:38:58.832Z | resolving_call | [16] Received metadata
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | subchannel_call | [19] receive HTTP/2 data frame of length 115
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | subchannel_call | [19] parsed message of length 115
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | subchannel_call | [19] pushing to reader message of length 115
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | load_balancing_call | [18] Received message
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | resolving_call | [16] Received message
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | resolving_call | [16] startRead called
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | retrying_call | [17] startRead called
2025-02-07T09:38:58.833Z root ERROR D 2025-02-07T09:38:58.833Z | load_balancing_call | [18] startRead called
2025-02-07T09:39:40.987Z daemon INFO time="2025-02-07T15:09:40+05:30" level=info msg="Loading hardware from: C:\\Users\\Lalit\\AppData\\Local\\Arduino15\\packages"
2025-02-07T09:39:40.987Z daemon INFO time="2025-02-07T15:09:40+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\Lalit\\AppData\\Local\\Arduino15\\library_index.json"
2025-02-07T09:39:40.988Z daemon INFO time="2025-02-07T15:09:40+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Lalit\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-02-07T09:39:40.989Z daemon INFO time="2025-02-07T15:09:40+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Lalit\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-02-07T09:39:40.989Z root ERROR D 2025-02-07T09:39:40.989Z | subchannel_call | [19] receive HTTP/2 data frame of length 306
2025-02-07T09:39:40.989Z root ERROR D 2025-02-07T09:39:40.989Z | subchannel_call | [19] parsed message of length 306
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.989Z | subchannel_call | [19] pushing to reader message of length 306
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.989Z | load_balancing_call | [18] Received message
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.989Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.989Z | resolving_call | [16] Received message
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.989Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | resolving_call | [16] startRead called
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | retrying_call | [17] startRead called
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | load_balancing_call | [18] startRead called
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | subchannel_call | [19] receive HTTP/2 data frame of length 850
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | subchannel_call | [19] parsed message of length 850
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | subchannel_call | [19] pushing to reader message of length 850
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | load_balancing_call | [18] Received message
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | resolving_call | [16] Received message
2025-02-07T09:39:40.990Z root ERROR D 2025-02-07T09:39:40.990Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:39:40.991Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | resolving_call | [16] startRead called
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | retrying_call | [17] startRead called
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | load_balancing_call | [18] startRead called
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | subchannel_call | [19] receive HTTP/2 data frame of length 514
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | subchannel_call | [19] parsed message of length 514
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | subchannel_call | [19] pushing to reader message of length 514
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | load_balancing_call | [18] Received message
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | resolving_call | [16] Received message
2025-02-07T09:39:40.991Z root ERROR D 2025-02-07T09:39:40.991Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:39:40.991Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Lalit\AppData\Local\Arduino15\package_index.json: open C:\Users\Lalit\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | subchannel_call | [19] receive HTTP/2 data frame of length 160
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | subchannel_call | [19] parsed message of length 160
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | subchannel_call | [19] pushing to reader message of length 160
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | load_balancing_call | [18] Received message
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | resolving_call | [16] Received message
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.991Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:39:40.992Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | resolving_call | [16] startRead called
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | retrying_call | [17] startRead called
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | load_balancing_call | [18] startRead called
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | subchannel_call | [19] receive HTTP/2 data frame of length 158
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | subchannel_call | [19] parsed message of length 158
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | subchannel_call | [19] pushing to reader message of length 158
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | load_balancing_call | [18] Received message
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | resolving_call | [16] Received message
2025-02-07T09:39:40.992Z root ERROR D 2025-02-07T09:39:40.992Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:39:40.992Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | resolving_call | [16] startRead called
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | retrying_call | [17] startRead called
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | load_balancing_call | [18] startRead called
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] receive HTTP/2 data frame of length 167
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] parsed message of length 167
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] pushing to reader message of length 167
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | load_balancing_call | [18] Received message
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | retrying_call | [17] Received message from child [18]
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | resolving_call | [16] Received message
2025-02-07T09:39:40.993Z root ERROR D 2025-02-07T09:39:40.993Z | resolving_call | [16] Finished filtering received message
2025-02-07T09:39:40.993Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Lalit\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] Received server trailers:
grpc-status: 0
grpc-message:
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] received status code 0 from server
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] received status details string "" from server
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] close http2 stream with code 0
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.993Z | subchannel_call | [19] ended with status: code=0 details=""
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.993Z | load_balancing_call | [18] Received status
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.994Z | load_balancing_call | [18] ended with status: code=0 details=""
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.994Z | retrying_call | [17] Received status from child [18]
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.994Z | retrying_call | [17] state=COMMITTED handling status with progress PROCESSED from child [18] in state ACTIVE
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.994Z | retrying_call | [17] ended with status: code=0 details=""
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.994Z | resolving_call | [16] Received status
2025-02-07T09:39:40.994Z root ERROR D 2025-02-07T09:39:40.994Z | resolving_call | [16] ended with status: code=0 details=""
2025-02-07T09:39:40.995Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2025-02-07T09:39:40.995Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777546
at v.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777562)
at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777232)
2025-02-07T09:39:40.995Z root ERROR D 2025-02-07T09:39:40.995Z | subchannel_call | [19] HTTP/2 stream closed with code 0
2025-02-07T10:09:41.009Z root ERROR D 2025-02-07T10:09:41.008Z | channel | (1) dns:localhost:56169 Idle timer triggered after 1800000ms of inactivity
2025-02-07T10:09:41.009Z root ERROR D 2025-02-07T10:09:41.008Z | subchannel_refcount | (3) 127.0.0.1:56169 refcount 2 -> 1
2025-02-07T10:09:41.009Z root ERROR D 2025-02-07T10:09:41.008Z | connectivity_state | (1) dns:localhost:56169 READY -> IDLE
2025-02-07T10:09:45.751Z root ERROR D 2025-02-07T10:09:45.750Z | subchannel_refcount | (3) 127.0.0.1:56169 refcount 1 -> 0
2025-02-07T10:09:45.751Z root ERROR D 2025-02-07T10:09:45.750Z | subchannel | (3) 127.0.0.1:56169 READY -> IDLE
2025-02-07T10:09:45.752Z root ERROR D 2025-02-07T10:09:45.751Z | transport | (4) 127.0.0.1:56169 session closed
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
