I downloaded the latest Arduino version 2.3.2 and every time I open it the Arduino logo appears and keeps flashing on the screen and the app doesn't work at all.
I've tried to sync date and time, the problem still exists.
I have ran PowerShell in the Arduino IDE folder, wrote the command &".\Arduino IDE", hit Enter, and that's the output I've got:
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 4732
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/remon/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-07-23T17:44:38.486Z root INFO Backend Object.initialize: 9.6 ms [Finished 1.028 s after backend start]
2024-07-23T17:44:38.488Z root INFO Backend Object.configure: 8.1 ms [Finished 1.028 s after backend start]
2024-07-23T17:44:38.488Z root INFO Backend s.onStart: 5.1 ms [Finished 1.028 s after backend start]
2024-07-23T17:44:38.489Z root INFO Backend s.configure: 0.6 ms [Finished 1.082 s after backend start]
2024-07-23T17:44:38.490Z root INFO Backend d.onStart: 0.4 ms [Finished 1.082 s after backend start]
2024-07-23T17:44:38.492Z root INFO Backend d.configure: 0.2 ms [Finished 1.082 s after backend start]
2024-07-23T17:44:38.493Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 53.6 ms [Finished 1.083 s after backend start]
2024-07-23T17:44:38.493Z root INFO Backend c.onStart: 0.5 ms [Finished 1.083 s after backend start]
2024-07-23T17:44:38.494Z root INFO Backend a.configure: 2.2 ms [Finished 1.085 s after backend start]
2024-07-23T17:44:38.498Z config INFO >>> Initializing CLI configuration...
2024-07-23T17:44:38.498Z root INFO Backend c.initialize: 1.0 ms [Finished 1.085 s after backend start]
2024-07-23T17:44:38.498Z root INFO Backend R.onStart: 1.4 ms [Finished 1.086 s after backend start]
2024-07-23T17:44:38.500Z config INFO Loading CLI configuration from c:\Users\remon\.arduinoIDE\arduino-cli.yaml...
2024-07-23T17:44:38.501Z daemon INFO Starting daemon from C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2024-07-23T17:44:38.501Z root INFO Backend a.initialize: 0.7 ms [Finished 1.088 s after backend start]
2024-07-23T17:44:38.501Z root INFO Backend w.onStart: 1.9 ms [Finished 1.089 s after backend start]
2024-07-23T17:44:38.501Z root INFO Backend r.configure: 3.2 ms [Finished 1.090 s after backend start]
2024-07-23T17:44:38.502Z discovery-log INFO start
2024-07-23T17:44:38.502Z discovery-log INFO start new deferred
2024-07-23T17:44:38.502Z root INFO Backend d.initialize: 0.8 ms [Finished 1.091 s after backend start]
2024-07-23T17:44:38.502Z root INFO Backend y.onStart: 4.3 ms [Finished 1.094 s after backend start]
2024-07-23T17:44:38.502Z root INFO Backend r.configure: 3.7 ms [Finished 1.095 s after backend start]
2024-07-23T17:44:38.502Z root INFO Backend a.onStart: 1.0 ms [Finished 1.098 s after backend start]
2024-07-23T17:44:38.502Z root INFO Backend h.configure: 0.9 ms [Finished 1.098 s after backend start]
2024-07-23T17:44:38.502Z root INFO Backend s.configure: 0.3 ms [Finished 1.098 s after backend start]
2024-07-23T17:44:38.502Z root INFO Backend l.configure: 0.2 ms [Finished 1.098 s after backend start]
2024-07-23T17:44:38.509Z root INFO Theia app listening on http://127.0.0.1:59985.
2024-07-23T17:44:38.509Z root INFO Finished starting backend application: 7.1 ms [Finished 1.105 s after backend start]
2024-07-23T17:44:38.526Z root WARN The local plugin referenced by local-dir:/c%3A/Users/remon/.arduinoIDE/plugins does not exist.
2024-07-23T17:44:38.526Z root WARN The local plugin referenced by local-dir:/c%3A/Users/remon/.arduinoIDE/extensions does not exist.
2024-07-23T17:44:38.527Z root WARN The local plugin referenced by local-dir:C:\Users\remon\.arduinoIDE\plugins does not exist.
2024-07-23T17:44:38.552Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\remon\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\remon\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\remon\\OneDrive\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-07-23T17:44:38.552Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-07-23T17:44:38.552Z config INFO Loaded the CLI configuration.
2024-07-23T17:44:38.560Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/remon/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/remon/OneDrive/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-07-23T17:44:38.560Z config INFO Validating the CLI configuration...
2024-07-23T17:44:38.561Z config INFO The CLI config is valid.
2024-07-23T17:44:38.561Z config INFO <<< Initialized the CLI configuration.
2024-07-23T17:44:38.606Z root INFO Resolve plugins list: 106.1 ms [Finished 1.201 s after backend start]
2024-07-23T17:44:38.649Z daemon INFO time="2024-07-23T20:44:38+03:00" level=info msg="Using config file: c:\\Users\\remon\\.arduinoIDE\\arduino-cli.yaml"
time="2024-07-23T20:44:38+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-07-23T20:44:38+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-07-23T17:44:38.659Z daemon INFO Daemon is now listening on 127.0.0.1:59986
{"IP":"127.0.0.1","Port":"59986"}
2024-07-23T17:44:38.659Z daemon INFO Daemon is running.
2024-07-23T17:44:38.712Z daemon INFO time="2024-07-23T20:44:38+03:00" level=info msg="Updating libraries index"
time="2024-07-23T20:44:38+03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-07-23T17:44:38.754Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-07-23T17:44:38.755Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\remon\AppData\Local\Arduino15\package_index.json: open C:\Users\remon\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-07-23T17:44:38.756Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-07-23T17:44:38.757Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-07-23T17:44:38.757Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\remon\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-07-23T17:44:38.768Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\remon\AppData\Local\Arduino15\package_index.json: open C:\Users\remon\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\remon\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-07-23T17:44:38.769Z daemon INFO time="2024-07-23T20:44:38+03:00" level=info msg="Loading hardware from: C:\\Users\\remon\\AppData\\Local\\Arduino15\\packages"
time="2024-07-23T20:44:38+03:00" level=info msg="Loading libraries index file" index="C:\\Users\\remon\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-07-23T20:44:38+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\remon\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-07-23T20:44:38+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\remon\\OneDrive\\Documents\\Arduino\\libraries" location=user
2024-07-23T17:44:38.837Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-07-23T17:44:38.841Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
at t.callErrorFromStatus (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:763461)
at Object.onReceiveStatus (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:791078)
at Object.onReceiveStatus (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:784102)
at C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:870224
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeServerStreamRequest (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:790845)
at s.updateIndex (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:855121)
at C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:623733
at C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:624081
at new Promise (<anonymous>)
at E.doUpdateIndex (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:624060)
at E.updatePlatformIndex (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:623705)
at E.updateIndex (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:623073)
at E.initInstanceWithFallback (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:621317)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-07-23T17:44:38.842Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-07-23T17:44:38.844Z daemon INFO time="2024-07-23T20:44:38+03:00" level=info msg="Updating libraries index"
time="2024-07-23T20:44:38+03:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2024-07-23T20:44:38+03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-07-23T17:44:38.852Z daemon INFO time="2024-07-23T20:44:38+03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-07-23T17:44:38.854Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-07-23T17:44:38.854Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\remon\AppData\Local\Arduino15\package_index.json: open C:\Users\remon\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-07-23T17:44:38.855Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-07-23T17:44:38.855Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-07-23T17:44:38.855Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\remon\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-07-23T17:44:38.857Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-07-23T17:44:38.857Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:622877
at E.evaluateErrorStatus (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:622893)
at async a.<anonymous> (C:\Users\Public\Downloads\arduino-ide_2.3.2_Windows_64bit\resources\app\lib\backend\main.js:2:622563)
2024-07-23T17:44:40.279Z root INFO Deploy plugins list: 106.1 ms [Finished 2.876 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-07-23T17:44:41.677Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 294.8 ms [Finished 2.950 s after frontend start]
2024-07-23T17:44:41.677Z root WARN A command editor.action.toggleStickyScroll is already registered.
