IDE hangs on startup: "discovery teensy:teensy-discovery not found"
Continuing the discussion from Arduino 2.3.0 can't open the app on WIN11:
Hi!
Not sure if I should add to this topic or start a new one, but I'm having the same issue. I've done everything suggested - Open as administrator, delete folders in AppData, etc. Opening through he Windows PowerShell, here's what I get:
type or paste code herePS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 8628
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/rob.reynolds/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-01T18:15:00.730Z root INFO Backend Object.initialize: 5.6 ms [Finished 0.476 s after backend start]
2024-03-01T18:15:00.732Z root INFO Backend Object.configure: 5.4 ms [Finished 0.477 s after backend start]
2024-03-01T18:15:00.732Z root INFO Backend s.onStart: 1.9 ms [Finished 0.477 s after backend start]
2024-03-01T18:15:00.733Z root INFO Backend s.configure: 0.3 ms [Finished 0.496 s after backend start]
2024-03-01T18:15:00.733Z root INFO Backend d.onStart: 0.2 ms [Finished 0.496 s after backend start]
2024-03-01T18:15:00.734Z root INFO Backend d.configure: 0.1 ms [Finished 0.496 s after backend start]
2024-03-01T18:15:00.735Z root INFO Backend d.initialize: 18.8 ms [Finished 0.496 s after backend start]
2024-03-01T18:15:00.735Z root INFO Backend c.onStart: 0.2 ms [Finished 0.496 s after backend start]
2024-03-01T18:15:00.735Z root INFO Backend a.configure: 1.9 ms [Finished 0.498 s after backend start]
2024-03-01T18:15:00.737Z config INFO >>> Initializing CLI configuration...
2024-03-01T18:15:00.737Z root INFO Backend c.initialize: 0.5 ms [Finished 0.499 s after backend start]
2024-03-01T18:15:00.737Z root INFO Backend R.onStart: 1.1 ms [Finished 0.499 s after backend start]
2024-03-01T18:15:00.738Z config INFO Loading CLI configuration from c:\Users\rob.reynolds\.arduinoIDE\arduino-cli.yaml...
2024-03-01T18:15:00.739Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-01T18:15:00.739Z root INFO Backend a.initialize: 0.3 ms [Finished 0.500 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend w.onStart: 1.0 ms [Finished 0.501 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend r.configure: 1.6 ms [Finished 0.501 s after backend start]
2024-03-01T18:15:00.739Z discovery-log INFO start
2024-03-01T18:15:00.739Z discovery-log INFO start new deferred
2024-03-01T18:15:00.739Z root INFO Backend d.initialize: 0.4 ms [Finished 0.501 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend y.onStart: 1.9 ms [Finished 0.503 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend r.configure: 1.8 ms [Finished 0.503 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend a.onStart: 0.4 ms [Finished 0.504 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend h.configure: 0.4 ms [Finished 0.504 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend s.configure: 0.1 ms [Finished 0.505 s after backend start]
2024-03-01T18:15:00.739Z root INFO Backend l.configure: 0.1 ms [Finished 0.505 s after backend start]
2024-03-01T18:15:00.741Z root INFO Theia app listening on http://127.0.0.1:50444.
2024-03-01T18:15:00.741Z root INFO Finished starting backend application: 2.3 ms [Finished 0.507 s after backend start]
2024-03-01T18:15:00.752Z root WARN The local plugin referenced by local-dir:/c%3A/Users/rob.reynolds/.arduinoIDE/plugins does not exist.
2024-03-01T18:15:00.752Z root WARN The local plugin referenced by local-dir:/c%3A/Users/rob.reynolds/.arduinoIDE/extensions does not exist.
2024-03-01T18:15:00.753Z root WARN The local plugin referenced by local-dir:C:\Users\rob.reynolds\.arduinoIDE\plugins does not exist.
2024-03-01T18:15:00.760Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\rob.reynolds\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-01T18:15:00.760Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-01T18:15:00.760Z config INFO Loaded the CLI configuration.
2024-03-01T18:15:00.763Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/rob.reynolds/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/rob.reynolds/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-01T18:15:00.763Z config INFO Validating the CLI configuration...
2024-03-01T18:15:00.765Z config INFO The CLI config is valid.
2024-03-01T18:15:00.765Z config INFO <<< Initialized the CLI configuration.
2024-03-01T18:15:00.783Z root INFO Resolve plugins list: 45.2 ms [Finished 0.548 s after backend start]
Restoring workspace roots: c:\Users\rob.reynolds\Documents\Arduino\WiFiWebserverBlink\WiFiWebserverBlink.ino
isTempSketch: false. Input was c:\Users\rob.reynolds\Documents\Arduino\WiFiWebserverBlink\WiFiWebserverBlink.ino
2024-03-01T18:15:00.866Z daemon INFO time="2024-03-01T11:15:00-07:00" level=info msg="Using config file: c:\\Users\\rob.reynolds\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-01T11:15:00-07:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-01T11:15:00-07:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-01T18:15:00.877Z daemon INFO Daemon is now listening on 127.0.0.1:50445
{"IP":"127.0.0.1","Port":"50445"}
2024-03-01T18:15:00.877Z daemon INFO Daemon is running.
2024-03-01T18:15:01.009Z daemon INFO time="2024-03-01T11:15:00-07:00" level=info msg="Checking signature" index="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-03-01T11:15:00-07:00" level=info msg="Loading hardware from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading package SparkFun from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
time="2024-03-01T11:15:00-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="SparkFun:apollo3@2.2.1"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="SparkFun:esp32@1.0.0"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.3"
time="2024-03-01T11:15:00-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="SparkFun:arm-none-eabi-gcc@8-2018-q4-major"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading package arduino from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-03-01T11:15:00-07:00" level=info msg="Missing signature file" index="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.0.5"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.13"
time="2024-03-01T11:15:00-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading package builtin from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-03-01T11:15:00-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-03-01T11:15:00-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.9.1"
time="2024-03-01T11:15:00-07:00" level=info msg="Loading package esp32 from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-03-01T18:15:01.049Z daemon INFO time="2024-03-01T11:15:01-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.14"
time="2024-03-01T11:15:01-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:esptool_py@2.6.1"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230419"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-80-g6c4433a-5.2.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package esp8266 from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-03-01T18:15:01.060Z daemon INFO time="2024-03-01T11:15:01-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2024-03-01T11:15:01-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package teensy from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
time="2024-03-01T11:15:01-07:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="teensy:avr@1.58.1"
time="2024-03-01T11:15:01-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.58.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading hardware from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware"
2024-03-01T18:15:01.093Z daemon INFO time="2024-03-01T11:15:01-07:00" level=info msg="Loading package amd64 from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\amd64"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package attiny-master from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\attiny-master"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="attiny-master:variants@"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package ia64 from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\ia64"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package license from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\license"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package sparkfun from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="sparkfun:avr@1.0.0"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="sparkfun:esp8266@1.6.4"
time="2024-03-01T11:15:01-07:00" level=info msg="Loaded platform" platform="sparkfun:samd@1.6.1"
time="2024-03-01T11:15:01-07:00" level=info msg="Loading package x86 from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\x86"
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.5\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun\\avr\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun\\esp8266\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun\\samd\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\apollo3\\2.2.1\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\esp32\\1.0.0\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.3\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries" location=platform
time="2024-03-01T11:15:01-07:00" level=info msg="Loading libraries index file" index="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-01T18:15:01.095Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-03-01T18:15:01.278Z daemon INFO time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-01T18:15:01.281Z daemon INFO time="2024-03-01T11:15:01-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\libraries" location=user
2024-03-01T18:15:01.617Z root INFO Deploy plugins list: 45.2 ms [Finished 1.383 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-03-01T18:15:02.608Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 154.7 ms [Finished 1.687 s after frontend start]
2024-03-01T18:15:02.608Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-01T18:15:03.007Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-03-01T18:15:03.008Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-01T18:15:03.009Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-01T18:15:03.011Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-03-01T18:15:03.552Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Checking signature" index="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-01T18:15:03.552Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading hardware from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages"
2024-03-01T18:15:03.553Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package SparkFun from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
2024-03-01T18:15:03.554Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="SparkFun:apollo3@2.2.1"
2024-03-01T18:15:03.555Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
2024-03-01T18:15:03.556Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="SparkFun:esp32@1.0.0"
2024-03-01T18:15:03.558Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-01T18:15:03.558Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.3"
2024-03-01T18:15:03.558Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\tools"
2024-03-01T18:15:03.558Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="SparkFun:arm-none-eabi-gcc@8-2018-q4-major"
2024-03-01T18:15:03.559Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package arduino from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-03-01T18:15:03.561Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Missing signature file" index="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-03-01T18:15:03.564Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2024-03-01T18:15:03.565Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.0.5"
2024-03-01T18:15:03.566Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.13"
2024-03-01T18:15:03.566Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-03-01T18:15:03.567Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
2024-03-01T18:15:03.567Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
2024-03-01T18:15:03.568Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
2024-03-01T18:15:03.568Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-03-01T18:15:03.568Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
2024-03-01T18:15:03.568Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-03-01T18:15:03.568Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-03-01T18:15:03.568Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package builtin from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-01T18:15:03.569Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-01T18:15:03.570Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-03-01T18:15:03.570Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-01T18:15:03.570Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-01T18:15:03.570Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-01T18:15:03.570Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.9.1"
2024-03-01T18:15:03.570Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package esp32 from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-03-01T18:15:03.598Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.14"
time="2024-03-01T11:15:03-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-03-01T18:15:03.599Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:esptool_py@2.6.1"
2024-03-01T18:15:03.599Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-03-01T18:15:03.599Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-03-01T18:15:03.600Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-03-01T18:15:03.600Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230419"
2024-03-01T18:15:03.600Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-01T18:15:03.601Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-03-01T18:15:03.601Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-03-01T18:15:03.601Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-80-g6c4433a-5.2.0"
2024-03-01T18:15:03.601Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-01T18:15:03.601Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-01T18:15:03.601Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-01T18:15:03.602Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package esp8266 from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-03-01T18:15:03.611Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2024-03-01T11:15:03-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2024-03-01T18:15:03.611Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-03-01T18:15:03.611Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2024-03-01T18:15:03.611Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-03-01T18:15:03.612Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package teensy from: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
2024-03-01T18:15:03.613Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="teensy:avr@1.58.1"
2024-03-01T18:15:03.613Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading tools from dir: C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
2024-03-01T18:15:03.614Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
2024-03-01T18:15:03.614Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.58.0"
time="2024-03-01T11:15:03-07:00" level=info msg="Loading hardware from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware"
2024-03-01T18:15:03.614Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package amd64 from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\amd64"
2024-03-01T18:15:03.614Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package attiny-master from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\attiny-master"
2024-03-01T18:15:03.615Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="attiny-master:variants@"
2024-03-01T18:15:03.615Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package ia64 from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\ia64"
2024-03-01T18:15:03.616Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package license from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\license"
2024-03-01T18:15:03.618Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package sparkfun from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun"
2024-03-01T18:15:03.619Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="sparkfun:avr@1.0.0"
2024-03-01T18:15:03.620Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="sparkfun:esp8266@1.6.4"
time="2024-03-01T11:15:03-07:00" level=info msg="Loaded platform" platform="sparkfun:samd@1.6.1"
2024-03-01T18:15:03.621Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading package x86 from: C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\x86"
2024-03-01T18:15:03.623Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-03-01T18:15:03.624Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\apollo3\\2.2.1\\libraries" location=platform
2024-03-01T18:15:03.625Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
2024-03-01T18:15:03.626Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\esp32\\1.0.0\\libraries" location=platform
2024-03-01T18:15:03.627Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.3\\libraries" location=platform
2024-03-01T18:15:03.628Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun\\avr\\libraries" location=platform
2024-03-01T18:15:03.629Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun\\esp8266\\libraries" location=platform
2024-03-01T18:15:03.630Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\hardware\\sparkfun\\samd\\libraries" location=platform
2024-03-01T18:15:03.632Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\libraries" location=platform
2024-03-01T18:15:03.635Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries" location=platform
2024-03-01T18:15:03.637Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
2024-03-01T18:15:03.638Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.5\\libraries" location=platform
2024-03-01T18:15:03.640Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-03-01T18:15:03.642Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
2024-03-01T18:15:03.642Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Loading libraries index file" index="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-01T18:15:03.777Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-01T18:15:03.778Z daemon INFO time="2024-03-01T11:15:03-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\rob.reynolds\\Documents\\Arduino\\libraries" location=user
2024-03-01T18:15:04.862Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-03-01T18:15:04.862Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
Marking workspace as a closed sketch. Workspace URI: file:///c%3A/Users/rob.reynolds/Documents/Arduino/WiFiWebserverBlink/WiFiWebserverBlink.ino. Date: 1709316962142.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Storing the sketch as a workspace root: <c:\Users\rob.reynolds\Documents\Arduino\WiFiWebserverBlink\WiFiWebserverBlink.ino>.
Stored workspaces roots: c:\Users\rob.reynolds\Documents\Arduino\WiFiWebserverBlink\WiFiWebserverBlink.ino
No sketches were scheduled for deletion.
I've also attached the log file.
2024-03-01_log.log (45.8 KB)
It seems like "Error loading hardware platform: discovery teensy:teensy-discovery not found" seems to be the issue, or at least one of them. If anyone know the fix/workaround for this (perhaps @ptillisch ), it would be greatly appreciated. If this should have been a new topic, I apologize.
Thanks!
Rob
Hi @SFERob. This indicates that something is wrong with the installation of the "Teensy" boards platform on your computer.
Other users who experienced this problem reported that it was fixed after uninstalling and then reinstalling the platform. Normally we can use the convenient Boards Manager GUI to uninstall platforms, but since the IDE doesn't start it will instead be necessary to uninstall it manually. After that, the IDE should start up and you can use Boards Manager to reinstall the platform.
I'll provide instructions you can follow to do that:
A. Uninstall "Teensy" Platform
  1. Close the Arduino IDE window if it is running.
  2. Delete the folder at the following path:
    C:\Users\rob.reynolds\AppData\Local\Arduino15\packages\teensy\
    :warning: Please be very careful when deleting things from your computer. When in doubt, back up!
    :exclamation: If looking for it with your file browser or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  3. Start Arduino IDE.
The IDE should start successfully this time.
B. Reinstall "Teensy" Platform
The instructions above uninstalled the "Teensy" boards platform. If you need that platform, you should now reinstall it by following the official instructions here:
https://www.pjrc.com/arduino-ide-2-0-0-teensy-support/
Hopefully that will produce a fully working installation that won't interfere with the IDE's ability to start up on future sessions.
Please let me know if you have any questions or problems while following those instructions.
Well that was so much faster and simpler than I expected. Thanks so much, I really appreciate your help and quick response!
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
