IDE hangs on startup: "discovery teensy:teensy-discovery not found"
Me too.
Where is the previous version?
You can download Arduino IDE 2.3.3 from the links under the "Assets" section of the release page in the project's GitHub repository here:
Please add a reply here to let us know whether the problem also occurs when you use Arduino IDE 2.3.3.
Yes, same problem with 2.3.3. It hangs on the pulsating splash screen. No indication of anything.
Might it not like a version 1.x (1.8.13) also being installed?
WIN10 with all updates installed.
No, that is not the cause. There is no problem with having Arduino IDE 1.8.13 and Arduino IDE 2.x installed at the same time.
I'm going to ask you to provide some additional information that might help us to identify the problem.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
    A context menu will open
  5. Select "Open PowerShell window here" from the menu.
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait until you are sure the IDE startup has gone into the hang state
    (as indicated by no additional output being printed to the terminal).
  9. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  10. Press the Ctrl+Shift+A keyboard shortcut.
    This will select all the text in the PowerShell window.
  11. Press the Ctrl+C keyboard shortcut.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the "Reply" button.
  13. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  14. Press the Ctrl+V keyboard shortcut.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 12040
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/dave/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-12-09T02:12:49.655Z root INFO Backend Object.initialize: 4.1 ms [Finished 0.498 s after backend start]
2024-12-09T02:12:49.655Z root INFO Backend Object.configure: 3.4 ms [Finished 0.498 s after backend start]
2024-12-09T02:12:49.655Z root INFO Backend s.onStart: 2.0 ms [Finished 0.498 s after backend start]
2024-12-09T02:12:49.656Z root INFO Backend s.configure: 0.3 ms [Finished 0.518 s after backend start]
2024-12-09T02:12:49.656Z root INFO Backend d.onStart: 0.2 ms [Finished 0.518 s after backend start]
2024-12-09T02:12:49.657Z root INFO Backend d.configure: 0.1 ms [Finished 0.518 s after backend start]
2024-12-09T02:12:49.658Z root INFO Backend d.initialize: 20.3 ms [Finished 0.519 s after backend start]
2024-12-09T02:12:49.658Z root INFO Backend c.onStart: 0.2 ms [Finished 0.519 s after backend start]
2024-12-09T02:12:49.658Z root INFO Backend a.configure: 0.9 ms [Finished 0.519 s after backend start]
2024-12-09T02:12:49.660Z config INFO >>> Initializing CLI configuration...
2024-12-09T02:12:49.660Z root INFO Backend c.initialize: 0.4 ms [Finished 0.520 s after backend start]
2024-12-09T02:12:49.660Z root INFO Backend x.onStart: 0.7 ms [Finished 0.520 s after backend start]
2024-12-09T02:12:49.661Z config INFO Loading CLI configuration from c:\Users\dave\.arduinoIDE\arduino-cli.yaml...
2024-12-09T02:12:49.661Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-12-09T02:12:49.661Z root INFO Backend a.initialize: 0.3 ms [Finished 0.521 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend w.onStart: 1.0 ms [Finished 0.522 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend r.configure: 1.7 ms [Finished 0.522 s after backend start]
2024-12-09T02:12:49.661Z discovery-log INFO start
2024-12-09T02:12:49.661Z discovery-log INFO start new deferred
2024-12-09T02:12:49.661Z root INFO Backend d.initialize: 0.4 ms [Finished 0.522 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend y.onStart: 1.9 ms [Finished 0.524 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend r.configure: 1.6 ms [Finished 0.524 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend a.onStart: 0.4 ms [Finished 0.525 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend h.configure: 0.3 ms [Finished 0.525 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend s.configure: 0.1 ms [Finished 0.525 s after backend start]
2024-12-09T02:12:49.661Z root INFO Backend l.configure: 0.1 ms [Finished 0.525 s after backend start]
2024-12-09T02:12:49.664Z root INFO Theia app listening on http://127.0.0.1:64045.
2024-12-09T02:12:49.664Z root INFO Finished starting backend application: 2.6 ms [Finished 0.528 s after backend start]
2024-12-09T02:12:49.665Z root WARN The local plugin referenced by local-dir:/c%3A/Users/dave/.arduinoIDE/plugins does not exist.
2024-12-09T02:12:49.665Z root WARN The local plugin referenced by local-dir:/c%3A/Users/dave/.arduinoIDE/extensions does not exist.
2024-12-09T02:12:49.665Z root WARN The local plugin referenced by local-dir:C:\Users\dave\.arduinoIDE\plugins does not exist.
2024-12-09T02:12:49.673Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\dave\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\dave\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\dave\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-12-09T02:12:49.673Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-12-09T02:12:49.673Z config INFO Loaded the CLI configuration.
2024-12-09T02:12:49.683Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/dave/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/dave/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-12-09T02:12:49.683Z config INFO Validating the CLI configuration...
2024-12-09T02:12:49.684Z config INFO The CLI config is valid.
2024-12-09T02:12:49.684Z config INFO <<< Initialized the CLI configuration.
2024-12-09T02:12:49.702Z root INFO Resolve plugins list: 41.5 ms [Finished 0.566 s after backend start]
2024-12-09T02:12:49.728Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="arduino-cli version 1.1.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Using config file: c:\\Users\\dave\\.arduinoIDE\\arduino-cli.yaml"
time="2024-12-08T18:12:49-08:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:64046
{"IP":"127.0.0.1","Port":"64046"}
2024-12-09T02:12:49.728Z daemon INFO Daemon is running.
2024-12-09T02:12:49.845Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="Checking signature" index="C:\\Users\\dave\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\dave\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-12-08T18:12:49-08:00" level=info msg="Loading hardware from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package Seeeduino from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware"
time="2024-12-08T18:12:49-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="Seeeduino:samd@1.8.3"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="Seeeduino:CMSIS@5.7.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="Seeeduino:CMSIS-Atmel@1.2.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="Seeeduino:arduinoOTA@1.2.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="Seeeduino:arm-none-eabi-gcc@7-2017q4"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="Seeeduino:bossac@1.7.0-arduino3"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="Seeeduino:bossac@1.8.0-48-gb176eee"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package adafruit from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="adafruit:avr@1.4.15"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="adafruit:samd@1.7.11"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="adafruit:CMSIS@5.4.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="adafruit:CMSIS-Atmel@1.2.2"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="adafruit:arm-none-eabi-gcc@9-2019q4"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="adafruit:bossac@1.8.0-48-gb176eee"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package arduino from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.13"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package builtin from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package esp32 from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-12-09T02:12:49.896Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
2024-12-09T02:12:49.943Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.6"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.2.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20220706"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package esp8266 from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading package rp2040 from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="rp2040:rp2040@3.1.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-elf2uf2@1.5.0-b-c7bab52"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@1.5.0-b-c7bab52"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@1.5.0-b-c7bab52"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@1.5.0-b-c7bab52"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@1.5.0-b-03f2812"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@1.5.0-b-c7bab52"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-12-09T02:12:49.945Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="Loading package teensy from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
2024-12-09T02:12:49.948Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded platform" platform="teensy:avr@1.57.2"
time="2024-12-08T18:12:49-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@5.4.1"
time="2024-12-08T18:12:49-08:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.57.2"
2024-12-09T02:12:49.993Z daemon INFO time="2024-12-08T18:12:49-08:00" level=info msg="Searching tools required for platform rp2040:rp2040@3.1.0"
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.11\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.1.0\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:49-08:00" level=info msg="Loading libraries index file" index="C:\\Users\\dave\\AppData\\Local\\Arduino15\\library_index.json"
2024-12-09T02:12:49.995Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-12-09T02:12:50.183Z daemon INFO time="2024-12-08T18:12:50-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2024-12-09T02:12:50.185Z daemon INFO time="2024-12-08T18:12:50-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-12-09T02:12:50.525Z root INFO Deploy plugins list: 41.5 ms [Finished 1.389 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-12-09T02:12:51.484Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 142.9 ms [Finished 1.717 s after frontend start]
2024-12-09T02:12:51.484Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-12-09T02:12:51.740Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 164.6 ms [Finished 2.013 s after frontend start]
2024-12-09T02:12:53.396Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-12-09T02:12:53.397Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-12-09T02:12:53.398Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-12-09T02:12:53.401Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-12-09T02:12:53.835Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking signature" index="C:\\Users\\dave\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\dave\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-12-09T02:12:53.836Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading hardware from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages"
2024-12-09T02:12:53.837Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package Seeeduino from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware"
2024-12-09T02:12:53.838Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="Seeeduino:samd@1.8.3"
2024-12-09T02:12:53.838Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools"
2024-12-09T02:12:53.838Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="Seeeduino:CMSIS@5.7.0"
2024-12-09T02:12:53.838Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="Seeeduino:CMSIS-Atmel@1.2.1"
2024-12-09T02:12:53.838Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="Seeeduino:arduinoOTA@1.2.1"
2024-12-09T02:12:53.838Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="Seeeduino:arm-none-eabi-gcc@7-2017q4"
2024-12-09T02:12:53.839Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="Seeeduino:bossac@1.7.0-arduino3"
2024-12-09T02:12:53.839Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="Seeeduino:bossac@1.8.0-48-gb176eee"
2024-12-09T02:12:53.839Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package adafruit from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware"
2024-12-09T02:12:53.840Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="adafruit:avr@1.4.15"
2024-12-09T02:12:53.843Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="adafruit:samd@1.7.11"
2024-12-09T02:12:53.843Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools"
2024-12-09T02:12:53.843Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="adafruit:CMSIS@5.4.0"
2024-12-09T02:12:53.843Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="adafruit:CMSIS-Atmel@1.2.2"
2024-12-09T02:12:53.843Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="adafruit:arm-none-eabi-gcc@9-2019q4"
2024-12-09T02:12:53.843Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="adafruit:bossac@1.8.0-48-gb176eee"
2024-12-09T02:12:53.844Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package arduino from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-12-09T02:12:53.846Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2024-12-09T02:12:53.847Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.13"
2024-12-09T02:12:53.847Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-12-09T02:12:53.847Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
2024-12-09T02:12:53.847Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-12-09T02:12:53.848Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
2024-12-09T02:12:53.849Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package builtin from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-12-09T02:12:53.850Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-12-09T02:12:53.850Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-12-09T02:12:53.851Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-12-09T02:12:53.851Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-12-09T02:12:53.851Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-12-09T02:12:53.851Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
2024-12-09T02:12:53.851Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-12-09T02:12:53.852Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package esp32 from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-12-09T02:12:53.893Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
2024-12-09T02:12:53.919Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.6"
2024-12-09T02:12:53.919Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-12-09T02:12:53.919Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.2.1"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20220706"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-12-09T02:12:53.920Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
2024-12-09T02:12:53.921Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
2024-12-09T02:12:53.921Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
2024-12-09T02:12:53.921Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package esp8266 from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-12-09T02:12:53.934Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2024-12-09T02:12:53.934Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2024-12-09T02:12:53.934Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2024-12-09T02:12:53.935Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-12-09T02:12:53.935Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2024-12-09T02:12:53.935Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-12-09T02:12:53.935Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package rp2040 from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="rp2040:rp2040@3.1.0"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-elf2uf2@1.5.0-b-c7bab52"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@1.5.0-b-c7bab52"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@1.5.0-b-c7bab52"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@1.5.0-b-c7bab52"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@1.5.0-b-03f2812"
2024-12-09T02:12:53.946Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@1.5.0-b-c7bab52"
2024-12-09T02:12:53.947Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-12-09T02:12:53.947Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loading package teensy from: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
2024-12-09T02:12:53.950Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2024-12-08T18:12:53-08:00" level=info msg="Loaded platform" platform="teensy:avr@1.57.2"
2024-12-09T02:12:53.950Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-12-08T18:12:53-08:00" level=info msg="Loading tools from dir: C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
2024-12-09T02:12:53.951Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@5.4.1"
2024-12-09T02:12:53.951Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.57.2"
2024-12-09T02:12:53.961Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Searching tools required for platform rp2040:rp2040@3.1.0"
2024-12-09T02:12:53.962Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-12-09T02:12:53.966Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.968Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.970Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.1.0\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.972Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.974Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.976Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.978Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.11\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.980Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" isSingleLibrary=false location=platform
2024-12-09T02:12:53.982Z daemon INFO time="2024-12-08T18:12:53-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-12-08T18:12:53-08:00" level=info msg="Loading libraries index file" index="C:\\Users\\dave\\AppData\\Local\\Arduino15\\library_index.json"
2024-12-09T02:12:54.176Z daemon INFO time="2024-12-08T18:12:54-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2024-12-09T02:12:54.177Z daemon INFO time="2024-12-08T18:12:54-08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\dave\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-12-09T02:12:57.060Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-12-09T02:12:57.060Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777546
    at v.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777562)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777232)
Arduino IDE 2.3.4
FYI: CTRL-SHIFT-A  does not select ALL in PS for me.
Ah. So now I have deleted the Teensy package at C:\Users\dave\AppData\Local\Arduino15\packages\
That seems to do it, per others haveing the same problem / indication.
Odd that Teensy didn't seem to show up in 1.8.13.
Thanks for taking the time to post an update. Great work of finding the relevant error in the log and tracking down the fix!
Regards, Per
