IDE hangs on startup: "discovery teensy:teensy-discovery not installed"
Hello there, I have downloaded the newest released Arduino 2.0 IDE onto my Windows 11 64bit computer and I don't seem to be able to get it to do anything after the program opens. It just opens shows the main screen then seems to freeze and doesn't load any boards or libraries even after leaving alone for 30+minutes. It then won't even let me shut it down I have to use the Windows Taskmaster app instead, this would indicate to me that it is trying to do something, just not sure what. I have loaded the exact same software download onto my Windows 10 64bit laptop and it all works fine.
Any ideas what I can try.
Chris.
Hi @CeeTee. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<user name>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  7. Wait for the Arduino IDE to finish starting, or failing to start.
  8. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  9. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  10. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  11. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  14. Press Ctrl+V.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hello, thank you for the quick reply. Please find attached below the results from thePowerShell window.
PS C:\Users\ctee\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 10804
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/ctee/.theia'
root INFO Backend Object.initialize: 5.5 ms [Finished 2.183 s after backend start]
root INFO Backend Object.configure: 4.4 ms [Finished 2.183 s after backend start]
root INFO Backend MessagingContribution.onStart: 1.8 ms [Finished 2.183 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 2.270 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 2.270 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.2 ms [Finished 2.271 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 87.1 ms [Finished 2.271 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.3 ms [Finished 2.271 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.3 ms [Finished 2.273 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 2.273 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 0.9 ms [Finished 2.273 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 2.275 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.3 ms [Finished 2.276 s after backend start]
root INFO Backend NodeFileUploadService.configure: 2.3 ms [Finished 2.276 s after backend start]
daemon INFO Starting daemon from C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 0.9 ms [Finished 2.277 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.7 ms [Finished 2.278 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.6 ms [Finished 2.279 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 2.280 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 2.281 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.281 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 1.8 ms [Finished 2.283 s after backend start]
root INFO Theia app listening on http://localhost:60718.
root INFO Finished starting backend application: 6.2 ms [Finished 2.286 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/ctee/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\ctee\.arduinoProIDE\plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/ctee/.arduinoIDE/extensions does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root ERROR ---- !!!SLOW!!! DURATION: loadCliConfig took 153.089 ms. Args: [] ----
root INFO Resolve plugins list: 169.7 ms [Finished 2.448 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 7.4 ms [Finished 2.456 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 4.7 ms [Finished 2.460 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 21.4 ms [Finished 2.482 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 6.5 ms [Finished 2.488 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.4 ms [Finished 2.491 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 335.2 ms [Finished 2.826 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 221.4 ms [Finished 3.047 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 188.8 ms [Finished 3.236 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 167.6 ms [Finished 3.404 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 144.6 ms [Finished 3.548 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 138.3 ms [Finished 3.687 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 48.3 ms [Finished 3.735 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 170.5 ms [Finished 3.906 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 146.4 ms [Finished 4.052 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 178.0 ms [Finished 4.230 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 161.1 ms [Finished 4.391 s after backend start]
root INFO Deploy plugins list: 169.7 ms [Finished 4.409 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 296.4 ms [Finished 3.058 s after frontend start]
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 143.7 ms [Finished 3.383 s after frontend start]
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Start frontend contributions: 736.6 ms [Finished 3.435 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO <<< Nothing to restore.
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 79.9 ms [Finished 3.563 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f] Waiting for backend deployment: 239.0 ms [Finished 3.668 s after frontend start]
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
Checking for update
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128) starting instance
root INFO Frontend application start: 2051.6 ms [Finished 7.458 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 894.9 ms [Finished 4.460 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO Executing startup tasks: []
Update for version 2.0.0 is not available (latest version: 2.0.0, downgrade is allowed).
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f] Sync of 16 plugins: 2066.7 ms [Finished 5.735 s after frontend start]
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][marus25.cortex-debug]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][vscode.cpp]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][vscode.json]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][vscode.json-language-features]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f] Load contributions of 16 plugins: 108.6 ms [Finished 5.844 s after frontend start]
root WARN Mismatching sketch file <Dual.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <lipo.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <BarnDoor.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <encoder3.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <CANTest1e.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <CANTest2e.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <Kuckuck_F.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <stepper4.ino> and sketch folder name <Stepper4>. Skipping
root WARN Mismatching sketch file <CompNumber.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <LOWLatency.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <st7735bench.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <SerialBinary.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <entryapp-gene.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <dht.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <TFT_Shield.ino> and sketch folder name <TFT>. Skipping
root WARN Mismatching sketch file <glow.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <life.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <jnr.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <lcdLightControl.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <chip8.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <flash.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <fonts.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <jpeg2.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <lines.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <polar.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <scope.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <cube.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <fizz.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <jpeg.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <logo.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <mono.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <song.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <tilt.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <walk.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <blobs.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <chess.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <cobra.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <cube2.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <noisy.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <simon.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <tiled.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <LHLong_reset_test.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <apitest.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <formats.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <gd3load.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <ili9488.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <tempest.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <welcome.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <kenney.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <sketch.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <video1.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <video2.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <viewer.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <bargraph.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <bringup0.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <circular.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <examples.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <invaders.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <specgram.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <frogger.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <slotgag.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <sprites.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <widgets.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <fireflies.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <sunflower.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <paletted.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <terminal.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <MeasureFrequency.cpp.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <manicminer.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <tesla_winder_teensy20.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <tut-bitmaps.ino> and sketch folder name <contrib>. Skipping
root WARN Mismatching sketch file <helloworld.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <radarchart.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <reflection.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <send_data.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <fastLogger.pde> and sketch folder name <Fast Logger>. Skipping
root WARN Mismatching sketch file <nightstrike.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <interrupts.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <record_asm.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <Teensy_Serial_Barebones.ino> and sketch folder name <Arduino>. Skipping
root WARN Mismatching sketch file <binaryLogger.pde> and sketch folder name <Fast Logger>. Skipping
root WARN Mismatching sketch file <TMC2100.ino> and sketch folder name <software>. Skipping
root WARN Mismatching sketch file <TMC2130.ino> and sketch folder name <software>. Skipping
root WARN Mismatching sketch file <TMC220X.ino> and sketch folder name <software>. Skipping
root WARN Mismatching sketch file <TMC5160.ino> and sketch folder name <software>. Skipping
root WARN Mismatching sketch file <t4_overclock.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <LOWLatency.ino> and sketch folder name <LOWLatency.ino>. Skipping
root WARN Mismatching sketch file <record_asm_t4.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <i2cSlaveLogger.pde> and sketch folder name <Fast Logger>. Skipping
root WARN Mismatching sketch file <i2cMasterSender.pde> and sketch folder name <Fast Logger>. Skipping
root WARN Mismatching sketch file <record_hardware.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <record_rle_data.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <Avisos.ino> and sketch folder name <GD3_DialVX>. Skipping
root WARN Mismatching sketch file <earth.ino> and sketch folder name <GPS>. Skipping
root WARN Mismatching sketch file <record_low_speed_data.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <dac_fifo_dma.ino> and sketch folder name <teensy-samples-master>. Skipping
root WARN Mismatching sketch file <new_ino.ino> and sketch folder name <Tset-master>. Skipping
root WARN Mismatching sketch file <ECU.ino> and sketch folder name <project-arduino-ecu-a7603efe1300>. Skipping
root WARN Mismatching sketch file <MSCtest.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <serial_protocol_17.ino> and sketch folder name <Serial_protocol-17>. Skipping
root WARN Mismatching sketch file <Clockwise.ino> and sketch folder name <Stepper_Motor_Speed_Control>. Skipping
root WARN Mismatching sketch file <record_high_speed_rle_data.ino> and sketch folder name <TeensyLogicAnalyzer>. Skipping
root WARN Mismatching sketch file <input_capture_dma.ino> and sketch folder name <teensy-samples-master>. Skipping
root WARN Mismatching sketch file <Deaccelerate.ino> and sketch folder name <Stepper_Motor_Speed_Control>. Skipping
root WARN Mismatching sketch file <AntiClockwise.ino> and sketch folder name <Stepper_Motor_Speed_Control>. Skipping
root WARN Mismatching sketch file <Accelrate_Motor.ino> and sketch folder name <Stepper_Motor_Speed_Control>. Skipping
root WARN Mismatching sketch file <dac_fifo_dma.ino> and sketch folder name <LOW_Latency>. Skipping
root WARN Mismatching sketch file <simple_decode.ino> and sketch folder name <examples>. Skipping
root WARN Mismatching sketch file <lighttemplogger.pde> and sketch folder name <Light-and-Temp-logger-master>. Skipping
root WARN Mismatching sketch file <ECU.ino> and sketch folder name <SSnowden-project-arduino-ecu-a7603efe1300>. Skipping
root WARN Mismatching sketch file <input_capture_dma.ino> and sketch folder name <LOW_Latency>. Skipping
root WARN Mismatching sketch file <DD4WH_Bat_detector_v1_2.ino> and sketch folder name <Teensy-Bat-Detector-master>. Skipping
root WARN Mismatching sketch file <SdFatSDIO_low_latency_logger.ino> and sketch folder name <teensy-samples-master>. Skipping
root WARN Mismatching sketch file <command_list.ino> and sketch folder name <TestFlash>. Skipping
root WARN Mismatching sketch file <MultiWiiConf.pde> and sketch folder name <source>. Skipping
root WARN Mismatching sketch file <input_capture_period.ino> and sketch folder name <LOW_Latency>. Skipping
root WARN Mismatching sketch file <serialControl.ino> and sketch folder name <SerialControl>. Skipping
root WARN Mismatching sketch file <main.ino> and sketch folder name <Runnable>. Skipping
root WARN Mismatching sketch file <CAN_BoardTest.ino> and sketch folder name <ArduinoDUE_OBD_FreeRunningCAN-master>. Skipping
root WARN Mismatching sketch file <CAN_Example_2.ino> and sketch folder name <ArduinoDUE_OBD_FreeRunningCAN-master>. Skipping
root WARN Mismatching sketch file <OBD_Example_3.ino> and sketch folder name <ArduinoDUE_OBD_FreeRunningCAN-master>. Skipping
root WARN Mismatching sketch file <input_capture_period.ino> and sketch folder name <teensy-samples-master>. Skipping
root WARN Mismatching sketch file <LowLatencyLogger.ino> and sketch folder name <LowLatencyLoggerADXL345>. Skipping
root WARN Mismatching sketch file <LowLatencyLogger.ino> and sketch folder name <LowLatencyLoggerMPU6050>. Skipping
root WARN Mismatching sketch file <CompCrop_v0_32.ino> and sketch folder name <CompCrop>. Skipping
root WARN Mismatching sketch file <CompPage_v0_32.ino> and sketch folder name <CompPage>. Skipping
root WARN Mismatching sketch file <CompText_v0_32.ino> and sketch folder name <CompText>. Skipping
root WARN Mismatching sketch file <Diagnostics_functions.ino> and sketch folder name <FlashDiagnostics>. Skipping
root WARN Mismatching sketch file <SimpleStepper.ino> and sketch folder name <Stepper0_simplestExample>. Skipping
root WARN Mismatching sketch file <CAN_Example_2.ino> and sketch folder name <Examples>. Skipping
root WARN Mismatching sketch file <OBD_Example_3.ino> and sketch folder name <Examples>. Skipping
root WARN Mismatching sketch file <CompGauge_v0_32.ino> and sketch folder name <CompGauge>. Skipping
root WARN Mismatching sketch file <CompTimer_v0_32.ino> and sketch folder name <CompTimer>. Skipping
root WARN Mismatching sketch file <CompButton_v0_32.ino> and sketch folder name <CompButton>. Skipping
root WARN Mismatching sketch file <CompNumber_v0_32.ino> and sketch folder name <CompNumber>. Skipping
root WARN Mismatching sketch file <CompSlider_v0_32.ino> and sketch folder name <CompSlider>. Skipping
root WARN Mismatching sketch file <CompHotspot_v0_32.ino> and sketch folder name <CompHotspot>. Skipping
root WARN Mismatching sketch file <CompPicture_v0_32.ino> and sketch folder name <CompPicture>. Skipping
root WARN Mismatching sketch file <CompWaveform_v0_32.ino> and sketch folder name <CompWaveform>. Skipping
root WARN Mismatching sketch file <CompProgressBar_v0_32.ino> and sketch folder name <CompProgressBar>. Skipping
root WARN Mismatching sketch file <rotTextExample.ino> and sketch folder name <ILI9341_RotateCompressTextHack>. Skipping
root WARN Mismatching sketch file <CompDualStateButton_v0_32.ino> and sketch folder name <CompDualStateButton>. Skipping
root WARN Mismatching sketch file <CAN_Example_AnalogCan.ino.ino> and sketch folder name <CAN_Example_AnalogCan>. Skipping
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 4152.023 ms. Args: [{"uri":"file:///c%3A/Users/ctee/Documents/Arduino"}] ----
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 3011.437 ms. Args: [{}] ----
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(cortex-debug@0.3.10 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] Debugger contribution has been registered: cortex-debug
PLUGIN_HOST(12128): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12128): initializing(cpp@1.52.1 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(json@1.46.1 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(json-language-features@1.46.1 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(vscode-language-pack-cs@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12128): initializing(vscode-language-pack-de@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12128): initializing(vscode-language-pack-es@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12128): initializing(vscode-language-pack-fr@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(vscode-language-pack-it@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12128): initializing(vscode-language-pack-ja@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12128): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(vscode-language-pack-ru@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(vscode-language-pack-tr@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 12128] PLUGIN_HOST(12128): PluginManagerExtImpl/loadPlugin(C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][marus25.cortex-debug]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][arduino.vscode-arduino-tools]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][vscode.cpp]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][vscode.json]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][vscode.json-language-features]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [79771fd9-368a-4022-aa5f-310ee5144c7f] Start of 16 plugins: 2753.7 ms [Finished 8.618 s after frontend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\ctee\\.arduinoIDE\\arduino-cli.yaml","time":"2022-09-20T14:30:44+01:00"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"IP":"127.0.0.1","Port":"54953"}
daemon INFO Daemon is running.
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loading package Microsoft from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\Microsoft\\hardware","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-09-20T14:30:44+01:00","tool":"builtin:serial-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"Microsoft:win10","Installed":"1.1.2","Latest":"1.1.2","Name":"Windows 10 IoT Core"},"time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-09-20T14:30:44+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:mbed_edge","Installed":"3.3.0","Latest":"3.3.0","Name":"Arduino Mbed OS Edge Boards"},"time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:mbed_rp2040","Installed":"3.3.0","Latest":"3.3.0","Name":"Arduino Mbed OS RP2040 Boards"},"time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:sam","Installed":"1.6.12","Latest":"1.6.12","Name":"Arduino ARM (32-bits) Boards"},"time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-20T14:30:44+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:44+01:00","tool":{"version":"1.3.0","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"4.8.3-2014q1","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"7-2017q4","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"6.3.0-arduino17","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.6.1-arduino","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.9.1-arduino2","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"0.10.0-arduino1","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"0.11.0-arduino2","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.0.6","systems":null}}
daemon INFO {"level":"info","msg":"Loading package builtin from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-20T14:30:45+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"5.8-arduino11","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.0.5","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.3.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"0.9.1","systems":null}}
{"level":"info","msg":"Loading package esp8266 from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-09-20T14:30:45+01:00","tool":"builtin:serial-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"esp8266:esp8266","Installed":"3.0.2","Latest":"3.0.2","Name":"ESP8266 Boards (3.0.2)"},"time":"2022-09-20T14:30:45+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools","time":"2022-09-20T14:30:45+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"3.0.4-gcc10.3-1757bed","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"3.7.2-post1","systems":null}}
{"level":"info","msg":"Loading package teensy from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\installed.json.sig","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"teensy","time":"2022-09-20T14:30:45+01:00","tool":"teensy:teensy-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"teensy:avr","Installed":"1.56.1","Latest":"1.56.1","Name":"Teensy"},"time":"2022-09-20T14:30:45+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\tools","time":"2022-09-20T14:30:45+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\tools","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linux32.tar.bz2","ArchiveFileName":"teensy-compile-linux32.tar.bz2","Checksum":"SHA-256:f28a8bbaa28600404ed997dea48862b9e97a243fc1d74090d0365cbdb1290e52","Size":71528248,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linux64.tar.bz2","ArchiveFileName":"teensy-compile-linux64.tar.bz2","Checksum":"SHA-256:f61ee7358909e4aebc3c0de5ada2c61208d0ea0f01384d7f73b4a8ad396bf383","Size":72871529,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-compile-linuxaarch64.tar.bz2","Checksum":"SHA-256:257fd45f8ef802bd5c18991934eaad8819115749c7f3604a31c7a2445a1cc9b2","Size":73079610,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linuxarm.tar.bz2","ArchiveFileName":"teensy-compile-linuxarm.tar.bz2","Checksum":"SHA-256:e63680d1acea958a4082ee70a1bf4501c62dd2e594e525db921154c90cd8b234","Size":67881541,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-macos.tar.bz2","ArchiveFileName":"teensy-compile-macos.tar.bz2","Checksum":"SHA-256:cfab7921641ce18db7abb6a4dad8e18beedc389a506ccb6ead5f95c3e6cb4f22","Size":80269350,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-windows.tar.bz2","ArchiveFileName":"teensy-compile-windows.tar.bz2","Checksum":"SHA-256:c078866371fd7202639810c50aeb1ee469838e399617d93d38c823be4c3368e3","Size":84734981,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linux32.tar.bz2","ArchiveFileName":"teensy-monitor-linux32.tar.bz2","Checksum":"SHA-256:bcfd250e2a05acaaa0f0beecf9df658248807040797059e5cdd32907a29012a7","Size":10350,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linux64.tar.bz2","ArchiveFileName":"teensy-monitor-linux64.tar.bz2","Checksum":"SHA-256:244942670758685a28a8579fd25905df26ba4177a79fa3432b625f2043dfc91d","Size":10237,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-monitor-linuxaarch64.tar.bz2","Checksum":"SHA-256:24b30869b5e21cbf48287f0b800166030031233bd59e9c7a13bfa9c13df3abd8","Size":10060,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linuxarm.tar.bz2","ArchiveFileName":"teensy-monitor-linuxarm.tar.bz2","Checksum":"SHA-256:ce6cfd4773503cc315a6a94f6d2058b47b457a107a1a8dac954b73d1250a0cab","Size":9839,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-macos.tar.bz2","ArchiveFileName":"teensy-monitor-macos.tar.bz2","Checksum":"SHA-256:52f4cfaa6cd9113ba0dc6d5a804858d7d0068e382fa14f389f8de1b9d497f4b2","Size":12158,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-windows.tar.bz2","ArchiveFileName":"teensy-monitor-windows.tar.bz2","Checksum":"SHA-256:4161ae82eb994d40e041f6e1951066f74f12de4f64a389b4674df6f1e2c191d5","Size":20268,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:30:45+01:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linux32.tar.bz2","ArchiveFileName":"teensy-tools-linux32.tar.bz2","Checksum":"SHA-256:3c3bd3d6e5022b8f86d67bfcaf2e4c56a6ed953a7af220d9c9b733548e853eb1","Size":5379500,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linux64.tar.bz2","ArchiveFileName":"teensy-tools-linux64.tar.bz2","Checksum":"SHA-256:693328d829f3a712c2f839cb3ac4e1f77d9e41695f456e7afd06becc905d7f6e","Size":5364784,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-tools-linuxaarch64.tar.bz2","Checksum":"SHA-256:de7e25c6755ca58484920b76bcbd4099964ab663b3bbb8ecdccc9a96d58645e4","Size":5542878,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linuxarm.tar.bz2","ArchiveFileName":"teensy-tools-linuxarm.tar.bz2","Checksum":"SHA-256:c6e7decdbaef40e2d6e4c141fd867df0fe2c816184155f22a555276b8c60a126","Size":5432119,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-macos.tar.bz2","ArchiveFileName":"teensy-tools-macos.tar.bz2","Checksum":"SHA-256:1a70234a10b7ea03f595d0b46117c68cab7e358e7a5bbb2e9dac232132eaeb62","Size":6185990,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-windows.tar.bz2","ArchiveFileName":"teensy-tools-windows.tar.bz2","Checksum":"SHA-256:e03ed1e2755faf1fa50fe5fdce4a8fe29fc521a4c92b6d976fc788adb1a79f74","Size":5560519,"CachePath":"packages"}}]}}
daemon INFO {"index":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-09-20T14:30:45+01:00","trusted":true}
daemon INFO {"error":"opening signature file: open c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_teensy_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_teensy_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_teensy_index.json.sig","time":"2022-09-20T14:30:45+01:00"}
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not installed
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\3.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_edge\\3.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
{"index":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
daemon INFO {"dir":"c:\\Users\\ctee\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-20T14:30:45+01:00"}
root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-09-20T14:30:53+01:00"}
{"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-09-20T14:30:53+01:00"}
daemon INFO {"level":"info","msg":"Updating index","time":"2022-09-20T14:30:53+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [library-index]
root INFO core-client-provider [platform-index]
daemon INFO {"level":"info","msg":"URL: https://www.pjrc.com/teensy/td_156/package_teensy_index.json","time":"2022-09-20T14:30:58+01:00"}
{"level":"info","msg":"Updating index","time":"2022-09-20T14:30:58+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"www.pjrc.com","Path":"/teensy/td_156/package_teensy_index.json","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Loading package Microsoft from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\Microsoft\\hardware","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-09-20T14:31:00+01:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"Microsoft:win10","Installed":"1.1.2","Latest":"1.1.2","Name":"Windows 10 IoT Core"},"time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:mbed_edge","Installed":"3.3.0","Latest":"3.3.0","Name":"Arduino Mbed OS Edge Boards"},"time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:mbed_rp2040","Installed":"3.3.0","Latest":"3.3.0","Name":"Arduino Mbed OS RP2040 Boards"},"time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:sam","Installed":"1.6.12","Latest":"1.6.12","Name":"Arduino ARM (32-bits) Boards"},"time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.3.0","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"4.8.3-2014q1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"7-2017q4","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"6.3.0-arduino17","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.6.1-arduino","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.9.1-arduino2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"0.10.0-arduino1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"0.11.0-arduino2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.0.5","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.3.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.3.2","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"0.9.1","systems":null}}
daemon INFO {"level":"info","msg":"Loading package esp8266 from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"esp8266:esp8266","Installed":"3.0.2","Latest":"3.0.2","Name":"ESP8266 Boards (3.0.2)"},"time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"3.0.4-gcc10.3-1757bed","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"3.7.2-post1","systems":null}}
daemon INFO {"level":"info","msg":"Loading package teensy from: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\installed.json.sig","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"teensy","time":"2022-09-20T14:31:00+01:00","tool":"teensy:teensy-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"teensy:avr","Installed":"1.56.1","Latest":"1.56.1","Name":"Teensy"},"time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\tools","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\tools","time":"2022-09-20T14:31:00+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linux32.tar.bz2","ArchiveFileName":"teensy-compile-linux32.tar.bz2","Checksum":"SHA-256:f28a8bbaa28600404ed997dea48862b9e97a243fc1d74090d0365cbdb1290e52","Size":71528248,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linux64.tar.bz2","ArchiveFileName":"teensy-compile-linux64.tar.bz2","Checksum":"SHA-256:f61ee7358909e4aebc3c0de5ada2c61208d0ea0f01384d7f73b4a8ad396bf383","Size":72871529,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-compile-linuxaarch64.tar.bz2","Checksum":"SHA-256:257fd45f8ef802bd5c18991934eaad8819115749c7f3604a31c7a2445a1cc9b2","Size":73079610,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linuxarm.tar.bz2","ArchiveFileName":"teensy-compile-linuxarm.tar.bz2","Checksum":"SHA-256:e63680d1acea958a4082ee70a1bf4501c62dd2e594e525db921154c90cd8b234","Size":67881541,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-macos.tar.bz2","ArchiveFileName":"teensy-compile-macos.tar.bz2","Checksum":"SHA-256:cfab7921641ce18db7abb6a4dad8e18beedc389a506ccb6ead5f95c3e6cb4f22","Size":80269350,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-windows.tar.bz2","ArchiveFileName":"teensy-compile-windows.tar.bz2","Checksum":"SHA-256:c078866371fd7202639810c50aeb1ee469838e399617d93d38c823be4c3368e3","Size":84734981,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linux32.tar.bz2","ArchiveFileName":"teensy-monitor-linux32.tar.bz2","Checksum":"SHA-256:bcfd250e2a05acaaa0f0beecf9df658248807040797059e5cdd32907a29012a7","Size":10350,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linux64.tar.bz2","ArchiveFileName":"teensy-monitor-linux64.tar.bz2","Checksum":"SHA-256:244942670758685a28a8579fd25905df26ba4177a79fa3432b625f2043dfc91d","Size":10237,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-monitor-linuxaarch64.tar.bz2","Checksum":"SHA-256:24b30869b5e21cbf48287f0b800166030031233bd59e9c7a13bfa9c13df3abd8","Size":10060,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-linuxarm.tar.bz2","ArchiveFileName":"teensy-monitor-linuxarm.tar.bz2","Checksum":"SHA-256:ce6cfd4773503cc315a6a94f6d2058b47b457a107a1a8dac954b73d1250a0cab","Size":9839,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-macos.tar.bz2","ArchiveFileName":"teensy-monitor-macos.tar.bz2","Checksum":"SHA-256:52f4cfaa6cd9113ba0dc6d5a804858d7d0068e382fa14f389f8de1b9d497f4b2","Size":12158,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-monitor-windows.tar.bz2","ArchiveFileName":"teensy-monitor-windows.tar.bz2","Checksum":"SHA-256:4161ae82eb994d40e041f6e1951066f74f12de4f64a389b4674df6f1e2c191d5","Size":20268,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-20T14:31:00+01:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linux32.tar.bz2","ArchiveFileName":"teensy-tools-linux32.tar.bz2","Checksum":"SHA-256:3c3bd3d6e5022b8f86d67bfcaf2e4c56a6ed953a7af220d9c9b733548e853eb1","Size":5379500,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linux64.tar.bz2","ArchiveFileName":"teensy-tools-linux64.tar.bz2","Checksum":"SHA-256:693328d829f3a712c2f839cb3ac4e1f77d9e41695f456e7afd06becc905d7f6e","Size":5364784,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-tools-linuxaarch64.tar.bz2","Checksum":"SHA-256:de7e25c6755ca58484920b76bcbd4099964ab663b3bbb8ecdccc9a96d58645e4","Size":5542878,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-linuxarm.tar.bz2","ArchiveFileName":"teensy-tools-linuxarm.tar.bz2","Checksum":"SHA-256:c6e7decdbaef40e2d6e4c141fd867df0fe2c816184155f22a555276b8c60a126","Size":5432119,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-macos.tar.bz2","ArchiveFileName":"teensy-tools-macos.tar.bz2","Checksum":"SHA-256:1a70234a10b7ea03f595d0b46117c68cab7e358e7a5bbb2e9dac232132eaeb62","Size":6185990,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-tools-windows.tar.bz2","ArchiveFileName":"teensy-tools-windows.tar.bz2","Checksum":"SHA-256:e03ed1e2755faf1fa50fe5fdce4a8fe29fc521a4c92b6d976fc788adb1a79f74","Size":5560519,"CachePath":"packages"}}]}}
daemon INFO {"index":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-09-20T14:31:00+01:00","trusted":true}
daemon INFO {"error":"opening signature file: open c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_teensy_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_teensy_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\package_teensy_index.json.sig","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\3.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_edge\\3.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.1\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
{"index":"c:\\Users\\ctee\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"C:\\Users\\ctee\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
daemon INFO {"dir":"c:\\Users\\ctee\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-20T14:31:00+01:00"}
root ERROR Uncaught Exception:
root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
 - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not installed
    at isIndexUpdateRequiredBeforeInit (C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:329:11)
    at CoreClientProvider.evaluateErrorStatus (C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:183:16)
    at ClientReadableStreamImpl.<anonymous> (C:\Users\ctee\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:168:36)
    at ClientReadableStreamImpl.emit (node:events:394:28)
    at endReadableNT (node:internal/streams/readable:1331:12)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
I have noticed that there are 8 instances of 'Arduino IDE' showing in the Taskmaster window, is that correct..
Chris.
The problem is indicated by this error:
It seems that your "Teensy" boards platform installation is incomplete for some reason. It might have been caused by the Boards Manager installation process being interrupted (e.g., power outage, computer crash).
In order to recover, it will be necessary to manually remove the damaged Teensy boards platform installation and then reinstall the platform. I'll provide instructions:
  1. Delete the folder at this path:
    C:\Users\ctee\AppData\Local\Arduino15\packages\teensy
    :warning: Please be very careful when deleting things from your computer. When in doubt, back up!
    If looking for it with your file browser or command line, note that the C:\Users\ctee\AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  2. Close the Arduino IDE if it is running.
  3. Start the Arduino IDE.
    It should now start successfully.
  4. Select Tools > Board > Boards Manager from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  5. Scroll down through the list of boards platforms until you see"Teensy by Paul Stoffregen". Hover the mouse pointer over it.
  6. You will now see an INSTALL button appear at the bottom of the "Teensy by Paul Stoffregen" platform entry. Click the INSTALL button.
  7. Wait for the installation to finish.
The IDE should now be in a fully functional state, including support for your Teensy.
Please let me know if you have any questions or problems while following those instructions.
Hello ptillisch, thank you for the answer. I followed the steps you suggested and it worked straight the way. The problem appears to be with the Teensy install upsetting my 'BitDefender' security software, mainly the 'Advanced Threat' part which see's that installation as a 'malicous threat' and removes part of the teensy install. This doesn't occur when installing Teensyduino into1.8.19, but at least I now have it running which I am happy about.
Keep up the good work and thanks again.
Chris...
