Hi!
I've just installed Arduino IDE 2.3.2 on a clean install of Windows 11 Pro (23H2), and I'm unable to launch Arduino successfully, I get stuck at the loading logo and it just hangs.
Launched using PowerShell, and I get the following:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS C:\Users\Jaz> CD "C:\Program Files\Arduino IDE"
PS C:\Program Files\Arduino IDE> ls
Directory: C:\Program Files\Arduino IDE
Mode LastWriteTime Length Name
d----- 05/04/2024 11:04 locales
d----- 05/04/2024 11:04 resources
-a---- 20/02/2024 10:06 172661440 Arduino IDE.exe
-a---- 20/02/2024 10:06 135642 chrome_100_percent.pak
-a---- 20/02/2024 10:06 195396 chrome_200_percent.pak
-a---- 20/02/2024 10:06 4916712 d3dcompiler_47.dll
-a---- 20/02/2024 10:06 2887680 ffmpeg.dll
-a---- 20/02/2024 10:06 10717392 icudtl.dat
-a---- 20/02/2024 10:06 488960 libEGL.dll
-a---- 20/02/2024 10:06 7613952 libGLESv2.dll
-a---- 20/02/2024 10:06 1096 LICENSE.electron.txt
-a---- 20/02/2024 10:06 9227221 LICENSES.chromium.html
-a---- 20/02/2024 10:06 5483548 resources.pak
-a---- 20/02/2024 10:06 267462 snapshot_blob.bin
-a---- 20/02/2024 10:06 229928 Uninstall Arduino IDE.exe
-a---- 20/02/2024 09:49 47519 uninstallerIcon.ico
-a---- 20/02/2024 10:06 626313 v8_context_snapshot.bin
-a---- 20/02/2024 10:06 5180416 vk_swiftshader.dll
-a---- 20/02/2024 10:06 106 vk_swiftshader_icd.json
-a---- 20/02/2024 10:06 953856 vulkan-1.dll
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 21600
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Jaz/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-04-05T12:27:00.770Z root INFO Backend Object.initialize: 3.9 ms [Finished 0.463 s after backend start]
2024-04-05T12:27:00.771Z root INFO Backend Object.configure: 3.2 ms [Finished 0.463 s after backend start]
2024-04-05T12:27:00.771Z root INFO Backend s.onStart: 1.6 ms [Finished 0.463 s after backend start]
2024-04-05T12:27:00.772Z root INFO Backend s.configure: 0.4 ms [Finished 0.483 s after backend start]
2024-04-05T12:27:00.773Z root INFO Backend d.onStart: 0.3 ms [Finished 0.483 s after backend start]
2024-04-05T12:27:00.774Z root INFO Backend d.configure: 0.1 ms [Finished 0.483 s after backend start]
2024-04-05T12:27:00.774Z root INFO Backend d.initialize: 20.8 ms [Finished 0.484 s after backend start]
2024-04-05T12:27:00.774Z root INFO Backend c.onStart: 0.3 ms [Finished 0.484 s after backend start]
2024-04-05T12:27:00.775Z root INFO Backend a.configure: 1.3 ms [Finished 0.485 s after backend start]
2024-04-05T12:27:00.776Z config INFO >>> Initializing CLI configuration...
2024-04-05T12:27:00.776Z root INFO Backend c.initialize: 0.7 ms [Finished 0.485 s after backend start]
2024-04-05T12:27:00.776Z root INFO Backend R.onStart: 0.9 ms [Finished 0.486 s after backend start]
2024-04-05T12:27:00.777Z config INFO Loading CLI configuration from c:\Users\Jaz\.arduinoIDE\arduino-cli.yaml...
2024-04-05T12:27:00.778Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-05T12:27:00.778Z root INFO Backend a.initialize: 0.4 ms [Finished 0.487 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend w.onStart: 1.0 ms [Finished 0.488 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend r.configure: 1.6 ms [Finished 0.488 s after backend start]
2024-04-05T12:27:00.778Z discovery-log INFO start
2024-04-05T12:27:00.778Z discovery-log INFO start new deferred
2024-04-05T12:27:00.778Z root INFO Backend d.initialize: 0.4 ms [Finished 0.488 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend y.onStart: 1.9 ms [Finished 0.490 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend r.configure: 1.6 ms [Finished 0.490 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend a.onStart: 0.4 ms [Finished 0.491 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend h.configure: 0.4 ms [Finished 0.491 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend s.configure: 0.1 ms [Finished 0.491 s after backend start]
2024-04-05T12:27:00.778Z root INFO Backend l.configure: 0.1 ms [Finished 0.491 s after backend start]
2024-04-05T12:27:00.781Z root INFO Theia app listening on http://127.0.0.1:65107.
2024-04-05T12:27:00.781Z root INFO Finished starting backend application: 2.9 ms [Finished 0.494 s after backend start]
2024-04-05T12:27:00.786Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Jaz/.arduinoIDE/plugins does not exist.
2024-04-05T12:27:00.786Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Jaz/.arduinoIDE/extensions does not exist.
2024-04-05T12:27:00.786Z root WARN The local plugin referenced by local-dir:C:\Users\Jaz\.arduinoIDE\plugins does not exist.
2024-04-05T12:27:00.795Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Jaz\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Jaz\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-04-05T12:27:00.795Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-04-05T12:27:00.795Z config INFO Loaded the CLI configuration.
2024-04-05T12:27:00.798Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Jaz/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Jaz/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-04-05T12:27:00.798Z config INFO Validating the CLI configuration...
2024-04-05T12:27:00.798Z config INFO The CLI config is valid.
2024-04-05T12:27:00.798Z config INFO <<< Initialized the CLI configuration.
2024-04-05T12:27:00.814Z root INFO Resolve plugins list: 36.8 ms [Finished 0.527 s after backend start]
2024-04-05T12:27:00.890Z daemon INFO time="2024-04-05T13:27:00+01:00" level=info msg="Using config file: c:\\Users\\Jaz\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-05T13:27:00+01:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-04-05T13:27:00+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:65108
{"IP":"127.0.0.1","Port":"65108"}
2024-04-05T12:27:00.890Z daemon INFO Daemon is running.
2024-04-05T12:27:00.916Z daemon INFO time="2024-04-05T13:27:00+01:00" level=info msg="Updating libraries index"
time="2024-04-05T13:27:00+01:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-04-05T12:27:01.511Z root INFO Deploy plugins list: 36.8 ms [Finished 1.224 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-04-05T12:27:02.409Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 121.7 ms [Finished 1.538 s after frontend start]
2024-04-05T12:27:02.409Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-04-05T12:27:04.847Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-04-05T12:27:04.857Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Checking signature" index="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-04-05T12:27:04.858Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loading hardware from: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages"
2024-04-05T12:27:04.859Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loading package builtin from: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-04-05T12:27:04.859Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-04-05T13:27:04+01:00" level=info msg="Loading tools from dir: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-04-05T12:27:04.860Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-04-05T12:27:04.860Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-04-05T12:27:04.860Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-04-05T12:27:04.861Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-04-05T12:27:04.861Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-04-05T12:27:04.861Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Loading libraries index file" index="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\library_index.json"
2024-04-05T12:27:04.861Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-04-05T12:27:04.862Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Jaz\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-04-05T12:27:04.862Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Jaz\\Documents\\Arduino\\libraries" location=user
2024-04-05T12:27:04.866Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\Jaz\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-04-05T12:27:04.866Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Updating libraries index"
2024-04-05T12:27:04.868Z daemon INFO time="2024-04-05T13:27:04+01:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-04-05T12:27:04.869Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-04-05T12:27:08.564Z daemon INFO time="2024-04-05T13:27:08+01:00" level=info msg="Updating libraries index"
2024-04-05T12:27:08.566Z daemon INFO time="2024-04-05T13:27:08+01:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-04-05T12:27:12.050Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-04-05T12:27:12.060Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Checking signature" index="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-04-05T12:27:12.061Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loading hardware from: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages"
2024-04-05T12:27:12.061Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loading package builtin from: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-04-05T12:27:12.061Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-04-05T13:27:12+01:00" level=info msg="Loading tools from dir: C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-04-05T12:27:12.062Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-04-05T12:27:12.062Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-04-05T12:27:12.062Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-04-05T12:27:12.062Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-04-05T12:27:12.062Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-04-05T12:27:12.063Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Loading libraries index file" index="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\library_index.json"
2024-04-05T12:27:12.063Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Jaz\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-04-05T12:27:12.063Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Jaz\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-04-05T12:27:12.063Z daemon INFO time="2024-04-05T13:27:12+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Jaz\\Documents\\Arduino\\libraries" location=user
2024-04-05T12:27:12.065Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-04-05T12:27:12.065Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
2024-04-05T12:49:09.778Z root ERROR Uncaught Exception: Error: transport close
2024-04-05T12:49:09.779Z root ERROR Error: transport close
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1095642
at Map.forEach (<anonymous>)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1095621
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1062813
at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1062903)
at s.fire (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1064706)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1090506
at Object.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1090476)
at e.dispose (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1055872)
After trying the solutions posted under similar issues (IDE Hangs On Startup, Can't Open Arduino IDE 2.3.2, Arduino IDE 3.2.3 Windows 10 Won't Launch), I tried the solution which was posted under IDE 2.2.01 Hangs On Startup, which was to launch Arduino IDE from PowerShell using:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE" --hostname ::
This has got it up and running, so that's a start.
A suggested patch is to modify the Arduino IDE shortcut with the " --hostname ::" flag.
More detail in the original post, screenshot below:
Hopefully this can help others who are stuck with the same issue, and possibly contribute to a fix for the bug its self.
TheTechnician
