IDE hangs on startup: "Error verifying signature: openpgp: signature expired"
PS C:\Users\ADMIN\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\ADMIN\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\ADMIN\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 21056
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/ADMIN/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-06-26T22:21:32.766Z root INFO Backend Object.initialize: 4.2 ms [Finished 0.533 s after backend start]
2024-06-26T22:21:32.766Z root INFO Backend Object.configure: 3.5 ms [Finished 0.533 s after backend start]
2024-06-26T22:21:32.766Z root INFO Backend s.onStart: 1.8 ms [Finished 0.533 s after backend start]
2024-06-26T22:21:32.767Z root INFO Backend s.configure: 0.3 ms [Finished 0.556 s after backend start]
2024-06-26T22:21:32.767Z root INFO Backend d.onStart: 0.2 ms [Finished 0.556 s after backend start]
2024-06-26T22:21:32.768Z root INFO Backend d.configure: 0.1 ms [Finished 0.556 s after backend start]
2024-06-26T22:21:32.769Z root INFO Backend d.initialize: 22.7 ms [Finished 0.556 s after backend start]
2024-06-26T22:21:32.770Z root INFO Backend c.onStart: 0.2 ms [Finished 0.556 s after backend start]
2024-06-26T22:21:32.770Z root INFO Backend a.configure: 1.1 ms [Finished 0.557 s after backend start]
2024-06-26T22:21:32.771Z config INFO >>> Initializing CLI configuration...
2024-06-26T22:21:32.772Z root INFO Backend c.initialize: 0.5 ms [Finished 0.558 s after backend start]
2024-06-26T22:21:32.772Z root INFO Backend R.onStart: 0.7 ms [Finished 0.558 s after backend start]
2024-06-26T22:21:32.772Z config INFO Loading CLI configuration from c:\Users\ADMIN\.arduinoIDE\arduino-cli.yaml...
2024-06-26T22:21:32.773Z daemon INFO Starting daemon from C:\Users\ADMIN\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-06-26T22:21:32.773Z root INFO Backend a.initialize: 0.6 ms [Finished 0.559 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend w.onStart: 1.4 ms [Finished 0.560 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend r.configure: 2.2 ms [Finished 0.560 s after backend start]
2024-06-26T22:21:32.773Z discovery-log INFO start
2024-06-26T22:21:32.773Z discovery-log INFO start new deferred
2024-06-26T22:21:32.773Z root INFO Backend d.initialize: 0.5 ms [Finished 0.561 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend y.onStart: 1.8 ms [Finished 0.562 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend r.configure: 1.4 ms [Finished 0.562 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend a.onStart: 0.4 ms [Finished 0.563 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend h.configure: 0.3 ms [Finished 0.563 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend s.configure: 0.1 ms [Finished 0.564 s after backend start]
2024-06-26T22:21:32.773Z root INFO Backend l.configure: 0.1 ms [Finished 0.564 s after backend start]
2024-06-26T22:21:32.775Z root INFO Theia app listening on http://127.0.0.1:55809.
2024-06-26T22:21:32.775Z root INFO Finished starting backend application: 2.4 ms [Finished 0.566 s after backend start]
2024-06-26T22:21:32.783Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ADMIN/.arduinoIDE/plugins does not exist.
2024-06-26T22:21:32.783Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ADMIN/.arduinoIDE/extensions does not exist.
2024-06-26T22:21:32.783Z root WARN The local plugin referenced by local-dir:C:\Users\ADMIN\.arduinoIDE\plugins does not exist.
2024-06-26T22:21:32.796Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\ADMIN\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\ADMIN\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-06-26T22:21:32.796Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-06-26T22:21:32.796Z config INFO Loaded the CLI configuration.
2024-06-26T22:21:32.802Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/ADMIN/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/ADMIN/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-06-26T22:21:32.802Z config INFO Validating the CLI configuration...
2024-06-26T22:21:32.803Z config INFO The CLI config is valid.
2024-06-26T22:21:32.803Z config INFO <<< Initialized the CLI configuration.
2024-06-26T22:21:32.824Z root INFO Resolve plugins list: 52.1 ms [Finished 0.615 s after backend start]
2024-06-26T22:21:32.842Z daemon INFO time="2024-06-27T03:51:32+05:30" level=info msg="Using config file: c:\\Users\\ADMIN\\.arduinoIDE\\arduino-cli.yaml"
time="2024-06-27T03:51:32+05:30" level=info msg="arduino-cli.exe version 0.35.3"
2024-06-26T22:21:32.842Z daemon INFO time="2024-06-27T03:51:32+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-06-26T22:21:32.851Z daemon INFO Daemon is now listening on 127.0.0.1:55810
{"IP":"127.0.0.1","Port":"55810"}
2024-06-26T22:21:32.851Z daemon INFO Daemon is running.
2024-06-26T22:21:32.876Z daemon INFO time="2024-06-27T03:51:32+05:30" level=info msg="Updating libraries index"
2024-06-26T22:21:32.886Z daemon INFO time="2024-06-27T03:51:32+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-06-26T22:21:33.793Z root INFO Deploy plugins list: 52.1 ms [Finished 1.584 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-06-26T22:21:34.682Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 158.2 ms [Finished 1.789 s after frontend start]
2024-06-26T22:21:34.682Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-06-26T22:21:36.431Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-06-26T22:21:36.442Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Checking signature" index="C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-06-26T22:21:36.444Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loading hardware from: C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\packages"
2024-06-26T22:21:36.445Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loading package builtin from: C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-06-26T22:21:36.445Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-06-27T03:51:36+05:30" level=info msg="Loading tools from dir: C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-06-26T22:21:36.446Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-06-26T22:21:36.446Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-06-26T22:21:36.447Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-06-26T22:21:36.447Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-06-26T22:21:36.447Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-06-26T22:21:36.447Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\library_index.json"
2024-06-26T22:21:36.448Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\ADMIN\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-06-26T22:21:36.448Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\ADMIN\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-06-26T22:21:36.448Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\ADMIN\\Documents\\Arduino\\libraries" location=user
2024-06-26T22:21:36.494Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\ADMIN\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-06-26T22:21:36.495Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Updating libraries index"
2024-06-26T22:21:36.496Z daemon INFO time="2024-06-27T03:51:36+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-06-26T22:21:36.498Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-06-26T22:21:39.507Z daemon INFO time="2024-06-27T03:51:39+05:30" level=info msg="Updating libraries index"
2024-06-26T22:21:39.508Z daemon INFO time="2024-06-27T03:51:39+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-06-26T22:21:53.998Z root ERROR Detected an error response during the gR
this my code. my arduino is not working is getting stuck at the loading page, i have windows 11. please help
Hi @nir7398687443.
This error occurs when your system time is incorrect. You should be able to fix it by syncing the system time. I'll provide instructions you can follow to do that:
  1. Right click the Windows Start icon () on the taskbar.
    A context menu will open.
  2. Select "Settings" from the context menu.
    Windows "Settings" will open.
  3. Select "Time & language" from the navigation panel on the left side of the window.
  4. Select "Date & time" from the list on the right side of the Settings window.
    The Date & time settings section will expand.
  5. Click the "Sync now" button that is under the "Additional settings" section of the page.
  6. Wait for the syncing process to finish.
  7. Close any Arduino IDE windows that are open.
  8. Start Arduino IDE again.
Hopefully this time Arduino IDE will start up fully and work as expected.
thanks man appreciate it
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
