IDE hangs on startup: "Error verifying signature: openpgp: signature expired"
PS C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 15632
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Lenovo/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-07-06T18:26:05.597Z root INFO Backend Object.initialize: 6.2 ms [Finished 0.853 s after backend start]
2024-07-06T18:26:05.598Z root INFO Backend Object.configure: 5.0 ms [Finished 0.853 s after backend start]
2024-07-06T18:26:05.598Z root INFO Backend s.onStart: 2.7 ms [Finished 0.853 s after backend start]
2024-07-06T18:26:05.599Z root INFO Backend s.configure: 0.5 ms [Finished 0.889 s after backend start]
2024-07-06T18:26:05.600Z root INFO Backend d.onStart: 0.3 ms [Finished 0.889 s after backend start]
2024-07-06T18:26:05.601Z root INFO Backend d.configure: 0.2 ms [Finished 0.889 s after backend start]
2024-07-06T18:26:05.602Z root INFO Backend d.initialize: 35.5 ms [Finished 0.889 s after backend start]
2024-07-06T18:26:05.602Z root INFO Backend c.onStart: 0.4 ms [Finished 0.889 s after backend start]
2024-07-06T18:26:05.603Z root INFO Backend a.configure: 1.7 ms [Finished 0.891 s after backend start]
2024-07-06T18:26:05.606Z config INFO >>> Initializing CLI configuration...
2024-07-06T18:26:05.606Z root INFO Backend c.initialize: 0.8 ms [Finished 0.891 s after backend start]
2024-07-06T18:26:05.606Z root INFO Backend R.onStart: 1.0 ms [Finished 0.892 s after backend start]
2024-07-06T18:26:05.607Z config INFO Loading CLI configuration from c:\Users\Lenovo\.arduinoIDE\arduino-cli.yaml...
2024-07-06T18:26:05.608Z daemon INFO Starting daemon from C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-07-06T18:26:05.608Z root INFO Backend a.initialize: 0.6 ms [Finished 0.893 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend w.onStart: 1.5 ms [Finished 0.894 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend r.configure: 2.4 ms [Finished 0.895 s after backend start]
2024-07-06T18:26:05.608Z discovery-log INFO start
2024-07-06T18:26:05.608Z discovery-log INFO start new deferred
2024-07-06T18:26:05.608Z root INFO Backend d.initialize: 0.8 ms [Finished 0.895 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend y.onStart: 3.1 ms [Finished 0.898 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend r.configure: 2.5 ms [Finished 0.898 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend a.onStart: 0.7 ms [Finished 0.900 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend h.configure: 0.6 ms [Finished 0.900 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend s.configure: 0.2 ms [Finished 0.900 s after backend start]
2024-07-06T18:26:05.608Z root INFO Backend l.configure: 0.1 ms [Finished 0.900 s after backend start]
2024-07-06T18:26:05.612Z root INFO Theia app listening on http://127.0.0.1:50357.
2024-07-06T18:26:05.613Z root INFO Finished starting backend application: 4.4 ms [Finished 0.905 s after backend start]
2024-07-06T18:26:05.621Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Lenovo/.arduinoIDE/plugins does not exist.
2024-07-06T18:26:05.621Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Lenovo/.arduinoIDE/extensions does not exist.
2024-07-06T18:26:05.621Z root WARN The local plugin referenced by local-dir:C:\Users\Lenovo\.arduinoIDE\plugins does not exist.
2024-07-06T18:26:05.642Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Lenovo\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Lenovo\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-07-06T18:26:05.642Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-07-06T18:26:05.642Z config INFO Loaded the CLI configuration.
2024-07-06T18:26:05.713Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Lenovo/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Lenovo/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-07-06T18:26:05.713Z config INFO Validating the CLI configuration...
2024-07-06T18:26:05.713Z config INFO The CLI config is valid.
2024-07-06T18:26:05.713Z config INFO <<< Initialized the CLI configuration.
2024-07-06T18:26:05.748Z root INFO Resolve plugins list: 141.9 ms [Finished 1.040 s after backend start]
2024-07-06T18:26:05.810Z daemon INFO time="2024-07-07T02:26:05+08:00" level=info msg="Using config file: c:\\Users\\Lenovo\\.arduinoIDE\\arduino-cli.yaml"
time="2024-07-07T02:26:05+08:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-07-06T18:26:05.810Z daemon INFO time="2024-07-07T02:26:05+08:00" level=info msg="Executing `arduino-cli daemon`"
2024-07-06T18:26:05.821Z daemon INFO Daemon is now listening on 127.0.0.1:50358
{"IP":"127.0.0.1","Port":"50358"}
2024-07-06T18:26:05.821Z daemon INFO Daemon is running.
2024-07-06T18:26:05.874Z daemon INFO time="2024-07-07T02:26:05+08:00" level=info msg="Updating libraries index"
time="2024-07-07T02:26:05+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-07-06T18:26:09.164Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 456.6 ms [Finished 3.316 s after frontend start]
2024-07-06T18:26:09.176Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-07-06T18:26:09.452Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 113.8 ms [Finished 3.647 s after frontend start]
2024-07-06T18:26:10.394Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-07-06T18:26:10.422Z daemon INFO time="2024-07-07T02:26:10+08:00" level=info msg="Checking signature" index="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-07-07T02:26:10+08:00" level=info msg="Loading hardware from: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages"
time="2024-07-07T02:26:10+08:00" level=info msg="Loading package builtin from: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-07-07T02:26:10+08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-07-07T02:26:10+08:00" level=info msg="Loading tools from dir: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-07-07T02:26:10+08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-07-07T02:26:10+08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-07-07T02:26:10+08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-07-07T02:26:10+08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-07-07T02:26:10+08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-07-07T02:26:10+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-07-07T02:26:10+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-07-07T02:26:10+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Lenovo\\Documents\\Arduino\\libraries" location=user
2024-07-06T18:26:10.423Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Lenovo\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-07-06T18:26:10.459Z root INFO Deploy plugins list: 141.9 ms [Finished 5.751 s after backend start]
2024-07-06T18:26:10.532Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\Lenovo\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-07-06T18:26:10.533Z daemon INFO time="2024-07-07T02:26:10+08:00" level=info msg="Updating libraries index"
2024-07-06T18:26:10.535Z daemon INFO time="2024-07-07T02:26:10+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-07-06T18:26:10.537Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-07-06T18:26:14.031Z daemon INFO time="2024-07-07T02:26:14+08:00" level=info msg="Updating libraries index"
2024-07-06T18:26:14.033Z daemon INFO time="2024-07-07T02:26:14+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-07-06T18:26:18.275Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-07-06T18:26:18.291Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Checking signature" index="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-07-06T18:26:18.293Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loading hardware from: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages"
2024-07-06T18:26:18.294Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loading package builtin from: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-07-06T18:26:18.294Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-07-07T02:26:18+08:00" level=info msg="Loading tools from dir: C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-07-06T18:26:18.296Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-07-06T18:26:18.296Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-07-06T18:26:18.296Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-07-06T18:26:18.296Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-07-06T18:26:18.297Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-07-06T18:26:18.297Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\library_index.json"
2024-07-06T18:26:18.297Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-07-06T18:26:18.297Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Lenovo\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-07-06T18:26:18.298Z daemon INFO time="2024-07-07T02:26:18+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Lenovo\\Documents\\Arduino\\libraries" location=user
2024-07-06T18:26:18.372Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-07-06T18:26:18.372Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async a.<anonymous> (C:\Users\Lenovo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
Hi @xres77.
This error occurs when your system time is incorrect. You should be able to fix it by syncing the system time. I'll provide instructions you can follow to do that:
  1. Right click the Windows Start icon () on the taskbar.
    A context menu will open.
  2. Select "Settings" from the context menu.
    Windows "Settings" will open.
  3. Select "Time & language" from the navigation panel on the left side of the window.
  4. Select "Date & time" from the list on the right side of the Settings window.
    The Date & time settings section will expand.
  5. Click the "Sync now" button that is under the "Additional settings" section of the page.
  6. Wait for the syncing process to finish.
  7. Close any Arduino IDE windows that are open.
  8. Start Arduino IDE again.
Hopefully this time Arduino IDE will start up fully and work as expected.
it's work thank you
You are welcome. I'm glad it is working now.
Regards,
Per
A post was split to a new topic: Servo library fails to compile: "This library only supports boards with an AVR, SAM, SAMD, NRF52, STM32F4, Renesas or XMC processor."
