IDE hangs on startup: "Failed to initialize the CLI configuration"
Arduino IDE 2.1.0
Starting backend process. PID: 18576
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///e%3A/Users/astrnt/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-09-02T01:37:52.240Z root INFO Backend Object.initialize: 4.4 ms [Finished 1.978 s after backend start]
2023-09-02T01:37:52.240Z root INFO Backend Object.configure: 3.6 ms [Finished 1.979 s after backend start]
2023-09-02T01:37:52.240Z root INFO Backend MessagingContribution.onStart: 1.7 ms [Finished 1.979 s after backend start]
2023-09-02T01:37:52.241Z root INFO Backend OSBackendApplicationContribution.configure: 0.4 ms [Finished 2.027 s after backend start]
2023-09-02T01:37:52.242Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 2.027 s after backend start]
2023-09-02T01:37:52.243Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 2.027 s after backend start]
2023-09-02T01:37:52.244Z root INFO Backend PluginLocalizationBackendContribution.initialize: 48.4 ms [Finished 2.027 s after backend start]
2023-09-02T01:37:52.244Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.3 ms [Finished 2.027 s after backend start]
2023-09-02T01:37:52.245Z root INFO Backend ElectronTokenBackendContribution.configure: 1.0 ms [Finished 2.029 s after backend start]
2023-09-02T01:37:52.246Z config INFO >>> Initializing CLI configuration...
2023-09-02T01:37:52.246Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 2.029 s after backend start]
2023-09-02T01:37:52.246Z root INFO Backend ConfigServiceImpl.onStart: 1.0 ms [Finished 2.030 s after backend start]
2023-09-02T01:37:52.248Z config INFO Loading CLI configuration from e:\Users\astrnt\.arduinoIDE\arduino-cli.yaml...
2023-09-02T01:37:52.248Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 2.031 s after backend start]
2023-09-02T01:37:52.248Z root INFO Backend ArduinoDaemonImpl.onStart: 1.2 ms [Finished 2.032 s after backend start]
2023-09-02T01:37:52.249Z root INFO Backend NodeFileUploadService.configure: 2.1 ms [Finished 2.032 s after backend start]
2023-09-02T01:37:52.249Z daemon INFO Starting daemon from E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-09-02T01:37:52.249Z discovery-log INFO start
2023-09-02T01:37:52.249Z discovery-log INFO start new deferred
2023-09-02T01:37:52.249Z root INFO Backend HostedPluginLocalizationService.initialize: 0.5 ms [Finished 2.033 s after backend start]
2023-09-02T01:37:52.249Z root INFO Backend BoardDiscovery.onStart: 1.2 ms [Finished 2.033 s after backend start]
2023-09-02T01:37:52.250Z root INFO Backend FileDownloadEndpoint.configure: 1.1 ms [Finished 2.034 s after backend start]
2023-09-02T01:37:52.250Z root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 2.036 s after backend start]
2023-09-02T01:37:52.250Z root INFO Backend PluginApiContribution.configure: 0.5 ms [Finished 2.036 s after backend start]
2023-09-02T01:37:52.251Z root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 2.037 s after backend start]
2023-09-02T01:37:52.251Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.037 s after backend start]
2023-09-02T01:37:52.251Z root INFO Backend PlotterBackendContribution.configure: 1.0 ms [Finished 2.039 s after backend start]
2023-09-02T01:37:52.254Z root INFO Theia app listening on http://localhost:10624.
2023-09-02T01:37:52.255Z root INFO Finished starting backend application: 5.2 ms [Finished 2.042 s after backend start]
2023-09-02T01:37:52.256Z root WARN The local plugin referenced by local-dir:/e%3A/Users/astrnt/.arduinoIDE/plugins does not exist.
2023-09-02T01:37:52.256Z root WARN The local plugin referenced by local-dir:/e%3A/Users/astrnt/.arduinoIDE/extensions does not exist.
2023-09-02T01:37:52.256Z root WARN The local plugin referenced by local-dir:E:\Users\astrnt\.arduinoIDE\plugins does not exist.
2023-09-02T01:37:52.280Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-09-02T01:37:52.280Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-09-02T01:37:52.280Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-09-02T01:37:52.281Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-09-02T01:37:52.281Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-09-02T01:37:52.281Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-09-02T01:37:52.281Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-09-02T01:37:52.281Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-09-02T01:37:52.282Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-09-02T01:37:52.282Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-09-02T01:37:52.282Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-09-02T01:37:52.282Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-09-02T01:37:52.282Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-09-02T01:37:52.283Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-09-02T01:37:52.283Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-09-02T01:37:52.283Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-09-02T01:37:52.283Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-09-02T01:37:52.283Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-09-02T01:37:52.284Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-09-02T01:37:52.284Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-09-02T01:37:52.284Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-09-02T01:37:52.284Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-09-02T01:37:52.285Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-09-02T01:37:52.285Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-09-02T01:37:52.285Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-09-02T01:37:52.285Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-09-02T01:37:52.285Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-09-02T01:37:52.287Z config INFO Loaded CLI configuration: {}
2023-09-02T01:37:52.287Z config ERROR Failed to initialize the CLI configuration.
2023-09-02T01:37:52.321Z root INFO Resolve plugins list: 73.5 ms [Finished 2.108 s after backend start]
2023-09-02T01:37:52.330Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\cortex-debug\extension\dist\extension.js": 9.0 ms [Finished 2.118 s after backend start]
2023-09-02T01:37:52.334Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 3.9 ms [Finished 2.122 s after backend start]
2023-09-02T01:37:52.351Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-cpp\extension": 16.0 ms [Finished 2.138 s after backend start]
2023-09-02T01:37:52.370Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json\extension": 17.3 ms [Finished 2.155 s after backend start]
2023-09-02T01:37:52.372Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 4.0 ms [Finished 2.159 s after backend start]
2023-09-02T01:37:52.481Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-bg\extension": 109.2 ms [Finished 2.269 s after backend start]
2023-09-02T01:37:52.545Z daemon INFO INFO[0000] Using config file: e:\Users\astrnt\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.2
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:10626
{"IP":"127.0.0.1","Port":"10626"}
2023-09-02T01:37:52.546Z daemon INFO Daemon is running.
2023-09-02T01:37:52.697Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-cs\extension": 215.4 ms [Finished 2.484 s after backend start]
2023-09-02T01:37:52.705Z daemon INFO INFO[0000] Loading hardware from: E:\Users\astrnt\AppData\Local\Arduino15\packages
2023-09-02T01:37:52.859Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-de\extension": 162.5 ms [Finished 2.647 s after backend start]
2023-09-02T01:37:52.860Z daemon INFO INFO[0000] Loading package builtin from: E:\Users\astrnt\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: E:\Users\astrnt\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: E:\Users\astrnt\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:dfu-discovery@0.1.2"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
INFO[0000] Checking signature                            index="E:\\Users\\astrnt\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="E:\\Users\\astrnt\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Loading libraries index file                  index="E:\\Users\\astrnt\\AppData\\Local\\Arduino15\\library_index.json"
2023-09-02T01:37:52.967Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-es\extension": 107.4 ms [Finished 2.754 s after backend start]
2023-09-02T01:37:53.042Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-fr\extension": 75.1 ms [Finished 2.829 s after backend start]
2023-09-02T01:37:53.043Z daemon INFO INFO[0000] Adding libraries dir                          dir="E:\\Users\\astrnt\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir                          dir="E:\\Users\\astrnt\\Documents\\Arduino\\libraries" location=user
2023-09-02T01:37:53.122Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-hu\extension": 80.3 ms [Finished 2.910 s after backend start]
2023-09-02T01:37:53.237Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-it\extension": 114.7 ms [Finished 3.024 s after backend start]
2023-09-02T01:37:53.326Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ja\extension": 88.7 ms [Finished 3.113 s after backend start]
2023-09-02T01:37:53.413Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ko\extension": 86.6 ms [Finished 3.200 s after backend start]
2023-09-02T01:37:53.449Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-nl\extension": 36.7 ms [Finished 3.237 s after backend start]
2023-09-02T01:37:53.543Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-pl\extension": 93.5 ms [Finished 3.330 s after backend start]
2023-09-02T01:37:53.623Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-pt-BR\extension": 79.8 ms [Finished 3.410 s after backend start]
2023-09-02T01:37:53.702Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ru\extension": 79.6 ms [Finished 3.490 s after backend start]
2023-09-02T01:37:53.767Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-tr\extension": 64.2 ms [Finished 3.554 s after backend start]
2023-09-02T01:37:53.813Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-uk\extension": 46.0 ms [Finished 3.600 s after backend start]
2023-09-02T01:37:53.871Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "E:\Users\astrnt\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-zh-hans\extension": 58.0 ms [Finished 3.658 s after backend start]
2023-09-02T01:37:53.893Z root INFO Deploy plugins list: 73.5 ms [Finished 3.659 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-09-02T01:37:55.199Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 254.1 ms [Finished 2.832 s after frontend start]
Hi @astrnt_he. I see the cause of the problem here in the logs:
Arduino IDE stores some configuration information in various files on your computer. The contents of one of these files was somehow deleted. None of the information stored in the file is irreplaceable, so the loss of the information is not a problem, but the fact that the file exists, but is missing essential configuration information trips Arduino IDE up.
The file is automatically generated with all the essential data contents if Arduino doesn't find an existing file when it attempts to load it on startup, so the simple fix for this problem is to delete the file. I'll provide instructions you can follow to do that:
  1. Close all Arduino IDE windows if it is running.
  2. Delete the file at the following path:
    E:\Users\astrnt\.arduinoIDE\arduino-cli.yaml
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
Now start Arduino IDE again. Hopefully this time it will start up completely and be in a full functional state.
Please let me know if you have any questions or problems while following those instructions.
