Hey, I downloaded Arduino for Mac Silicon version (since I use Apple M2 Pro chip), but for some reason, it doesn't operate properly. When I open the application, it opens a blank white tab, and it just doesn't do anything after that (shown in the image below).
I checked the "Arduino15" folder, and it only has an 'inventory.yaml' folder, not like a bulk amount of folders normally. When I initiated the terminal folder, it showed this following message:
Last login: Wed Apr 23 16:57:32 on ttys000
/Applications/Arduino\ IDE.app/Contents/MacOS/Arduino\ IDE ; exit;
hyunwoo@10-18-140-181 ~ % /Applications/Arduino\ IDE.app/Contents/MacOS/Arduino\ IDE ; exit;
Arduino IDE 2.3.6
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.6" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-09T11:22:51.016Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.6","cliVersion":"1.2.0","buildDate":"2025-04-09T11:22:51.016Z"}
Starting backend process. PID: 78002
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/hyunwoo/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-04-27T20:55:29.661Z root INFO Backend u.initialize: 19.2 ms [Finished 0.327 s after backend start]
2025-04-27T20:55:29.663Z root INFO Backend Object.initialize: 18.5 ms [Finished 0.327 s after backend start]
2025-04-27T20:55:29.663Z root INFO Backend a.initialize: 0.4 ms [Finished 0.327 s after backend start]
2025-04-27T20:55:29.663Z root INFO Backend a.initialize: 0.2 ms [Finished 0.327 s after backend start]
2025-04-27T20:55:29.663Z root INFO Backend u.initialize: 0.4 ms [Finished 0.328 s after backend start]
2025-04-27T20:55:29.665Z root INFO Backend l.initialize: 19.2 ms [Finished 0.328 s after backend start]
2025-04-27T20:55:29.668Z root INFO configured all backend app contributions
2025-04-27T20:55:29.668Z root INFO Backend l.onStart: 0.5 ms [Finished 0.335 s after backend start]
2025-04-27T20:55:29.669Z root INFO Backend d.onStart: 0.0 ms [Finished 0.335 s after backend start]
2025-04-27T20:55:29.669Z root INFO Backend a.onStart: 0.1 ms [Finished 0.335 s after backend start]
2025-04-27T20:55:29.669Z config INFO >>> Initializing CLI configuration...
2025-04-27T20:55:29.669Z root INFO Backend x.onStart: 0.2 ms [Finished 0.335 s after backend start]
2025-04-27T20:55:29.669Z config INFO Loading CLI configuration from /Users/hyunwoo/.arduinoIDE/arduino-cli.yaml...
2025-04-27T20:55:29.669Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-27T20:55:29.669Z root INFO Backend w.onStart: 0.1 ms [Finished 0.336 s after backend start]
2025-04-27T20:55:29.669Z discovery-log INFO start
2025-04-27T20:55:29.669Z discovery-log INFO start new deferred
2025-04-27T20:55:29.669Z root INFO Backend v.onStart: 0.1 ms [Finished 0.336 s after backend start]
2025-04-27T20:55:29.669Z root INFO Backend a.onStart: 0.0 ms [Finished 0.336 s after backend start]
2025-04-27T20:55:29.676Z root WARN The local plugin referenced by local-dir:/Users/hyunwoo/.arduinoIDE/plugins does not exist.
2025-04-27T20:55:29.676Z root WARN The local plugin referenced by local-dir:/Users/hyunwoo/.arduinoIDE/deployedPlugins does not exist.
2025-04-27T20:55:29.685Z root ERROR Failed to start the backend application:
2025-04-27T20:55:29.685Z root ERROR Error: getaddrinfo ENOTFOUND localhost
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:26)
2025-04-27T20:55:29.685Z root ERROR Uncaught Exception: Error: getaddrinfo ENOTFOUND localhost
Can anyone help?
