Hi I tried a few of the similar problems as mine and their fixes but to no avail.
I try this in terminal:
"/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
And this is what I get:
IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.255Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.261Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.261Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
at Socket.<anonymous> (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:42907)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-08-05T17:07:00.261Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.261Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.268Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.268Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.268Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.269Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.274Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.274Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.274Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.276Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.280Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.281Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.281Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.281Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.287Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.287Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.287Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.288Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.293Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.293Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.293Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.294Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.299Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.299Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.299Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.300Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.306Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.306Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.306Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.306Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.312Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.312Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.312Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.312Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.318Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.318Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.318Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.318Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.324Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.324Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.324Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.324Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.330Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.330Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.330Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-08-05T17:07:00.331Z daemon INFO Daemon exited with exit code: 7.
2024-08-05T17:07:00.336Z daemon INFO Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
2024-08-05T17:07:00.336Z daemon ERROR Error: Error: invalid path creating config dir: /Users/panomacmini/Library/Arduino15 error: mkdir /Users/panomacmini: permission denied
panomacmini is an older login profile that no longer exists and I am using louisconstant
If someone could help me out it would be much appreciated...
thanks,
Louis
