After installing IDE 2.3.4 either with Windows .exe or .msi, the IDE does not open. It keeps showing the -/+ infinity circle even leaving it for a while. I have uninstalled/reinstall and restart the laptop. It has the same problem.
Please help.
Open the Arduino IDE installation folder. ⓘ The default installation location is at one of the following paths:
C:\Program Files\Arduino IDE
C:\Users\<username>\AppData\Local\Programs\Arduino IDE
(where <username> is your Windows username) If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
A context menu will open
Select "Open PowerShell window here" from the menu.
Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
Type the following command:
& ".\Arduino IDE"
Press the Enter key.
Debug output should now be printed to the PowerShell window as Arduino IDE starts.
Wait until you are sure the IDE startup has gone into the hang state
(as indicated by no additional output being printed to the terminal).
Switch back to the PowerShell window if the Arduino IDE window took the focus.
Press the Ctrl+Shift+A keyboard shortcut.
This will select all the text in the PowerShell window.
Press the Ctrl+C keyboard shortcut.
This will copy the contents of the PowerShell window to the clipboard.
Open a forum reply here by clicking the "Reply" button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
PS C:\Users\a0867436\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 12520
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/a0867436/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-02-05T19:06:43.986Z root INFO Backend Object.initialize: 3.9 ms [Finished 0.654 s after backend start]
2025-02-05T19:06:43.989Z root INFO Backend Object.configure: 3.1 ms [Finished 0.654 s after backend start]
2025-02-05T19:06:43.989Z root INFO Backend s.onStart: 1.3 ms [Finished 0.654 s after backend start]
2025-02-05T19:06:43.989Z root INFO Backend s.configure: 0.5 ms [Finished 0.676 s after backend start]
2025-02-05T19:06:43.991Z root INFO Backend d.onStart: 0.4 ms [Finished 0.676 s after backend start]
2025-02-05T19:06:43.991Z root INFO Backend d.configure: 0.2 ms [Finished 0.676 s after backend start]
2025-02-05T19:06:43.993Z root INFO Backend d.initialize: 21.8 ms [Finished 0.677 s after backend start]
2025-02-05T19:06:43.993Z root INFO Backend c.onStart: 0.2 ms [Finished 0.677 s after backend start]
2025-02-05T19:06:43.994Z root INFO Backend a.configure: 3.3 ms [Finished 0.680 s after backend start]
2025-02-05T19:06:43.995Z config INFO >>> Initializing CLI configuration...
2025-02-05T19:06:43.995Z root INFO Backend c.initialize: 0.7 ms [Finished 0.680 s after backend start]
2025-02-05T19:06:43.996Z root INFO Backend x.onStart: 1.2 ms [Finished 0.681 s after backend start]
2025-02-05T19:06:43.996Z config INFO Loading CLI configuration from c:\Users\a0867436\.arduinoIDE\arduino-cli.yaml...
2025-02-05T19:06:43.997Z daemon INFO Starting daemon from C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-02-05T19:06:43.997Z root INFO Backend a.initialize: 0.3 ms [Finished 0.682 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend w.onStart: 2.3 ms [Finished 0.684 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend r.configure: 3.0 ms [Finished 0.684 s after backend start]
2025-02-05T19:06:43.997Z discovery-log INFO start
2025-02-05T19:06:43.997Z discovery-log INFO start new deferred
2025-02-05T19:06:43.997Z root INFO Backend d.initialize: 0.4 ms [Finished 0.685 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend y.onStart: 2.0 ms [Finished 0.686 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend r.configure: 1.8 ms [Finished 0.687 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend a.onStart: 0.4 ms [Finished 0.688 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend h.configure: 0.3 ms [Finished 0.688 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend s.configure: 0.1 ms [Finished 0.688 s after backend start]
2025-02-05T19:06:43.997Z root INFO Backend l.configure: 0.0 ms [Finished 0.688 s after backend start]
2025-02-05T19:06:44.000Z root INFO Theia app listening on http://127.0.0.1:63632.
2025-02-05T19:06:44.000Z root INFO Finished starting backend application: 2.9 ms [Finished 0.691 s after backend start]
2025-02-05T19:06:44.040Z root WARN The local plugin referenced by local-dir:/c%3A/Users/a0867436/.arduinoIDE/plugins does not exist.
2025-02-05T19:06:44.040Z root WARN The local plugin referenced by local-dir:/c%3A/Users/a0867436/.arduinoIDE/extensions does not exist.
2025-02-05T19:06:44.040Z root WARN The local plugin referenced by local-dir:C:\Users\a0867436\.arduinoIDE\plugins does not exist.
2025-02-05T19:06:44.110Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-02-05T19:06:44.110Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-02-05T19:06:44.164Z root INFO Resolve plugins list: 167.7 ms [Finished 0.854 s after backend start]
2025-02-05T19:06:44.345Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="arduino-cli version 1.1.1"
2025-02-05T19:06:44.350Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Using config file: c:\\Users\\a0867436\\.arduinoIDE\\arduino-cli.yaml"
time="2025-02-05T13:06:44-06:00" level=info msg="Executing `arduino-cli daemon`"
2025-02-05T19:06:44.365Z daemon INFO Daemon is now listening on 127.0.0.1:63634
{"IP":"127.0.0.1","Port":"63634"}
2025-02-05T19:06:44.365Z root ERROR E "webproxy.ext.ti.com:" scheme not supported in proxy URI
2025-02-05T19:06:44.365Z daemon INFO Daemon is running.
2025-02-05T19:06:44.412Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\a0867436\\Documents\\Arduino","data":"C:\\Users\\a0867436\\AppData\\Local\\Arduino15"}}
2025-02-05T19:06:44.412Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\a0867436\\Documents\\Arduino","data":"C:\\Users\\a0867436\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-02-05T19:06:44.412Z config INFO Loaded the CLI configuration.
2025-02-05T19:06:44.417Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/a0867436/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/a0867436/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-02-05T19:06:44.417Z config INFO Validating the CLI configuration...
2025-02-05T19:06:44.426Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-05T19:06:44.438Z config INFO The CLI config is valid.
2025-02-05T19:06:44.438Z config INFO <<< Initialized the CLI configuration.
2025-02-05T19:06:44.461Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2025-02-05T19:06:44.461Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\a0867436\AppData\Local\Arduino15\package_index.json: open C:\Users\a0867436\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2025-02-05T19:06:44.462Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-02-05T19:06:44.462Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-02-05T19:06:44.462Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\a0867436\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-05T19:06:44.466Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\a0867436\AppData\Local\Arduino15\package_index.json: open C:\Users\a0867436\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\a0867436\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-05T19:06:44.467Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Loading hardware from: C:\\Users\\a0867436\\AppData\\Local\\Arduino15\\packages"
time="2025-02-05T13:06:44-06:00" level=info msg="Loading libraries index file" index="C:\\Users\\a0867436\\AppData\\Local\\Arduino15\\library_index.json"
time="2025-02-05T13:06:44-06:00" level=info msg="Adding libraries dir" dir="C:\\Users\\a0867436\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-02-05T13:06:44-06:00" level=info msg="Adding libraries dir" dir="C:\\Users\\a0867436\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-02-05T19:06:44.509Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-02-05T19:06:44.510Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-02-05T19:06:44.514Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
at t.callErrorFromStatus (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:921712)
at Object.onReceiveStatus (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:949334)
at Object.onReceiveStatus (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:942356)
at C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1028497
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeServerStreamRequest (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:949101)
at s.updateIndex (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
at C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:778402
at C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:778750
at new Promise (<anonymous>)
at v.doUpdateIndex (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:778729)
at v.updatePlatformIndex (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:778374)
at v.updateIndex (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777742)
at v.initInstanceWithFallback (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:776035)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-02-05T19:06:44.516Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-02-05T13:06:44-06:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-02-05T19:06:44.520Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-05T19:06:44.522Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2025-02-05T19:06:44.522Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\a0867436\AppData\Local\Arduino15\package_index.json: open C:\Users\a0867436\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2025-02-05T19:06:44.523Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Loading hardware from: C:\\Users\\a0867436\\AppData\\Local\\Arduino15\\packages"
2025-02-05T19:06:44.523Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Loading libraries index file" index="C:\\Users\\a0867436\\AppData\\Local\\Arduino15\\library_index.json"
2025-02-05T19:06:44.524Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-02-05T19:06:44.524Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-02-05T19:06:44.525Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\a0867436\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-05T19:06:44.526Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2025-02-05T19:06:44.526Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777546
at v.evaluateErrorStatus (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777562)
at async a.<anonymous> (C:\Users\a0867436\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777232)
2025-02-05T19:06:44.526Z daemon INFO time="2025-02-05T13:06:44-06:00" level=info msg="Adding libraries dir" dir="C:\\Users\\a0867436\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-02-05T19:06:45.456Z root INFO Deploy plugins list: 167.7 ms [Finished 2.147 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-02-05T19:06:45.993Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 150.9 ms [Finished 1.858 s after frontend start]
2025-02-05T19:06:45.993Z root WARN A command editor.action.toggleStickyScroll is already registered.
On the first run after a fresh installation, Arduino IDE downloads some additional essential components from the Internet and installs them. If it can't install those components then the startup fails. So the computer must have access to the Internet on the first startup.
The errors indicate Arduino IDE is not able to access the Internet. If it is not already, please connect your computer to the Internet, close the Arduino IDE window, then start Arduino IDE again. This time it should start up successfully.
After that first run, an Internet connection is not required. However, there are some supplemental features such as "Library Manager" that have an inherent dependency on the Internet. Those features will not be usable while your computer is offline. But the essential functionality of editing, compiling, and uploading sketches will be available even without an Internet connection.
