2024-03-29 16:22:44 Arduino IDE 2.3.2
2024-03-29 16:22:44 Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
2024-03-29 16:22:44 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-03-29 16:22:44 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-03-29 16:22:44 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-03-29 16:22:44 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-03-29 16:22:44 Starting backend process. PID: 20324
2024-03-29 16:22:44 Using browser-only version of superagent in non-browser environment
2024-03-29 16:22:44 Configuration directory URI: 'file:///c%3A/Users/sahit_2vxodk4/.arduinoIDE'
2024-03-29 16:22:44 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-29 16:22:44 2024-03-29T10:52:44.841Z root INFO Backend Object.initialize: 4.8 ms [Finished 0.581 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.842Z root INFO Backend Object.configure: 4.0 ms [Finished 0.581 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.842Z root INFO Backend s.onStart: 2.1 ms [Finished 0.581 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.843Z root INFO Backend s.configure: 0.4 ms [Finished 0.605 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.844Z root INFO Backend d.onStart: 0.3 ms [Finished 0.605 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.844Z root INFO Backend d.configure: 0.1 ms [Finished 0.605 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.845Z root INFO Backend d.initialize: 23.5 ms [Finished 0.605 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.846Z root INFO Backend c.onStart: 0.3 ms [Finished 0.605 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.847Z root INFO Backend a.configure: 1.5 ms [Finished 0.607 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.848Z config INFO >>> Initializing CLI configuration...
2024-03-29 16:22:44 2024-03-29T10:52:44.848Z root INFO Backend c.initialize: 0.7 ms [Finished 0.607 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.849Z root INFO Backend R.onStart: 0.9 ms [Finished 0.608 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.849Z config INFO Loading CLI configuration from c:\Users\sahit_2vxodk4\.arduinoIDE\arduino-cli.yaml...
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend a.initialize: 0.4 ms [Finished 0.609 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend w.onStart: 1.3 ms [Finished 0.610 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend r.configure: 2.1 ms [Finished 0.610 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z discovery-log INFO start
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z discovery-log INFO start new deferred
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend d.initialize: 0.7 ms [Finished 0.611 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend y.onStart: 2.4 ms [Finished 0.613 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend r.configure: 1.8 ms [Finished 0.613 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend a.onStart: 0.5 ms [Finished 0.614 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend h.configure: 0.4 ms [Finished 0.614 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend s.configure: 0.1 ms [Finished 0.614 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.850Z root INFO Backend l.configure: 0.1 ms [Finished 0.615 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.853Z root INFO Theia app listening on http://127.0.0.1:51859.
2024-03-29 16:22:44 2024-03-29T10:52:44.853Z root INFO Finished starting backend application: 3.0 ms [Finished 0.617 s after backend start]
2024-03-29 16:22:44 2024-03-29T10:52:44.867Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sahit_2vxodk4/.arduinoIDE/plugins does not exist.
2024-03-29 16:22:44 2024-03-29T10:52:44.868Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sahit_2vxodk4/.arduinoIDE/extensions does not exist.
2024-03-29 16:22:44 2024-03-29T10:52:44.868Z root WARN The local plugin referenced by local-dir:C:\Users\sahit_2vxodk4\.arduinoIDE\plugins does not exist.
2024-03-29 16:22:44 2024-03-29T10:52:44.878Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\sahit_2vxodk4\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-29 16:22:44 2024-03-29T10:52:44.878Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-29 16:22:44 2024-03-29T10:52:44.878Z config INFO Loaded the CLI configuration.
2024-03-29 16:22:44 2024-03-29T10:52:44.880Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/sahit_2vxodk4/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/sahit_2vxodk4/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-29 16:22:44 2024-03-29T10:52:44.880Z config INFO Validating the CLI configuration...
2024-03-29 16:22:44 2024-03-29T10:52:44.880Z config INFO The CLI config is valid.
2024-03-29 16:22:44 2024-03-29T10:52:44.880Z config INFO <<< Initialized the CLI configuration.
2024-03-29 16:22:44 2024-03-29T10:52:44.901Z root INFO Resolve plugins list: 52.1 ms [Finished 0.665 s after backend start]
2024-03-29 16:22:45 2024-03-29T10:52:45.066Z daemon INFO time="2024-03-29T16:22:45+05:30" level=info msg="Using config file: c:\\Users\\sahit_2vxodk4\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-29T16:22:45+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-29T16:22:45+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:51861
{"IP":"127.0.0.1","Port":"51861"}
2024-03-29 16:22:45 2024-03-29T10:52:45.066Z daemon INFO Daemon is running.
2024-03-29 16:22:45 2024-03-29T10:52:45.173Z daemon INFO time="2024-03-29T16:22:45+05:30" level=info msg="Updating libraries index"
time="2024-03-29T16:22:45+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:22:45 2024-03-29T10:52:45.899Z root INFO Deploy plugins list: 52.1 ms [Finished 1.664 s after backend start]
2024-03-29 16:22:46 Opening channel for service path '/services/electron-window'.
2024-03-29 16:22:46 Opening channel for service path '/services/ide-updater'.
2024-03-29 16:22:46 2024-03-29T10:52:46.728Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 174.1 ms [Finished 1.780 s after frontend start]
2024-03-29 16:22:46 2024-03-29T10:52:46.729Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-29 16:22:49 2024-03-29T10:52:49.702Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-03-29 16:22:49 2024-03-29T10:52:49.714Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Checking signature" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-29 16:22:49 2024-03-29T10:52:49.715Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loading hardware from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages"
2024-03-29 16:22:49 2024-03-29T10:52:49.716Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loading package builtin from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-29 16:22:49 2024-03-29T10:52:49.716Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-29T16:22:49+05:30" level=info msg="Loading tools from dir: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-29 16:22:49 2024-03-29T10:52:49.717Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-03-29 16:22:49 2024-03-29T10:52:49.717Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-29 16:22:49 2024-03-29T10:52:49.717Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-29 16:22:49 2024-03-29T10:52:49.717Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-29 16:22:49 2024-03-29T10:52:49.718Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-29 16:22:49 2024-03-29T10:52:49.719Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-29 16:22:49 2024-03-29T10:52:49.719Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-29 16:22:49 2024-03-29T10:52:49.720Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-29 16:22:49 2024-03-29T10:52:49.720Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\Documents\\Arduino\\libraries" location=user
2024-03-29 16:22:49 2024-03-29T10:52:49.726Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-29 16:22:49 2024-03-29T10:52:49.727Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Updating libraries index"
2024-03-29 16:22:49 2024-03-29T10:52:49.730Z daemon INFO time="2024-03-29T16:22:49+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:22:49 2024-03-29T10:52:49.731Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-03-29 16:22:53 2024-03-29T10:52:53.033Z daemon INFO time="2024-03-29T16:22:53+05:30" level=info msg="Updating libraries index"
2024-03-29 16:22:53 2024-03-29T10:52:53.034Z daemon INFO time="2024-03-29T16:22:53+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:22:56 2024-03-29T10:52:56.699Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-03-29 16:22:56 2024-03-29T10:52:56.709Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Checking signature" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-29 16:22:56 2024-03-29T10:52:56.709Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loading hardware from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages"
2024-03-29 16:22:56 2024-03-29T10:52:56.710Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loading package builtin from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-29 16:22:56 2024-03-29T10:52:56.710Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-29T16:22:56+05:30" level=info msg="Loading tools from dir: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-29 16:22:56 2024-03-29T10:52:56.710Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-03-29T16:22:56+05:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-29 16:22:56 2024-03-29T10:52:56.710Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-29 16:22:56 2024-03-29T10:52:56.710Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-29 16:22:56 2024-03-29T10:52:56.710Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-29 16:22:56 2024-03-29T10:52:56.711Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-29 16:22:56 2024-03-29T10:52:56.711Z daemon INFO time="2024-03-29T16:22:56+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-29T16:22:56+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\Documents\\Arduino\\libraries" location=user
2024-03-29 16:22:56 2024-03-29T10:52:56.711Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-29 16:22:56 2024-03-29T10:52:56.713Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-03-29 16:22:56 2024-03-29T10:52:56.713Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
2024-03-29 16:23:20 Closing channel on service path '/services/electron-window'.
2024-03-29 16:23:20 Closing channel on service path '/services/ide-updater'.
2024-03-29 16:23:20 Stored workspaces roots:
2024-03-29 16:23:20 No sketches were scheduled for deletion.
2024-03-29 16:23:56 Arduino IDE 2.3.2
2024-03-29 16:23:56 Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
2024-03-29 16:23:56 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-03-29 16:23:56 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-03-29 16:23:56 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-03-29 16:23:56 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-03-29 16:23:56 Starting backend process. PID: 18760
2024-03-29 16:23:57 Using browser-only version of superagent in non-browser environment
2024-03-29 16:23:57 Configuration directory URI: 'file:///c%3A/Users/sahit_2vxodk4/.arduinoIDE'
2024-03-29 16:23:57 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-29 16:23:57 2024-03-29T10:53:57.314Z root INFO Backend Object.initialize: 4.3 ms [Finished 0.493 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.315Z root INFO Backend Object.configure: 3.6 ms [Finished 0.493 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.315Z root INFO Backend s.onStart: 1.8 ms [Finished 0.493 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.316Z root INFO Backend s.configure: 0.3 ms [Finished 0.514 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.316Z root INFO Backend d.onStart: 0.2 ms [Finished 0.514 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.317Z root INFO Backend d.configure: 0.1 ms [Finished 0.514 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.318Z root INFO Backend d.initialize: 21.3 ms [Finished 0.515 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.318Z root INFO Backend c.onStart: 0.2 ms [Finished 0.515 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.319Z root INFO Backend a.configure: 1.1 ms [Finished 0.516 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.320Z config INFO >>> Initializing CLI configuration...
2024-03-29 16:23:57 2024-03-29T10:53:57.321Z root INFO Backend c.initialize: 0.5 ms [Finished 0.516 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.321Z root INFO Backend R.onStart: 0.7 ms [Finished 0.517 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.321Z config INFO Loading CLI configuration from c:\Users\sahit_2vxodk4\.arduinoIDE\arduino-cli.yaml...
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend a.initialize: 0.4 ms [Finished 0.518 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend w.onStart: 1.1 ms [Finished 0.518 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend r.configure: 1.9 ms [Finished 0.519 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z discovery-log INFO start
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z discovery-log INFO start new deferred
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend d.initialize: 0.5 ms [Finished 0.519 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend y.onStart: 2.3 ms [Finished 0.521 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend r.configure: 1.9 ms [Finished 0.521 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend a.onStart: 0.5 ms [Finished 0.522 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend h.configure: 0.4 ms [Finished 0.522 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend s.configure: 0.1 ms [Finished 0.523 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.322Z root INFO Backend l.configure: 0.1 ms [Finished 0.523 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.325Z root INFO Theia app listening on http://127.0.0.1:51885.
2024-03-29 16:23:57 2024-03-29T10:53:57.325Z root INFO Finished starting backend application: 2.8 ms [Finished 0.525 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.337Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sahit_2vxodk4/.arduinoIDE/plugins does not exist.
2024-03-29 16:23:57 2024-03-29T10:53:57.337Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sahit_2vxodk4/.arduinoIDE/extensions does not exist.
2024-03-29 16:23:57 2024-03-29T10:53:57.337Z root WARN The local plugin referenced by local-dir:C:\Users\sahit_2vxodk4\.arduinoIDE\plugins does not exist.
2024-03-29 16:23:57 2024-03-29T10:53:57.343Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\sahit_2vxodk4\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-29 16:23:57 2024-03-29T10:53:57.343Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-29 16:23:57 2024-03-29T10:53:57.343Z config INFO Loaded the CLI configuration.
2024-03-29 16:23:57 2024-03-29T10:53:57.344Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/sahit_2vxodk4/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/sahit_2vxodk4/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-29 16:23:57 2024-03-29T10:53:57.344Z config INFO Validating the CLI configuration...
2024-03-29 16:23:57 2024-03-29T10:53:57.345Z config INFO The CLI config is valid.
2024-03-29 16:23:57 2024-03-29T10:53:57.345Z config INFO <<< Initialized the CLI configuration.
2024-03-29 16:23:57 2024-03-29T10:53:57.385Z root INFO Resolve plugins list: 63.2 ms [Finished 0.584 s after backend start]
2024-03-29 16:23:57 2024-03-29T10:53:57.439Z daemon INFO time="2024-03-29T16:23:57+05:30" level=info msg="Using config file: c:\\Users\\sahit_2vxodk4\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-29T16:23:57+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-29T16:23:57+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-03-29 16:23:57 2024-03-29T10:53:57.452Z daemon INFO Daemon is now listening on 127.0.0.1:51886
{"IP":"127.0.0.1","Port":"51886"}
2024-03-29 16:23:57 2024-03-29T10:53:57.452Z daemon INFO Daemon is running.
2024-03-29 16:23:57 2024-03-29T10:53:57.479Z daemon INFO time="2024-03-29T16:23:57+05:30" level=info msg="Updating libraries index"
2024-03-29 16:23:57 2024-03-29T10:53:57.481Z daemon INFO time="2024-03-29T16:23:57+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:23:58 2024-03-29T10:53:58.451Z root INFO Deploy plugins list: 63.2 ms [Finished 1.652 s after backend start]
2024-03-29 16:23:58 Opening channel for service path '/services/electron-window'.
2024-03-29 16:23:59 Opening channel for service path '/services/ide-updater'.
2024-03-29 16:23:59 2024-03-29T10:53:59.257Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 165.5 ms [Finished 1.832 s after frontend start]
2024-03-29 16:23:59 2024-03-29T10:53:59.257Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-29 16:24:00 Closing channel on service path '/services/electron-window'.
2024-03-29 16:24:00 Closing channel on service path '/services/ide-updater'.
2024-03-29 16:24:00 Stored workspaces roots:
2024-03-29 16:24:00 No sketches were scheduled for deletion.
2024-03-29 16:39:15 Arduino IDE 2.3.2
2024-03-29 16:39:15 Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
2024-03-29 16:39:16 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-03-29 16:39:16 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-03-29 16:39:16 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-03-29 16:39:16 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-03-29 16:39:16 Starting backend process. PID: 8568
2024-03-29 16:39:16 Using browser-only version of superagent in non-browser environment
2024-03-29 16:39:16 Configuration directory URI: 'file:///c%3A/Users/sahit_2vxodk4/.arduinoIDE'
2024-03-29 16:39:16 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-29 16:39:16 2024-03-29T11:09:16.772Z root INFO Backend Object.initialize: 27.5 ms [Finished 0.644 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.774Z root INFO Backend Object.configure: 26.2 ms [Finished 0.644 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.774Z root INFO Backend s.onStart: 2.8 ms [Finished 0.644 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.775Z root INFO Backend s.configure: 0.8 ms [Finished 0.719 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.776Z root INFO Backend d.onStart: 0.4 ms [Finished 0.719 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.777Z root INFO Backend d.configure: 0.5 ms [Finished 0.719 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.779Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 74.9 ms [Finished 0.720 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.779Z root INFO Backend c.onStart: 0.4 ms [Finished 0.720 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.780Z root INFO Backend a.configure: 1.8 ms [Finished 0.722 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.782Z config INFO >>> Initializing CLI configuration...
2024-03-29 16:39:16 2024-03-29T11:09:16.782Z root INFO Backend c.initialize: 1.1 ms [Finished 0.722 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.782Z root INFO Backend R.onStart: 1.3 ms [Finished 0.723 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.783Z config INFO Loading CLI configuration from c:\Users\sahit_2vxodk4\.arduinoIDE\arduino-cli.yaml...
2024-03-29 16:39:16 2024-03-29T11:09:16.784Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend a.initialize: 0.6 ms [Finished 0.725 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend w.onStart: 2.0 ms [Finished 0.726 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend r.configure: 3.1 ms [Finished 0.726 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z discovery-log INFO start
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z discovery-log INFO start new deferred
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend d.initialize: 0.6 ms [Finished 0.727 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend y.onStart: 3.1 ms [Finished 0.730 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend r.configure: 2.8 ms [Finished 0.730 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend a.onStart: 1.0 ms [Finished 0.732 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend h.configure: 0.6 ms [Finished 0.732 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend s.configure: 0.3 ms [Finished 0.732 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.785Z root INFO Backend l.configure: 0.1 ms [Finished 0.733 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.789Z root INFO Theia app listening on http://127.0.0.1:52282.
2024-03-29 16:39:16 2024-03-29T11:09:16.789Z root INFO Finished starting backend application: 4.4 ms [Finished 0.736 s after backend start]
2024-03-29 16:39:16 2024-03-29T11:09:16.809Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sahit_2vxodk4/.arduinoIDE/plugins does not exist.
2024-03-29 16:39:16 2024-03-29T11:09:16.809Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sahit_2vxodk4/.arduinoIDE/extensions does not exist.
2024-03-29 16:39:16 2024-03-29T11:09:16.810Z root WARN The local plugin referenced by local-dir:C:\Users\sahit_2vxodk4\.arduinoIDE\plugins does not exist.
2024-03-29 16:39:16 2024-03-29T11:09:16.817Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\sahit_2vxodk4\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-29 16:39:16 2024-03-29T11:09:16.817Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-29 16:39:16 2024-03-29T11:09:16.817Z config INFO Loaded the CLI configuration.
2024-03-29 16:39:16 2024-03-29T11:09:16.824Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/sahit_2vxodk4/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/sahit_2vxodk4/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-29 16:39:16 2024-03-29T11:09:16.824Z config INFO Validating the CLI configuration...
2024-03-29 16:39:16 2024-03-29T11:09:16.825Z config INFO The CLI config is valid.
2024-03-29 16:39:16 2024-03-29T11:09:16.825Z config INFO <<< Initialized the CLI configuration.
2024-03-29 16:39:16 2024-03-29T11:09:16.850Z root INFO Resolve plugins list: 67.4 ms [Finished 0.797 s after backend start]
2024-03-29 16:39:17 2024-03-29T11:09:17.014Z daemon INFO time="2024-03-29T16:39:17+05:30" level=info msg="Using config file: c:\\Users\\sahit_2vxodk4\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-29T16:39:17+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-29T16:39:17+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52283
{"IP":"127.0.0.1","Port":"52283"}
2024-03-29 16:39:17 2024-03-29T11:09:17.015Z daemon INFO Daemon is running.
2024-03-29 16:39:17 2024-03-29T11:09:17.048Z daemon INFO time="2024-03-29T16:39:17+05:30" level=info msg="Updating libraries index"
time="2024-03-29T16:39:17+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:39:17 2024-03-29T11:09:17.750Z root INFO Deploy plugins list: 67.4 ms [Finished 1.698 s after backend start]
2024-03-29 16:39:18 Opening channel for service path '/services/electron-window'.
2024-03-29 16:39:18 Opening channel for service path '/services/ide-updater'.
2024-03-29 16:39:18 2024-03-29T11:09:18.765Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 188.6 ms [Finished 1.872 s after frontend start]
2024-03-29 16:39:18 2024-03-29T11:09:18.765Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-29 16:39:18 2024-03-29T11:09:18.986Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 154.1 ms [Finished 2.126 s after frontend start]
2024-03-29 16:39:20 2024-03-29T11:09:20.893Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-03-29 16:39:20 2024-03-29T11:09:20.894Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\package_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-03-29 16:39:20 2024-03-29T11:09:20.894Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Loading hardware from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages"
time="2024-03-29T16:39:20+05:30" level=info msg="Loading package builtin from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-03-29T16:39:20+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-29T16:39:20+05:30" level=info msg="Loading tools from dir: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-29T16:39:20+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-03-29T16:39:20+05:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-03-29T16:39:20+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-03-29T16:39:20+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-29 16:39:20 2024-03-29T11:09:20.894Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-29 16:39:20 2024-03-29T11:09:20.894Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-29 16:39:20 2024-03-29T11:09:20.894Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-29 16:39:20 2024-03-29T11:09:20.894Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\Documents\\Arduino\\libraries" location=user
2024-03-29 16:39:20 2024-03-29T11:09:20.895Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-29 16:39:20 2024-03-29T11:09:20.902Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\package_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-03-29 16:39:20 2024-03-29T11:09:20.903Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Updating libraries index"
2024-03-29 16:39:20 2024-03-29T11:09:20.903Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-29 16:39:20 2024-03-29T11:09:20.905Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-29 16:39:20 2024-03-29T11:09:20.908Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-03-29 16:39:20 2024-03-29T11:09:20.909Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-03-29 16:39:20 2024-03-29T11:09:20.910Z daemon INFO time="2024-03-29T16:39:20+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:39:25 2024-03-29T11:09:25.898Z daemon INFO time="2024-03-29T16:39:25+05:30" level=info msg="Updating libraries index"
2024-03-29 16:39:25 2024-03-29T11:09:25.901Z daemon INFO time="2024-03-29T16:39:25+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-29 16:39:29 2024-03-29T11:09:29.531Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: openpgp: signature expired
2024-03-29 16:39:29 2024-03-29T11:09:29.543Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Checking signature" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-29 16:39:29 2024-03-29T11:09:29.544Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loading hardware from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages"
2024-03-29 16:39:29 2024-03-29T11:09:29.545Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loading package builtin from: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-29 16:39:29 2024-03-29T11:09:29.545Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-29T16:39:29+05:30" level=info msg="Loading tools from dir: C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-29 16:39:29 2024-03-29T11:09:29.546Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-03-29 16:39:29 2024-03-29T11:09:29.546Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-29 16:39:29 2024-03-29T11:09:29.546Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-29 16:39:29 2024-03-29T11:09:29.546Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-29 16:39:29 2024-03-29T11:09:29.547Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-29 16:39:29 2024-03-29T11:09:29.547Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-29 16:39:29 2024-03-29T11:09:29.547Z daemon INFO time="2024-03-29T16:39:29+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-29T16:39:29+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\sahit_2vxodk4\\Documents\\Arduino\\libraries" location=user
2024-03-29 16:39:29 2024-03-29T11:09:29.547Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\sahit_2vxodk4\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-29 16:39:29 2024-03-29T11:09:29.549Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-03-29 16:39:29 2024-03-29T11:09:29.549Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-03-29 16:45:35 Closing channel on service path '/services/electron-window'.
2024-03-29 16:45:35 Closing channel on service path '/services/ide-updater'.
2024-03-29 16:45:35 Stored workspaces roots:
2024-03-29 16:45:35 No sketches were scheduled for deletion.
Hi @sahithyan10117.
This error occurs when your system time is incorrect. You should be able to fix it by syncing the system time. I'll provide instructions you can follow to do that:
- Right click the Windows Start icon (⊞) on the taskbar.
A context menu will open. - Select "Settings" from the context menu.
Windows "Settings" will open. - Select "Time & language" from the navigation panel on the left side of the window.
- Select "Date & time" from the list on the right side of the Settings window.
The Date & time settings section will expand. - Click the "Sync now" button that is under the "Additional settings" section of the page.
- Wait for the syncing process to finish.
- Close any Arduino IDE windows that are open.
- Start Arduino IDE again.
Hopefully this time Arduino IDE will start up fully and work as expected.
