Arduino IDE was fine before a restart of my PC. Now, the IDE refuses to launch and is stuck in a booting loop with the logo pulsing. I have the snippet of my powershell output here:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS C:\Users\calvi\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Users\calvi\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\calvi\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 15344
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/calvi/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-03-30T03:36:26.699Z root INFO Backend Object.initialize: 4.9 ms [Finished 0.618 s after backend start]
2025-03-30T03:36:26.700Z root INFO Backend Object.configure: 3.9 ms [Finished 0.618 s after backend start]
2025-03-30T03:36:26.700Z root INFO Backend s.onStart: 2.5 ms [Finished 0.618 s after backend start]
2025-03-30T03:36:26.701Z root INFO Backend s.configure: 0.4 ms [Finished 0.642 s after backend start]
2025-03-30T03:36:26.701Z root INFO Backend d.onStart: 0.3 ms [Finished 0.642 s after backend start]
2025-03-30T03:36:26.702Z root INFO Backend d.configure: 0.1 ms [Finished 0.642 s after backend start]
2025-03-30T03:36:26.703Z root INFO Backend d.initialize: 24.2 ms [Finished 0.642 s after backend start]
2025-03-30T03:36:26.704Z root INFO Backend c.onStart: 0.3 ms [Finished 0.642 s after backend start]
2025-03-30T03:36:26.704Z root INFO Backend a.configure: 1.1 ms [Finished 0.643 s after backend start]
2025-03-30T03:36:26.706Z config INFO >>> Initializing CLI configuration...
2025-03-30T03:36:26.706Z root INFO Backend c.initialize: 0.5 ms [Finished 0.644 s after backend start]
2025-03-30T03:36:26.706Z root INFO Backend x.onStart: 0.7 ms [Finished 0.644 s after backend start]
2025-03-30T03:36:26.707Z config INFO Loading CLI configuration from c:\Users\calvi\.arduinoIDE\arduino-cli.yaml...
2025-03-30T03:36:26.708Z daemon INFO Starting daemon from C:\Users\calvi\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-30T03:36:26.708Z root INFO Backend a.initialize: 0.5 ms [Finished 0.645 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend w.onStart: 1.3 ms [Finished 0.646 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend r.configure: 2.2 ms [Finished 0.646 s after backend start]
2025-03-30T03:36:26.708Z discovery-log INFO start
2025-03-30T03:36:26.708Z discovery-log INFO start new deferred
2025-03-30T03:36:26.708Z root INFO Backend d.initialize: 0.6 ms [Finished 0.647 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend y.onStart: 2.5 ms [Finished 0.649 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend r.configure: 2.1 ms [Finished 0.649 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend a.onStart: 0.5 ms [Finished 0.650 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend h.configure: 0.4 ms [Finished 0.651 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend s.configure: 0.2 ms [Finished 0.651 s after backend start]
2025-03-30T03:36:26.708Z root INFO Backend l.configure: 0.1 ms [Finished 0.651 s after backend start]
2025-03-30T03:36:26.711Z root INFO Theia app listening on http://127.0.0.1:50253.
2025-03-30T03:36:26.711Z root INFO Finished starting backend application: 3.6 ms [Finished 0.654 s after backend start]
2025-03-30T03:36:26.712Z root WARN The local plugin referenced by local-dir:/c%3A/Users/calvi/.arduinoIDE/plugins does not exist.
2025-03-30T03:36:26.712Z root WARN The local plugin referenced by local-dir:/c%3A/Users/calvi/.arduinoIDE/extensions does not exist.
2025-03-30T03:36:26.712Z root WARN The local plugin referenced by local-dir:C:\Users\calvi\.arduinoIDE\plugins does not exist.
2025-03-30T03:36:26.722Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://downloads.arduino.cc/packages/package_index.json=","https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json","https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"]},"directories":{"builtin":{"libraries":"C:\\Users\\calvi\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\calvi\\AppData\\Local\\Arduino15","user":"c:\\Users\\calvi\\OneDrive\\Documents\\Arduino"},"locale":"en"}
2025-03-30T03:36:26.722Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-03-30T03:36:26.722Z config INFO Loaded the CLI configuration.
Restoring workspace roots: c:\Users\calvi\Downloads\SDP_Final_Code_3_24_2025\SDP_Final_Code_3_24_2025\SDP_Final_Code_3_24_2025.ino
isTempSketch: false. Input was c:\Users\calvi\Downloads\SDP_Final_Code_3_24_2025\SDP_Final_Code_3_24_2025\SDP_Final_Code_3_24_2025.ino
2025-03-30T03:36:26.796Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/calvi/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/calvi/OneDrive/Documents/Arduino","additionalUrls":["https://downloads.arduino.cc/packages/package_index.json=","https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json","https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"],"network":"none","locale":"en"}
2025-03-30T03:36:26.796Z config INFO Validating the CLI configuration...
2025-03-30T03:36:26.797Z config INFO The CLI config is valid.
2025-03-30T03:36:26.797Z config INFO <<< Initialized the CLI configuration.
2025-03-30T03:36:26.817Z root INFO Resolve plugins list: 110.0 ms [Finished 0.759 s after backend start]
2025-03-30T03:36:26.883Z daemon INFO time="2025-03-29T20:36:26-07:00" level=info msg="arduino-cli version 1.1.1"
time="2025-03-29T20:36:26-07:00" level=info msg="Using config file: c:\\Users\\calvi\\.arduinoIDE\\arduino-cli.yaml"
time="2025-03-29T20:36:26-07:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50254
{"IP":"127.0.0.1","Port":"50254"}
2025-03-30T03:36:26.883Z daemon INFO Daemon is running.
2025-03-30T03:36:26.910Z daemon INFO time="2025-03-29T20:36:26-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-03-29T20:36:26-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-30T03:36:27.157Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.json="
time="2025-03-29T20:36:27-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.json="
2025-03-30T03:36:27.301Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Updating index" url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
time="2025-03-29T20:36:27-07:00" level=info msg="Starting download" url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
2025-03-30T03:36:27.540Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Updating index" url="https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"
2025-03-30T03:36:27.541Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Starting download" url="https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"
2025-03-30T03:36:27.577Z root INFO Deploy plugins list: 110.0 ms [Finished 1.519 s after backend start]
2025-03-30T03:36:27.749Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Some indexes could not be updated.
2025-03-30T03:36:27.759Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Checking signature" index="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-03-30T03:36:27.761Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\calvi\AppData\Local\Arduino15\package_index.json=: open c:\Users\calvi\AppData\Local\Arduino15\package_index.json=: The system cannot find the file specified.
2025-03-30T03:36:27.763Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Missing signature file" index="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json"
2025-03-30T03:36:27.763Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loading hardware from: c:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages"
2025-03-30T03:36:27.764Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loading package builtin from: C:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-03-30T03:36:27.765Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-03-30T03:36:27.765Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loading tools from dir: C:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-03-30T03:36:27.765Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-03-30T03:36:27.765Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-03-30T03:36:27.766Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2025-03-30T03:36:27.766Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-03-30T03:36:27.766Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-03-30T03:36:27.778Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Loading libraries index file" index="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\library_index.json"
2025-03-30T03:36:27.973Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\calvi\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-03-30T03:36:27.973Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\calvi\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-03-30T03:36:27.984Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file c:\Users\calvi\AppData\Local\Arduino15\package_index.json=: open c:\Users\calvi\AppData\Local\Arduino15\package_index.json=: The system cannot find the file specified.
2025-03-30T03:36:27.985Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-30T03:36:27.986Z daemon INFO time="2025-03-29T20:36:27-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-30T03:36:27.987Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
Opening channel for service path '/services/electron-window'.
2025-03-30T03:36:28.186Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.json="
2025-03-30T03:36:28.186Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.json="
2025-03-30T03:36:28.187Z root INFO core-client-provider [platform-index] Downloading index: package_index.json=
Opening channel for service path '/services/ide-updater'.
2025-03-30T03:36:28.376Z root INFO core-client-provider [platform-index] Downloading index: package_stmicroelectronics_index.json
2025-03-30T03:36:28.376Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Updating index" url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
time="2025-03-29T20:36:28-07:00" level=info msg="Starting download" url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
2025-03-30T03:36:28.435Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 138.5 ms [Finished 1.652 s after frontend start]
2025-03-30T03:36:28.435Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-03-30T03:36:28.585Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Updating index" url="https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"
2025-03-30T03:36:28.586Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Starting download" url="https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"
2025-03-30T03:36:28.587Z root INFO core-client-provider [platform-index] Downloading index: package_stmicroelectronics_index.json
2025-03-30T03:36:28.789Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-30T03:36:28.790Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-30T03:36:28.982Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.json="
2025-03-30T03:36:28.983Z daemon INFO time="2025-03-29T20:36:28-07:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.json="
2025-03-30T03:36:29.100Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Updating index" url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
2025-03-30T03:36:29.101Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Starting download" url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
2025-03-30T03:36:29.324Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Updating index" url="https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"
2025-03-30T03:36:29.325Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Starting download" url="https://github.com/stm32duino/BoardManagerFiles/raw/master/package_stmicroelectronics_index.json"
2025-03-30T03:36:29.541Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Some indexes could not be updated.
2025-03-30T03:36:29.557Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Checking signature" index="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-03-30T03:36:29.558Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\calvi\AppData\Local\Arduino15\package_index.json=: open c:\Users\calvi\AppData\Local\Arduino15\package_index.json=: The system cannot find the file specified.
2025-03-30T03:36:29.558Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Missing signature file" index="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json"
time="2025-03-29T20:36:29-07:00" level=info msg="Loading hardware from: c:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages"
2025-03-30T03:36:29.559Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loading package builtin from: C:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-03-30T03:36:29.559Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-03-29T20:36:29-07:00" level=info msg="Loading tools from dir: C:\\Users\\calvi\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-03-30T03:36:29.560Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-03-30T03:36:29.560Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-03-30T03:36:29.560Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2025-03-30T03:36:29.560Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-03-30T03:36:29.560Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-03-30T03:36:29.573Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Loading libraries index file" index="c:\\Users\\calvi\\AppData\\Local\\Arduino15\\library_index.json"
2025-03-30T03:36:29.752Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\calvi\\AppData\\Local\\Arduino15\\libraries" isS> & ".\Arduino IDE"location=ide
2025-03-30T03:36:29.752Z daemon INFO time="2025-03-29T20:36:29-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\calvi\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-03-30T03:36:29.761Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2025-03-30T03:36:29.761Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Users\calvi\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777546
at v.evaluateErrorStatus (C:\Users\calvi\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777562)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async a.<anonymous> (C:\Users\calvi\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:777232)
