I've been using ide 2 without issue for months. I wanted to install the uno R4 boards. They did not appear in the list of boards to install. I restarted the IDE and it remains frozen with the logo.
(on Windows 10)
here is what "& ".\Arduino IDE"" gave:
PS C:\Program Files\Arduino IDE> ".\Arduino IDE"
.\Arduino IDE
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.1
Starting backend process. PID: 14676
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Ronan/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-08-25T07:07:37.965Z root INFO Backend Object.initialize: 3.3 ms [Finished 1.269 s after backend start]
2023-08-25T07:07:37.965Z root INFO Backend Object.configure: 2.7 ms [Finished 1.269 s after backend start]
2023-08-25T07:07:37.966Z root INFO Backend MessagingContribution.onStart: 1.2 ms [Finished 1.269 s after backend start]
2023-08-25T07:07:37.967Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.297 s after backend start]
2023-08-25T07:07:37.967Z root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.297 s after backend start]2023-08-25T07:07:37.968Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.297 s after backend start]
2023-08-25T07:07:37.969Z root INFO Backend PluginLocalizationBackendContribution.initialize: 28.7 ms [Finished 1.298 s after backend start]
2023-08-25T07:07:37.969Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.298 s after backend start]
2023-08-25T07:07:37.970Z root INFO Backend ElectronTokenBackendContribution.configure: 1.6 ms [Finished 1.299 s after backend start]
2023-08-25T07:07:37.970Z config INFO >>> Initializing CLI configuration...
2023-08-25T07:07:37.970Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.300 s after backend start]
2023-08-25T07:07:37.970Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 1.300 s after backend start]
2023-08-25T07:07:37.971Z config INFO Loading CLI configuration from c:\Users\Ronan\.arduinoIDE\arduino-cli.yaml...
2023-08-25T07:07:37.971Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.301 s after backend start]
2023-08-25T07:07:37.972Z root INFO Backend ArduinoDaemonImpl.onStart: 0.9 ms [Finished 1.301 s after backend start]
2023-08-25T07:07:37.972Z root INFO Backend NodeFileUploadService.configure: 1.6 ms [Finished 1.302 s after backend start]
2023-08-25T07:07:37.972Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-08-25T07:07:37.972Z discovery-log INFO start
2023-08-25T07:07:37.972Z discovery-log INFO start new deferred
2023-08-25T07:07:37.972Z root INFO Backend HostedPluginLocalizationService.initialize: 0.4 ms [Finished 1.302 s after backend start]
2023-08-25T07:07:37.972Z root INFO Backend BoardDiscovery.onStart: 0.8 ms [Finished 1.303 s after backend start]
2023-08-25T07:07:37.972Z root INFO Backend FileDownloadEndpoint.configure: 0.7 ms [Finished 1.303 s after backend start]2023-08-25T07:07:37.972Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.304 s after backend start]
2023-08-25T07:07:37.972Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.304 s after backend start]
2023-08-25T07:07:37.973Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 1.305 s after backend start]
2023-08-25T07:07:37.973Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 1.305 s after backend start]
2023-08-25T07:07:37.974Z root INFO Backend PlotterBackendContribution.configure: 0.8 ms [Finished 1.306 s after backend start]
2023-08-25T07:07:37.977Z root INFO Theia app listening on http://localhost:60927.
2023-08-25T07:07:37.977Z root INFO Finished starting backend application: 5.0 ms [Finished 1.310 s after backend start]
2023-08-25T07:07:37.978Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Ronan/.arduinoIDE/plugins does not exist.
2023-08-25T07:07:37.979Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Ronan/.arduinoIDE/extensions does not exist.
2023-08-25T07:07:37.979Z root WARN The local plugin referenced by local-dir:C:\Users\Ronan\.arduinoIDE\plugins does not exist.
Restoring workspace roots: d:\Users\Ronan\Documents\Arduino\Blink\Blink.ino
isTempSketch: false. Input was d:\Users\Ronan\Documents\Arduino\Blink\Blink.ino
2023-08-25T07:07:37.994Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:37.994Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-08-25T07:07:37.995Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:37.996Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-08-25T07:07:37.996Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:37.997Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-08-25T07:07:37.997Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:37.997Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-08-25T07:07:37.998Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:37.999Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-08-25T07:07:38.000Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.000Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-08-25T07:07:38.001Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.001Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-08-25T07:07:38.002Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.003Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-08-25T07:07:38.003Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.003Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-08-25T07:07:38.004Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.004Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-08-25T07:07:38.009Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.009Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-08-25T07:07:38.009Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-08-25T07:07:38.009Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-08-25T07:07:38.009Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-08-25T07:07:38.010Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.010Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-08-25T07:07:38.011Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-08-25T07:07:38.011Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.012Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-08-25T07:07:38.015Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.018Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-08-25T07:07:38.019Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.019Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-08-25T07:07:38.020Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.022Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-08-25T07:07:38.022Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-25T07:07:38.023Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-08-25T07:07:38.027Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://adafruit.github.io/arduino-board-index/package_adafruit_index.json","https://downloads.arduino.cc/packages/package_index.json","https://github.com/adafruit/arduino-board-index/blob/gh-pages/package_adafruit_index.json","https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json","https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json","https://mcudude.github.io/MegaCore/package_MCUdude_MegaCore_index.json","https://mcudude.github.io/MegaCoreX/package_MCUdude_MegaCoreX_index.json","https://raw.githubusercontent.com/Longan-Labs/LONGAN-SAME-TOOLS/master/package_longan_samd_index.json","https://raw.githubusercontent.com/niladridmgit/CuriosityNiladriSAME51/master/package_curiosityniladri_same_index.json","https://raw.githubusercontent.com/niladridmgit/curiosityniladri/master/package_curiosityniladri_index.json","https://raw.githubusercontent.com/stm32duino/BoardManagerFiles/master/STM32/package_stm_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\Ronan\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\staging","user":"d:\\Users\\Ronan\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"fr","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"network":{"proxy":"http://_/","user_agent_ext":"daemon"},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-08-25T07:07:38.028Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-08-25T07:07:38.030Z config INFO Loaded the CLI configuration.
2023-08-25T07:07:38.042Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Ronan/AppData/Local/Arduino15","sketchDirUri":"file:///d%3A/Users/Ronan/Documents/Arduino","additionalUrls":["https://adafruit.github.io/arduino-board-index/package_adafruit_index.json","https://downloads.arduino.cc/packages/package_index.json","https://github.com/adafruit/arduino-board-index/blob/gh-pages/package_adafruit_index.json","https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json","https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json","https://mcudude.github.io/MegaCore/package_MCUdude_MegaCore_index.json","https://mcudude.github.io/MegaCoreX/package_MCUdude_MegaCoreX_index.json","https://raw.githubusercontent.com/Longan-Labs/LONGAN-SAME-TOOLS/master/package_longan_samd_index.json","https://raw.githubusercontent.com/niladridmgit/CuriosityNiladriSAME51/master/package_curiosityniladri_same_index.json","https://raw.githubusercontent.com/niladridmgit/curiosityniladri/master/package_curiosityniladri_index.json","https://raw.githubusercontent.com/stm32duino/BoardManagerFiles/master/STM32/package_stm_index.json"],"network":{"protocol":"http","hostname":"_","password":"","username":"","port":""},"locale":"fr"}
2023-08-25T07:07:38.043Z config INFO Validating the CLI configuration...
2023-08-25T07:07:38.044Z config INFO The CLI config is valid.
2023-08-25T07:07:38.044Z config INFO <<< Initialized the CLI configuration.
2023-08-25T07:07:38.052Z root INFO Resolve plugins list: 81.4 ms [Finished 1.385 s after backend start]
2023-08-25T07:07:38.056Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 3.2 ms [Finished 1.388 s after backend start]
2023-08-25T07:07:38.057Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 1.7 ms [Finished 1.390 s after backend start]
2023-08-25T07:07:38.064Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 6.6 ms [Finished 1.397 s after backend start]
2023-08-25T07:07:38.066Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.3 ms [Finished 1.399 s after backend start]
2023-08-25T07:07:38.067Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.5 ms [Finished 1.400 s after backend start]
2023-08-25T07:07:38.127Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 60.5 ms [Finished 1.460 s after backend start]
2023-08-25T07:07:38.141Z daemon INFO INFO[0000] Using config file: c:\Users\Ronan\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.3
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:60928
{"IP":"127.0.0.1","Port":"60928"}
2023-08-25T07:07:38.142Z daemon INFO Daemon is running.
2023-08-25T07:07:38.221Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 93.1 ms [Finished 1.553 s after backend start]
2023-08-25T07:07:38.225Z daemon INFO INFO[0000] Loading hardware from: c:\Users\Ronan\AppData\Local\Arduino15\packages
2023-08-25T07:07:38.306Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 85.0 ms [Finished 1.638 s after backend start]
2023-08-25T07:07:38.306Z daemon INFO INFO[0000] Loading package CuriosityNiladriSAME from: C:\Users\Ronan\AppData\Local\Arduino15\packages\CuriosityNiladriSAME\hardware
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="CuriosityNiladriSAME:same@1.0.0"
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\CuriosityNiladriSAME\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\CuriosityNiladriSAME\tools
INFO[0000] Loaded tool tool="CuriosityNiladriSAME:CMSIS@5.4.0"
INFO[0000] Loaded tool tool="CuriosityNiladriSAME:CMSIS-Atmel@1.2.1"
INFO[0000] Loaded tool tool="CuriosityNiladriSAME:arm-none-eabi-gcc@9-2019q4"
INFO[0000] Loading package Longan from: C:\Users\Ronan\AppData\Local\Arduino15\packages\Longan\hardware
INFO[0000] Loaded platform platform="Longan:samd@1.0.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\Longan\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\Longan\tools
INFO[0000] Loaded tool tool="Longan:CMSIS@5.4.0"
INFO[0000] Loaded tool tool="Longan:CMSIS-Atmel@1.2.1"
INFO[0000] Loaded tool tool="Longan:arm-none-eabi-gcc@9-2019q4"
INFO[0000] Loaded tool tool="Longan:bossac@1.9.2"
INFO[0000] Loading package STM32 from: C:\Users\Ronan\AppData\Local\Arduino15\packages\STM32\hardware
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\STM32\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\STM32\tools
INFO[0000] Loaded tool tool="STM32:CMSIS@5.5.1"
INFO[0000] Loaded tool tool="STM32:STM32Tools@1.4.0"
INFO[0000] Loaded tool tool="STM32:xpack-arm-none-eabi-gcc@9.2.1-1.1"
INFO[0000] Loading package STMicroelectronics from: C:\Users\Ronan\AppData\Local\Arduino15\packages\STMicroelectronics\hardware
INFO[0000] Loaded platform platform="STMicroelectronics:stm32@2.4.0"
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\STMicroelectronics\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\STMicroelectronics\tools
INFO[0000] Loaded tool tool="STMicroelectronics:CMSIS@5.7.0"
INFO[0000] Loaded tool tool="STMicroelectronics:STM32Tools@2.1.1"
INFO[0000] Loaded tool tool="STMicroelectronics:xpack-arm-none-eabi-gcc@10.3.1-2.3"
INFO[0000] Loading package adafruit from: C:\Users\Ronan\AppData\Local\Arduino15\packages\adafruit\hardware
INFO[0000] Loaded platform platform="adafruit:samd@1.7.10"
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\adafruit\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\adafruit\tools
INFO[0000] Loaded tool tool="adafruit:CMSIS@5.4.0"
INFO[0000] Loaded tool tool="adafruit:CMSIS-Atmel@1.2.2"
INFO[0000] Loaded tool tool="adafruit:arm-none-eabi-gcc@9-2019q4"
INFO[0000] Loaded tool tool="adafruit:bossac@1.8.0-48-gb176eee"
INFO[0000] Loading package arduino from: C:\Users\Ronan\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: Le fichier sp├®cifi├® est introuvable." index="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Loaded platform platform="arduino:megaavr@1.8.7"
INFO[0000] Loaded platform platform="arduino:renesas_uno@1.0.2"
INFO[0000] Loaded platform platform="arduino:sam@1.6.12"
INFO[0000] Loaded platform platform="arduino:samd@1.8.13"
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:CMSIS@4.5.0"
INFO[0000] Loaded tool tool="arduino:CMSIS-Atmel@1.2.0"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.2.1"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
INFO[0000] Loaded tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loaded tool tool="arduino:bossac@1.6.1-arduino"
INFO[0000] Loaded tool tool="arduino:bossac@1.7.0-arduino3"
INFO[0000] Loaded tool tool="arduino:bossac@1.8.0-48-gb176eee"
INFO[0000] Loaded tool tool="arduino:bossac@1.9.1-arduino5"
INFO[0000] Loaded tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0000] Loaded tool tool="arduino:openocd@0.10.0-arduino7"
INFO[0000] Loaded tool tool="arduino:openocd@0.11.0-arduino2"
INFO[0000] Loading package builtin from: C:\Users\Ronan\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.9.1"
INFO[0000] Loading package curiosityniladri from: C:\Users\Ronan\AppData\Local\Arduino15\packages\curiosityniladri\hardware
INFO[0000] Loaded platform platform="curiosityniladri:samd@1.1.0"
INFO[0000] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\curiosityniladri\tools
INFO[0000] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\curiosityniladri\tools
INFO[0000] Loaded tool tool="curiosityniladri:CMSIS@5.4.0"
INFO[0000] Loaded tool tool="curiosityniladri:arm-none-eabi-gcc@9-2019q4"
INFO[0000] Loading hardware from: d:\Users\Ronan\Documents\Arduino\hardware
INFO[0000] Loading package MegaCore-master from: D:\Users\Ronan\Documents\Arduino\hardware\MegaCore-master
INFO[0000] Loaded platform platform="MegaCore-master:avr@2.1.2"
INFO[0000] Loading package MegaCoreX-master from: D:\Users\Ronan\Documents\Arduino\hardware\MegaCoreX-master
INFO[0000] Loaded platform platform="MegaCoreX-master:megaavr@1.0.6"
INFO[0000] Checking signature index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig"
2023-08-25T07:07:38.312Z daemon INFO INFO[0000] Checking signature index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-08-25T07:07:38.370Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 63.9 ms [Finished 1.702 s after backend start]
2023-08-25T07:07:38.370Z daemon INFO INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig"
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig"
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_MCUdude_MegaCore_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_MCUdude_MegaCore_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_MCUdude_MegaCore_index.json.sig"
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_longan_samd_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_longan_samd_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_longan_samd_index.json.sig"
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_same_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_same_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_same_index.json.sig"
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_index.json.sig"
INFO[0000] Starting download url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2023-08-25T07:07:38.374Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\Ronan\AppData\Local\Arduino15\package_stm_index.json: open c:\Users\Ronan\AppData\Local\Arduino15\package_stm_index.json: Le fichier sp├®cifi├® est introuvable.
2023-08-25T07:07:38.374Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\Ronan\AppData\Local\Arduino15\package_MCUdude_MegaCoreX_index.json: open c:\Users\Ronan\AppData\Local\Arduino15\package_MCUdude_MegaCoreX_index.json: Le fichier sp├®cifi├® est introuvable.
2023-08-25T07:07:38.421Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 51.4 ms [Finished 1.754 s after backend start]
2023-08-25T07:07:38.454Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 32.9 ms [Finished 1.787 s after backend start]
2023-08-25T07:07:38.497Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 42.8 ms [Finished 1.830 s after backend start]
2023-08-25T07:07:38.539Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 41.8 ms [Finished 1.872 s after backend start]
2023-08-25T07:07:38.581Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 42.5 ms [Finished 1.914 s after backend start]
2023-08-25T07:07:38.598Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 17.0 ms [Finished 1.931 s after backend start]
2023-08-25T07:07:38.643Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 44.2 ms [Finished 1.975 s after backend start]
2023-08-25T07:07:38.685Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 42.9 ms [Finished 2.018 s after backend start]
2023-08-25T07:07:38.732Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 46.9 ms [Finished 2.065 s after backend start]
2023-08-25T07:07:38.773Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 40.6 ms [Finished 2.106 s after backend start]
2023-08-25T07:07:38.809Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 35.9 ms [Finished 2.142 s after backend start]
2023-08-25T07:07:38.850Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 40.6 ms [Finished 2.182 s after backend start]
2023-08-25T07:07:38.867Z root INFO Deploy plugins list: 81.4 ms [Finished 2.182 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-08-25T07:07:39.606Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 129.9 ms [Finished 1.565 s after frontend start]
2023-08-25T07:07:45.183Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:07:45.184Z daemon INFO INFO[0007] Starting download url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
2023-08-25T07:07:47.462Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:07:47.463Z daemon INFO INFO[0009] Starting download url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.13.0_Windows_64bit.zip"
2023-08-25T07:07:49.750Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.13.0 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.13.0_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:07:49.751Z daemon INFO INFO[0011] Starting download url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
2023-08-25T07:07:52.018Z daemon INFO INFO[0013] Loading tools from dir: c:\Users\Ronan\AppData\Local\Arduino15\packages\builtin\tools
2023-08-25T07:07:52.019Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:07:52.020Z daemon INFO INFO[0013] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0013] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0013] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0013] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0013] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0013] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0013] Loaded tool tool="builtin:serial-monitor@0.9.1"
2023-08-25T07:07:52.023Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:dfu-discovery not installed
2023-08-25T07:07:52.024Z daemon INFO INFO[0013] Adding libraries dir dir="D:\\Users\\Ronan\\Documents\\Arduino\\hardware\\MegaCore-master\\avr\\libraries" location=platform
2023-08-25T07:07:52.025Z daemon INFO INFO[0013] Adding libraries dir dir="D:\\Users\\Ronan\\Documents\\Arduino\\hardware\\MegaCoreX-master\\megaavr\\libraries" location=platform
2023-08-25T07:07:52.027Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.4.0\\libraries" location=platform
2023-08-25T07:07:52.030Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\Longan\\hardware\\samd\\1.0.6\\libraries" location=platform
2023-08-25T07:07:52.032Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.2\\libraries" location=platform
2023-08-25T07:07:52.034Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\libraries" location=platform
2023-08-25T07:07:52.037Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries" location=platform
2023-08-25T07:07:52.039Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
2023-08-25T07:07:52.041Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2023-08-25T07:07:52.044Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\CuriosityNiladriSAME\\hardware\\same\\1.0.0\\libraries" location=platform
2023-08-25T07:07:52.046Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\curiosityniladri\\hardware\\samd\\1.1.0\\libraries" location=platform
2023-08-25T07:07:52.049Z daemon INFO INFO[0013] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.10\\libraries" location=platform
INFO[0013] Loading libraries index file index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\library_index.json"
2023-08-25T07:07:52.149Z daemon INFO INFO[0014] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-08-25T07:07:52.150Z daemon INFO INFO[0014] Adding libraries dir dir="d:\\Users\\Ronan\\Documents\\Arduino\\libraries" location=user
2023-08-25T07:07:52.994Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-08-25T07:07:52.995Z daemon INFO INFO[0014] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-08-25T07:07:52.996Z daemon INFO INFO[0014] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-08-25T07:07:52.997Z root INFO core-client-provider [platform-index]
2023-08-25T07:07:55.270Z daemon INFO INFO[0017] Updating index url="https://adafruit.github.io/arduino-board-index/package_adafruit_index.json"
2023-08-25T07:07:55.271Z daemon INFO INFO[0017] Starting download url="https://adafruit.github.io/arduino-board-index/package_adafruit_index.json"
2023-08-25T07:07:55.272Z root INFO core-client-provider [platform-index]
2023-08-25T07:07:57.537Z daemon INFO INFO[0019] Updating index url="https://downloads.arduino.cc/packages/package_index.json"
2023-08-25T07:07:57.537Z daemon INFO INFO[0019] Starting download url="https://downloads.arduino.cc/packages/package_index.json"
2023-08-25T07:07:57.539Z root INFO core-client-provider [platform-index]
2023-08-25T07:07:59.818Z daemon INFO INFO[0021] Updating index url="https://github.com/adafruit/arduino-board-index/blob/gh-pages/package_adafruit_index.json"
2023-08-25T07:07:59.818Z daemon INFO INFO[0021] Starting download url="https://github.com/adafruit/arduino-board-index/blob/gh-pages/package_adafruit_index.json"
2023-08-25T07:07:59.820Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:06.646Z daemon INFO INFO[0028] Updating index url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
2023-08-25T07:08:06.647Z daemon INFO INFO[0028] Starting download url="https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json"
2023-08-25T07:08:06.649Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:08.930Z daemon INFO INFO[0030] Updating index url="https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json"
2023-08-25T07:08:08.930Z daemon INFO INFO[0030] Starting download url="https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json"
2023-08-25T07:08:08.933Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:11.200Z daemon INFO INFO[0033] Updating index url="https://mcudude.github.io/MegaCore/package_MCUdude_MegaCore_index.json"
2023-08-25T07:08:11.200Z daemon INFO INFO[0033] Starting download url="https://mcudude.github.io/MegaCore/package_MCUdude_MegaCore_index.json"
2023-08-25T07:08:11.203Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:13.474Z daemon INFO INFO[0035] Updating index url="https://mcudude.github.io/MegaCoreX/package_MCUdude_MegaCoreX_index.json"
2023-08-25T07:08:13.475Z daemon INFO INFO[0035] Starting download url="https://mcudude.github.io/MegaCoreX/package_MCUdude_MegaCoreX_index.json"
2023-08-25T07:08:13.476Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:15.763Z daemon INFO INFO[0037] Updating index url="https://raw.githubusercontent.com/Longan-Labs/LONGAN-SAME-TOOLS/master/package_longan_samd_index.json"
2023-08-25T07:08:15.764Z daemon INFO INFO[0037] Starting download url="https://raw.githubusercontent.com/Longan-Labs/LONGAN-SAME-TOOLS/master/package_longan_samd_index.json"
2023-08-25T07:08:15.765Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:18.041Z daemon INFO INFO[0039] Updating index url="https://raw.githubusercontent.com/niladridmgit/CuriosityNiladriSAME51/master/package_curiosityniladri_same_index.json"
2023-08-25T07:08:18.042Z daemon INFO INFO[0039] Starting download url="https://raw.githubusercontent.com/niladridmgit/CuriosityNiladriSAME51/master/package_curiosityniladri_same_index.json"
2023-08-25T07:08:18.042Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:20.329Z daemon INFO INFO[0042] Updating index url="https://raw.githubusercontent.com/niladridmgit/curiosityniladri/master/package_curiosityniladri_index.json"
2023-08-25T07:08:20.329Z daemon INFO INFO[0042] Starting download url="https://raw.githubusercontent.com/niladridmgit/curiosityniladri/master/package_curiosityniladri_index.json"
2023-08-25T07:08:20.332Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:27.168Z daemon INFO INFO[0049] Updating index url="https://raw.githubusercontent.com/stm32duino/BoardManagerFiles/master/STM32/package_stm_index.json"
2023-08-25T07:08:27.169Z daemon INFO INFO[0049] Starting download url="https://raw.githubusercontent.com/stm32duino/BoardManagerFiles/master/STM32/package_stm_index.json"
2023-08-25T07:08:27.169Z root INFO core-client-provider [platform-index]
2023-08-25T07:08:29.441Z root ERROR Failed to update platform indexes.
2023-08-25T07:08:29.442Z daemon INFO INFO[0051] Loading hardware from: c:\Users\Ronan\AppData\Local\Arduino15\packages
2023-08-25T07:08:29.444Z daemon INFO INFO[0051] Loading package CuriosityNiladriSAME from: C:\Users\Ronan\AppData\Local\Arduino15\packages\CuriosityNiladriSAME\hardware
2023-08-25T07:08:29.444Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="CuriosityNiladriSAME:same@1.0.0"
2023-08-25T07:08:29.445Z daemon INFO INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\CuriosityNiladriSAME\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\CuriosityNiladriSAME\tools
INFO[0051] Loaded tool tool="CuriosityNiladriSAME:CMSIS@5.4.0"
2023-08-25T07:08:29.445Z daemon INFO INFO[0051] Loaded tool tool="CuriosityNiladriSAME:CMSIS-Atmel@1.2.1"
INFO[0051] Loaded tool tool="CuriosityNiladriSAME:arm-none-eabi-gcc@9-2019q4"
2023-08-25T07:08:29.446Z daemon INFO INFO[0051] Loading package Longan from: C:\Users\Ronan\AppData\Local\Arduino15\packages\Longan\hardware
2023-08-25T07:08:29.446Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="Longan:samd@1.0.6"
2023-08-25T07:08:29.447Z daemon INFO INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\Longan\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\Longan\tools
2023-08-25T07:08:29.447Z daemon INFO INFO[0051] Loaded tool tool="Longan:CMSIS@5.4.0"
INFO[0051] Loaded tool tool="Longan:CMSIS-Atmel@1.2.1"
INFO[0051] Loaded tool tool="Longan:arm-none-eabi-gcc@9-2019q4"
2023-08-25T07:08:29.448Z daemon INFO INFO[0051] Loaded tool tool="Longan:bossac@1.9.2"
2023-08-25T07:08:29.448Z daemon INFO INFO[0051] Loading package STM32 from: C:\Users\Ronan\AppData\Local\Arduino15\packages\STM32\hardware
INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\STM32\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\STM32\tools
2023-08-25T07:08:29.449Z daemon INFO INFO[0051] Loaded tool tool="STM32:CMSIS@5.5.1"
INFO[0051] Loaded tool tool="STM32:STM32Tools@1.4.0"
INFO[0051] Loaded tool tool="STM32:xpack-arm-none-eabi-gcc@9.2.1-1.1"
2023-08-25T07:08:29.449Z daemon INFO INFO[0051] Loading package STMicroelectronics from: C:\Users\Ronan\AppData\Local\Arduino15\packages\STMicroelectronics\hardware
2023-08-25T07:08:29.461Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="STMicroelectronics:stm32@2.4.0"
2023-08-25T07:08:29.462Z daemon INFO INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\STMicroelectronics\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\STMicroelectronics\tools
INFO[0051] Loaded tool tool="STMicroelectronics:CMSIS@5.7.0"
INFO[0051] Loaded tool tool="STMicroelectronics:STM32Tools@2.1.1"
2023-08-25T07:08:29.463Z daemon INFO INFO[0051] Loaded tool tool="STMicroelectronics:xpack-arm-none-eabi-gcc@10.3.1-2.3"
2023-08-25T07:08:29.463Z daemon INFO INFO[0051] Loading package adafruit from: C:\Users\Ronan\AppData\Local\Arduino15\packages\adafruit\hardware
2023-08-25T07:08:29.465Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="adafruit:samd@1.7.10"
2023-08-25T07:08:29.466Z daemon INFO INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\adafruit\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\adafruit\tools
2023-08-25T07:08:29.466Z daemon INFO INFO[0051] Loaded tool tool="adafruit:CMSIS@5.4.0"
INFO[0051] Loaded tool tool="adafruit:CMSIS-Atmel@1.2.2"
INFO[0051] Loaded tool tool="adafruit:arm-none-eabi-gcc@9-2019q4"
2023-08-25T07:08:29.467Z daemon INFO INFO[0051] Loaded tool tool="adafruit:bossac@1.8.0-48-gb176eee"
INFO[0051] Loading package arduino from: C:\Users\Ronan\AppData\Local\Arduino15\packages\arduino\hardware
2023-08-25T07:08:29.473Z daemon INFO INFO[0051] Checking signature error="opening signature file: open C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: Le fichier sp├®cifi├® est introuvable." index="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
2023-08-25T07:08:29.474Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="arduino:avr@1.8.6"
2023-08-25T07:08:29.475Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="arduino:megaavr@1.8.7"
2023-08-25T07:08:29.476Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="arduino:renesas_uno@1.0.2"
INFO[0051] Loaded platform platform="arduino:sam@1.6.12"
2023-08-25T07:08:29.477Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="arduino:samd@1.8.13"
2023-08-25T07:08:29.478Z daemon INFO INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\arduino\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\arduino\tools
2023-08-25T07:08:29.478Z daemon INFO INFO[0051] Loaded tool tool="arduino:CMSIS@4.5.0"INFO[0051] Loaded tool tool="arduino:CMSIS-Atmel@1.2.0"
2023-08-25T07:08:29.479Z daemon INFO INFO[0051] Loaded tool tool="arduino:arduinoOTA@1.2.1"
INFO[0051] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0051] Loaded tool tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
INFO[0051] Loaded tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0051] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
2023-08-25T07:08:29.479Z daemon INFO INFO[0051] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0051] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0051] Loaded tool tool="arduino:bossac@1.6.1-arduino"
INFO[0051] Loaded tool tool="arduino:bossac@1.7.0-arduino3"
INFO[0051] Loaded tool tool="arduino:bossac@1.8.0-48-gb176eee"
INFO[0051] Loaded tool tool="arduino:bossac@1.9.1-arduino5"
2023-08-25T07:08:29.480Z daemon INFO INFO[0051] Loaded tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0051] Loaded tool tool="arduino:openocd@0.10.0-arduino7"
INFO[0051] Loaded tool tool="arduino:openocd@0.11.0-arduino2"
2023-08-25T07:08:29.480Z daemon INFO INFO[0051] Loading package builtin from: C:\Users\Ronan\AppData\Local\Arduino15\packages\builtin
INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\builtin\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\builtin\tools
2023-08-25T07:08:29.481Z daemon INFO INFO[0051] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0051] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0051] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0051] Loaded tool tool="builtin:serial-discovery@1.3.2"
2023-08-25T07:08:29.481Z daemon INFO INFO[0051] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0051] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0051] Loaded tool tool="builtin:serial-monitor@0.9.1"
2023-08-25T07:08:29.482Z daemon INFO INFO[0051] Loading package curiosityniladri from: C:\Users\Ronan\AppData\Local\Arduino15\packages\curiosityniladri\hardware
2023-08-25T07:08:29.482Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="curiosityniladri:samd@1.1.0"
2023-08-25T07:08:29.483Z daemon INFO INFO[0051] Checking existence of 'tools' path: C:\Users\Ronan\AppData\Local\Arduino15\packages\curiosityniladri\tools
INFO[0051] Loading tools from dir: C:\Users\Ronan\AppData\Local\Arduino15\packages\curiosityniladri\tools
INFO[0051] Loaded tool tool="curiosityniladri:CMSIS@5.4.0"
2023-08-25T07:08:29.483Z daemon INFO INFO[0051] Loaded tool tool="curiosityniladri:arm-none-eabi-gcc@9-2019q4"
INFO[0051] Loading hardware from: d:\Users\Ronan\Documents\Arduino\hardware
2023-08-25T07:08:29.484Z daemon INFO INFO[0051] Loading package MegaCore-master from: D:\Users\Ronan\Documents\Arduino\hardware\MegaCore-master
2023-08-25T07:08:29.486Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="MegaCore-master:avr@2.1.2"
2023-08-25T07:08:29.488Z daemon INFO INFO[0051] Loading package MegaCoreX-master from: D:\Users\Ronan\Documents\Arduino\hardware\MegaCoreX-master
2023-08-25T07:08:29.488Z daemon INFO INFO[0051] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0051] Loaded platform platform="MegaCoreX-master:megaavr@1.0.6"
2023-08-25T07:08:29.498Z daemon INFO INFO[0051] Checking signature index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-08-25T07:08:29.505Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig"
2023-08-25T07:08:29.514Z daemon INFO INFO[0051] Checking signature index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-08-25T07:08:29.521Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_adafruit_index.json.sig"
2023-08-25T07:08:29.526Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig"
2023-08-25T07:08:29.527Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\Ronan\AppData\Local\Arduino15\package_stm_index.json: open c:\Users\Ronan\AppData\Local\Arduino15\package_stm_index.json: Le fichier sp├®cifi├® est introuvable.
2023-08-25T07:08:29.532Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_MCUdude_MegaCore_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_MCUdude_MegaCore_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_MCUdude_MegaCore_index.json.sig"
2023-08-25T07:08:29.533Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\Ronan\AppData\Local\Arduino15\package_MCUdude_MegaCoreX_index.json: open c:\Users\Ronan\AppData\Local\Arduino15\package_MCUdude_MegaCoreX_index.json: Le fichier sp├®cifi├® est introuvable.
2023-08-25T07:08:29.537Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_longan_samd_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_longan_samd_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_longan_samd_index.json.sig"
2023-08-25T07:08:29.542Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_same_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_same_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_same_index.json.sig"
2023-08-25T07:08:29.547Z daemon INFO INFO[0051] Checking signature error="opening signature file: open c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_index.json.sig: Le fichier sp├®cifi├® est introuvable." index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_index.json" signatureFile="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\package_curiosityniladri_index.json.sig"
2023-08-25T07:08:29.549Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\Ronan\AppData\Local\Arduino15\package_stm_index.json: open c:\Users\Ronan\AppData\Local\Arduino15\package_stm_index.json: Le fichier sp├®cifi├® est introuvable.
2023-08-25T07:08:29.549Z daemon INFO INFO[0051] Starting download url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.13.0_Windows_64bit.zip"
2023-08-25T07:08:31.810Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.13.0 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.13.0_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
[7280:0825/090936.829:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
2023-08-25T07:09:49.861Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:09:49.863Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:09:49.863Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2023-08-25T07:09:49.864Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:dfu-discovery not installed
2023-08-25T07:09:49.865Z root ERROR Uncaught Exception:
2023-08-25T07:09:49.865Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:dfu-discovery not installed
at isIndexUpdateRequiredBeforeInit (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:388:11)
at CoreClientProvider.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:200:16)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async ClientReadableStreamImpl.<anonymous> (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:184:31)
2023-08-25T07:09:49.866Z daemon INFO INFO[0053] Starting download url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
INFO[0056] Starting download url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
INFO[0058] Starting download url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
INFO[0060] Loading tools from dir: c:\Users\Ronan\AppData\Local\Arduino15\packages\builtin\tools
INFO[0060] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0060] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0060] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0060] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0060] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0060] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0060] Loaded tool tool="builtin:serial-monitor@0.9.1"
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.4.0\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.2\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
INFO[0060] Adding libraries dir dir="D:\\Users\\Ronan\\Documents\\Arduino\\hardware\\MegaCoreX-master\\megaavr\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\Longan\\hardware\\samd\\1.0.6\\libraries" location=platform
INFO[0060] Adding libraries dir dir="D:\\Users\\Ronan\\Documents\\Arduino\\hardware\\MegaCore-master\\avr\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\curiosityniladri\\hardware\\samd\\1.1.0\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.10\\libraries" location=platform
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\packages\\CuriosityNiladriSAME\\hardware\\same\\1.0.0\\libraries" location=platform
INFO[0060] Loading libraries index file index="c:\\Users\\Ronan\\AppData\\Local\\Arduino15\\library_index.json"
INFO[0060] Adding libraries dir dir="C:\\Users\\Ronan\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0060] Adding libraries dir dir="d:\\Users\\Ronan\\Documents\\Arduino\\libraries" location=user
