PS C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 12412
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/U3I5LD7/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-08-09T12:19:37.492Z root INFO Backend Object.initialize: 5.7 ms [Finished 0.499 s after backend start]
2024-08-09T12:19:37.494Z root INFO Backend Object.configure: 4.5 ms [Finished 0.499 s after backend start]
2024-08-09T12:19:37.494Z root INFO Backend s.onStart: 2.4 ms [Finished 0.499 s after backend start]
2024-08-09T12:19:37.494Z root INFO Backend s.configure: 0.3 ms [Finished 0.521 s after backend start]
2024-08-09T12:19:37.495Z root INFO Backend d.onStart: 0.2 ms [Finished 0.521 s after backend start]
2024-08-09T12:19:37.495Z root INFO Backend d.configure: 0.1 ms [Finished 0.521 s after backend start]
2024-08-09T12:19:37.496Z root INFO Backend d.initialize: 21.6 ms [Finished 0.521 s after backend start]
2024-08-09T12:19:37.496Z root INFO Backend c.onStart: 0.2 ms [Finished 0.521 s after backend start]
2024-08-09T12:19:37.497Z root INFO Backend a.configure: 2.1 ms [Finished 0.523 s after backend start]
2024-08-09T12:19:37.498Z config INFO >>> Initializing CLI configuration...
2024-08-09T12:19:37.498Z root INFO Backend c.initialize: 0.4 ms [Finished 0.523 s after backend start]
2024-08-09T12:19:37.498Z root INFO Backend R.onStart: 0.6 ms [Finished 0.524 s after backend start]
2024-08-09T12:19:37.499Z config INFO Loading CLI configuration from c:\Users\U3I5LD7\.arduinoIDE\arduino-cli.yaml...
2024-08-09T12:19:37.499Z daemon INFO Starting daemon from C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-08-09T12:19:37.499Z root INFO Backend a.initialize: 0.3 ms [Finished 0.524 s after backend start]
2024-08-09T12:19:37.499Z root INFO Backend w.onStart: 1.1 ms [Finished 0.525 s after backend start]
2024-08-09T12:19:37.499Z root INFO Backend r.configure: 1.6 ms [Finished 0.525 s after backend start]
2024-08-09T12:19:37.499Z discovery-log INFO start
2024-08-09T12:19:37.499Z discovery-log INFO start new deferred
2024-08-09T12:19:37.500Z root INFO Backend d.initialize: 0.3 ms [Finished 0.526 s after backend start]
2024-08-09T12:19:37.500Z root INFO Backend y.onStart: 1.6 ms [Finished 0.527 s after backend start]
2024-08-09T12:19:37.500Z root INFO Backend r.configure: 1.5 ms [Finished 0.527 s after backend start]
2024-08-09T12:19:37.500Z root INFO Backend a.onStart: 0.4 ms [Finished 0.528 s after backend start]
2024-08-09T12:19:37.500Z root INFO Backend h.configure: 0.3 ms [Finished 0.528 s after backend start]
2024-08-09T12:19:37.500Z root INFO Backend s.configure: 0.1 ms [Finished 0.528 s after backend start]
2024-08-09T12:19:37.500Z root INFO Backend l.configure: 0.0 ms [Finished 0.528 s after backend start]
2024-08-09T12:19:37.502Z root INFO Theia app listening on http://127.0.0.1:64389.
2024-08-09T12:19:37.502Z root INFO Finished starting backend application: 2.2 ms [Finished 0.530 s after backend start]
2024-08-09T12:19:37.526Z root WARN The local plugin referenced by local-dir:/c%3A/Users/U3I5LD7/.arduinoIDE/plugins does not exist.
2024-08-09T12:19:37.526Z root WARN The local plugin referenced by local-dir:/c%3A/Users/U3I5LD7/.arduinoIDE/extensions does not exist.
2024-08-09T12:19:37.526Z root WARN The local plugin referenced by local-dir:C:\Users\U3I5LD7\.arduinoIDE\plugins does not exist.
2024-08-09T12:19:37.530Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\U3I5LD7\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\U3I5LD7\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\U3I5LD7\\OneDrive - Dr. Ing. h.c. F. Porsche AG\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-08-09T12:19:37.530Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-08-09T12:19:37.530Z config INFO Loaded the CLI configuration.
2024-08-09T12:19:37.536Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/U3I5LD7/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/U3I5LD7/OneDrive%20-%20Dr.%20Ing.%20h.c.%20F.%20Porsche%20AG/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-08-09T12:19:37.536Z config INFO Validating the CLI configuration...
2024-08-09T12:19:37.539Z config INFO The CLI config is valid.
2024-08-09T12:19:37.539Z config INFO <<< Initialized the CLI configuration.
2024-08-09T12:19:37.561Z root INFO Resolve plugins list: 62.4 ms [Finished 0.590 s after backend start]
2024-08-09T12:19:37.714Z daemon INFO time="2024-08-09T14:19:37+02:00" level=info msg="Using config file: c:\\Users\\U3I5LD7\\.arduinoIDE\\arduino-cli.yaml"
time="2024-08-09T14:19:37+02:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-08-09T14:19:37+02:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:64391
{"IP":"127.0.0.1","Port":"64391"}
2024-08-09T12:19:37.714Z daemon INFO Daemon is running.
2024-08-09T12:19:37.769Z root ERROR Uncaught Exception: Error: 13 INTERNAL: Received RST_STREAM with code 0
2024-08-09T12:19:37.769Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 0
at t.callErrorFromStatus (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
at Object.onReceiveStatus (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788777)
at Object.onReceiveStatus (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784657)
at Object.onReceiveStatus (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
at C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeUnaryRequest (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788318)
at s.create (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
at instance (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:621987)
at new Promise (<anonymous>)
at E.createClient (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:621964)
at E.create (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:620823)
at C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:619701
at C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1062813
at i.invoke (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1062903)
at s.fire (C:\Users\U3I5LD7\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1064706)
2024-08-09T12:19:38.464Z root INFO Deploy plugins list: 62.4 ms [Finished 1.493 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-08-09T12:19:39.156Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 138.1 ms [Finished 1.565 s after frontend start]
2024-08-09T12:19:39.156Z root WARN A command editor.action.toggleStickyScroll is already registered.
i think the error is here - 2024-08-09T12:19:37.769Z root ERROR Uncaught Exception: Error: 13 INTERNAL: Received RST_STREAM with code 0
could you help me out?
