PS C:\Users\equlibrino\AppData\Local\Programs\arduino-ide> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 27332
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/equlibrino/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-19T16:46:54.337Z root INFO Backend Object.initialize: 12.7 ms [Finished 1.281 s after backend start]
2024-03-19T16:46:54.346Z root INFO Backend Object.configure: 11.9 ms [Finished 1.281 s after backend start]
2024-03-19T16:46:54.346Z root INFO Backend s.onStart: 5.7 ms [Finished 1.281 s after backend start]
2024-03-19T16:46:54.348Z root INFO Backend s.configure: 0.6 ms [Finished 1.333 s after backend start]
2024-03-19T16:46:54.349Z root INFO Backend d.onStart: 0.4 ms [Finished 1.333 s after backend start]
2024-03-19T16:46:54.351Z root INFO Backend d.configure: 0.2 ms [Finished 1.333 s after backend start]
2024-03-19T16:46:54.353Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 51.4 ms [Finished 1.334 s after backend start]
2024-03-19T16:46:54.353Z root INFO Backend c.onStart: 0.5 ms [Finished 1.334 s after backend start]
2024-03-19T16:46:54.354Z root INFO Backend a.configure: 10.0 ms [Finished 1.344 s after backend start]
2024-03-19T16:46:54.357Z config INFO >>> Initializing CLI configuration...
2024-03-19T16:46:54.358Z root INFO Backend c.initialize: 1.4 ms [Finished 1.345 s after backend start]
2024-03-19T16:46:54.358Z root INFO Backend R.onStart: 2.4 ms [Finished 1.347 s after backend start]
2024-03-19T16:46:54.360Z config INFO Loading CLI configuration from c:\Users\equlibrino\.arduinoIDE\arduino-cli.yaml...
2024-03-19T16:46:54.361Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:54.361Z root INFO Backend a.initialize: 0.8 ms [Finished 1.348 s after backend start]
2024-03-19T16:46:54.361Z root INFO Backend w.onStart: 2.6 ms [Finished 1.350 s after backend start]
2024-03-19T16:46:54.361Z root INFO Backend r.configure: 4.0 ms [Finished 1.351 s after backend start]
2024-03-19T16:46:54.362Z discovery-log INFO start
2024-03-19T16:46:54.362Z discovery-log INFO start new deferred
2024-03-19T16:46:54.362Z root INFO Backend d.initialize: 1.1 ms [Finished 1.352 s after backend start]
2024-03-19T16:46:54.362Z root INFO Backend y.onStart: 4.0 ms [Finished 1.355 s after backend start]
2024-03-19T16:46:54.362Z root INFO Backend r.configure: 3.6 ms [Finished 1.356 s after backend start]
2024-03-19T16:46:54.362Z root INFO Backend a.onStart: 1.1 ms [Finished 1.359 s after backend start]
2024-03-19T16:46:54.362Z root INFO Backend h.configure: 0.9 ms [Finished 1.359 s after backend start]
2024-03-19T16:46:54.362Z root INFO Backend s.configure: 0.4 ms [Finished 1.359 s after backend start]
2024-03-19T16:46:54.362Z root INFO Backend l.configure: 0.2 ms [Finished 1.360 s after backend start]
2024-03-19T16:46:54.370Z root INFO Theia app listening on http://127.0.0.1:55705.
2024-03-19T16:46:54.370Z root INFO Finished starting backend application: 8.9 ms [Finished 1.368 s after backend start]
2024-03-19T16:46:54.392Z root WARN The local plugin referenced by local-dir:/c%3A/Users/equlibrino/.arduinoIDE/plugins does not exist.
2024-03-19T16:46:54.392Z root WARN The local plugin referenced by local-dir:/c%3A/Users/equlibrino/.arduinoIDE/extensions does not exist.
2024-03-19T16:46:54.393Z root WARN The local plugin referenced by local-dir:C:\Users\equlibrino\.arduinoIDE\plugins does not exist.
2024-03-19T16:46:54.407Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\equlibrino\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\equlibrino\\AppData\\Local\\Arduino15\\staging","user":"."},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-19T16:46:54.407Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-19T16:46:54.407Z config INFO Loaded the CLI configuration.
2024-03-19T16:46:54.412Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/equlibrino/AppData/Local/Arduino15","sketchDirUri":"file:///.","additionalUrls":[],"network":"none","locale":"en"}
2024-03-19T16:46:54.412Z config INFO Validating the CLI configuration...
2024-03-19T16:46:54.413Z config INFO The CLI config is valid.
2024-03-19T16:46:54.413Z config INFO <<< Initialized the CLI configuration.
2024-03-19T16:46:54.537Z root INFO Resolve plugins list: 177.9 ms [Finished 1.534 s after backend start]
2024-03-19T16:46:55.596Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:55.597Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
at Socket.<anonymous> (C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:43051)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-03-19T16:46:55.597Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:55.871Z daemon INFO time="2024-03-19T19:46:55+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:55.996Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:55.997Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.001Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:56.082Z daemon INFO time="2024-03-19T19:46:55+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:56.221Z daemon INFO time="2024-03-19T19:46:56+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:46:56+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-19T19:46:56+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:55706
{"IP":"127.0.0.1","Port":"55706"}
Daemon is now listening on 127.0.0.1:55707
{"IP":"127.0.0.1","Port":"55707"}
2024-03-19T16:46:56.325Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.365Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.365Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:56.464Z daemon INFO time="2024-03-19T19:46:56+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:56.466Z daemon INFO time="2024-03-19T19:46:56+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55708
{"IP":"127.0.0.1","Port":"55708"}
2024-03-19T16:46:56.562Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.562Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.562Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:56.666Z daemon INFO time="2024-03-19T19:46:56+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:56.729Z daemon INFO time="2024-03-19T19:46:56+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55709
{"IP":"127.0.0.1","Port":"55709"}
2024-03-19T16:46:56.827Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.830Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:56.830Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:56.995Z daemon INFO time="2024-03-19T19:46:56+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:56.995Z daemon INFO time="2024-03-19T19:46:56+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55710
{"IP":"127.0.0.1","Port":"55710"}
2024-03-19T16:46:57.008Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.009Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.009Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:57.377Z daemon INFO time="2024-03-19T19:46:57+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:57.377Z daemon INFO time="2024-03-19T19:46:57+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:46:57+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-19T19:46:57+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:55712
{"IP":"127.0.0.1","Port":"55712"}
2024-03-19T16:46:57.411Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.411Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.411Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:57.618Z daemon INFO time="2024-03-19T19:46:57+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:57.619Z daemon INFO time="2024-03-19T19:46:57+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55715
{"IP":"127.0.0.1","Port":"55715"}
2024-03-19T16:46:57.629Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.629Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.630Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:57.835Z daemon INFO time="2024-03-19T19:46:57+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:57.836Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.836Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:57.836Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:57.867Z daemon INFO time="2024-03-19T19:46:57+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55717
{"IP":"127.0.0.1","Port":"55717"}
2024-03-19T16:46:58.085Z daemon INFO time="2024-03-19T19:46:57+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:58.085Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.085Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.085Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:58.087Z daemon INFO time="2024-03-19T19:46:58+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:46:58+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-19T19:46:58+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:55718
{"IP":"127.0.0.1","Port":"55718"}
2024-03-19T16:46:58.219Z daemon INFO time="2024-03-19T19:46:58+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:58.336Z daemon INFO time="2024-03-19T19:46:58+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55719
{"IP":"127.0.0.1","Port":"55719"}
2024-03-19T16:46:58.337Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.337Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.337Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:58.583Z daemon INFO time="2024-03-19T19:46:58+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:58.584Z daemon INFO time="2024-03-19T19:46:58+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55720
{"IP":"127.0.0.1","Port":"55720"}
2024-03-19T16:46:58.716Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.717Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.717Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:58.826Z root INFO Deploy plugins list: 177.9 ms [Finished 5.823 s after backend start]
2024-03-19T16:46:58.874Z daemon INFO time="2024-03-19T19:46:58+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:58.916Z daemon INFO time="2024-03-19T19:46:58+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:46:58.917Z daemon INFO time="2024-03-19T19:46:58+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:46:58.918Z daemon INFO time="2024-03-19T19:46:58+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:46:58.922Z daemon INFO Daemon is now listening on 127.0.0.1:55721
{"IP":"127.0.0.1","Port":"55721"}
2024-03-19T16:46:58.952Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.953Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:58.953Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:59.101Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.101Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.101Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:59.128Z daemon INFO time="2024-03-19T19:46:58+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:59.212Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:46:59+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:46:59.213Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:46:59.216Z daemon INFO Daemon is now listening on 127.0.0.1:55722
{"IP":"127.0.0.1","Port":"55722"}
2024-03-19T16:46:59.276Z daemon INFO time="2024-03-19T19:46:59+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:59.314Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.315Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.315Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:59.338Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:46:59.338Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:46:59.339Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:46:59.340Z daemon INFO Daemon is now listening on 127.0.0.1:55723
{"IP":"127.0.0.1","Port":"55723"}
2024-03-19T16:46:59.476Z daemon INFO time="2024-03-19T19:46:59+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:59.585Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:46:59.586Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:46:59.586Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:46:59.590Z daemon INFO Daemon is now listening on 127.0.0.1:55724
{"IP":"127.0.0.1","Port":"55724"}
2024-03-19T16:46:59.610Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.610Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.610Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:59.737Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.737Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.737Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:46:59.787Z daemon INFO time="2024-03-19T19:46:59+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:46:59.833Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:46:59.833Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:46:59.834Z daemon INFO time="2024-03-19T19:46:59+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:46:59.836Z daemon INFO Daemon is now listening on 127.0.0.1:55725
{"IP":"127.0.0.1","Port":"55725"}
2024-03-19T16:46:59.904Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.905Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:46:59.905Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
Opening channel for service path '/services/electron-window'.
2024-03-19T16:46:59.975Z daemon INFO time="2024-03-19T19:46:59+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:00.045Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:47:00+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:00.046Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:00.049Z daemon INFO Daemon is now listening on 127.0.0.1:55726
{"IP":"127.0.0.1","Port":"55726"}
2024-03-19T16:47:00.125Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.125Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.125Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:00.125Z daemon INFO time="2024-03-19T19:46:59+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:00.187Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:00.188Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:00.189Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:00.191Z daemon INFO Daemon is now listening on 127.0.0.1:55727
{"IP":"127.0.0.1","Port":"55727"}
Opening channel for service path '/services/ide-updater'.
2024-03-19T16:47:00.312Z daemon INFO time="2024-03-19T19:47:00+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:00.334Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.334Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.334Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:00.378Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55728
{"IP":"127.0.0.1","Port":"55728"}
2024-03-19T16:47:00.547Z daemon INFO time="2024-03-19T19:47:00+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:00.588Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.588Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.589Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:00.636Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55730
{"IP":"127.0.0.1","Port":"55730"}
2024-03-19T16:47:00.879Z daemon INFO time="2024-03-19T19:47:00+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:00.906Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.907Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:00.907Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:00.929Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:00.934Z daemon INFO time="2024-03-19T19:47:00+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:00.936Z daemon INFO Daemon is now listening on 127.0.0.1:55732
{"IP":"127.0.0.1","Port":"55732"}
2024-03-19T16:47:01.082Z daemon INFO time="2024-03-19T19:47:00+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:01.084Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 641.4 ms [Finished 6.075 s after frontend start]
2024-03-19T16:47:01.102Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-19T16:47:01.111Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:01.111Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:01.111Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:01.152Z daemon INFO time="2024-03-19T19:47:01+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:01.152Z daemon INFO time="2024-03-19T19:47:01+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:01.152Z daemon INFO time="2024-03-19T19:47:01+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:01.238Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 117.1 ms [Finished 6.271 s after frontend start]
2024-03-19T16:47:01.353Z daemon INFO time="2024-03-19T19:47:01+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:01.400Z daemon INFO time="2024-03-19T19:47:01+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:01.405Z daemon INFO Daemon is now listening on 127.0.0.1:55733
{"IP":"127.0.0.1","Port":"55733"}
2024-03-19T16:47:01.407Z daemon INFO Daemon is now listening on 127.0.0.1:55734
{"IP":"127.0.0.1","Port":"55734"}
[7980:0319/194701.458:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+├Â"
2024-03-19T16:47:01.601Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:01.601Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:01.601Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:01.763Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 395.1 ms [Finished 6.831 s after frontend start]
2024-03-19T16:47:01.820Z daemon INFO time="2024-03-19T19:47:01+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:01.859Z daemon INFO time="2024-03-19T19:47:01+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:01.859Z daemon INFO time="2024-03-19T19:47:01+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:01.861Z daemon INFO Daemon is now listening on 127.0.0.1:55735
{"IP":"127.0.0.1","Port":"55735"}
2024-03-19T16:47:01.922Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:01.922Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:01.922Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.057Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.057Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.057Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.090Z daemon INFO time="2024-03-19T19:47:01+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:02.161Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:47:02+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:02.162Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:02.164Z daemon INFO Daemon is now listening on 127.0.0.1:55736
{"IP":"127.0.0.1","Port":"55736"}
2024-03-19T16:47:02.227Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.227Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.227Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.272Z daemon INFO time="2024-03-19T19:47:02+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:02.334Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:02.335Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:02.337Z daemon INFO Daemon is now listening on 127.0.0.1:55737
{"IP":"127.0.0.1","Port":"55737"}
2024-03-19T16:47:02.400Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.400Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.400Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.413Z daemon INFO time="2024-03-19T19:47:02+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:02.459Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:02.459Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:02.478Z daemon INFO Daemon is now listening on 127.0.0.1:55738
{"IP":"127.0.0.1","Port":"55738"}
2024-03-19T16:47:02.567Z daemon INFO time="2024-03-19T19:47:02+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:02.594Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.594Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.594Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.644Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:02.651Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:02.652Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:02.660Z daemon INFO Daemon is now listening on 127.0.0.1:55739
{"IP":"127.0.0.1","Port":"55739"}
2024-03-19T16:47:02.765Z daemon INFO time="2024-03-19T19:47:02+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:02.775Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.775Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.775Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.820Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:02.821Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:02.821Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:02.823Z daemon INFO Daemon is now listening on 127.0.0.1:55740
{"IP":"127.0.0.1","Port":"55740"}
2024-03-19T16:47:02.930Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.930Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:02.930Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:02.959Z daemon INFO time="2024-03-19T19:47:02+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.000Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:03.001Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:03.002Z daemon INFO time="2024-03-19T19:47:02+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:03.005Z daemon INFO Daemon is now listening on 127.0.0.1:55741
{"IP":"127.0.0.1","Port":"55741"}
2024-03-19T16:47:03.086Z daemon INFO time="2024-03-19T19:47:02+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.102Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.102Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.102Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:03.142Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:47:03+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:03.142Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:03.144Z daemon INFO Daemon is now listening on 127.0.0.1:55742
{"IP":"127.0.0.1","Port":"55742"}
2024-03-19T16:47:03.249Z daemon INFO time="2024-03-19T19:47:03+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.256Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.256Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.256Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:03.345Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:03.347Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:03.347Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:03.349Z daemon INFO Daemon is now listening on 127.0.0.1:55743
{"IP":"127.0.0.1","Port":"55743"}
2024-03-19T16:47:03.408Z daemon INFO time="2024-03-19T19:47:03+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.451Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.451Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.451Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:03.471Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55744
{"IP":"127.0.0.1","Port":"55744"}
2024-03-19T16:47:03.588Z daemon INFO time="2024-03-19T19:47:03+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.612Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.613Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.613Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:03.637Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55745
{"IP":"127.0.0.1","Port":"55745"}
2024-03-19T16:47:03.731Z daemon INFO time="2024-03-19T19:47:03+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.753Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.753Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.753Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:03.777Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:03.777Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:03.787Z daemon INFO Daemon is now listening on 127.0.0.1:55746
{"IP":"127.0.0.1","Port":"55746"}
2024-03-19T16:47:03.883Z daemon INFO time="2024-03-19T19:47:03+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:03.901Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.901Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:03.901Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:03.934Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:03.935Z daemon INFO time="2024-03-19T19:47:03+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:03.938Z daemon INFO Daemon is now listening on 127.0.0.1:55747
{"IP":"127.0.0.1","Port":"55747"}
2024-03-19T16:47:04.062Z daemon INFO time="2024-03-19T19:47:03+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:04.088Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.088Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.089Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:04.142Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:04.143Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:04.144Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:04.150Z daemon INFO Daemon is now listening on 127.0.0.1:55748
{"IP":"127.0.0.1","Port":"55748"}
2024-03-19T16:47:04.273Z daemon INFO time="2024-03-19T19:47:04+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:04.276Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.276Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.276Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:04.324Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:04.325Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:04.325Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:04.327Z daemon INFO Daemon is now listening on 127.0.0.1:55749
{"IP":"127.0.0.1","Port":"55749"}
2024-03-19T16:47:04.430Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.431Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.431Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:04.553Z daemon INFO time="2024-03-19T19:47:04+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:04.586Z daemon INFO time="2024-03-19T19:47:04+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:04.587Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.587Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.587Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:04.621Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:04.621Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:04.626Z daemon INFO Daemon is now listening on 127.0.0.1:55750
{"IP":"127.0.0.1","Port":"55750"}
2024-03-19T16:47:04.666Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:04.667Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:04.669Z daemon INFO Daemon is now listening on 127.0.0.1:55751
{"IP":"127.0.0.1","Port":"55751"}
2024-03-19T16:47:04.749Z daemon INFO time="2024-03-19T19:47:04+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:04.788Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.788Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.788Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:04.825Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:04.825Z daemon INFO time="2024-03-19T19:47:04+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:04.830Z daemon INFO Daemon is now listening on 127.0.0.1:55752
{"IP":"127.0.0.1","Port":"55752"}
2024-03-19T16:47:04.969Z daemon INFO time="2024-03-19T19:47:04+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:04.978Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.979Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:04.979Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.044Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:05.044Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:05.050Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:05.054Z daemon INFO Daemon is now listening on 127.0.0.1:55753
{"IP":"127.0.0.1","Port":"55753"}
2024-03-19T16:47:05.188Z daemon INFO time="2024-03-19T19:47:04+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:05.192Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.192Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.193Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.251Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:05.251Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:05.254Z daemon INFO Daemon is now listening on 127.0.0.1:55754
{"IP":"127.0.0.1","Port":"55754"}
2024-03-19T16:47:05.336Z daemon INFO time="2024-03-19T19:47:05+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:05.370Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.370Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.370Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.388Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55755
{"IP":"127.0.0.1","Port":"55755"}
2024-03-19T16:47:05.499Z daemon INFO time="2024-03-19T19:47:05+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:05.532Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.532Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.532Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.552Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55756
{"IP":"127.0.0.1","Port":"55756"}
2024-03-19T16:47:05.652Z daemon INFO time="2024-03-19T19:47:05+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:05.660Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.660Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.660Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.702Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:05.702Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:05.703Z daemon INFO Daemon is now listening on 127.0.0.1:55757
{"IP":"127.0.0.1","Port":"55757"}
2024-03-19T16:47:05.782Z daemon INFO time="2024-03-19T19:47:05+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:05.808Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.808Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.808Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.826Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55758
{"IP":"127.0.0.1","Port":"55758"}
2024-03-19T16:47:05.926Z daemon INFO time="2024-03-19T19:47:05+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:05.942Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.942Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:05.942Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:05.974Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:05.974Z daemon INFO time="2024-03-19T19:47:05+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:05.977Z daemon INFO Daemon is now listening on 127.0.0.1:55759
{"IP":"127.0.0.1","Port":"55759"}
2024-03-19T16:47:06.073Z daemon INFO time="2024-03-19T19:47:05+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:06.094Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.095Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.095Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:06.120Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:47:06+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:06.120Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:06.130Z daemon INFO Daemon is now listening on 127.0.0.1:55760
{"IP":"127.0.0.1","Port":"55760"}
2024-03-19T16:47:06.218Z daemon INFO time="2024-03-19T19:47:06+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:06.233Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.233Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.233Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:06.269Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:06.270Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:06.270Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:06.272Z daemon INFO Daemon is now listening on 127.0.0.1:55761
{"IP":"127.0.0.1","Port":"55761"}
2024-03-19T16:47:06.372Z daemon INFO time="2024-03-19T19:47:06+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:06.410Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.410Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.410Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:06.434Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55762
{"IP":"127.0.0.1","Port":"55762"}
2024-03-19T16:47:06.537Z daemon INFO time="2024-03-19T19:47:06+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:06.567Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.567Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.567Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:06.599Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:06.599Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:06.600Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:06.608Z daemon INFO Daemon is now listening on 127.0.0.1:55763
{"IP":"127.0.0.1","Port":"55763"}
2024-03-19T16:47:06.712Z daemon INFO time="2024-03-19T19:47:06+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:06.750Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.750Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.750Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:06.774Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55764
{"IP":"127.0.0.1","Port":"55764"}
2024-03-19T16:47:06.883Z daemon INFO time="2024-03-19T19:47:06+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:06.917Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.917Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:06.917Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:06.942Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:06.943Z daemon INFO time="2024-03-19T19:47:06+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:06.951Z daemon INFO Daemon is now listening on 127.0.0.1:55765
{"IP":"127.0.0.1","Port":"55765"}
2024-03-19T16:47:07.043Z daemon INFO time="2024-03-19T19:47:06+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:07.082Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.082Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.082Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:07.105Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:47:07+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-19T19:47:07+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:55766
{"IP":"127.0.0.1","Port":"55766"}
2024-03-19T16:47:07.221Z daemon INFO time="2024-03-19T19:47:07+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:07.242Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.242Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.242Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:07.306Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:07.307Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:07.308Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:07.310Z daemon INFO Daemon is now listening on 127.0.0.1:55767
{"IP":"127.0.0.1","Port":"55767"}
2024-03-19T16:47:07.435Z daemon INFO time="2024-03-19T19:47:07+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:07.482Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.483Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.483Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:07.532Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:07.535Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:07.536Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:07.540Z daemon INFO Daemon is now listening on 127.0.0.1:55769
{"IP":"127.0.0.1","Port":"55769"}
2024-03-19T16:47:07.674Z daemon INFO time="2024-03-19T19:47:07+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:07.674Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.675Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.675Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:07.740Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:07.741Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:07.742Z daemon INFO Daemon is now listening on 127.0.0.1:55770
{"IP":"127.0.0.1","Port":"55770"}
2024-03-19T16:47:07.834Z daemon INFO time="2024-03-19T19:47:07+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:07.869Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.870Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:07.870Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:07.899Z daemon INFO time="2024-03-19T19:47:07+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:55772
{"IP":"127.0.0.1","Port":"55772"}
2024-03-19T16:47:08.004Z daemon INFO time="2024-03-19T19:47:07+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:08.007Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:08.008Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:08.008Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:08.065Z daemon INFO time="2024-03-19T19:47:08+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-19T19:47:08+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:08.066Z daemon INFO time="2024-03-19T19:47:08+03:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-19T16:47:08.068Z daemon INFO Daemon is now listening on 127.0.0.1:55773
{"IP":"127.0.0.1","Port":"55773"}
2024-03-19T16:47:08.148Z daemon INFO time="2024-03-19T19:47:08+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:08.156Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:08.157Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:08.157Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-19T16:47:08.203Z daemon INFO time="2024-03-19T19:47:08+03:00" level=info msg="Using config file: c:\\Users\\equlibrino\\.arduinoIDE\\arduino-cli.yaml"
2024-03-19T16:47:08.204Z daemon INFO time="2024-03-19T19:47:08+03:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-19T16:47:08.206Z daemon INFO Daemon is now listening on 127.0.0.1:55774
{"IP":"127.0.0.1","Port":"55774"}
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
2024-03-19T16:47:08.343Z daemon INFO time="2024-03-19T19:47:08+03:00" level=warning msg="Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor."
2024-03-19T16:47:08.425Z daemon INFO Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:08.426Z daemon ERROR Error: Unable to get Documents Folder: Sistem belirtilen yolu bulam─▒yor.
2024-03-19T16:47:08.426Z daemon INFO Starting daemon from C:\Users\equlibrino\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
Hi @equlibrino.
On startup, Arduino IDE queries the Windows operating system for the location of your user "Documents" folder. The reason Arduino IDE is not starting is because when it makes this query Windows responds that the "Documents" folder doesn't exist. Since that folder should always exist, the IDE fails to start with this "Unable to get Documents Folder: ..." error.
Traditionally, the default location of the "Documents" folder was a path with this format:
C:\Users\<username>\Documents
(where <username> is your Windows username)
Although that is the default, it is possible to customize the location of this folder. If the location was changed to a drive that is not accessible (e.g., a USB drive that is unplugged), that could cause the "Unable to get Documents Folder: ..." error.
If you have the Windows "OneDrive folder syncing" feature enabled, the "Documents" folder is located under the OneDrive storage by default, at a path with this format:
C:\Users\<username>\OneDrive\Documents
(where the name of the Documents folder might actually be the localized equivalent)
It is also possible the folder could be located on alternative cloud storage providers (e.g., Dropbox.
When other users reported encountering this "Unable to get Documents Folder: ..." error, we often found that the problem was caused by them having disabled OneDrive in some manner, or else by them not having a connection to the OneDrive service.
Can you think of anything unusual about your system that might cause Arduino IDE to not be able to access your "Documents" folder?
thank you man
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
