IDE hangs on startup: "Unable to get Documents Folder"
After installing IDE 2.3.2 on W11 it only opens a window where the Arduino logo is flashing.
And Arduino steal all the memory on my computer.
After a while the screen goes black and computer freeze.
Did run it in powershield.
 at Socket.push (node:internal/streams/readable:234:10)
    at Pipe.onStreamRead (node:internal/stream_base_co^A  s:190:23)
2024-09-24T11:13:05.958Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:06.073Z daemon INFO time="2024-09-24T13:13:05+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:06.081Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-24T13:13:06+02:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-09-24T13:13:06+02:00" level=info msg="Executing `arduino-cli daemon`"
2024-09-24T11:13:06.082Z daemon INFO Daemon is now listening on 127.0.0.1:60585
{"IP":"127.0.0.1","Port":"60585"}
2024-09-24T11:13:06.116Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.116Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
    at Socket.<anonymous> (C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
    at Socket.emit (node:events:514:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-09-24T11:13:06.116Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:06.234Z daemon INFO time="2024-09-24T13:13:06+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:06.244Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:06.244Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Executing `arduino-cli daemon`"
2024-09-24T11:13:06.246Z daemon INFO Daemon is now listening on 127.0.0.1:60586
{"IP":"127.0.0.1","Port":"60586"}
2024-09-24T11:13:06.277Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.278Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.278Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:06.389Z daemon INFO time="2024-09-24T13:13:06+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:06.407Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:06.409Z daemon INFO Daemon is now listening on 127.0.0.1:60587
{"IP":"127.0.0.1","Port":"60587"}
2024-09-24T11:13:06.437Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.437Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.437Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:06.552Z daemon INFO time="2024-09-24T13:13:06+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:06.552Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:06.553Z daemon INFO Daemon is now listening on 127.0.0.1:60588
{"IP":"127.0.0.1","Port":"60588"}
2024-09-24T11:13:06.595Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.595Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.595Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:06.711Z daemon INFO time="2024-09-24T13:13:06+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:06.722Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:06.723Z daemon INFO Daemon is now listening on 127.0.0.1:60589
{"IP":"127.0.0.1","Port":"60589"}
2024-09-24T11:13:06.758Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.758Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.758Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:06.884Z daemon INFO time="2024-09-24T13:13:06+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:06.931Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.932Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:06.932Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:07.061Z daemon INFO time="2024-09-24T13:13:06+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:60590
{"IP":"127.0.0.1","Port":"60590"}
2024-09-24T11:13:07.061Z daemon INFO time="2024-09-24T13:13:06+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:07.088Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-24T13:13:07+02:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-09-24T11:13:07.088Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Executing `arduino-cli daemon`"
2024-09-24T11:13:07.089Z daemon INFO Daemon is now listening on 127.0.0.1:60591
{"IP":"127.0.0.1","Port":"60591"}
2024-09-24T11:13:07.104Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.104Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.104Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:07.222Z daemon INFO time="2024-09-24T13:13:07+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:07.223Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:60592
{"IP":"127.0.0.1","Port":"60592"}
2024-09-24T11:13:07.263Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.263Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.263Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:07.388Z daemon INFO time="2024-09-24T13:13:07+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:07.400Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:07.401Z daemon INFO Daemon is now listening on 127.0.0.1:60593
{"IP":"127.0.0.1","Port":"60593"}
2024-09-24T11:13:07.430Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.430Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.430Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:07.551Z daemon INFO time="2024-09-24T13:13:07+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:07.583Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:07.585Z daemon INFO Daemon is now listening on 127.0.0.1:60594
{"IP":"127.0.0.1","Port":"60594"}
2024-09-24T11:13:07.600Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.600Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.601Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:07.723Z daemon INFO time="2024-09-24T13:13:07+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:07.724Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
2024-09-24T11:13:07.724Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Executing `arduino-cli daemon`"
2024-09-24T11:13:07.725Z daemon INFO Daemon is now listening on 127.0.0.1:60595
{"IP":"127.0.0.1","Port":"60595"}
2024-09-24T11:13:07.767Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.767Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2024-09-24T11:13:07.768Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:07.889Z daemon INFO time="2024-09-24T13:13:07+02:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2024-09-24T11:13:07.889Z daemon INFO time="2024-09-24T13:13:07+02:00" level=info msg="Using config file: c:\\Users\\arild\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:60596
{"IP":"127.0.0.1","Port":"60596"}
2024-09-24T11:13:07.917Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:07.918Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:07.918Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.046Z daemon INFO runtime stack:
runtime.throw({0x1215ccb?, 0x0?})
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x4ef97ff8d0 sp=0x4ef97ff8a0 pc=0x74afe5
runtime.(*mheap).sysAlloc(0x1c2f040, 0x7fffd3efa4a8?, 0x1c3f400, 0x1)
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x4ef97ff980 sp=0x4ef97ff8d0 pc=0x71fa49
runtime.(*mheap).grow(0x1c2f040, 0x7fffd59b55a5?)
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x4ef97ffa00 sp=0x4ef97ff980 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xfb?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x4ef97ffaa0 sp=0x4ef97ffa00 pc=0x73ba50
runtime.(*mheap).alloc.func1()
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x4ef97ffae8 sp=0x4ef97ffaa0 pc=0x73b4dc
runtime.(*mheap).alloc(0x4ef97ffb88?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x4ef97ffb30 sp=0x4ef97ffae8 pc=0x73b43b
runtime.(*mcentral).grow(0x0?)
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x4ef97ffb70 sp=0x4ef97ffb30 pc=0x729df2
runtime.(*mcentral).cacheSpan(0x1c40980)
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x4ef97ffbc8 sp=0x4ef97ffb70 pc=0x729c66
runtime.(*mcache).refill(0x24d08190108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x4ef97ffc08 sp=0x4ef97ffbc8 pc=0x7293b3
runtime.(*mcache).nextFree(0x24d08190108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x4ef97ffc50 sp=0x4ef97ffc08 pc=0x720085
runtime.mallocgc(0xc0, 0x1076d20, 0x1)
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x4ef97ffcb8 sp=0x4ef97ffc50 pc=0x720648
runtime.newobject(0x4ef97ffd18?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x4ef97ffce0 sp=0x4ef97ffcb8 pc=0x720b85
internal/cpu.doinit()
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x4ef97ffd40 sp=0x4ef97ffce0 pc=0x71521e
internal/cpu.Initialize({0x0, 0x0})
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x4ef97ffd60 sp=0x4ef97ffd40 pc=0x714c7d
runtime.cpuinit(...)
        /usr/local/go/src/runtime/proc.go:639
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x4ef97ffda0 sp=0x4ef97ffd60 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x4ef97ffda8 sp=0x4ef97ffda0 pc=0x7790fc
2024-09-24T11:13:08.081Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.097Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.098Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.098Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.220Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xecbb3ff9c0 sp=0xecbb3ff990 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xecbb3ffa70 sp=0xecbb3ff9c0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xecbb3ffaf0 sp=0xecbb3ffa70 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xecbb3ffb90 sp=0xecbb3ffaf0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xecbb3ffbd8 sp=0xecbb3ffb90 pc=0x73b4dc
runtime.(*mheap).alloc(0xecbb3ffc78?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xecbb3ffc20 sp=0xecbb3ffbd8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xecbb3ffc60 sp=0xecbb3ffc20 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xecbb3ffcb8 sp=0xecbb3ffc60 pc=0x729c66
runtime.(*mcache).refill(0x2bf5cf50108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xecbb3ffcf8 sp=0xecbb3ffcb8 pc=0x7293b3
runtime.(*mcache).nextFree(0x2bf5cf50108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xecbb3ffd40 sp=0xecbb3ffcf8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xecbb3ffda8 sp=0xecbb3ffd40 pc=0x720648
runtime.newobject(0xecbb3ffe08?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xecbb3ffdd0 sp=0xecbb3ffda8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xecbb3ffe30 sp=0xecbb3ffdd0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xecbb3ffe50 sp=0xecbb3ffe30 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xecbb3ffe90 sp=0xecbb3ffe50 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xecbb3ffe98 sp=0xecbb3ffe90 pc=0x7790fc
2024-09-24T11:13:08.220Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.248Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.248Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.248Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.364Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x7f5fbff940 sp=0x7f5fbff910 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x7f5fbff9f0 sp=0x7f5fbff940 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x7f5fbffa70 sp=0x7f5fbff9f0 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x7f5fbffb10 sp=0x7f5fbffa70 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x7f5fbffb58 sp=0x7f5fbffb10 pc=0x73b4dc
runtime.(*mheap).alloc(0x7f5fbffbf8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x7f5fbffba0 sp=0x7f5fbffb58 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x7f5fbffbe0 sp=0x7f5fbffba0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x7f5fbffc38 sp=0x7f5fbffbe0 pc=0x729c66
runtime.(*mcache).refill(0x259d9390108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x7f5fbffc78 sp=0x7f5fbffc38 pc=0x7293b3
runtime.(*mcache).nextFree(0x259d9390108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x7f5fbffcc0 sp=0x7f5fbffc78 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x7f5fbffd28 sp=0x7f5fbffcc0 pc=0x720648
runtime.newobject(0x7f5fbffd88?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x7f5fbffd50 sp=0x7f5fbffd28 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x7f5fbffdb0 sp=0x7f5fbffd50 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x7f5fbffdd0 sp=0x7f5fbffdb0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x7f5fbffe10 sp=0x7f5fbffdd0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x7f5fbffe18 sp=0x7f5fbffe10 pc=0x7790fc
2024-09-24T11:13:08.365Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.392Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.392Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.393Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.506Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xd9e4fff260 sp=0xd9e4fff230 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xd9e4fff310 sp=0xd9e4fff260 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xd9e4fff390 sp=0xd9e4fff310 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xf4?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xd9e4fff430 sp=0xd9e4fff390 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xd9e4fff478 sp=0xd9e4fff430 pc=0x73b4dc
runtime.(*mheap).alloc(0xd9e4fff518?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xd9e4fff4c0 sp=0xd9e4fff478 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xd9e4fff500 sp=0xd9e4fff4c0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xd9e4fff558 sp=0xd9e4fff500 pc=0x729c66
runtime.(*mcache).refill(0x20787dc0108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xd9e4fff598 sp=0xd9e4fff558 pc=0x7293b3
runtime.(*mcache).nextFree(0x20787dc0108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xd9e4fff5e0 sp=0xd9e4fff598 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xd9e4fff648 sp=0xd9e4fff5e0 pc=0x720648
runtime.newobject(0xd9e4fff6a8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xd9e4fff670 sp=0xd9e4fff648 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xd9e4fff6d0 sp=0xd9e4fff670 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xd9e4fff6f0 sp=0xd9e4fff6d0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xd9e4fff730 sp=0xd9e4fff6f0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xd9e4fff738 sp=0xd9e4fff730 pc=0x7790fc
2024-09-24T11:13:08.506Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.537Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.537Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.537Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.651Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xc29bdff690 sp=0xc29bdff660 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xc29bdff740 sp=0xc29bdff690 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xc29bdff7c0 sp=0xc29bdff740 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xf8?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xc29bdff860 sp=0xc29bdff7c0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xc29bdff8a8 sp=0xc29bdff860 pc=0x73b4dc
runtime.(*mheap).alloc(0xc29bdff948?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xc29bdff8f0 sp=0xc29bdff8a8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xc29bdff930 sp=0xc29bdff8f0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xc29bdff988 sp=0xc29bdff930 pc=0x729c66
runtime.(*mcache).refill(0x1dfe4210108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xc29bdff9c8 sp=0xc29bdff988 pc=0x7293b3
runtime.(*mcache).nextFree(0x1dfe4210108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xc29bdffa10 sp=0xc29bdff9c8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xc29bdffa78 sp=0xc29bdffa10 pc=0x720648
runtime.newobject(0xc29bdffad8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xc29bdffaa0 sp=0xc29bdffa78 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xc29bdffb00 sp=0xc29bdffaa0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xc29bdffb20 sp=0xc29bdffb00 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xc29bdffb60 sp=0xc29bdffb20 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xc29bdffb68 sp=0xc29bdffb60 pc=0x7790fc
2024-09-24T11:13:08.651Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.678Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.678Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.678Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.794Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x6cca5ff500 sp=0x6cca5ff4d0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x6cca5ff5b0 sp=0x6cca5ff500 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x6cca5ff630 sp=0x6cca5ff5b0 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xf7?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x6cca5ff6d0 sp=0x6cca5ff630 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x6cca5ff718 sp=0x6cca5ff6d0 pc=0x73b4dc
runtime.(*mheap).alloc(0x6cca5ff7b8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x6cca5ff760 sp=0x6cca5ff718 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x6cca5ff7a0 sp=0x6cca5ff760 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x6cca5ff7f8 sp=0x6cca5ff7a0 pc=0x729c66
runtime.(*mcache).refill(0x231420a0108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x6cca5ff838 sp=0x6cca5ff7f8 pc=0x7293b3
runtime.(*mcache).nextFree(0x231420a0108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x6cca5ff880 sp=0x6cca5ff838 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x6cca5ff8e8 sp=0x6cca5ff880 pc=0x720648
runtime.newobject(0x6cca5ff948?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x6cca5ff910 sp=0x6cca5ff8e8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x6cca5ff970 sp=0x6cca5ff910 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x6cca5ff990 sp=0x6cca5ff970 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x6cca5ff9d0 sp=0x6cca5ff990 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x6cca5ff9d8 sp=0x6cca5ff9d0 pc=0x7790fc
2024-09-24T11:13:08.794Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.821Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.821Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.821Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:08.936Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x60d69ff7b0 sp=0x60d69ff780 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x60d69ff860 sp=0x60d69ff7b0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x60d69ff8e0 sp=0x60d69ff860 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xf9?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x60d69ff980 sp=0x60d69ff8e0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x60d69ff9c8 sp=0x60d69ff980 pc=0x73b4dc
runtime.(*mheap).alloc(0x60d69ffa68?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x60d69ffa10 sp=0x60d69ff9c8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x60d69ffa50 sp=0x60d69ffa10 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x60d69ffaa8 sp=0x60d69ffa50 pc=0x729c66
runtime.(*mcache).refill(0x20a87440108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x60d69ffae8 sp=0x60d69ffaa8 pc=0x7293b3
runtime.(*mcache).nextFree(0x20a87440108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x60d69ffb30 sp=0x60d69ffae8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x60d69ffb98 sp=0x60d69ffb30 pc=0x720648
runtime.newobject(0x60d69ffbf8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x60d69ffbc0 sp=0x60d69ffb98 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x60d69ffc20 sp=0x60d69ffbc0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x60d69ffc40 sp=0x60d69ffc20 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x60d69ffc80 sp=0x60d69ffc40 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x60d69ffc88 sp=0x60d69ffc80 pc=0x7790fc
2024-09-24T11:13:08.936Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:08.965Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.965Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:08.965Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.080Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x12201ff6d0 sp=0x12201ff6a0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x12201ff780 sp=0x12201ff6d0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x12201ff800 sp=0x12201ff780 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x12201ff8a0 sp=0x12201ff800 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x12201ff8e8 sp=0x12201ff8a0 pc=0x73b4dc
runtime.(*mheap).alloc(0x12201ff988?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x12201ff930 sp=0x12201ff8e8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x12201ff970 sp=0x12201ff930 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x12201ff9c8 sp=0x12201ff970 pc=0x729c66
runtime.(*mcache).refill(0x209cb460108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x12201ffa08 sp=0x12201ff9c8 pc=0x7293b3
runtime.(*mcache).nextFree(0x209cb460108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x12201ffa50 sp=0x12201ffa08 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x12201ffab8 sp=0x12201ffa50 pc=0x720648
runtime.newobject(0x12201ffb18?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x12201ffae0 sp=0x12201ffab8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x12201ffb40 sp=0x12201ffae0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x12201ffb60 sp=0x12201ffb40 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x12201ffba0 sp=0x12201ffb60 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x12201ffba8 sp=0x12201ffba0 pc=0x7790fc
2024-09-24T11:13:09.080Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:09.107Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:09.107Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:09.107Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.224Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x730d7ff990 sp=0x730d7ff960 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x730d7ffa40 sp=0x730d7ff990 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x730d7ffac0 sp=0x730d7ffa40 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x730d7ffb60 sp=0x730d7ffac0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x730d7ffba8 sp=0x730d7ffb60 pc=0x73b4dc
runtime.(*mheap).alloc(0x730d7ffc48?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x730d7ffbf0 sp=0x730d7ffba8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x730d7ffc30 sp=0x730d7ffbf0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x730d7ffc88 sp=0x730d7ffc30 pc=0x729c66
runtime.(*mcache).refill(0x228b7100108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x730d7ffcc8 sp=0x730d7ffc88 pc=0x7293b3
runtime.(*mcache).nextFree(0x228b7100108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x730d7ffd10 sp=0x730d7ffcc8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x730d7ffd78 sp=0x730d7ffd10 pc=0x720648
runtime.newobject(0x730d7ffdd8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x730d7ffda0 sp=0x730d7ffd78 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x730d7ffe00 sp=0x730d7ffda0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x730d7ffe20 sp=0x730d7ffe00 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x730d7ffe60 sp=0x730d7ffe20 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x730d7ffe68 sp=0x730d7ffe60 pc=0x7790fc
2024-09-24T11:13:09.225Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:09.252Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:09.252Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:09.252Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.391Z daemon ERROR Error: spawn UNKNOWN
    at ChildProcess.spawn (node:internal/child_process:413:11)
    at spawn (node:child_process:783:9)
    at w.spawnDaemonProcess (C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:42605)
    at async w.start (C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:41402)
    at async t.retry (C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1128353)
2024-09-24T11:13:09.391Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.392Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xde66dff710 sp=0xde66dff6e0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xde66dff7c0 sp=0xde66dff710 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xde66dff840 sp=0xde66dff7c0 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xde66dff8e0 sp=0xde66dff840 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xde66dff928 sp=0xde66dff8e0 pc=0x73b4dc
runtime.(*mheap).alloc(0xde66dff9c8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xde66dff970 sp=0xde66dff928 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xde66dff9b0 sp=0xde66dff970 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xde66dffa08 sp=0xde66dff9b0 pc=0x729c66
runtime.(*mcache).refill(0x28a65400108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xde66dffa48 sp=0xde66dffa08 pc=0x7293b3
runtime.(*mcache).nextFree(0x28a65400108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xde66dffa90 sp=0xde66dffa48 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xde66dffaf8 sp=0xde66dffa90 pc=0x720648
runtime.newobject(0xde66dffb58?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xde66dffb20 sp=0xde66dffaf8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xde66dffb80 sp=0xde66dffb20 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xde66dffba0 sp=0xde66dffb80 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xde66dffbe0 sp=0xde66dffba0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xde66dffbe8 sp=0xde66dffbe0 pc=0x7790fc
2024-09-24T11:13:09.392Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:09.505Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:09.505Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.619Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:09.619Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.714Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:09.714Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.807Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:09.807Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:09.908Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:09.908Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.020Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:10.020Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.139Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:10.139Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.251Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:10.251Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.366Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:10.366Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.477Z daemon ERROR Error: spawn UNKNOWN
2024-09-24T11:13:10.477Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.617Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:10.617Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:10.617Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.726Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x98be9ff510 sp=0x98be9ff4e0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x98be9ff5c0 sp=0x98be9ff510 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x98be9ff640 sp=0x98be9ff5c0 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x98be9ff6e0 sp=0x98be9ff640 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x98be9ff728 sp=0x98be9ff6e0 pc=0x73b4dc
runtime.(*mheap).alloc(0x98be9ff7c8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x98be9ff770 sp=0x98be9ff728 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x98be9ff7b0 sp=0x98be9ff770 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x98be9ff808 sp=0x98be9ff7b0 pc=0x729c66
runtime.(*mcache).refill(0x25002120108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x98be9ff848 sp=0x98be9ff808 pc=0x7293b3
runtime.(*mcache).nextFree(0x25002120108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x98be9ff890 sp=0x98be9ff848 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x98be9ff8f8 sp=0x98be9ff890 pc=0x720648
runtime.newobject(0x98be9ff958?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x98be9ff920 sp=0x98be9ff8f8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x98be9ff980 sp=0x98be9ff920 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x98be9ff9a0 sp=0x98be9ff980 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x98be9ff9e0 sp=0x98be9ff9a0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x98be9ff9e8 sp=0x98be9ff9e0 pc=0x7790fc
2024-09-24T11:13:10.727Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:10.751Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:10.751Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:10.751Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:10.868Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xeb379ff480 sp=0xeb379ff450 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xeb379ff530 sp=0xeb379ff480 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xeb379ff5b0 sp=0xeb379ff530 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xf6?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xeb379ff650 sp=0xeb379ff5b0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xeb379ff698 sp=0xeb379ff650 pc=0x73b4dc
runtime.(*mheap).alloc(0xeb379ff738?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xeb379ff6e0 sp=0xeb379ff698 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xeb379ff720 sp=0xeb379ff6e0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xeb379ff778 sp=0xeb379ff720 pc=0x729c66
runtime.(*mcache).refill(0x2e273c10108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xeb379ff7b8 sp=0xeb379ff778 pc=0x7293b3
runtime.(*mcache).nextFree(0x2e273c10108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xeb379ff800 sp=0xeb379ff7b8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xeb379ff868 sp=0xeb379ff800 pc=0x720648
runtime.newobject(0xeb379ff8c8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xeb379ff890 sp=0xeb379ff868 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xeb379ff8f0 sp=0xeb379ff890 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xeb379ff910 sp=0xeb379ff8f0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xeb379ff950 sp=0xeb379ff910 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xeb379ff958 sp=0xeb379ff950 pc=0x7790fc
2024-09-24T11:13:10.868Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:10.893Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:10.894Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:10.894Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.010Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xadb5dff660 sp=0xadb5dff630 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xadb5dff710 sp=0xadb5dff660 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xadb5dff790 sp=0xadb5dff710 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xadb5dff830 sp=0xadb5dff790 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xadb5dff878 sp=0xadb5dff830 pc=0x73b4dc
runtime.(*mheap).alloc(0xadb5dff918?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xadb5dff8c0 sp=0xadb5dff878 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xadb5dff900 sp=0xadb5dff8c0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xadb5dff958 sp=0xadb5dff900 pc=0x729c66
runtime.(*mcache).refill(0x2aa27ab0108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xadb5dff998 sp=0xadb5dff958 pc=0x7293b3
runtime.(*mcache).nextFree(0x2aa27ab0108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xadb5dff9e0 sp=0xadb5dff998 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xadb5dffa48 sp=0xadb5dff9e0 pc=0x720648
runtime.newobject(0xadb5dffaa8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xadb5dffa70 sp=0xadb5dffa48 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xadb5dffad0 sp=0xadb5dffa70 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xadb5dffaf0 sp=0xadb5dffad0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xadb5dffb30 sp=0xadb5dffaf0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xadb5dffb38 sp=0xadb5dffb30 pc=0x7790fc
2024-09-24T11:13:11.010Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.034Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.034Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.034Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.148Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x3f099ff7e0 sp=0x3f099ff7b0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x3f099ff890 sp=0x3f099ff7e0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x3f099ff910 sp=0x3f099ff890 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xfa?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x3f099ff9b0 sp=0x3f099ff910 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x3f099ff9f8 sp=0x3f099ff9b0 pc=0x73b4dc
runtime.(*mheap).alloc(0x3f099ffa98?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x3f099ffa40 sp=0x3f099ff9f8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x3f099ffa80 sp=0x3f099ffa40 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x3f099ffad8 sp=0x3f099ffa80 pc=0x729c66
runtime.(*mcache).refill(0x14d99d60108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x3f099ffb18 sp=0x3f099ffad8 pc=0x7293b3
runtime.(*mcache).nextFree(0x14d99d60108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x3f099ffb60 sp=0x3f099ffb18 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x3f099ffbc8 sp=0x3f099ffb60 pc=0x720648
runtime.newobject(0x3f099ffc28?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x3f099ffbf0 sp=0x3f099ffbc8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x3f099ffc50 sp=0x3f099ffbf0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x3f099ffc70 sp=0x3f099ffc50 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x3f099ffcb0 sp=0x3f099ffc70 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x3f099ffcb8 sp=0x3f099ffcb0 pc=0x7790fc
2024-09-24T11:13:11.148Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.172Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.172Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.172Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.287Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x8303bff790 sp=0x8303bff760 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x8303bff840 sp=0x8303bff790 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x8303bff8c0 sp=0x8303bff840 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x8303bff960 sp=0x8303bff8c0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x8303bff9a8 sp=0x8303bff960 pc=0x73b4dc
runtime.(*mheap).alloc(0x8303bffa48?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x8303bff9f0 sp=0x8303bff9a8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x8303bffa30 sp=0x8303bff9f0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x8303bffa88 sp=0x8303bffa30 pc=0x729c66
runtime.(*mcache).refill(0x1c305510108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x8303bffac8 sp=0x8303bffa88 pc=0x7293b3
runtime.(*mcache).nextFree(0x1c305510108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x8303bffb10 sp=0x8303bffac8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x8303bffb78 sp=0x8303bffb10 pc=0x720648
runtime.newobject(0x8303bffbd8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x8303bffba0 sp=0x8303bffb78 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x8303bffc00 sp=0x8303bffba0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x8303bffc20 sp=0x8303bffc00 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x8303bffc60 sp=0x8303bffc20 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x8303bffc68 sp=0x8303bffc60 pc=0x7790fc
2024-09-24T11:13:11.287Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.310Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.310Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.310Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.426Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x9aa3bff730 sp=0x9aa3bff700 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x9aa3bff7e0 sp=0x9aa3bff730 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x9aa3bff860 sp=0x9aa3bff7e0 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x9aa3bff900 sp=0x9aa3bff860 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x9aa3bff948 sp=0x9aa3bff900 pc=0x73b4dc
runtime.(*mheap).alloc(0x9aa3bff9e8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x9aa3bff990 sp=0x9aa3bff948 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x9aa3bff9d0 sp=0x9aa3bff990 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x9aa3bffa28 sp=0x9aa3bff9d0 pc=0x729c66
runtime.(*mcache).refill(0x28eb1800108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x9aa3bffa68 sp=0x9aa3bffa28 pc=0x7293b3
runtime.(*mcache).nextFree(0x28eb1800108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x9aa3bffab0 sp=0x9aa3bffa68 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x9aa3bffb18 sp=0x9aa3bffab0 pc=0x720648
runtime.newobject(0x9aa3bffb78?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x9aa3bffb40 sp=0x9aa3bffb18 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x9aa3bffba0 sp=0x9aa3bffb40 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x9aa3bffbc0 sp=0x9aa3bffba0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x9aa3bffc00 sp=0x9aa3bffbc0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x9aa3bffc08 sp=0x9aa3bffc00 pc=0x7790fc
2024-09-24T11:13:11.426Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.451Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.451Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.451Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.565Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xcea7dff890 sp=0xcea7dff860 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xcea7dff940 sp=0xcea7dff890 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xcea7dff9c0 sp=0xcea7dff940 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xcea7dffa60 sp=0xcea7dff9c0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xcea7dffaa8 sp=0xcea7dffa60 pc=0x73b4dc
runtime.(*mheap).alloc(0xcea7dffb48?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xcea7dffaf0 sp=0xcea7dffaa8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xcea7dffb30 sp=0xcea7dffaf0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xcea7dffb88 sp=0xcea7dffb30 pc=0x729c66
runtime.(*mcache).refill(0x2c133740108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xcea7dffbc8 sp=0xcea7dffb88 pc=0x7293b3
runtime.(*mcache).nextFree(0x2c133740108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xcea7dffc10 sp=0xcea7dffbc8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xcea7dffc78 sp=0xcea7dffc10 pc=0x720648
runtime.newobject(0xcea7dffcd8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xcea7dffca0 sp=0xcea7dffc78 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xcea7dffd00 sp=0xcea7dffca0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xcea7dffd20 sp=0xcea7dffd00 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xcea7dffd60 sp=0xcea7dffd20 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xcea7dffd68 sp=0xcea7dffd60 pc=0x7790fc
2024-09-24T11:13:11.565Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.589Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.589Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.589Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.700Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x4b00bff6b0 sp=0x4b00bff680 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x4b00bff760 sp=0x4b00bff6b0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x4b00bff7e0 sp=0x4b00bff760 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x4b00bff880 sp=0x4b00bff7e0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x4b00bff8c8 sp=0x4b00bff880 pc=0x73b4dc
runtime.(*mheap).alloc(0x4b00bff968?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x4b00bff910 sp=0x4b00bff8c8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x4b00bff950 sp=0x4b00bff910 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x4b00bff9a8 sp=0x4b00bff950 pc=0x729c66
runtime.(*mcache).refill(0x1e64f660108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x4b00bff9e8 sp=0x4b00bff9a8 pc=0x7293b3
runtime.(*mcache).nextFree(0x1e64f660108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x4b00bffa30 sp=0x4b00bff9e8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x4b00bffa98 sp=0x4b00bffa30 pc=0x720648
runtime.newobject(0x4b00bffaf8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x4b00bffac0 sp=0x4b00bffa98 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x4b00bffb20 sp=0x4b00bffac0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x4b00bffb40 sp=0x4b00bffb20 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x4b00bffb80 sp=0x4b00bffb40 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x4b00bffb88 sp=0x4b00bffb80 pc=0x7790fc
2024-09-24T11:13:11.700Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.724Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.724Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.724Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.840Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x73b91ff4f0 sp=0x73b91ff4c0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x73b91ff5a0 sp=0x73b91ff4f0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x73b91ff620 sp=0x73b91ff5a0 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x73b91ff6c0 sp=0x73b91ff620 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x73b91ff708 sp=0x73b91ff6c0 pc=0x73b4dc
runtime.(*mheap).alloc(0x73b91ff7a8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x73b91ff750 sp=0x73b91ff708 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x73b91ff790 sp=0x73b91ff750 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x73b91ff7e8 sp=0x73b91ff790 pc=0x729c66
runtime.(*mcache).refill(0x2408b810108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x73b91ff828 sp=0x73b91ff7e8 pc=0x7293b3
runtime.(*mcache).nextFree(0x2408b810108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x73b91ff870 sp=0x73b91ff828 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x73b91ff8d8 sp=0x73b91ff870 pc=0x720648
runtime.newobject(0x73b91ff938?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x73b91ff900 sp=0x73b91ff8d8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x73b91ff960 sp=0x73b91ff900 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x73b91ff980 sp=0x73b91ff960 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x73b91ff9c0 sp=0x73b91ff980 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x73b91ff9c8 sp=0x73b91ff9c0 pc=0x7790fc
2024-09-24T11:13:11.840Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.863Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.863Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.863Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:11.975Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x8bf25ff2d0 sp=0x8bf25ff2a0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x8bf25ff380 sp=0x8bf25ff2d0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x8bf25ff400 sp=0x8bf25ff380 pc=0x73c176
runtime.(*mheap).allocSpan(0x1c2f040, 0x1, 0x0, 0xf5?)
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x8bf25ff4a0 sp=0x8bf25ff400 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x8bf25ff4e8 sp=0x8bf25ff4a0 pc=0x73b4dc
runtime.(*mheap).alloc(0x8bf25ff588?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x8bf25ff530 sp=0x8bf25ff4e8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x8bf25ff570 sp=0x8bf25ff530 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x8bf25ff5c8 sp=0x8bf25ff570 pc=0x729c66
runtime.(*mcache).refill(0x1ee83990108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x8bf25ff608 sp=0x8bf25ff5c8 pc=0x7293b3
runtime.(*mcache).nextFree(0x1ee83990108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x8bf25ff650 sp=0x8bf25ff608 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x8bf25ff6b8 sp=0x8bf25ff650 pc=0x720648
runtime.newobject(0x8bf25ff718?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x8bf25ff6e0 sp=0x8bf25ff6b8 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x8bf25ff740 sp=0x8bf25ff6e0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x8bf25ff760 sp=0x8bf25ff740 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x8bf25ff7a0 sp=0x8bf25ff760 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x8bf25ff7a8 sp=0x8bf25ff7a0 pc=0x7790fc
2024-09-24T11:13:11.976Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:11.999Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.999Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:11.999Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.112Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xf52f7ff590 sp=0xf52f7ff560 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xf52f7ff640 sp=0xf52f7ff590 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xf52f7ff6c0 sp=0xf52f7ff640 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xf52f7ff760 sp=0xf52f7ff6c0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xf52f7ff7a8 sp=0xf52f7ff760 pc=0x73b4dc
runtime.(*mheap).alloc(0xf52f7ff848?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xf52f7ff7f0 sp=0xf52f7ff7a8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xf52f7ff830 sp=0xf52f7ff7f0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xf52f7ff888 sp=0xf52f7ff830 pc=0x729c66
runtime.(*mcache).refill(0x210c7bd0108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xf52f7ff8c8 sp=0xf52f7ff888 pc=0x7293b3
runtime.(*mcache).nextFree(0x210c7bd0108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xf52f7ff910 sp=0xf52f7ff8c8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xf52f7ff978 sp=0xf52f7ff910 pc=0x720648
runtime.newobject(0xf52f7ff9d8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xf52f7ff9a0 sp=0xf52f7ff978 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xf52f7ffa00 sp=0xf52f7ff9a0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xf52f7ffa20 sp=0xf52f7ffa00 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xf52f7ffa60 sp=0xf52f7ffa20 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xf52f7ffa68 sp=0xf52f7ffa60 pc=0x7790fc
2024-09-24T11:13:12.112Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:12.138Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.138Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.138Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.252Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xfbc3ff490 sp=0xfbc3ff460 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xfbc3ff540 sp=0xfbc3ff490 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xfbc3ff5c0 sp=0xfbc3ff540 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xfbc3ff660 sp=0xfbc3ff5c0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xfbc3ff6a8 sp=0xfbc3ff660 pc=0x73b4dc
runtime.(*mheap).alloc(0xfbc3ff748?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xfbc3ff6f0 sp=0xfbc3ff6a8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xfbc3ff730 sp=0xfbc3ff6f0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xfbc3ff788 sp=0xfbc3ff730 pc=0x729c66
runtime.(*mcache).refill(0x165fb930108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xfbc3ff7c8 sp=0xfbc3ff788 pc=0x7293b3
runtime.(*mcache).nextFree(0x165fb930108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xfbc3ff810 sp=0xfbc3ff7c8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xfbc3ff878 sp=0xfbc3ff810 pc=0x720648
runtime.newobject(0xfbc3ff8d8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xfbc3ff8a0 sp=0xfbc3ff878 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xfbc3ff900 sp=0xfbc3ff8a0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xfbc3ff920 sp=0xfbc3ff900 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xfbc3ff960 sp=0xfbc3ff920 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xfbc3ff968 sp=0xfbc3ff960 pc=0x7790fc
2024-09-24T11:13:12.252Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:12.278Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.278Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
    at Socket.<anonymous> (C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
    at Socket.emit (node:events:514:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Socket.push (node:internal/streams/readable:234:10)
    at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-09-24T11:13:12.278Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.392Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xee6abff660 sp=0xee6abff630 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xee6abff710 sp=0xee6abff660 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xee6abff790 sp=0xee6abff710 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xee6abff830 sp=0xee6abff790 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xee6abff878 sp=0xee6abff830 pc=0x73b4dc
runtime.(*mheap).alloc(0xee6abff918?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xee6abff8c0 sp=0xee6abff878 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xee6abff900 sp=0xee6abff8c0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xee6abff958 sp=0xee6abff900 pc=0x729c66
runtime.(*mcache).refill(0x2a07f060108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xee6abff998 sp=0xee6abff958 pc=0x7293b3
runtime.(*mcache).nextFree(0x2a07f060108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xee6abff9e0 sp=0xee6abff998 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xee6abffa48 sp=0xee6abff9e0 pc=0x720648
runtime.newobject(0xee6abffaa8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xee6abffa70 sp=0xee6abffa48 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xee6abffad0 sp=0xee6abffa70 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xee6abffaf0 sp=0xee6abffad0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xee6abffb30 sp=0xee6abffaf0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xee6abffb38 sp=0xee6abffb30 pc=0x7790fc
2024-09-24T11:13:12.392Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:12.419Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.419Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.419Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.534Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xe71f3ff420 sp=0xe71f3ff3f0 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xe71f3ff4d0 sp=0xe71f3ff420 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xe71f3ff550 sp=0xe71f3ff4d0 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xe71f3ff5f0 sp=0xe71f3ff550 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xe71f3ff638 sp=0xe71f3ff5f0 pc=0x73b4dc
runtime.(*mheap).alloc(0xe71f3ff6d8?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xe71f3ff680 sp=0xe71f3ff638 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xe71f3ff6c0 sp=0xe71f3ff680 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xe71f3ff718 sp=0xe71f3ff6c0 pc=0x729c66
runtime.(*mcache).refill(0x230c2180108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xe71f3ff758 sp=0xe71f3ff718 pc=0x7293b3
runtime.(*mcache).nextFree(0x230c2180108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xe71f3ff7a0 sp=0xe71f3ff758 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xe71f3ff808 sp=0xe71f3ff7a0 pc=0x720648
runtime.newobject(0xe71f3ff868?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xe71f3ff830 sp=0xe71f3ff808 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xe71f3ff890 sp=0xe71f3ff830 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xe71f3ff8b0 sp=0xe71f3ff890 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xe71f3ff8f0 sp=0xe71f3ff8b0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xe71f3ff8f8 sp=0xe71f3ff8f0 pc=0x7790fc
2024-09-24T11:13:12.534Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:12.560Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.560Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.560Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.674Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x396bbff860 sp=0x396bbff830 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0x396bbff910 sp=0x396bbff860 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0x396bbff990 sp=0x396bbff910 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x396bbffa30 sp=0x396bbff990 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x396bbffa78 sp=0x396bbffa30 pc=0x73b4dc
runtime.(*mheap).alloc(0x396bbffb18?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x396bbffac0 sp=0x396bbffa78 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x396bbffb00 sp=0x396bbffac0 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x396bbffb58 sp=0x396bbffb00 pc=0x729c66
runtime.(*mcache).refill(0x22a86900108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x396bbffb98 sp=0x396bbffb58 pc=0x7293b3
runtime.(*mcache).nextFree(0x22a86900108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x396bbffbe0 sp=0x396bbffb98 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x396bbffc48 sp=0x396bbffbe0 pc=0x720648
runtime.newobject(0x396bbffca8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x396bbffc70 sp=0x396bbffc48 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x396bbffcd0 sp=0x396bbffc70 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x396bbffcf0 sp=0x396bbffcd0 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x396bbffd30 sp=0x396bbffcf0 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x396bbffd38 sp=0x396bbffd30 pc=0x7790fc
2024-09-24T11:13:12.674Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:12.706Z daemon INFO fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.706Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2024-09-24T11:13:12.706Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.820Z daemon INFO runtime stack:
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0xaf8b7ff5a0 sp=0xaf8b7ff570 pc=0x74afe5
        /usr/local/go/src/runtime/malloc.go:741 +0x3e9 fp=0xaf8b7ff650 sp=0xaf8b7ff5a0 pc=0x71fa49
        /usr/local/go/src/runtime/mheap.go:1483 +0x76 fp=0xaf8b7ff6d0 sp=0xaf8b7ff650 pc=0x73c176
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0xaf8b7ff770 sp=0xaf8b7ff6d0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0xaf8b7ff7b8 sp=0xaf8b7ff770 pc=0x73b4dc
runtime.(*mheap).alloc(0xaf8b7ff858?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0xaf8b7ff800 sp=0xaf8b7ff7b8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0xaf8b7ff840 sp=0xaf8b7ff800 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0xaf8b7ff898 sp=0xaf8b7ff840 pc=0x729c66
runtime.(*mcache).refill(0x26285890108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0xaf8b7ff8d8 sp=0xaf8b7ff898 pc=0x7293b3
runtime.(*mcache).nextFree(0x26285890108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0xaf8b7ff920 sp=0xaf8b7ff8d8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0xaf8b7ff988 sp=0xaf8b7ff920 pc=0x720648
runtime.newobject(0xaf8b7ff9e8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0xaf8b7ff9b0 sp=0xaf8b7ff988 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0xaf8b7ffa10 sp=0xaf8b7ff9b0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0xaf8b7ffa30 sp=0xaf8b7ffa10 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0xaf8b7ffa70 sp=0xaf8b7ffa30 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0xaf8b7ffa78 sp=0xaf8b7ffa70 pc=0x7790fc
2024-09-24T11:13:12.820Z daemon INFO Daemon exited with exit code: 2.
2024-09-24T11:13:12.846Z daemon INFO fatal error: pageAlloc: out of memory
2024-09-24T11:13:12.847Z daemon ERROR Error: fatal error: pageAlloc: out of memory
2024-09-24T11:13:12.847Z daemon INFO Starting daemon from C:\Users\arild\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T11:13:12.969Z daemon INFO runtime stack:
runtime.throw({0x120028d?, 0xc000000000?})
        /usr/local/go/src/runtime/panic.go:1077 +0x65 fp=0x53d55ff7e8 sp=0x53d55ff7b8 pc=0x74afe5
runtime.(*pageAlloc).grow(0x1c2f048, 0x400000?, 0x400000)
        /usr/local/go/src/runtime/mpagealloc.go:406 +0x25c fp=0x53d55ff860 sp=0x53d55ff7e8 pc=0x73dc7c
runtime.(*mheap).grow(0x1c2f040?, 0x7fffd59b55a5?)
        /usr/local/go/src/runtime/mheap.go:1543 +0x285 fp=0x53d55ff8e0 sp=0x53d55ff860 pc=0x73c385
        /usr/local/go/src/runtime/mheap.go:1250 +0x1b0 fp=0x53d55ff980 sp=0x53d55ff8e0 pc=0x73ba50
        /usr/local/go/src/runtime/mheap.go:968 +0x5c fp=0x53d55ff9c8 sp=0x53d55ff980 pc=0x73b4dc
runtime.(*mheap).alloc(0x53d55ffa68?, 0x77aeea?, 0x76?)
        /usr/local/go/src/runtime/mheap.go:962 +0x5b fp=0x53d55ffa10 sp=0x53d55ff9c8 pc=0x73b43b
        /usr/local/go/src/runtime/mcentral.go:246 +0x52 fp=0x53d55ffa50 sp=0x53d55ffa10 pc=0x729df2
        /usr/local/go/src/runtime/mcentral.go:166 +0x306 fp=0x53d55ffaa8 sp=0x53d55ffa50 pc=0x729c66
runtime.(*mcache).refill(0x1dd16e40108, 0x80?)
        /usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x53d55ffae8 sp=0x53d55ffaa8 pc=0x7293b3
runtime.(*mcache).nextFree(0x1dd16e40108, 0x1c)
        /usr/local/go/src/runtime/malloc.go:925 +0x85 fp=0x53d55ffb30 sp=0x53d55ffae8 pc=0x720085
        /usr/local/go/src/runtime/malloc.go:1112 +0x448 fp=0x53d55ffb98 sp=0x53d55ffb30 pc=0x720648
runtime.newobject(0x53d55ffbf8?)
        /usr/local/go/src/runtime/malloc.go:1324 +0x25 fp=0x53d55ffbc0 sp=0x53d55ffb98 pc=0x720b85
        /usr/local/go/src/internal/cpu/cpu_x86.go:51 +0x1e fp=0x53d55ffc20 sp=0x53d55ffbc0 pc=0x71521e
        /usr/local/go/src/internal/cpu/cpu.go:125 +0x1d fp=0x53d55ffc40 sp=0x53d55ffc20 pc=0x714c7d
runtime.schedinit()
        /usr/local/go/src/runtime/proc.go:729 +0x9d fp=0x53d55ffc80 sp=0x53d55ffc40 pc=0x74e73d
runtime.rt0_go()
        /usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x53d55ffc88 sp=0x53d55ffc80 pc=0x7790fc
Hi @arildbern.
On startup, Arduino IDE queries the Windows operating system for the location of your user "Documents" folder. The reason Arduino IDE is not starting is because when it makes this query Windows responds that the "Documents" folder doesn't exist. Since that folder should always exist, the IDE fails to start with this "Unable to get Documents Folder: ..." error.
Traditionally, the default location of the "Documents" folder was a path with this format:
C:\Users\<username>\Documents
(where <username> is your Windows username)
Although that is the default, it is possible to customize the location of this folder. If the location was changed to a drive that is not accessible (e.g., a USB drive that is unplugged), that could cause the "Unable to get Documents Folder: ..." error.
If you have the Windows "OneDrive folder syncing" feature enabled, the "Documents" folder is located under the OneDrive storage by default, at a path with this format:
C:\Users\<username>\OneDrive\Documents
(where the name of the Documents folder might actually be the localized equivalent)
It is also possible the folder could be located on alternative cloud storage providers (e.g., Dropbox.
When other users reported encountering this "Unable to get Documents Folder: ..." error, we often found that the problem was caused by them having disabled OneDrive in some manner, or else by them not having a connection to the OneDrive service.
Can you think of anything unusual about your system that might cause Arduino IDE to not be able to access your "Documents" folder?
I dont have a "Documents" folder in C:\User
But i have one documents folder in OneDrive yes. This is an empty folder.
I tried installing on D: but to no avail.
I dont know how to fix this.
You can try the following procedure to correct the configuration of the "Documents" folder:
  1. Start Windows "File Explorer".
  2. Right click on the "Documents" folder.
    A context menu will open.
  3. Select "Properties" from the menu.
    The "Documents Properties" dialog will open.
  4. Select the "Location" tab in the "Documents Properties" dialog.
  5. Click the "Restore Default" button.
  6. Verify that the path shown in the field now has the following format:
  7. Click the "OK" button.
    The "Documents Properties" dialog will close.
Make sure OneDrive is running, and configured so as Documents is always on your HD as well as in the cloud.
I think another option is to turn off OneDrive if you don;t need that functionality.
It took me a while to get it working and I don't remember the steps but it can be done.
I cant find "Location" tab in the in Document properties. And am i suppose to use the document folder in OneDrive?
That says D:\OneDrive
My current installation location is C:\Users\arild\AppData\Local\Programs\Arduino IDE
I created a "NEW FOLDER", called it "Documents" in C:\Users<username>\Documents
Its working :slight_smile:
It may be working for that scenario, but now you have two Documents folders. Good luck.
