PS C:\Users\andre\AppData\Local\Programs\arduino-ide> &".\Arduino IDE"
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Users\andre\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\andre\AppData\Local\Programs\arduino-ide\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 7000
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/andre/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-09-03T14:00:25.343Z root INFO Backend Object.initialize: 14.2 ms [Finished 0.864 s after backend start]
2023-09-03T14:00:25.343Z root INFO Backend Object.configure: 13.2 ms [Finished 0.864 s after backend start]
2023-09-03T14:00:25.344Z root INFO Backend a.onStart: 1.8 ms [Finished 0.864 s after backend start]
2023-09-03T14:00:25.345Z root INFO Backend a.configure: 0.4 ms [Finished 0.900 s after backend start]
2023-09-03T14:00:25.348Z root INFO Backend u.onStart: 0.3 ms [Finished 0.900 s after backend start]
2023-09-03T14:00:25.350Z root INFO Backend d.configure: 0.1 ms [Finished 0.901 s after backend start]
2023-09-03T14:00:25.358Z root INFO Backend d.initialize: 36.6 ms [Finished 0.901 s after backend start]
2023-09-03T14:00:25.363Z root INFO Backend c.onStart: 0.3 ms [Finished 0.901 s after backend start]
2023-09-03T14:00:25.365Z root INFO Backend s.configure: 1.8 ms [Finished 0.903 s after backend start]
2023-09-03T14:00:25.373Z config INFO >>> Initializing CLI configuration...
2023-09-03T14:00:25.374Z root INFO Backend c.initialize: 0.7 ms [Finished 0.903 s after backend start]
2023-09-03T14:00:25.383Z root INFO Backend P.onStart: 3.3 ms [Finished 0.906 s after backend start]
2023-09-03T14:00:25.384Z config INFO Loading CLI configuration from c:\Users\andre\.arduinoIDE\arduino-cli.yaml...
2023-09-03T14:00:25.398Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2023-09-03T14:00:25.398Z root INFO Backend s.initialize: 0.4 ms [Finished 0.908 s after backend start]
2023-09-03T14:00:25.399Z root INFO Backend w.onStart: 8.6 ms [Finished 0.916 s after backend start]
2023-09-03T14:00:25.405Z root INFO Backend r.configure: 14.9 ms [Finished 0.921 s after backend start]
2023-09-03T14:00:25.407Z discovery-log INFO start
2023-09-03T14:00:25.415Z discovery-log INFO start new deferred
2023-09-03T14:00:25.420Z root INFO Backend d.initialize: 0.5 ms [Finished 0.924 s after backend start]
2023-09-03T14:00:25.420Z root INFO Backend y.onStart: 9.0 ms [Finished 0.932 s after backend start]
2023-09-03T14:00:25.430Z root INFO Backend r.configure: 12.3 ms [Finished 0.941 s after backend start]
2023-09-03T14:00:25.433Z root INFO Backend s.onStart: 1.0 ms [Finished 0.957 s after backend start]
2023-09-03T14:00:25.434Z root INFO Backend h.configure: 1.8 ms [Finished 0.958 s after backend start]
2023-09-03T14:00:25.438Z root INFO Backend a.configure: 13.3 ms [Finished 0.979 s after backend start]
2023-09-03T14:00:25.443Z root INFO Backend s.configure: 0.1 ms [Finished 0.991 s after backend start]
2023-09-03T14:00:25.444Z root INFO Backend l.configure: 0.1 ms [Finished 0.997 s after backend start]
2023-09-03T14:00:25.454Z root INFO Theia app listening on http://localhost:62237.
2023-09-03T14:00:25.458Z root INFO Finished starting backend application: 47.1 ms [Finished 1.013 s after backend start]
2023-09-03T14:00:25.482Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/plugins does not exist.
2023-09-03T14:00:25.492Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/extensions does not exist.
2023-09-03T14:00:25.506Z root WARN The local plugin referenced by local-dir:C:\Users\andre\.arduinoIDE\plugins does not exist.
2023-09-03T14:00:25.624Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\andre\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\andre\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\andre\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\andre\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"nl","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-09-03T14:00:25.639Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-09-03T14:00:25.686Z config INFO Loaded the CLI configuration.
2023-09-03T14:00:25.846Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/andre/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/andre/Documents/Arduino","additionalUrls":[],"network":"none","locale":"nl"}
2023-09-03T14:00:25.889Z config INFO Validating the CLI configuration...
2023-09-03T14:00:25.905Z config INFO The CLI config is valid.
2023-09-03T14:00:25.943Z config INFO <<< Initialized the CLI configuration.
2023-09-03T14:00:26.103Z root INFO Resolve plugins list: 719.1 ms [Finished 1.661 s after backend start]
2023-09-03T14:00:27.349Z daemon INFO time="2023-09-03T16:00:27+02:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-09-03T16:00:27+02:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-09-03T16:00:27+02:00" level=info msg="Executing `arduino-cli daemon`"
2023-09-03T14:00:27.489Z daemon INFO Daemon is now listening on 127.0.0.1:62242
{"IP":"127.0.0.1","Port":"62242"}
2023-09-03T14:00:27.501Z daemon INFO Daemon is running.
2023-09-03T14:00:27.791Z daemon INFO time="2023-09-03T16:00:27+02:00" level=info msg="Checking signature" index="c:\\Users\\andre\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\andre\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2023-09-03T16:00:27+02:00" level=info msg="Loading hardware from: c:\\Users\\andre\\AppData\\Local\\Arduino15\\packages"
time="2023-09-03T16:00:27+02:00" level=info msg="Loading package arduino from: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2023-09-03T14:00:27.808Z daemon INFO time="2023-09-03T16:00:27+02:00" level=info msg="Missing signature file" index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2023-09-03T16:00:27+02:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2023-09-03T16:00:27+02:00" level=info msg="Missing signature file" index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
2023-09-03T14:00:27.857Z daemon INFO time="2023-09-03T16:00:27+02:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
2023-09-03T14:00:28.002Z daemon INFO time="2023-09-03T16:00:27+02:00" level=info msg="Missing signature file" index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.2\\installed.json"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.0.2"
time="2023-09-03T16:00:27+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-09-03T16:00:27+02:00" level=info msg="Loading tools from dir: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2023-09-03T16:00:27+02:00" level=info msg="Loading package builtin from: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2023-09-03T16:00:27+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-09-03T16:00:27+02:00" level=info msg="Loading tools from dir: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2023-09-03T16:00:27+02:00" level=info msg="Loading package emoro from: C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\emoro\\hardware"
time="2023-09-03T16:00:27+02:00" level=info msg="Missing signature file" index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\emoro\\hardware\\avr\\3.2.2\\installed.json"
time="2023-09-03T16:00:27+02:00" level=info msg="Loaded platform" platform="emoro:avr@3.2.2"
time="2023-09-03T16:00:27+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
time="2023-09-03T16:00:27+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
time="2023-09-03T16:00:27+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.2\\libraries" location=platform
time="2023-09-03T16:00:27+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\emoro\\hardware\\avr\\3.2.2\\libraries" location=platform
time="2023-09-03T16:00:27+02:00" level=info msg="Loading libraries index file" index="c:\\Users\\andre\\AppData\\Local\\Arduino15\\library_index.json"
2023-09-03T14:00:28.665Z daemon INFO time="2023-09-03T16:00:28+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-09-03T16:00:28+02:00" level=info msg="Adding libraries dir" dir="c:\\Users\\andre\\Documents\\Arduino\\libraries" location=user
2023-09-03T14:00:29.212Z discovery-log INFO start request start watch
2023-09-03T14:00:29.233Z discovery-log INFO start requested start watch
2023-09-03T14:00:29.257Z discovery-log INFO start resolved watching
2023-09-03T14:00:29.273Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="starting discovery builtin:dfu-discovery process"
2023-09-03T14:00:29.283Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="starting discovery builtin:serial-discovery process"
2023-09-03T14:00:29.295Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="starting discovery builtin:mdns-discovery process"
2023-09-03T14:00:29.419Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="started discovery builtin:serial-discovery process"
time="2023-09-03T16:00:29+02:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:serial-discovery"
2023-09-03T14:00:29.488Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2023-09-03T16:00:29+02:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:dfu-discovery"
2023-09-03T14:00:29.530Z root INFO Deploy plugins list: 719.1 ms [Finished 5.088 s after backend start]
2023-09-03T14:00:29.531Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2023-09-03T16:00:29+02:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:mdns-discovery"
2023-09-03T14:00:29.898Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2023-09-03T14:00:29.907Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2023-09-03T14:00:29.980Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2023-09-03T14:00:29.986Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2023-09-03T14:00:30.006Z daemon INFO time="2023-09-03T16:00:29+02:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
2023-09-03T14:00:30.031Z daemon INFO time="2023-09-03T16:00:30+02:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2023-09-03T14:00:30.082Z daemon INFO time="2023-09-03T16:00:30+02:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2023-09-03T14:00:30.099Z daemon INFO time="2023-09-03T16:00:30+02:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2023-09-03T14:00:30.175Z daemon INFO time="2023-09-03T16:00:30+02:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
