When i try to open Arduino IDE 2.3.2 it hangs at the splash screen. I have tried a few things i found in this forum with no luck.
Hi @atxfz09. Please add a forum reply here to tell us which operating system you are using (e.g., "Windows")?
I ask because I would like to give you the appropriate instructions for your operating system.
I have experienced the same problem just now,and my operating system is Windows 10
(the version of my Arduino IDE is also 2.3.2)
I tried to delete the folders mentioned in this thread: IDE hangs on startup - Software / IDE 2.x - Arduino Forum
but it didn't work.
The following is my debug output after running Powershell:
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: D:\Arduino\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': D:\Arduino\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 27384
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/xidamei/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-07-05T15:26:02.540Z root INFO Backend Object.initialize: 5.2 ms [Finished 0.573 s after backend start]
2024-07-05T15:26:02.541Z root INFO Backend Object.configure: 4.3 ms [Finished 0.573 s after backend start]
2024-07-05T15:26:02.541Z root INFO Backend s.onStart: 2.4 ms [Finished 0.573 s after backend start]
2024-07-05T15:26:02.542Z root INFO Backend s.configure: 0.4 ms [Finished 0.616 s after backend start]
2024-07-05T15:26:02.543Z root INFO Backend d.onStart: 0.3 ms [Finished 0.616 s after backend start]
2024-07-05T15:26:02.545Z root INFO Backend d.configure: 0.1 ms [Finished 0.617 s after backend start]
2024-07-05T15:26:02.546Z root INFO Backend d.initialize: 43.8 ms [Finished 0.617 s after backend start]
2024-07-05T15:26:02.546Z root INFO Backend c.onStart: 0.2 ms [Finished 0.617 s after backend start]
2024-07-05T15:26:02.547Z root INFO Backend a.configure: 1.7 ms [Finished 0.619 s after backend start]
2024-07-05T15:26:02.548Z config INFO >>> Initializing CLI configuration...
2024-07-05T15:26:02.549Z root INFO Backend c.initialize: 0.9 ms [Finished 0.620 s after backend start]
2024-07-05T15:26:02.549Z root INFO Backend R.onStart: 1.2 ms [Finished 0.620 s after backend start]
2024-07-05T15:26:02.550Z config INFO Loading CLI configuration from c:\Users\xidamei\.arduinoIDE\arduino-cli.yaml...
2024-07-05T15:26:02.551Z daemon INFO Starting daemon from D:\Arduino\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-07-05T15:26:02.551Z root INFO Backend a.initialize: 0.7 ms [Finished 0.622 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend w.onStart: 2.1 ms [Finished 0.624 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend r.configure: 3.5 ms [Finished 0.624 s after backend start]
2024-07-05T15:26:02.551Z discovery-log INFO start
2024-07-05T15:26:02.551Z discovery-log INFO start new deferred
2024-07-05T15:26:02.551Z root INFO Backend d.initialize: 0.5 ms [Finished 0.625 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend y.onStart: 2.1 ms [Finished 0.626 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend r.configure: 1.8 ms [Finished 0.626 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend a.onStart: 0.9 ms [Finished 0.629 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend h.configure: 0.7 ms [Finished 0.629 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend s.configure: 0.2 ms [Finished 0.629 s after backend start]
2024-07-05T15:26:02.551Z root INFO Backend l.configure: 0.1 ms [Finished 0.629 s after backend start]
2024-07-05T15:26:02.555Z root INFO Theia app listening on http://127.0.0.1:43199.
2024-07-05T15:26:02.555Z root INFO Finished starting backend application: 3.8 ms [Finished 0.632 s after backend start]
2024-07-05T15:26:02.562Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xidamei/.arduinoIDE/plugins does not exist.
2024-07-05T15:26:02.563Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xidamei/.arduinoIDE/extensions does not exist.
2024-07-05T15:26:02.563Z root WARN The local plugin referenced by local-dir:C:\Users\xidamei\.arduinoIDE\plugins does not exist.
2024-07-05T15:26:02.571Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\xidamei\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\xidamei\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\xidamei\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-07-05T15:26:02.571Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-07-05T15:26:02.571Z config INFO Loaded the CLI configuration.
2024-07-05T15:26:02.573Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/xidamei/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/xidamei/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-07-05T15:26:02.573Z config INFO Validating the CLI configuration...
2024-07-05T15:26:02.574Z config INFO The CLI config is valid.
2024-07-05T15:26:02.574Z config INFO <<< Initialized the CLI configuration.
2024-07-05T15:26:02.604Z root INFO Resolve plugins list: 54.8 ms [Finished 0.681 s after backend start]
2024-07-05T15:26:02.724Z daemon INFO time="2024-07-05T23:26:02+08:00" level=info msg="Using config file: c:\\Users\\xidamei\\.arduinoIDE\\arduino-cli.yaml"
time="2024-07-05T23:26:02+08:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-07-05T23:26:02+08:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:43200
{"IP":"127.0.0.1","Port":"43200"}
2024-07-05T15:26:02.725Z daemon INFO Daemon is running.
2024-07-05T15:26:02.748Z daemon INFO time="2024-07-05T23:26:02+08:00" level=info msg="Updating libraries index"
time="2024-07-05T23:26:02+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-07-05T15:26:03.563Z root INFO Deploy plugins list: 54.8 ms [Finished 1.641 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-07-05T15:26:04.480Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 163.6 ms [Finished 1.819 s after frontend start]
2024-07-05T15:26:04.480Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-07-05T15:26:04.725Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 165.7 ms [Finished 2.100 s after frontend start]
Could you please help me to solve this problem?Thanks a lot.
don't know why but it‘s solved.
thanks.
I'm glad it is working now. Thanks for taking the time to post an update!
Regards,
Per
