IDE hangs on startup, with no error shown in logs
PS C:\Users\ID-117\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.1
Starting backend process. PID: 21920
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/ID-117/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-08-20T07:09:49.566Z root INFO Backend Object.initialize: 4.2 ms [Finished 1.311 s after backend start]
2023-08-20T07:09:49.566Z root INFO Backend Object.configure: 3.6 ms [Finished 1.311 s after backend start]
2023-08-20T07:09:49.566Z root INFO Backend MessagingContribution.onStart: 1.3 ms [Finished 1.311 s after backend start]
2023-08-20T07:09:49.567Z root INFO Backend OSBackendApplicationContribution.configure: 0.8 ms [Finished 1.346 s after backend start]
2023-08-20T07:09:49.568Z root INFO Backend DefaultWorkspaceServer.onStart: 0.7 ms [Finished 1.346 s after backend start]
2023-08-20T07:09:49.569Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 1.346 s after backend start]
2023-08-20T07:09:49.569Z root INFO Backend PluginLocalizationBackendContribution.initialize: 34.7 ms [Finished 1.347 s after backend start]
2023-08-20T07:09:49.570Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.347 s after backend start]
2023-08-20T07:09:49.570Z root INFO Backend ElectronTokenBackendContribution.configure: 0.9 ms [Finished 1.348 s after backend start]
2023-08-20T07:09:49.571Z config INFO >>> Initializing CLI configuration...
2023-08-20T07:09:49.571Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.348 s after backend start]
2023-08-20T07:09:49.572Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 1.348 s after backend start]
2023-08-20T07:09:49.572Z config INFO Loading CLI configuration from c:\Users\ID-117\.arduinoIDE\arduino-cli.yaml...
2023-08-20T07:09:49.573Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.350 s after backend start]
2023-08-20T07:09:49.573Z root INFO Backend ArduinoDaemonImpl.onStart: 0.9 ms [Finished 1.350 s after backend start]
2023-08-20T07:09:49.573Z root INFO Backend NodeFileUploadService.configure: 2.1 ms [Finished 1.351 s after backend start]
2023-08-20T07:09:49.573Z daemon INFO Starting daemon from C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-08-20T07:09:49.573Z discovery-log INFO start
2023-08-20T07:09:49.573Z discovery-log INFO start new deferred
2023-08-20T07:09:49.574Z root INFO Backend HostedPluginLocalizationService.initialize: 0.4 ms [Finished 1.351 s after backend start]
2023-08-20T07:09:49.574Z root INFO Backend BoardDiscovery.onStart: 0.9 ms [Finished 1.352 s after backend start]
2023-08-20T07:09:49.574Z root INFO Backend FileDownloadEndpoint.configure: 0.8 ms [Finished 1.352 s after backend start]
2023-08-20T07:09:49.575Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.353 s after backend start]
2023-08-20T07:09:49.575Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.354 s after backend start]
2023-08-20T07:09:49.576Z root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.355 s after backend start]
2023-08-20T07:09:49.576Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.355 s after backend start]
2023-08-20T07:09:49.576Z root INFO Backend PlotterBackendContribution.configure: 0.8 ms [Finished 1.357 s after backend start]
2023-08-20T07:09:49.579Z root INFO Theia app listening on http://localhost:63705.
2023-08-20T07:09:49.580Z root INFO Finished starting backend application: 5.7 ms [Finished 1.360 s after backend start]
2023-08-20T07:09:49.610Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ID-117/.arduinoIDE/plugins does not exist.
2023-08-20T07:09:49.610Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ID-117/.arduinoIDE/extensions does not exist.
2023-08-20T07:09:49.611Z root WARN The local plugin referenced by local-dir:C:\Users\ID-117\.arduinoIDE\plugins does not exist.
2023-08-20T07:09:49.656Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.657Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-08-20T07:09:49.657Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.658Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-08-20T07:09:49.658Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.658Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-08-20T07:09:49.659Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.659Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-08-20T07:09:49.660Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.660Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-08-20T07:09:49.661Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.661Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-08-20T07:09:49.662Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-08-20T07:09:49.662Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.662Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-08-20T07:09:49.663Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.663Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-08-20T07:09:49.664Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.664Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-08-20T07:09:49.665Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.665Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-08-20T07:09:49.666Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.666Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-08-20T07:09:49.667Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.667Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-08-20T07:09:49.668Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.671Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-08-20T07:09:49.671Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.672Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-08-20T07:09:49.672Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.673Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-08-20T07:09:49.673Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.673Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-08-20T07:09:49.674Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.674Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-08-20T07:09:49.675Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.675Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-08-20T07:09:49.676Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-08-20T07:09:49.676Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-08-20T07:09:49.676Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-08-20T07:09:49.682Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\ID-117\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\ID-117\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\ID-117\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-08-20T07:09:49.685Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-08-20T07:09:49.685Z config INFO Loaded the CLI configuration.
2023-08-20T07:09:49.689Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/ID-117/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/ID-117/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-08-20T07:09:49.690Z config INFO Validating the CLI configuration...
2023-08-20T07:09:49.690Z config INFO The CLI config is valid.
2023-08-20T07:09:49.690Z config INFO <<< Initialized the CLI configuration.
2023-08-20T07:09:49.707Z root INFO Resolve plugins list: 134.2 ms [Finished 1.487 s after backend start]
2023-08-20T07:09:49.711Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 4.1 ms [Finished 1.491 s after backend start]
2023-08-20T07:09:49.715Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 4.0 ms [Finished 1.495 s after backend start]
2023-08-20T07:09:49.730Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 15.0 ms [Finished 1.511 s after backend start]
2023-08-20T07:09:49.732Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.2 ms [Finished 1.513 s after backend start]
2023-08-20T07:09:49.734Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.9 ms [Finished 1.515 s after backend start]
2023-08-20T07:09:49.827Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 93.1 ms [Finished 1.608 s after backend start]
2023-08-20T07:09:49.848Z daemon INFO INFO[0000] Using config file: c:\Users\ID-117\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.3
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:63706
{"IP":"127.0.0.1","Port":"63706"}
2023-08-20T07:09:49.849Z daemon INFO Daemon is running.
2023-08-20T07:09:49.959Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 131.4 ms [Finished 1.739 s after backend start]
2023-08-20T07:09:50.063Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 104.0 ms [Finished 1.843 s after backend start]
2023-08-20T07:09:50.063Z daemon INFO INFO[0000] Loading hardware from: C:\Users\ID-117\AppData\Local\Arduino15\packages
INFO[0000] Loading package builtin from: C:\Users\ID-117\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\ID-117\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\ID-117\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0000] Checking signature                            index="C:\\Users\\ID-117\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\ID-117\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Starting download                             url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2023-08-20T07:09:50.130Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 66.7 ms [Finished 1.910 s after backend start]
2023-08-20T07:09:50.168Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 38.2 ms [Finished 1.948 s after backend start]
2023-08-20T07:09:50.212Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 44.4 ms [Finished 1.993 s after backend start]
2023-08-20T07:09:50.266Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 53.0 ms [Finished 2.046 s after backend start]
2023-08-20T07:09:50.325Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 59.2 ms [Finished 2.105 s after backend start]
2023-08-20T07:09:50.390Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 65.3 ms [Finished 2.171 s after backend start]
2023-08-20T07:09:50.413Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 23.3 ms [Finished 2.194 s after backend start]
2023-08-20T07:09:50.462Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 48.9 ms [Finished 2.243 s after backend start]
2023-08-20T07:09:50.529Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 66.2 ms [Finished 2.309 s after backend start]
2023-08-20T07:09:50.633Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 103.8 ms [Finished 2.413 s after backend start]
2023-08-20T07:09:50.758Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 125.4 ms [Finished 2.539 s after backend start]
2023-08-20T07:09:50.828Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 69.6 ms [Finished 2.608 s after backend start]
2023-08-20T07:09:50.927Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\ID-117\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 99.6 ms [Finished 2.708 s after backend start]
2023-08-20T07:09:50.928Z root INFO Deploy plugins list: 134.2 ms [Finished 2.708 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-08-20T07:09:51.834Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 301.5 ms [Finished 2.072 s after frontend start]
2023-08-20T07:10:23.680Z daemon INFO INFO[0033] Installing tool                               Tool="builtin:mdns-discovery@1.0.9"
2023-08-20T07:10:23.931Z daemon INFO INFO[0034] Skipping tool configuration.                  Tool="builtin:mdns-discovery@1.0.9"
2023-08-20T07:10:23.934Z daemon INFO INFO[0034] Tool installed                                Tool="builtin:mdns-discovery@1.0.9"
INFO[0034] Starting download                             url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.13.0_Windows_64bit.zip"
2023-08-20T07:10:45.855Z daemon INFO INFO[0056] Installing tool                               Tool="builtin:serial-monitor@0.13.0"
2023-08-20T07:10:45.970Z daemon INFO INFO[0056] Skipping tool configuration.                  Tool="builtin:serial-monitor@0.13.0"
INFO[0056] Tool installed                                Tool="builtin:serial-monitor@0.13.0"
2023-08-20T07:10:45.973Z daemon INFO INFO[0056] Starting download                             url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
Hi @rofiqvb. Are you experiencing some problem with Arduino IDE? The output you shared looks perfectly normal, without any indication that something is wrong.
. : File C:\Users\andre\Documents\WindowsPowerShell\profile.ps1 cannot be loaded because running scripts is disabled
on this system. For more information, see about_Execution_Policies at https:/go.microsoft.com/fwlink/?LinkID=135170.
At line:1 char:3
+ . 'C:\Users\andre\Documents\WindowsPowerShell\profile.ps1'
    + CategoryInfo          : SecurityError: (:) [], PSSecurityException
    + FullyQualifiedErrorId : UnauthorizedAccess
PS C:\Users\andre\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 9824
Configuration directory URI: 'file:///c%3A/Users/andre/.arduinoIDE'
2024-06-12T02:43:00.290Z root INFO Backend Object.initialize: 3.5 ms [Finished 0.412 s after backend start]
2024-06-12T02:43:00.291Z root INFO Backend Object.configure: 2.9 ms [Finished 0.412 s after backend start]
2024-06-12T02:43:00.291Z root INFO Backend s.onStart: 1.4 ms [Finished 0.412 s after backend start]
2024-06-12T02:43:00.292Z root INFO Backend s.configure: 0.3 ms [Finished 0.431 s after backend start]
2024-06-12T02:43:00.292Z root INFO Backend d.onStart: 0.2 ms [Finished 0.431 s after backend start]
2024-06-12T02:43:00.293Z root INFO Backend d.configure: 0.1 ms [Finished 0.431 s after backend start]
2024-06-12T02:43:00.294Z root INFO Backend d.initialize: 18.5 ms [Finished 0.431 s after backend start]
2024-06-12T02:43:00.294Z root INFO Backend c.onStart: 0.2 ms [Finished 0.431 s after backend start]
2024-06-12T02:43:00.295Z root INFO Backend a.configure: 1.1 ms [Finished 0.432 s after backend start]
2024-06-12T02:43:00.296Z config INFO >>> Initializing CLI configuration...
2024-06-12T02:43:00.296Z root INFO Backend c.initialize: 0.4 ms [Finished 0.432 s after backend start]
2024-06-12T02:43:00.297Z root INFO Backend R.onStart: 0.6 ms [Finished 0.433 s after backend start]
2024-06-12T02:43:00.297Z config INFO Loading CLI configuration from c:\Users\andre\.arduinoIDE\arduino-cli.yaml...
2024-06-12T02:43:00.298Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-06-12T02:43:00.298Z root INFO Backend a.initialize: 0.4 ms [Finished 0.434 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend w.onStart: 1.3 ms [Finished 0.435 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend r.configure: 2.3 ms [Finished 0.435 s after backend start]
2024-06-12T02:43:00.298Z discovery-log INFO start
2024-06-12T02:43:00.298Z discovery-log INFO start new deferred
2024-06-12T02:43:00.298Z root INFO Backend d.initialize: 0.4 ms [Finished 0.435 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend y.onStart: 1.9 ms [Finished 0.437 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend r.configure: 1.7 ms [Finished 0.437 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend a.onStart: 0.4 ms [Finished 0.438 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend h.configure: 0.3 ms [Finished 0.438 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend s.configure: 0.1 ms [Finished 0.438 s after backend start]
2024-06-12T02:43:00.298Z root INFO Backend l.configure: 0.0 ms [Finished 0.438 s after backend start]
2024-06-12T02:43:00.300Z root INFO Theia app listening on http://127.0.0.1:52543.
2024-06-12T02:43:00.300Z root INFO Finished starting backend application: 2.1 ms [Finished 0.440 s after backend start]
2024-06-12T02:43:00.306Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/plugins does not exist.
2024-06-12T02:43:00.306Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/extensions does not exist.
2024-06-12T02:43:00.306Z root WARN The local plugin referenced by local-dir:C:\Users\andre\.arduinoIDE\plugins does not exist.
2024-06-12T02:43:00.312Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\andre\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\andre\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\andre\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-06-12T02:43:00.312Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-06-12T02:43:00.312Z config INFO Loaded the CLI configuration.
2024-06-12T02:43:00.318Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/andre/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/andre/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-06-12T02:43:00.318Z config INFO Validating the CLI configuration...
2024-06-12T02:43:00.320Z config INFO The CLI config is valid.
2024-06-12T02:43:00.320Z config INFO <<< Initialized the CLI configuration.
2024-06-12T02:43:00.338Z root INFO Resolve plugins list: 40.2 ms [Finished 0.477 s after backend start]
2024-06-12T02:43:00.362Z daemon INFO time="2024-06-11T22:43:00-04:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2024-06-11T22:43:00-04:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-06-11T22:43:00-04:00" level=info msg="Executing `arduino-cli daemon`"
2024-06-12T02:43:00.372Z daemon INFO Daemon is now listening on 127.0.0.1:52544
{"IP":"127.0.0.1","Port":"52544"}
2024-06-12T02:43:00.372Z daemon INFO Daemon is running.
2024-06-12T02:43:01.079Z root INFO Deploy plugins list: 40.2 ms [Finished 1.220 s after backend start]
Hi @king_kim. Are you encountering some problem while using Arduino IDE? If so, please provide a detailed description of the problem.
I examined the terminal logs you shared, but they look like the logs we would expect to see when Arduino IDE is working perfectly so they don't give me any idea about what problem you might be having.
Hi @ptillisch. I'm experiencing some problems while opening the Arduino IDE. It keeps hanging on the Arduino Logo Bouncing up and down. So far 3 computers in my house are having this problem. I'm on Windows 11, version 23H2.
So far to fix it I've tried restarting my computer, uninstalling and reinstalling the software, and installing the zip folder. I've also noticed that none of my Chrome tabs will load when I open the software. I have to restart my computer to get anything to load.
Hi @ptillisch I tried installing the 1.8.19 version and it works! However, the 2.3.2 version won't. I think I'll just use this version for now. Have a great day everyone!
Thanks for taking the time to post an update. I'm glad you were able to find a workaround. If you later decide to give Arduino IDE 2.x another try and still encounter problems, let us know and we'll investigate further.
Regards,
Per
