I have a similar problem and this is the log I got, what could be the problem
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.3
Starting backend process. PID: 25652
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Eli/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2022-12-22T11:43:02.324Z root INFO Backend Object.initialize: 8.0 ms [Finished 2.414 s after backend start]
2022-12-22T11:43:02.325Z root INFO Backend Object.configure: 6.1 ms [Finished 2.414 s after backend start]
2022-12-22T11:43:02.325Z root INFO Backend MessagingContribution.onStart: 2.9 ms [Finished 2.414 s after backend start]
2022-12-22T11:43:02.327Z root INFO Backend OSBackendApplicationContribution.configure: 0.7 ms [Finished 2.486 s after ba
ckend start]
2022-12-22T11:43:02.328Z root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 2.486 s after backend start]
2022-12-22T11:43:02.330Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.3 ms [Finished 2.486 s aft
er backend start]
2022-12-22T11:43:02.332Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expecte
d maximum 50 milliseconds: 71.5 ms [Finished 2.487 s after backend start]
2022-12-22T11:43:02.333Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 2.487 s after ba
ckend start]
2022-12-22T11:43:02.335Z root INFO Backend ElectronTokenBackendContribution.configure: 2.9 ms [Finished 2.490 s after ba
ckend start]
2022-12-22T11:43:02.336Z root INFO Backend PluginDeployerContribution.initialize: 0.8 ms [Finished 2.490 s after backend
start]
2022-12-22T11:43:02.337Z root INFO Backend ConfigServiceImpl.onStart: 1.9 ms [Finished 2.492 s after backend start]
2022-12-22T11:43:02.339Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.8 ms [Finished 2.494 s after bac
kend start]
2022-12-22T11:43:02.340Z root INFO Backend ArduinoDaemonImpl.onStart: 2.3 ms [Finished 2.496 s after backend start]
2022-12-22T11:43:02.340Z root INFO Backend NodeFileUploadService.configure: 4.6 ms [Finished 2.496 s after backend start
2022-12-22T11:43:02.341Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduin
o-ide-extension\build\arduino-cli.exe...
2022-12-22T11:43:02.341Z discovery-log INFO start
2022-12-22T11:43:02.342Z discovery-log INFO start new deferred
2022-12-22T11:43:02.342Z root INFO Backend HostedPluginLocalizationService.initialize: 0.8 ms [Finished 2.498 s after ba
ckend start]
2022-12-22T11:43:02.342Z root INFO Backend BoardDiscovery.onStart: 1.8 ms [Finished 2.499 s after backend start]
2022-12-22T11:43:02.343Z root INFO Backend FileDownloadEndpoint.configure: 1.5 ms [Finished 2.500 s after backend start]
2022-12-22T11:43:02.343Z root INFO Backend AuthenticationServiceImpl.onStart: 0.7 ms [Finished 2.503 s after backend sta
rt]
2022-12-22T11:43:02.344Z root INFO Backend PluginApiContribution.configure: 1.2 ms [Finished 2.503 s after backend start
2022-12-22T11:43:02.346Z root INFO Backend HostedPluginReader.configure: 1.2 ms [Finished 2.506 s after backend start]
2022-12-22T11:43:02.346Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 2.507 s after backend start]
2022-12-22T11:43:02.347Z root INFO Backend PlotterBackendContribution.configure: 1.7 ms [Finished 2.509 s after backend
start]
2022-12-22T11:43:02.352Z root INFO Theia app listening on http://localhost:63050.
2022-12-22T11:43:02.354Z root INFO Finished starting backend application: 11.1 ms [Finished 2.516 s after backend start]
2022-12-22T11:43:02.357Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Eli/.arduinoIDE/plugins does not
exist.
2022-12-22T11:43:02.358Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Eli/.arduinoIDE/extensions does
not exist.
2022-12-22T11:43:02.361Z root WARN The local plugin referenced by local-dir:C:\Users\Eli\.arduinoProIDE\plugins does not
exist.
Restoring workspace roots: c:\Users\Eli\Dropbox\Tal Project\UnitTestnigCode\SeymourThingsboard_IVTEC
isTempSketch: false. Input was c:\Users\Eli\Dropbox\Tal Project\UnitTestnigCode\SeymourThingsboard_IVTEC\SeymourThingsbo
ard_IVTEC.ino
2022-12-22T11:43:02.410Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.410Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2022-12-22T11:43:02.411Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.416Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-be
ta.5" with engines:
2022-12-22T11:43:02.418Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.421Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2022-12-22T11:43:02.425Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.429Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2022-12-22T11:43:02.433Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.438Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-languag
e-features@1.46.1" with engines:
2022-12-22T11:43:02.442Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.448Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.
48.3" with engines:
2022-12-22T11:43:02.451Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.455Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.
53.2" with engines:
2022-12-22T11:43:02.459Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.463Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.
53.2" with engines:
2022-12-22T11:43:02.468Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.473Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.
53.2" with engines:
2022-12-22T11:43:02.477Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.481Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.
53.2" with engines:
2022-12-22T11:43:02.485Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.490Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.
48.3" with engines:
2022-12-22T11:43:02.495Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.498Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.
53.2" with engines:
2022-12-22T11:43:02.504Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.508Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.
53.2" with engines:
2022-12-22T11:43:02.511Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.514Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.
53.2" with engines:
2022-12-22T11:43:02.518Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.522Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.
48.3" with engines:
2022-12-22T11:43:02.526Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.529Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.
53.2" with engines:
2022-12-22T11:43:02.532Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.536Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt
-BR@1.53.2" with engines:
2022-12-22T11:43:02.540Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.543Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.
53.2" with engines:
2022-12-22T11:43:02.547Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.549Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.
53.2" with engines:
2022-12-22T11:43:02.554Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.557Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.
48.3" with engines:
2022-12-22T11:43:02.561Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-22T11:43:02.564Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-
zh-hans@1.53.2" with engines:
2022-12-22T11:43:02.618Z root INFO Resolve plugins list: 279.5 ms [Finished 2.780 s after backend start]
2022-12-22T11:43:02.629Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino I
DE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 10.4 ms [Finished 2.791 s after backend start]
2022-12-22T11:43:02.638Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "C:\Program
Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 8.9 ms [Finished 2.801 s after back
end start]
2022-12-22T11:43:02.659Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resour
ces\app\plugins\vscode-builtin-cpp\extension": 20.9 ms [Finished 2.822 s after backend start]
2022-12-22T11:43:02.666Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resou
rces\app\plugins\vscode-builtin-json\extension": 7.6 ms [Finished 2.829 s after backend start]
2022-12-22T11:43:02.668Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files
\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.1 ms [Finish
ed 2.832 s after backend start]
2022-12-22T11:43:02.825Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 156.4 ms [Finished 2.988 s after backend star
t]
2022-12-22T11:43:02.855Z daemon INFO ←[36mINFO←[0m[0000] Using config file: c:\Users\Eli\.arduinoIDE\arduino-cli.yaml
←[36mINFO←[0m[0000] arduino-cli.exe version 0.29.0
←[36mINFO←[0m[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"63051"}
2022-12-22T11:43:02.858Z daemon INFO Daemon is running.
2022-12-22T11:43:03.017Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 192.2 ms [Finished 3.180 s after backend star
t]
2022-12-22T11:43:03.028Z daemon INFO ←[36mINFO←[0m[0000] Loading hardware from: c:\Users\Eli\AppData\Local\Arduino15\pac
kages
2022-12-22T11:43:03.229Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 211.6 ms [Finished 3.392 s after backend star
t]
2022-12-22T11:43:03.231Z daemon INFO ←[36mINFO←[0m[0000] Loading package builtin from: C:\Users\Eli\AppData\Local\Arduin
o15\packages\builtin
←[36mINFO←[0m[0000] Checking existence of 'tools' path: C:\Users\Eli\AppData\Local\Arduino15\packages\builtin\tools
←[36mINFO←[0m[0000] Loading tools from dir: C:\Users\Eli\AppData\Local\Arduino15\packages\builtin\tools
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="builtin:ctags@5.8-arduino11"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="builtin:mdns-discovery@1.0.6"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="builtin:serial-discovery@1.3.2"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="builtin:serial-monitor@0.11.0"
←[36mINFO←[0m[0000] Loading package esp32 from: C:\Users\Eli\AppData\Local\Arduino15\packages\esp32\hardware
←[36mINFO←[0m[0000] Adding monitor tool ←[36mprotocol←[0m=serial ←[36mtool←[0m="builtin:serial
-monitor"
←[36mINFO←[0m[0000] Loaded platform ←[36mplatform←[0m="esp32:esp32@2.0.0"
←[36mINFO←[0m[0000] Checking existence of 'tools' path: C:\Users\Eli\AppData\Local\Arduino15\packages\esp32\tools
←[36mINFO←[0m[0000] Loading tools from dir: C:\Users\Eli\AppData\Local\Arduino15\packages\esp32\tools
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="esp32:esptool_py@3.1.0"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="esp32:mkspiffs@0.2.3"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-
2021r1"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp
-2021r1"
←[36mINFO←[0m[0000] Loaded tool ←[36mtool←[0m="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-e
sp-2021r1"
←[36mINFO←[0m[0000] Checking signature ←[36mindex←[0m="c:\\Users\\Eli\\AppData\\Local\\Arduin
o15\\package_index.json" ←[36msignatureFile←[0m="c:\\Users\\Eli\\AppData\\Local\\Arduino15\\package_index.json.sig" ←[36
mtrusted←[0m=true
←[36mINFO←[0m[0000] Adding libraries dir ←[36mdir←[0m="C:\\Users\\Eli\\AppData\\Local\\Arduino1
5\\packages\\esp32\\hardware\\esp32\\2.0.0\\libraries" ←[36mlocation←[0m=platform
←[36mINFO←[0m[0000] Loading libraries index file ←[36mindex←[0m="c:\\Users\\Eli\\AppData\\Local\\Arduin
o15\\library_index.json"
2022-12-22T11:43:03.399Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 170.0 ms [Finished 3.562 s after backend star
t]
2022-12-22T11:43:03.535Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 135.8 ms [Finished 3.698 s after backend star
t]
2022-12-22T11:43:03.537Z daemon INFO ←[36mINFO←[0m[0000] Adding libraries dir ←[36mdir←[0m="C:\
\Users\\Eli\\AppData\\Local\\Arduino15\\libraries" ←[36mlocation←[0m=ide
←[36mINFO←[0m[0000] Adding libraries dir ←[36mdir←[0m="c:\\Users\\Eli\\Documents\\Arduino\\libr
aries" ←[36mlocation←[0m=user
2022-12-22T11:43:03.630Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 95.6 ms [Finished 3.794 s after backend start
2022-12-22T11:43:03.724Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 93.4 ms [Finished 3.887 s after backend start
2022-12-22T11:43:03.842Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 117.9 ms [Finished 4.005 s after backend star
t]
2022-12-22T11:43:03.944Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 101.9 ms [Finished 4.107 s after backend star
t]
2022-12-22T11:43:03.989Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 45.0 ms [Finished 4.152 s after backend start
2022-12-22T11:43:04.082Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 93.0 ms [Finished 4.245 s after backend start
2022-12-22T11:43:04.182Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Progra
m Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 99.3 ms [Finished 4.345 s after backend
start]
2022-12-22T11:43:04.290Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 108.3 ms [Finished 4.453 s after backend star
t]
2022-12-22T11:43:04.379Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 89.3 ms [Finished 4.543 s after backend start
2022-12-22T11:43:04.454Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program F
iles\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 74.5 ms [Finished 4.617 s after backend start
2022-12-22T11:43:04.548Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Prog
ram Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 93.8 ms [Finished 4.711 s after bac
kend start]
2022-12-22T11:43:04.549Z root INFO Deploy plugins list: 279.5 ms [Finished 4.711 s after backend start]
2022-12-22T11:43:04.554Z discovery-log INFO start request start watch
2022-12-22T11:43:04.555Z discovery-log INFO start requested start watch
2022-12-22T11:43:04.558Z discovery-log INFO start resolved watching
2022-12-22T11:43:04.567Z daemon INFO ←[36mINFO←[0m[0001] starting discovery builtin:serial-discovery process
←[36mINFO←[0m[0001] starting discovery builtin:mdns-discovery process
2022-12-22T11:43:04.593Z daemon INFO ←[36mINFO←[0m[0001] started discovery builtin:mdns-discovery process
←[36mINFO←[0m[0001] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:mdns-discovery
←[36mINFO←[0m[0001] started discovery builtin:serial-discovery process
←[36mINFO←[0m[0001] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:serial-discovery
←[36mINFO←[0m[0001] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
←[36mINFO←[0m[0001] sending command START_SYNC to discovery builtin:mdns-discovery
←[36mINFO←[0m[0001] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version:
1
←[36mINFO←[0m[0001] sending command START_SYNC to discovery builtin:serial-discovery
←[36mINFO←[0m[0001] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
←[36mINFO←[0m[0001] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2022-12-22T11:43:04.645Z daemon INFO ←[36mINFO←[0m[0001] from discovery builtin:serial-discovery received message type:
add, port: COM7
←[36mINFO←[0m[0001] from discovery builtin:serial-discovery received message type: add, port: COM4
←[36mINFO←[0m[0001] from discovery builtin:serial-discovery received message type: add, port: COM12
2022-12-22T11:43:04.657Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM7",
"label":"COM7","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
2022-12-22T11:43:04.659Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4",
"label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
2022-12-22T11:43:04.661Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM12"
,"label":"COM12","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2022-12-22T11:43:05.713Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 361.5 ms
[Finished 3.223 s after frontend start]
[8068:1222/134305.816:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.817:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.821:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.825:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.829:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.833:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.836:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.841:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.845:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.848:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.852:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.857:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.861:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.864:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.868:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.873:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.877:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.880:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.884:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.888:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.893:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.897:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.900:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.903:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.908:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.911:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.914:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134305.917:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2022-12-22T11:43:05.954Z root WARN Frontend menus.onStart took longer than the expected maximum 100 milliseconds: 157.0
ms [Finished 3.502 s after frontend start]
2022-12-22T11:43:06.010Z sketches-service WARN Warning! The request sketch path was different than the response sketch p
ath from the CLI. This could be a potential bug. Request: <c:\Users\Eli\Dropbox\Tal Project\UnitTestnigCode\SeymourThing
sboard_IVTEC\SeymourThingsboard_IVTEC.ino>, response: <c:\Users\Eli\Dropbox\Tal Project\UnitTestnigCode\SeymourThingsboa
rd_IVTEC>.
[8068:1222/134306.145:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.146:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.150:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.153:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.158:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.161:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.164:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.167:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.170:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.174:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.176:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.180:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.183:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.186:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.190:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.194:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.196:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.200:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.203:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.207:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.210:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.213:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.216:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.220:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.224:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.226:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.230:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134306.233:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2022-12-22T11:43:06.404Z root WARN Frontend l.onStart took longer than the expected maximum 100 milliseconds: 405.4 ms [
Finished 3.978 s after frontend start]
2022-12-22T11:43:06.451Z root INFO Start frontend contributions: 1285.4 ms [Finished 3.989 s after frontend start]
2022-12-22T11:43:06.453Z root INFO Changed application state from 'init' to 'started_contributions'.
2022-12-22T11:43:06.489Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2022-12-22T11:43:06.490Z root INFO >>> Restoring the layout state...
2022-12-22T11:43:06.496Z root INFO ------- SERIALIZED LAYOUT DATA -------
2022-12-22T11:43:06.496Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions"
:{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Eli/Dropbox/Tal
%20Project/UnitTestnigCode/SeymourThingsboard_IVTEC/SeymourThingsboard_IVTEC.ino"}},"innerWidgetState":"{\"cursorState\"
:[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\
":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"
contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":635,\"provider\":\"indent\",\"foldedImports\":false},\"e
ditor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":
null},"pinned":[],"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryI
d":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId"
:"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library
-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerW
idgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\
"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\
"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{
\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",
\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget
\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables
:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\
":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions
\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,
\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"i
conClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:
watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"origi
nalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon cod
icon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWi
dgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalC
ontainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon
-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":
\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\"
:\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\"
:\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalCont
ainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-de
bug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"p
lugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Co
rtex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debu
g\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"
expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState
":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search
-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\
":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCas
eState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\
\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\
\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"t
itle\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"
enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOpti
ons\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"i
nclude\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"s
howReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\
\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistorySt
ate\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\
",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2022-12-22T11:43:06.514Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2022-12-22T11:43:06.593Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4] Waiting for backend deployment: 177.7 ms [Fini
shed 4.158 s after frontend start]
2022-12-22T11:43:07.291Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464) starting instance
2022-12-22T11:43:08.033Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4] Sync of 21 plugins: 1453.6 ms [Finished 5.612
2022-12-22T11:43:08.419Z root INFO <<< The layout has been successfully restored.
2022-12-22T11:43:08.612Z root INFO Initialize the workbench layout: 1954.3 ms [Finished 5.999 s after frontend start]
2022-12-22T11:43:08.618Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2022-12-22T11:43:08.620Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][marus25.cortex-debug]: Loaded contributions.
2022-12-22T11:43:08.621Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][arduino.vscode-arduino-tools]: Loaded contribu
tions.
2022-12-22T11:43:08.630Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][vscode.cpp]: Loaded contributions.
2022-12-22T11:43:08.631Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][vscode.json]: Loaded contributions.
2022-12-22T11:43:08.632Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][vscode.json-language-features]: Loaded contrib
utions.
2022-12-22T11:43:08.636Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-bg]: Loaded con
tributions.
2022-12-22T11:43:08.638Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-cs]: Loaded con
tributions.
2022-12-22T11:43:08.641Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-de]: Loaded con
tributions.
2022-12-22T11:43:08.645Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-es]: Loaded con
tributions.
2022-12-22T11:43:08.647Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-fr]: Loaded con
tributions.
2022-12-22T11:43:08.650Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-hu]: Loaded con
tributions.
2022-12-22T11:43:08.652Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-it]: Loaded con
tributions.
2022-12-22T11:43:08.655Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-ja]: Loaded con
tributions.
2022-12-22T11:43:08.658Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-ko]: Loaded con
tributions.
2022-12-22T11:43:08.662Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-nl]: Loaded con
tributions.
2022-12-22T11:43:08.664Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-pl]: Loaded con
tributions.
2022-12-22T11:43:08.667Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-pt-br]: Loaded
contributions.
2022-12-22T11:43:08.670Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-ru]: Loaded con
tributions.
2022-12-22T11:43:08.672Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-tr]: Loaded con
tributions.
2022-12-22T11:43:08.676Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-uk]: Loaded con
tributions.
2022-12-22T11:43:08.679Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-zh-hans]: Loade
d contributions.
2022-12-22T11:43:08.681Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4] Load contributions of 21 plugins: 187.9 ms [Fi
nished 6.188 s after frontend start]
2022-12-22T11:43:09.124Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2022-12-22T11:43:09.125Z root WARN a registered grammar configuration for 'cpp' language is overridden
[8068:1222/134309.224:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.226:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.229:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.232:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.234:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.238:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.241:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.246:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.249:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.251:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.254:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.257:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.260:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.263:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.266:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.269:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.271:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.274:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.280:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.282:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.285:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.287:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.290:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.294:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.297:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.299:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.301:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.304:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.317:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.318:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.322:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.324:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.328:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.331:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.333:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.336:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.339:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.341:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.345:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.348:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.352:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.355:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.357:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.361:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.364:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.367:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.369:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.371:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.374:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.377:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.380:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.382:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.384:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.386:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.389:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134309.393:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2022-12-22T11:43:09.767Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): PluginManagerExtImpl/init()
2022-12-22T11:43:09.771Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(cortex-debug@1.5.1 with C:\Pr
ogram Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2022-12-22T11:43:09.780Z root INFO [hosted-plugin: 24464] Debugger contribution has been registered: cortex-debug
2022-12-22T11:43:09.784Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-arduino-tools@0.0.2-be
ta.5 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2022-12-22T11:43:09.786Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(cpp@1.52.1 with C:\Program Fi
2022-12-22T11:43:09.787Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(json@1.46.1 with C:\Program F
2022-12-22T11:43:09.791Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(json-language-features@1.46.1
PLUGIN_HOST(24464): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_mod
2022-12-22T11:43:09.794Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-cs@1.53.
2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2022-12-22T11:43:09.797Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-de@1.53.
PLUGIN_HOST(24464): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_mod
2022-12-22T11:43:09.800Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-fr@1.53.
PLUGIN_HOST(24464): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_mod
2022-12-22T11:43:09.802Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-it@1.53.
PLUGIN_HOST(24464): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_mod
2022-12-22T11:43:09.805Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-ko@1.53.
PLUGIN_HOST(24464): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_mod
2022-12-22T11:43:09.807Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-pl@1.53.
PLUGIN_HOST(24464): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_
2022-12-22T11:43:09.810Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-ru@1.53.
PLUGIN_HOST(24464): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_mod
2022-12-22T11:43:09.814Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): initializing(vscode-language-pack-uk@1.48.
3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(24464): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\nod
2022-12-22T11:43:09.826Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): PluginManagerExtImpl/loadPlugin(C:\Program
Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2022-12-22T11:43:09.935Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): PluginManagerExtImpl/loadPlugin(C:\Program
Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
[8068:1222/134310.543:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.544:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.547:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.550:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.552:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.554:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.557:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.559:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.562:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.565:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.567:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.569:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.572:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.575:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.578:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.580:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.583:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.584:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.587:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.589:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.592:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.595:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.597:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.600:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.602:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.605:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.607:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.610:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.646:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.647:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.648:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.651:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.653:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.656:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.658:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.662:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.664:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.666:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.669:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.671:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.674:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.678:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.680:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.682:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.685:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.687:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.689:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.692:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.695:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.698:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.700:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.702:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.705:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.708:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.710:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.713:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.716:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.718:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.747:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.748:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.751:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.753:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.756:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.758:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.760:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.763:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.765:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.767:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.770:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.772:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.775:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.778:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.780:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.782:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.785:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.787:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.789:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.791:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.792:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.797:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.799:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.802:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.804:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.806:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.809:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.812:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.814:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2022-12-22T11:43:10.838Z root INFO Frontend application start: 5206.4 ms [Finished 10.997 s after backend start]
2022-12-22T11:43:10.853Z root INFO Replace loading indicator with ready workbench UI (animation): 1294.2 ms [Finished 7.
484 s after frontend start]
2022-12-22T11:43:10.854Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2022-12-22T11:43:10.855Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketP
airColorization.enabled"
Checking for update
2022-12-22T11:43:10.895Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][marus25.cortex-debug]: Started plugin.
2022-12-22T11:43:10.896Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][arduino.vscode-arduino-tools]: Started plugin.
2022-12-22T11:43:10.898Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][vscode.cpp]: Started plugin.
2022-12-22T11:43:10.901Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][vscode.json]: Started plugin.
2022-12-22T11:43:10.903Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][vscode.json-language-features]: Started plugin
2022-12-22T11:43:10.905Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-bg]: Started pl
ugin.
2022-12-22T11:43:10.909Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-cs]: Started pl
ugin.
2022-12-22T11:43:10.911Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-de]: Started pl
ugin.
2022-12-22T11:43:10.915Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-es]: Started pl
ugin.
2022-12-22T11:43:10.916Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-fr]: Started pl
ugin.
2022-12-22T11:43:10.919Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-hu]: Started pl
ugin.
2022-12-22T11:43:10.921Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-it]: Started pl
ugin.
2022-12-22T11:43:10.926Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-ja]: Started pl
ugin.
2022-12-22T11:43:10.929Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-ko]: Started pl
ugin.
2022-12-22T11:43:10.932Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-nl]: Started pl
ugin.
2022-12-22T11:43:10.934Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-pl]: Started pl
ugin.
2022-12-22T11:43:10.937Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-pt-br]: Started
plugin.
2022-12-22T11:43:10.939Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-ru]: Started pl
ugin.
2022-12-22T11:43:10.941Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-tr]: Started pl
ugin.
2022-12-22T11:43:10.944Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-uk]: Started pl
ugin.
2022-12-22T11:43:10.947Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4][ms-ceintl.vscode-language-pack-zh-hans]: Start
ed plugin.
[8068:1222/134310.990:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.991:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.995:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.997:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134310.999:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.002:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.004:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.007:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.009:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.012:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.014:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.017:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.019:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.021:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.024:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.026:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.029:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.032:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.034:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.036:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.038:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.040:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.043:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.046:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.049:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.051:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.053:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.055:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.057:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.144:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.145:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.149:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.151:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.154:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.156:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.159:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.163:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.166:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.168:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.171:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.173:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.176:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.178:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.182:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.184:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.186:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.189:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.191:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.195:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.198:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.200:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.203:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.205:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.207:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.210:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.214:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.216:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.219:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.298:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.299:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.303:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.304:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.309:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.315:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.318:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.321:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.326:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.330:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.334:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.336:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.338:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.341:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.343:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.347:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.349:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.351:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.353:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.356:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.358:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.361:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.365:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.367:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.369:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.372:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.374:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.377:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.379:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.482:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.484:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.487:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.488:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.491:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.497:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.503:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.504:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.508:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.510:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.513:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.515:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.518:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.520:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.523:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.525:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.527:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.531:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.533:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.535:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.538:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.540:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.543:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.546:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.549:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.551:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.554:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.556:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.559:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
Update for version 2.0.3 is not available (latest version: 2.0.3, downgrade is allowed).
[8068:1222/134311.659:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.660:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.664:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.665:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.667:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.670:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.672:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.675:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.677:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.680:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.683:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.685:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.687:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.689:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.692:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.694:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.698:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.700:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.702:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.705:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.708:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.710:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.714:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.716:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.719:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.721:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.723:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.726:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.728:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.856:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.861:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.862:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.864:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.867:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.869:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.872:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.874:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.876:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.879:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.882:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.884:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.889:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.893:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.895:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.898:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.900:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.903:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.905:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.908:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.910:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.914:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.916:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.918:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.920:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.922:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.925:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134311.929:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2022-12-22T11:43:13.193Z root ERROR ---- !!!SLOW!!! DURATION: search took 2120.523 ms. Args: [{"type":"Updatable"}] ----
2022-12-22T11:43:13.202Z root INFO [hosted-plugin: 24464] PLUGIN_HOST(24464): PluginManagerExtImpl/loadPlugin(C:\Program
Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2022-12-22T11:43:13.272Z root INFO [hosted-plugin: 24464] Debug configuration provider has been registered: cortex-debug
, trigger: 1
2022-12-22T11:43:13.279Z root INFO [hosted-plugin: 24464] GDB server console created
[8068:1222/134313.355:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.356:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.360:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.361:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.364:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.366:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.368:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.371:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.373:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.376:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.378:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.382:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.384:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.386:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.389:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.391:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.393:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.395:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.399:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.401:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.403:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.406:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.408:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.411:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.413:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.416:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.418:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.420:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.423:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.426:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.590:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.591:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.592:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.596:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.597:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.599:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.602:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.604:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.607:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.609:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.611:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.614:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.617:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.619:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.622:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.624:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.626:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.629:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.632:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.634:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.636:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.639:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.641:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.644:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.646:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.649:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.652:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.654:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.656:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.658:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
[8068:1222/134313.661:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters
2022-12-22T11:43:13.696Z root INFO [b2f30c61-1b68-4ce7-9100-7d5b103851c4] Start of 21 plugins: 5064.5 ms [Finished 11.27
3 s after frontend start]
[21908:1222/134459.966:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
PS C:\Program Files\Arduino IDE>
