PS C:\Users\tid\AppData\Local\Arduino15\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.0
Starting backend process. PID: 13840
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/tid/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-04-20T12:29:09.949Z root INFO Backend Object.initialize: 3.2 ms [Finished 0.904 s after backend start]
2023-04-20T12:29:09.949Z root INFO Backend Object.configure: 2.6 ms [Finished 0.904 s after backend start]
2023-04-20T12:29:09.950Z root INFO Backend MessagingContribution.onStart: 1.0 ms [Finished 0.904 s after backend start]
2023-04-20T12:29:09.950Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 0.932 s after backend start]
2023-04-20T12:29:09.951Z root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 0.932 s after backend start]
2023-04-20T12:29:09.952Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 0.932 s after backend start]
2023-04-20T12:29:09.952Z root INFO Backend PluginLocalizationBackendContribution.initialize: 28.3 ms [Finished 0.932 s after backend start]
2023-04-20T12:29:09.953Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 0.932 s after backend start]
2023-04-20T12:29:09.953Z root INFO Backend ElectronTokenBackendContribution.configure: 1.1 ms [Finished 0.934 s after backend start]
2023-04-20T12:29:09.954Z config INFO >>> Initializing CLI configuration...
2023-04-20T12:29:09.954Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 0.934 s after backend start]
2023-04-20T12:29:09.954Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 0.934 s after backend start]
2023-04-20T12:29:09.955Z config INFO Loading CLI configuration from c:\Users\tid\.arduinoIDE\arduino-cli.yaml...
2023-04-20T12:29:09.955Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 0.935 s after backend start]
2023-04-20T12:29:09.955Z root INFO Backend ArduinoDaemonImpl.onStart: 0.8 ms [Finished 0.936 s after backend start]
2023-04-20T12:29:09.955Z root INFO Backend NodeFileUploadService.configure: 1.7 ms [Finished 0.936 s after backend start]
2023-04-20T12:29:09.955Z daemon INFO Starting daemon from C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-04-20T12:29:09.956Z discovery-log INFO start
2023-04-20T12:29:09.956Z discovery-log INFO start new deferred
2023-04-20T12:29:09.956Z root INFO Backend HostedPluginLocalizationService.initialize: 0.3 ms [Finished 0.937 s after backend start]
2023-04-20T12:29:09.956Z root INFO Backend BoardDiscovery.onStart: 0.8 ms [Finished 0.937 s after backend start]
2023-04-20T12:29:09.956Z root INFO Backend FileDownloadEndpoint.configure: 0.7 ms [Finished 0.937 s after backend start]
2023-04-20T12:29:09.956Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 0.939 s after backend start]
2023-04-20T12:29:09.956Z root INFO Backend PluginApiContribution.configure: 0.3 ms [Finished 0.939 s after backend start]
2023-04-20T12:29:09.957Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 0.939 s after backend start]
2023-04-20T12:29:09.957Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 0.940 s after backend start]
2023-04-20T12:29:09.957Z root INFO Backend PlotterBackendContribution.configure: 0.7 ms [Finished 0.940 s after backend start]
2023-04-20T12:29:09.960Z root INFO Theia app listening on http://localhost:64566.
2023-04-20T12:29:09.961Z root INFO Finished starting backend application: 4.6 ms [Finished 0.944 s after backend start]
2023-04-20T12:29:09.972Z root WARN The local plugin referenced by local-dir:/c%3A/Users/tid/.arduinoIDE/plugins does not exist.
2023-04-20T12:29:09.972Z root WARN The local plugin referenced by local-dir:/c%3A/Users/tid/.arduinoIDE/extensions does not exist.
2023-04-20T12:29:09.973Z root WARN The local plugin referenced by local-dir:C:\Users\tid\.arduinoIDE\plugins does not exist.
2023-04-20T12:29:09.990Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.990Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-04-20T12:29:09.991Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.994Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-04-20T12:29:09.994Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.995Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-04-20T12:29:09.995Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.996Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-04-20T12:29:09.996Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.997Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-04-20T12:29:09.997Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.997Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-04-20T12:29:09.998Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.998Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-04-20T12:29:09.999Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:09.999Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-04-20T12:29:10.000Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.000Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-04-20T12:29:10.001Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.001Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-04-20T12:29:10.002Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.003Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-04-20T12:29:10.004Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.008Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-04-20T12:29:10.009Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.010Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-04-20T12:29:10.010Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.011Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-04-20T12:29:10.011Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.011Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-04-20T12:29:10.012Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.012Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-04-20T12:29:10.013Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.013Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-04-20T12:29:10.014Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.015Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-04-20T12:29:10.015Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.017Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-04-20T12:29:10.018Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.019Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-04-20T12:29:10.019Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T12:29:10.024Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-04-20T12:29:10.029Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\tid\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\tid\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\tid\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-04-20T12:29:10.029Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-04-20T12:29:10.029Z config INFO Loaded the CLI configuration.
2023-04-20T12:29:10.031Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/tid/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/tid/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-04-20T12:29:10.031Z config INFO Validating the CLI configuration...
2023-04-20T12:29:10.033Z config INFO The CLI config is valid.
2023-04-20T12:29:10.033Z config INFO <<< Initialized the CLI configuration.
2023-04-20T12:29:10.044Z root INFO Resolve plugins list: 89.1 ms [Finished 1.027 s after backend start]
2023-04-20T12:29:10.047Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 3.0 ms [Finished 1.030 s after backend start]
2023-04-20T12:29:10.049Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.3 ms [Finished 1.032 s after backend start]
2023-04-20T12:29:10.055Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 5.7 ms [Finished 1.038 s after backend start]
2023-04-20T12:29:10.058Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 3.4 ms [Finished 1.042 s after backend start]
2023-04-20T12:29:10.059Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.9 ms [Finished 1.043 s after backend start]
2023-04-20T12:29:10.109Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 49.5 ms [Finished 1.092 s after backend start]
2023-04-20T12:29:10.154Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 45.1 ms [Finished 1.137 s after backend start]
2023-04-20T12:29:10.243Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 89.6 ms [Finished 1.227 s after backend start]
2023-04-20T12:29:10.289Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 45.4 ms [Finished 1.272 s after backend start]
2023-04-20T12:29:10.317Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 27.9 ms [Finished 1.300 s after backend start]
2023-04-20T12:29:10.341Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 24.2 ms [Finished 1.324 s after backend start]
2023-04-20T12:29:10.371Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 29.6 ms [Finished 1.354 s after backend start]
2023-04-20T12:29:10.402Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 31.0 ms [Finished 1.385 s after backend start]
2023-04-20T12:29:10.442Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 40.3 ms [Finished 1.426 s after backend start]
2023-04-20T12:29:10.455Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 12.4 ms [Finished 1.438 s after backend start]
2023-04-20T12:29:10.486Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 31.3 ms [Finished 1.469 s after backend start]
2023-04-20T12:29:10.516Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 30.4 ms [Finished 1.500 s after backend start]
2023-04-20T12:29:10.550Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 33.4 ms [Finished 1.533 s after backend start]
2023-04-20T12:29:10.581Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 31.0 ms [Finished 1.564 s after backend start]
2023-04-20T12:29:10.604Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 22.8 ms [Finished 1.587 s after backend start]
2023-04-20T12:29:10.633Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\tid\AppData\Local\Arduino15\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 28.7 ms [Finished 1.616 s after backend start]
2023-04-20T12:29:10.633Z root INFO Deploy plugins list: 89.1 ms [Finished 1.616 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-04-20T12:29:11.308Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 138.4 ms [Finished 1.284 s after frontend start]
2023-04-20T12:29:13.362Z daemon INFO INFO[0000] Using config file: c:\Users\tid\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.2
INFO[0000] Executing `arduino-cli daemon`
2023-04-20T12:29:13.376Z daemon INFO Daemon is now listening on 127.0.0.1:51525
{"IP":"127.0.0.1","Port":"51525"}
2023-04-20T12:29:13.376Z daemon INFO Daemon is running.
2023-04-20T12:29:13.389Z daemon INFO INFO[0000] Loading hardware from: C:\Users\tid\AppData\Local\Arduino15\packages
2023-04-20T12:29:13.390Z daemon INFO INFO[0000] Loading libraries index file index="C:\\Users\\tid\\AppData\\Local\\Arduino15\\library_index.json"
2023-04-20T12:29:13.393Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\tid\AppData\Local\Arduino15\package_index.json: open C:\Users\tid\AppData\Local\Arduino15\package_index.json: Le fichier sp├®cifi├® est introuvable.
2023-04-20T12:29:13.393Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2023-04-20T12:29:13.395Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2023-04-20T12:29:13.396Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\tid\AppData\Local\Arduino15\library_index.json: Le fichier sp├®cifi├® est introuvable.
2023-04-20T12:29:13.398Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-04-20T12:29:13.399Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\tid\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="C:\\Users\\tid\\Documents\\Arduino\\libraries" location=user
2023-04-20T12:29:13.400Z daemon INFO INFO[0000] Updating libraries index
INFO[0000] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-04-20T12:29:13.401Z daemon INFO INFO[0000] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-04-20T12:29:13.402Z root INFO core-client-provider [platform-index]
2023-04-20T12:29:13.403Z daemon INFO INFO[0000] Starting download url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2023-04-20T12:29:13.404Z root INFO core-client-provider [library-index]
