IDE hangs on startup
I have problem while install Ardunio IDE 2.3.6,
After installed it freeze on this page
I already tried restarting both the program and my laptop, but it didn't help.
Has anyone experienced this before or have any suggestions?
Try synchronizing your system clock, and ensuring that you are connected to the internet. If those two things don't help, generate a log to help diagnose the issue. If you want us to look at you log, make sure that you use the <CODE/> button in the forum editor when pasting the log contents.
Thank you for your suggestion. I synchronized my system, and that solved the issue. Everything is working fine now!
@ratcha22 I'm glad I could solve your problem. To mark this question as solved (which helps future forum readers who have the same question), and allow the thread to be closed, please check the :white_check_mark: "Solution" checkbox below my answer above.
