IDE Help
[blushing] I think I found the problem.
The error I found was in the setup section of code,when I assign the pyro output pins…
Here is the error.
// Assign Pyro Firing Pins
  Serial.println("Assigning pyro firing pins");
  for(int thisPin = 0; thisPin < 7; thisPin++)
   pinMode(PyroPin[thisPin], OUTPUT);
The error is the thisPin < 7 of the for loop statement. There is only 6 ( 0 thru 5) pyro pins. Thus the loop tried to assign PyroPin[6], which is not a valued array element. The result is it screwed up the USB channel and hang.
This is the proper code, that assign the pyro output pins:
  for(int thisPin = 0; thisPin <= 5; thisPin++)
Now every thing works properly, with out errors.
Rocket Nut (red faced)
:slight_smile:
