the IDE do not reconnace the for loop and the serial monitor?
do some body knows how to fix it
int blueontime = 500;
int blueoftime = 500;
pinMode (redLEDpin,OUTPUT);
pinMode (blueLEDpin, OUTPUT);
for (int j=1;j<=10;j=j+1);{ // it does,t reconnice the "for" loop ???
digitalWrite (redLEDpin, HIGH);
delay (ontimered);
digitalWrite (redLEDpin, LOW);
delay (oftimered);}
digitalWrite (blueLEDpin, HIGH);
delay (blueontime);
digitalWrite (blueLEDpin,LOW);
delay (blueoftime); this problem
The trailing semicolon should not be there
There are no serial commands in the code that you posted
Your partial code does not compile so it's not going to do anything useful.
You will need a Serial.begin() and some other Serial commands before the serial monitor shows you anything.
Steve
for (int j=1;j<=10;j=j+1) ; {
The 'for' loop can only contain one statement or one block of statements surrounded by '{' and '}'. The ';' is a statement so what the compiler sees is:
for (int j=1; j<=10; j=j+1)
; // Do this null statement ten times...
// ... then do this block of statements once.
