IDE Version: 2.0.2
Date: 2022-11-17T11:52:32.665Z
CLI Version: 0.29.0 [76251df9]
Linux version FYI
for the last week IDE updater wants to update MFRC522@1.4.10 however, it states "Already installed MFRC522@1.4.10. Is there a reason for this behavior, something i'm missing, author error or version issue?
If you enable verbose output during compilation under file -> preferences in the IDE, you will find some lines containing the word candidates and lines telling you which library the IDE used.
But it had to do with searching through all of the libraries in your:
/libraries folder for any other libraries that have the same name property within their library.properties file. I used global search in sublime-text editor, but have also used grep
Some of them may be obvious, like same name, but with something at the end like -master or the like. Others may be more subtle like directory names like arduino_12345 (or some other number), where Arduino 1.x may have tried to install a library, had a failure and left that directory...
