I want to be able to enter, as required, a number (1-20) in IDE monitor and have that number LED turn on momentarily using 3 of the multiplexing SH74HC595N. Have found similar projects but not using the entry as required into the monitor.
The info on the multiplexer is ok and the flash rates etc, all leds will be the same single flash rate so do I use a variable? Need the most simple code for having the entry in the monitor (single number or say 4 numbers in series) processed thru multiplexer to specific leds
if (Serial.available()>1){
tensDigit = Serial.read() - 0x30; // result is 0 to 9
onesDigit = Serial.read() - 0x30; // result is 0 to 9
ledNumber = (tensDigit x 10) + onesDigit; // result is 00 to 19
unsigned ledTurnOn = 0x01 << ledNumber; // put a 1 in the correct bit location of a 32-bit unsigned long
// now break up the 4 bytes and send them out, left as an an exercise for the reader
Servo test code where a numeric command and a servo designator are sent from the serial monitor. You might use a similar approach for your LEDs.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
