IDE on RPi 4 - Unable to install WiFiNINA library
Hello,
I have a Nano 33 IoT and am using the IDE running on a Raspberry Pi (RPi 4). I hace tried to install the WiFiNINA library using the Manage Libraries option but nothing is installed.
It is not there in the Include library list under the Sketch option.
I have tried to run the ScanNetworks example sketch but I get the error message "WiFi shield not found".
I suspect that the #include <WiFi.h> should be replaced by #include <WiFiNINA.h> but, of course, I need that library.
Any suggestions about what I should do?
Regards,
Paul.
Make to install the board package and set the board type correctly.
PROBLEM RESOLVED
Hello Poki,
Yes I did install the board package. The problem was with installing the WiFiNINA library.
The problem turned out to be a file/directory permissions problem. The IDE was unable to write to the libraries directory.
Anyway, a solution to the problem is to run the IDE as root. I modified the shortcut command to be "sudo /usr/local/bin/arduino".
That did the trick. (Note the directory in which I placed the IDE.)
I should really sort out what the permissions problem is but this fix will do for now.
Regards,
Paul.
