Hello,
Thanks for the reply.
Here’s the error message:
Arduino: 1.8.10 (Linux), Board: “Arduino NANO 33 IoT”
Sketch uses 34736 bytes (13%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port /dev/ttyACM0
PORTS {/dev/ttyACM0, /dev/ttyAMA0, } / {/dev/ttyACM0, /dev/ttyAMA0, } => {}
Uploading using selected port: /dev/ttyACM0
/root/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3/bossac -i -d --port=ttyACM0 -U true -i -e -w -v /tmp/arduino_build_749485/ssd1306_128x64_i2c.ino.bin -R
An error occurred while uploading the sketch
No device found on ttyACM0
“Show verbose output during compilation”
option enabled in File → Preferences.
A new piece of information: The Nano is not faulty (probably). I am able to use the Web Editor on a Mac - this uploaded successfully. The problem appears to be with the IDE on the RPi.
I hope that this information helps. I shall look out for your reply.
Regards,
Paul.
