IDE problem windows 10
It's the first time I use arduino on this PC and after dl it I try to start I got the window and it close. The logs are clear so if somebody can help me
Hi @frunix. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to run the Arduino IDE from the command line, then share the output.
Please do this:
  1. Start File Explorer (AKA Windows Explorer).
  2. Open the Arduino IDE's installation folder (usually C:\Program Files (x86)\Arduino)
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. Click "Open PowerShell window here" (or "Open command window here" if using Windows 7). PowerShell (or cmd if using Windows 7) will now open with the current directory set to the Arduino IDE installation folder.
  5. Type .\arduino_debug
  6. Press Enter. Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  7. Wait for the Arduino IDE to finish starting, or failing to start.
  8. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  9. Right click on the title bar of the PowerShell window.
  10. Click Edit > Select All. This will select all the text in the PowerShell window.
  11. Press Ctrl+C. This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
    Code block
  14. Press Ctrl+V. This will paste the compilation output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Hopefully that will give us some information we can use to help you with the problem.
Hi PS C:\Program Files (x86)\Arduino> .\arduino_debug
Set log4j store directory C:\Users\Hecto\AppData\Local\Arduino15
Chargement de la configuration
Initialisation des paquets...
DEBUG StatusLogger Using ShutdownCallbackRegistry class org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry
DEBUG StatusLogger Not in a ServletContext environment, thus not loading WebLookup plugin.
DEBUG StatusLogger AsyncLogger.ThreadNameStrategy=UNCACHED (user specified null, default is UNCACHED)
TRACE StatusLogger Using default SystemClock for timestamps.
DEBUG StatusLogger org.apache.logging.log4j.core.util.SystemClock does not support precise timestamps.
DEBUG StatusLogger Took 0,111497 seconds to load 209 plugins from sun.misc.Launcher$AppClassLoader@af3868
DEBUG StatusLogger PluginManager 'Converter' found 44 plugins
DEBUG StatusLogger Starting OutputStreamManager SYSTEM_OUT.false.false-1
DEBUG StatusLogger Starting LoggerContext[name=af3868, org.apache.logging.log4j.core.LoggerContext@1381794]...
DEBUG StatusLogger Reconfiguration started for context[name=af3868] at URI null (org.apache.logging.log4j.core.LoggerContext@1381794) with optional ClassLoader: null
DEBUG StatusLogger PluginManager 'ConfigurationFactory' found 4 plugins
DEBUG StatusLogger Missing dependencies for Yaml support, ConfigurationFactory org.apache.logging.log4j.core.config.yaml.YamlConfigurationFactory is inactive
DEBUG StatusLogger Using configurationFactory org.apache.logging.log4j.core.config.ConfigurationFactory$Factory@139a379
TRACE StatusLogger Trying to find [log4j2-testaf3868.properties] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-testaf3868.properties] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-testaf3868.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-testaf3868.yml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-testaf3868.yml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-testaf3868.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-testaf3868.yaml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-testaf3868.yaml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-testaf3868.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-testaf3868.json] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-testaf3868.json] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-testaf3868.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-testaf3868.jsn] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-testaf3868.jsn] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-testaf3868.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-testaf3868.xml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-testaf3868.xml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-testaf3868.xml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.properties] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-test.properties] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-test.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.yml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-test.yml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-test.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.yaml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-test.yaml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-test.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.json] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-test.json] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-test.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.jsn] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-test.jsn] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-test.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.xml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2-test.xml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2-test.xml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2af3868.properties] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2af3868.properties] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2af3868.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2af3868.yml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2af3868.yml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2af3868.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2af3868.yaml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2af3868.yaml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2af3868.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2af3868.json] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2af3868.json] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2af3868.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2af3868.jsn] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2af3868.jsn] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2af3868.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2af3868.xml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2af3868.xml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2af3868.xml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.properties] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2.properties] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.yml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2.yml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.yaml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2.yaml] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.json] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2.json] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.jsn] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
TRACE StatusLogger Trying to find [log4j2.jsn] using sun.misc.Launcher$AppClassLoader@af3868 class loader.
TRACE StatusLogger Trying to find [log4j2.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.xml] using context class loader sun.misc.Launcher$AppClassLoader@af3868.
DEBUG StatusLogger Closing JarURLInputStream sun.net.www.protocol.jar.JarURLConnection$JarURLInputStream@2bce4f
DEBUG StatusLogger Apache Log4j Core 2.12.0 initializing configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml]
DEBUG StatusLogger Installed 1 script engine
DEBUG StatusLogger Oracle Nashorn version: 1.8.0_191, language: ECMAScript, threading: Not Thread Safe, compile: true, names: [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], factory class: jdk.nashorn.api.scripting.NashornScriptEngineFactory
INFO StatusLogger Scanning for classes in '/C:/Program Files (x86)/Arduino/lib/arduino-core.jar' matching criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Compiler$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Compiler$BuilderAction matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Compiler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.CompilerProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.CompilerUtils matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Constants matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.DefaultUncaughtExceptionHandler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.LoadVIDPIDSpecificPreferences matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.MessageConsumerOutputStream matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.MyStreamPumper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.ProgressAwareMessageConsumer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.UploaderUtils matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ConsoleProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.DownloadableContribution matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.DownloadableContributionVersionComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.DownloadableContributionsDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.GPGDetachedSignatureVerifier matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.GZippedJsonDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.JsonDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.NoopProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.SignatureVerifier matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.VersionComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.VersionHelper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.filters.DownloadableContributionWithVersionPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ContributedLibrary matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ContributedLibraryDependency matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ContributedLibraryReleases matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.EmptyLibrariesIndex matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibrariesIndex matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibrariesIndexer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibraryInstaller matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.UnavailableContributedLibrary matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedBoard matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedHelp matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedPackage matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedPlatform matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedTargetPackage matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedTargetPlatform matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedTool matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedToolReference matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributionInstaller matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributionsIndex matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributionsIndexer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.EmptyContributionIndex matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.HostDependentDownloadableContribution matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.PackageIndexFilenameFilter matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.TestPackageIndexFilenameFilter matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.filters.PlatformArchitecturePredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.files.DeleteFilesOnShutdown matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.filters.FileExecutablePredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.ExternalProcessOutputParser matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.I18NAwareMessageConsumer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.Language matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.Languages matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.net.CustomProxySelector$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.net.CustomProxySelector matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.net.PACSupportMethods matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.os.windows.Win32KnownFolders matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.BoardPort matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.Discovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.DiscoveryManager matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.Uploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.UploaderFactory matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.NetworkDiscovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.PluggableDiscovery$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.PluggableDiscovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.PluggableDiscoveryMessage matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.network.BoardReachabilityFilter matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.serial.SerialDiscovery$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.serial.SerialDiscovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.NoInteractionUserInfo matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SCP matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSH matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHClientSetupChainRing matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHConfigFileSetup$ConfigWrapper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHConfigFileSetup$OpenSSHConfigWrapper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHConfigFileSetup matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHPwdSetup matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.GenericNetworkUploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.MergeSketchWithBooloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.SSHUploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.SerialUploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.ArchiveExtractor matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.FileHash matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.MultiStepProgress matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.Pair matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.Progress matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.ReverseComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.CacheControl matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloader$Status matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloaderCache$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloaderCache$FileCached matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloaderCache matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.HttpConnectionManager matches criteria annotated with @Plugin
INFO StatusLogger Scanning for classes in '/C:/Program Files (x86)/Arduino/lib/pde.jar' matching criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.ConsoleOutputStream matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.UpdatableBoardsLibsFakeURLsHandler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.BuiltInCoreIsNewerCheck matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ContributionsSelfCheck$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ContributionsSelfCheck matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibraryOfSameTypeComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibraryTypeComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.filters.UpdatableLibraryPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryReleasesComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellEditor matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellJPanel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellRenderer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownAllLibraries matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownInstalledLibraryItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownInstalledLibraryItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfCategoryItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfCategoryItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfTypeItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfTypeItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownUpdatableLibrariesItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownUpdatableLibrariesItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibrariesIndexTableModel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibraryManagerUI$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibraryManagerUI$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibraryManagerUI matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.MultiLibraryInstallDialog$Result matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.MultiLibraryInstallDialog matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.filters.CategoryPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.filters.UpdatablePlatformPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformReleases matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformTableCellEditor matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformTableCellJPanel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformTableCellRenderer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributionIndexTableModel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributionManagerUI$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributionManagerUI matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.DropdownAllCoresItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.DropdownCoreOfCategoryItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.DropdownUpdatableCoresItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.DropdownItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilterJTextField$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilterJTextField$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilterJTextField matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilteredAbstractTableModel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialogUncaughtExceptionHandler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerTableCell matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.ProgressJProgressBar matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.listeners.AbstractKeyListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.listeners.DelegatingKeyListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.MonitorFactory matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.formatter.AStyle matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.formatter.AStyleInterface matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.Event matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.EventListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.JMenuUtils matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$6 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$7 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$8 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$9 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$OptionalButtonCallbacks matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.SplashScreenHelper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.StubMenuListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$6 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$6 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$7 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$8 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$9 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$WarningItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences matches criteria annotated with @Plugin
DEBUG StatusLogger Took 0,697209 seconds to load 0 plugins from package cc.arduino
DEBUG StatusLogger PluginManager 'Core' found 118 plugins
DEBUG StatusLogger PluginManager 'Level' found 0 plugins
DEBUG StatusLogger PluginManager 'Lookup' found 13 plugins
DEBUG StatusLogger Building Plugin[name=layout, class=org.apache.logging.log4j.core.layout.PatternLayout].
TRACE StatusLogger TypeConverterRegistry initializing.
DEBUG StatusLogger PluginManager 'TypeConverter' found 26 plugins
DEBUG StatusLogger PatternLayout$Builder(pattern="%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX}{UTC} %p %c{1.}:%L [%t] %m%n", PatternSelector=null, Configuration(Arduino), Replace=null, charset="null", alwaysWriteExceptions="null", disableAnsi="null", noConsoleNoAnsi="null", header="null", footer="null")
DEBUG StatusLogger Building Plugin[name=appender, class=org.apache.logging.log4j.core.appender.ConsoleAppender].
DEBUG StatusLogger ConsoleAppender$Builder(target="SYSTEM_ERR", follow="null", direct="null", bufferedIo="null", bufferSize="null", immediateFlush="null", ignoreExceptions="null", PatternLayout(%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX}{UTC} %p %c{1.}:%L [%t] %m%n), name="Console", Configuration(Arduino), Filter=null, ={})
DEBUG StatusLogger Starting OutputStreamManager SYSTEM_ERR.false.false
DEBUG StatusLogger Building Plugin[name=SizeBasedTriggeringPolicy, class=org.apache.logging.log4j.core.appender.rolling.SizeBasedTriggeringPolicy].
DEBUG StatusLogger createPolicy(size="50 MB")
DEBUG StatusLogger Building Plugin[name=Policies, class=org.apache.logging.log4j.core.appender.rolling.CompositeTriggeringPolicy].
DEBUG StatusLogger createPolicy(={SizeBasedTriggeringPolicy(size=52428800)})
DEBUG StatusLogger Building Plugin[name=DefaultRolloverStrategy, class=org.apache.logging.log4j.core.appender.rolling.DefaultRolloverStrategy].
DEBUG StatusLogger DefaultRolloverStrategy$Builder(max="20", min="null", fileIndex="null", compressionLevel="null", ={}, stopCustomActionsOnError="null", tempCompressedFilePattern="null", Configuration(Arduino))
DEBUG StatusLogger Building Plugin[name=appender, class=org.apache.logging.log4j.core.appender.RollingFileAppender].
DEBUG StatusLogger RollingFileAppender$Builder(fileName="C:\Users\Hecto\AppData\Local\Arduino15/logs/application.log", filePattern="C:\Users\Hecto\AppData\Local\Arduino15/logs/application-%d{MM-dd-yyyy}-%i.log.gz", append="null", locking="null", Policies(CompositeTriggeringPolicy(policies=[SizeBasedTriggeringPolicy(size=52428800)])), DefaultRolloverStrategy(DefaultRolloverStrategy(min=1, max=20, useMax=true)), advertise="null", advertiseUri="null", createOnDemand="null", filePermissions="null", fileOwner="null", fileGroup="null", bufferedIo="null", bufferSize="null", immediateFlush="null", ignoreExceptions="false", PatternLayout(%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX}{UTC} %p %c{1.}:%L [%t] %m%n), name="RollingFile", Configuration(Arduino), Filter=null, ={})
TRACE StatusLogger New file 'C:\Users\Hecto\AppData\Local\Arduino15/logs/application.log' created = false
DEBUG StatusLogger Returning file creation time for C:\Users\Hecto\AppData\Local\Arduino15\logs\application.log
DEBUG StatusLogger Starting RollingFileManager C:\Users\Hecto\AppData\Local\Arduino15/logs/application.log
DEBUG StatusLogger PluginManager 'FileConverter' found 2 plugins
DEBUG StatusLogger Setting prev file time to 2021-08-12T01:28:52.911+0200
DEBUG StatusLogger Initializing triggering policy CompositeTriggeringPolicy(policies=[SizeBasedTriggeringPolicy(size=52428800)])
DEBUG StatusLogger Initializing triggering policy SizeBasedTriggeringPolicy(size=52428800)
DEBUG StatusLogger Building Plugin[name=appenders, class=org.apache.logging.log4j.core.config.AppendersPlugin].
DEBUG StatusLogger createAppenders(={Console, RollingFile})
DEBUG StatusLogger Building Plugin[name=AppenderRef, class=org.apache.logging.log4j.core.config.AppenderRef].
DEBUG StatusLogger createAppenderRef(ref="Console", level="INFO", Filter=null)
DEBUG StatusLogger createAppenderRef(ref="RollingFile", level="null", Filter=null)
DEBUG StatusLogger Building Plugin[name=root, class=org.apache.logging.log4j.core.config.LoggerConfig$RootLogger].
DEBUG StatusLogger createLogger(additivity="null", level="DEBUG", includeLocation="null", ={Console, RollingFile}, ={}, Configuration(Arduino), Filter=null)
DEBUG StatusLogger Building Plugin[name=loggers, class=org.apache.logging.log4j.core.config.LoggersPlugin].
DEBUG StatusLogger createLoggers(={root})
DEBUG StatusLogger Configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml] initialized
DEBUG StatusLogger Starting configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml]
DEBUG StatusLogger Started configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml] OK.
TRACE StatusLogger Stopping org.apache.logging.log4j.core.config.DefaultConfiguration@3c4f91...
TRACE StatusLogger DefaultConfiguration notified 1 ReliabilityStrategies that config will be stopped.
TRACE StatusLogger DefaultConfiguration stopping root LoggerConfig.
TRACE StatusLogger DefaultConfiguration notifying ReliabilityStrategies that appenders will be stopped.
TRACE StatusLogger DefaultConfiguration stopping remaining Appenders.
DEBUG StatusLogger Shutting down OutputStreamManager SYSTEM_OUT.false.false-1
DEBUG StatusLogger Shut down OutputStreamManager SYSTEM_OUT.false.false-1, all resources released: true
DEBUG StatusLogger Appender DefaultConsole-1 stopped with status true
TRACE StatusLogger DefaultConfiguration stopped 1 remaining Appenders.
TRACE StatusLogger DefaultConfiguration cleaning Appenders from 1 LoggerConfigs.
DEBUG StatusLogger Stopped org.apache.logging.log4j.core.config.DefaultConfiguration@3c4f91 OK
TRACE StatusLogger Reregistering MBeans after reconfigure. Selector=org.apache.logging.log4j.core.selector.ClassLoaderContextSelector@6a5539
TRACE StatusLogger Reregistering context (1/1): 'af3868' org.apache.logging.log4j.core.LoggerContext@1381794
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868,component=StatusLogger'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868,component=ContextSelector'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868,component=Loggers,name='
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868,component=Appenders,name=
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868,component=AsyncAppenders,name='
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=af3868,component=AsyncLoggerRingBuffer'
,subtype=RingBuffer'
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=af3868
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=af3868,component=StatusLogger
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=af3868,component=ContextSelector
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=af3868,component=Loggers,name=
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=af3868,component=Appenders,name=Console
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=af3868,component=Appenders,name=RollingFile
TRACE StatusLogger Using DummyNanoClock for nanosecond timestamps.
DEBUG StatusLogger Reconfiguration complete for context[name=af3868] at URI jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml (org.apache.logging.log4j.core.LoggerContext@1381794) with optional ClassLoader: null
DEBUG StatusLogger Shutdown hook enabled. Registering a new one.
DEBUG StatusLogger LoggerContext[name=af3868, org.apache.logging.log4j.core.LoggerContext@1381794] started OK.
Préparation des cartes
java.io.IOException: Le fournisseur de fichier cloud n?est pas en cours d'exécution
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(FileInputStream.java:255)
at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284)
at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
at java.io.InputStreamReader.read(InputStreamReader.java:184)
at java.io.BufferedReader.fill(BufferedReader.java:161)
at java.io.BufferedReader.readLine(BufferedReader.java:324)
at java.io.BufferedReader.readLine(BufferedReader.java:389)
at processing.app.legacy.PApplet.loadStrings(PApplet.java:270)
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:100)
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:74)
at processing.app.packages.UserLibrary.create(UserLibrary.java:77)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanLibrary(LibrariesIndexer.java:224)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanInstalledLibraries(LibrariesIndexer.java:201)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:161)
at cc.arduino.contributions.libraries.LibrariesIndexer.setLibrariesFolders(LibrariesIndexer.java:120)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:677)
at processing.app.Base.onBoardOrPortChange(Base.java:1333)
at processing.app.Base$11.actionPerformed(Base.java:1537)
at processing.app.Base.rebuildBoardsMenu(Base.java:1509)
at processing.app.Base.(Base.java:277)
at processing.app.Base.main(Base.java:150)
java.lang.NullPointerException
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:101)
DEBUG StatusLogger Stopping LoggerContext[name=af3868, org.apache.logging.log4j.core.LoggerContext@1381794]
DEBUG StatusLogger Stopping LoggerContext[name=af3868, org.apache.logging.log4j.core.LoggerContext@1381794]...
TRACE StatusLogger Unregistering 1 MBeans: [org.apache.logging.log4j2:type=af3868]
TRACE StatusLogger Unregistering 1 MBeans: [org.apache.logging.log4j2:type=af3868,component=StatusLogger]
TRACE StatusLogger Unregistering 1 MBeans: [org.apache.logging.log4j2:type=af3868,component=ContextSelector]
TRACE StatusLogger Unregistering 1 MBeans: [org.apache.logging.log4j2:type=af3868,component=Loggers,name=]
TRACE StatusLogger Unregistering 2 MBeans: [org.apache.logging.log4j2:type=af3868,component=Appenders,name=RollingFile, org.apache.logging.log4j2:type=af3868,component=Appenders,name=Console]
TRACE StatusLogger Stopping XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml]...
TRACE StatusLogger XmlConfiguration notified 2 ReliabilityStrategies that config will be stopped.
TRACE StatusLogger XmlConfiguration stopping 1 LoggerConfigs.
TRACE StatusLogger XmlConfiguration stopping root LoggerConfig.
TRACE StatusLogger XmlConfiguration notifying ReliabilityStrategies that appenders will be stopped.
TRACE StatusLogger XmlConfiguration stopping remaining Appenders.
DEBUG StatusLogger Shutting down RollingFileManager C:\Users\Hecto\AppData\Local\Arduino15/logs/application.log
DEBUG StatusLogger All asynchronous threads have terminated
DEBUG StatusLogger RollingFileManager shutdown completed with status true
DEBUG StatusLogger Shut down RollingFileManager C:\Users\Hecto\AppData\Local\Arduino15/logs/application.log, all resources released: true
DEBUG StatusLogger Appender RollingFile stopped with status true
DEBUG StatusLogger Shutting down OutputStreamManager SYSTEM_ERR.false.false
DEBUG StatusLogger Shut down OutputStreamManager SYSTEM_ERR.false.false, all resources released: true
DEBUG StatusLogger Appender Console stopped with status true
TRACE StatusLogger XmlConfiguration stopped 2 remaining Appenders.
TRACE StatusLogger XmlConfiguration cleaning Appenders from 2 LoggerConfigs.
DEBUG StatusLogger Stopped XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml] OK
DEBUG StatusLogger Stopped LoggerContext[name=af3868, org.apache.logging.log4j.core.LoggerContext@1381794] with status true
Here's the important part
(translation: "The cloud file provider is not running")
I think you'll find the explanation and solution from this issue report:
or from the #8283 issue report linked to from that one.
yeah I close onedrive I try with it
It's working thanks you sir :slight_smile:
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
