hello friend actually I am beginner to arduino and I am using arduino uno r3 and the problem I am facing is that I am able to upload programs like blink ,sweep but the programs which I have put in sketch which is motor test is not being upload to the board and it is showing an error
Arduino: 1.6.4 (Windows 8.1), Board: "Arduino Uno"
Build options changed, rebuilding all
MotorTest.pde:5:21: fatal error: AFMotor.h: No such file or directory
compilation terminated.
Error compiling.
enabled in File > Preferences.
please help me
Where did you download the AFMotor library to?
I downloaded it on the desktop and then I added it to ide and then included it in the ide
Where exactly is the AFMotor folder ?
Did you stop/start the IDE after installing the library ?
How have you #included the library in your program ?
yeah it is in C:\Program Files\Arduino\libraries.
first of all I downloaded a zip file in the desktop then I added it the library from sketch option in the menu bar
and then included it in the library from the same option
User contributed libraries are meant to go in the libraries folder of the sketches folder so that they remain available when the IDE is upgraded.
What is the name of the AFMotor library folder and the names of the files that it contains ?
AFMOTORS.PDE
AFMOTORS.TXT
EXAMPLES
README.TXT
KEYWORDS .TXT
What is the folder name that those 5 files are in?
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom....
they are in afmotor named folder and please tell sketch of what do you want
rishabhmahajan:
You need to be really exact about the folder and filenames. Upper/lowercase matters and the folder name must match that of the .h and .cpp files exactly.
As to the files you say you do have, no wonder you get the error message
Do you actually have the file anywhere and if so, where ?
