IDE recognizes Uno R3 board as Duemilanove
I have a clone Arduino that visually looks to be a Uno R3.
Yet, the IDE will not program a sketch if I select Uno. It will program if I select Duemilanove.
What is the explanation for this?
The manufacturer loaded the wrong bootloader into the chip.
Attach an ISP-programmer and do a "burn bootloader" with the Uno selected - problem solved.
// Per.
So, I would need another ATmega328P? http://arduino.cc/en/Tutorial/ArduinoISP
If I don't reprogram will anything be impacted?
ieee488: So, I would need another ATmega328P? http://arduino.cc/en/Tutorial/ArduinoISP
You can use it as it is now, or re-flash the bootloader with something like this http://www.ebay.com/itm/321455871442
// Per.
Great. Thank you for the link.
