IDE Shutdown after Splash-Screen
the bundled software and also the installer from download-section does not start.
arduino.exe --l4j-debug is not writing a log-file
what are the system requirements for arduino uno
XP or higher Win OS, then there is a misunderstanding with Win 7
§ 433 BGB
Hello cerotto24,
Welcome to the community. :slight_smile:
Right click "arduino.exe"--> propertirs--> compatibility--> change settings for all users--> select the checkbox "Run this program as an administrator".
The issue should be solved. Otherwise delete arduino dump folder & the other arduino folder from "My documents". Then re-unzip arduino ide to desktop. It should work. Otherwise you have to update the java.
All the best!
thanks, it's working
keep in mind to have a information about this Win OS installation issue (for arduino dev)
