ide : some simple questions
hello all
i had a good start with the ide, but unfortunalety some questions. very basic, but i didn’t find an answer anywhere
  • for what is the stop button?
  • do the upload button compile the sketch first or only uploading?
  • what makes auto format?
  • how can i send a serial command from the ide to the board? (serial_read_basic)
  • when i download led_blink, it needs several seconds until the execution starts? why ? is this optimizing? the same after a reset and a power on in stand-alone.
  • what means the white number in the footer of the ide?
thanks for any help in advance
one addition :
has the serial port configurations in the tools pull down an effect. 9600 baud work as well differnt ports…
thanks again
Not much.
It should compile the sketch first, but I think it only does so if you save the sketch first. To be safe, you should compile first.
It cleans up the indentation of your code, so that, for example, statement inside a block are indented two spaces.
Right now, you can’t. You’ll need to use another program like zterm (on the Mac) or HyperTerminal on Windows. This feature should be added to the IDE soon.
The delay when the board resets gives the bootloader time to see if a program is being uploaded to the board. If not, it will launch the program that’s already on the board. Using the same pause after uploading helped squeeze the bootloader into less space on the board.
I believe that’s the number of the line that you’re currently editing (that the cursor is on).
The serial port speed in the menu only controls the speed used by the serial monitor. It should match the speed passed to beginSerial() in the code of your sketch. The speed used to upload the program to the board is always 19200, regardless of the menu setting (but it can be editing in the preferences.txt file as described in the FAQ).
hello
thanks a lot for the detailed answers. it helps me a lot!
much greetings and all the best
