IDE stuck loading
I have just upgraded to IDE 2.3.6 and it is stuck loading - I just get the bouncing logo.
I am using a MacBook (Apple Silicon) running MacOS 15.3.1
Any suggestions?
Hi @oldcabel. I'm going to ask you to provide some additional information that might help us to identify the problem.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Open macOS Launchpad.
  3. Type terminal in the "Search" field.
  4. Click on the "Terminal" icon.
    A "zsh" window will open.
  5. Type the following command in the zsh window:
    "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
  6. Press the Enter key.
  7. Wait until you are sure the IDE startup has gone into the hang state
    (as indicated by no additional output being printed to the Terminal window).
  8. Switch back to the Terminal window if the Arduino IDE window took the focus.
  9. Press the Command+A keyboard shortcut.
    This will select all the text in the Terminal window.
  10. Press the Command+C keyboard shortcut.
    This will copy the selected text to the clipboard.
  11. Open a forum reply here by clicking the "Reply" button.
  12. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
  13. Press the Command+V keyboard shortcut.
    This will paste the output into the code block.
  14. Move the cursor outside of the code block markup before you add any additional text to your reply.
  15. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
it is not stopping - I have just pasted the first page or so - it appears to be repeating the same lines over and over
OldChrisAbel@Christians-MacBook-Pro ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.6
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.6" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-09T11:22:51.016Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.6","cliVersion":"1.2.0","buildDate":"2025-04-09T11:22:51.016Z"}
Starting backend process. PID: 85506
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/OldChrisAbel/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-04-23T10:52:28.032Z root INFO Backend u.initialize: 10.2 ms [Finished 0.210 s after backend start]
2025-04-23T10:52:28.032Z root INFO Backend Object.initialize: 9.7 ms [Finished 0.210 s after backend start]
2025-04-23T10:52:28.032Z root INFO Backend a.initialize: 0.2 ms [Finished 0.210 s after backend start]
2025-04-23T10:52:28.032Z root INFO Backend a.initialize: 0.1 ms [Finished 0.210 s after backend start]
2025-04-23T10:52:28.032Z root INFO Backend u.initialize: 0.2 ms [Finished 0.211 s after backend start]
2025-04-23T10:52:28.033Z root INFO Backend l.initialize: 10.1 ms [Finished 0.211 s after backend start]
2025-04-23T10:52:28.035Z root INFO configured all backend app contributions
2025-04-23T10:52:28.036Z root INFO Backend l.onStart: 0.4 ms [Finished 0.214 s after backend start]
2025-04-23T10:52:28.036Z root INFO Backend d.onStart: 0.0 ms [Finished 0.214 s after backend start]
2025-04-23T10:52:28.036Z root INFO Backend a.onStart: 0.1 ms [Finished 0.214 s after backend start]
2025-04-23T10:52:28.036Z config INFO >>> Initializing CLI configuration...
2025-04-23T10:52:28.036Z root INFO Backend x.onStart: 0.1 ms [Finished 0.215 s after backend start]
2025-04-23T10:52:28.036Z config INFO Loading CLI configuration from /Users/OldChrisAbel/.arduinoIDE/arduino-cli.yaml...
2025-04-23T10:52:28.036Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.036Z root INFO Backend w.onStart: 0.1 ms [Finished 0.215 s after backend start]
2025-04-23T10:52:28.036Z discovery-log INFO start
2025-04-23T10:52:28.036Z discovery-log INFO start new deferred
2025-04-23T10:52:28.036Z root INFO Backend v.onStart: 0.1 ms [Finished 0.215 s after backend start]
2025-04-23T10:52:28.036Z root INFO Backend a.onStart: 0.0 ms [Finished 0.215 s after backend start]
2025-04-23T10:52:28.037Z root INFO Theia app listening on http://127.0.0.1:62538.
2025-04-23T10:52:28.037Z root INFO Finished starting backend application: 1.3 ms [Finished 0.216 s after backend start]
2025-04-23T10:52:28.038Z root WARN The local plugin referenced by local-dir:/Users/OldChrisAbel/.arduinoIDE/plugins does not exist.
2025-04-23T10:52:28.038Z root WARN The local plugin referenced by local-dir:/Users/OldChrisAbel/.arduinoIDE/deployedPlugins does not exist.
2025-04-23T10:52:28.039Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"daemon":{"port":"50051"},"directories":{"data":"/Users/christianabel 1/Library/Arduino15","downloads":"/Users/christianabel 1/Library/Arduino15/staging","user":"/Users/christianabel 1/Documents/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"sketch":{"always_export_binaries":false}}
2025-04-23T10:52:28.039Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-04-23T10:52:28.039Z config INFO Loaded the CLI configuration.
2025-04-23T10:52:28.041Z config WARN Could not ensure user directory existence: /Users/christianabel 1/Documents/Arduino Error: EACCES: permission denied, mkdir '/Users/christianabel 1/Documents'
    at async Object.mkdir (node:internal/fs/promises:855:10)
    at async x.ensureUserDirExists (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1055400)
    at async Promise.all (index 1)
    at async x.initConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1051070)
2025-04-23T10:52:28.041Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/christianabel%201/Library/Arduino15","sketchDirUri":"file:///Users/christianabel%201/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-04-23T10:52:28.041Z config INFO Validating the CLI configuration...
2025-04-23T10:52:28.042Z root ERROR Check accessible failed for input: /Users/christianabel 1/Documents/Arduino Error: ENOENT: no such file or directory, scandir '/Users/christianabel 1/Documents/Arduino'
2025-04-23T10:52:28.042Z config ERROR Failed to initialize the CLI configuration. Error: InvalidConfigError:
 - Could not access the sketchbook location at '/Users/christianabel 1/Documents/Arduino': Error: ENOENT: no such file or directory, scandir '/Users/christianabel 1/Documents/Arduino'
    at x.validateCliConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1053951)
    at async x.initConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:1051517)
2025-04-23T10:52:28.048Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.048Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.048Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
    at Socket.<anonymous> (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:6391693)
    at Socket.emit (node:events:519:28)
    at addChunk (node:internal/streams/readable:559:12)
    at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
    at Readable.push (node:internal/streams/readable:390:5)
    at Pipe.onStreamRead (node:internal/stream_base_commons:191:23)
2025-04-23T10:52:28.048Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.049Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.051Z root INFO Resolve plugins list: 14.0 ms [Finished 0.229 s after backend start]
2025-04-23T10:52:28.054Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.054Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.054Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.054Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.057Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.063Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.063Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.063Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.063Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.067Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.079Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.079Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.079Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.079Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.079Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.087Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.088Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.088Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.088Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.088Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.096Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.097Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.097Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.097Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.097Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.107Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.107Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.107Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.107Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.107Z daemon INFO Daemon exited with exit code: 10.
2025-04-23 20:52:28.116 Arduino IDE[85484:986304] +[IMKClient subclass]: chose IMKClient_Modern
2025-04-23 20:52:28.116 Arduino IDE[85484:986304] +[IMKInputSession subclass]: chose IMKInputSession_Modern
2025-04-23T10:52:28.118Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.118Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.118Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.118Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.118Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.130Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.130Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.130Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.130Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.130Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.137Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.137Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.138Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.138Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.141Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.148Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.148Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.148Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.148Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.148Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.159Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.159Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.159Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.159Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.159Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.167Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.167Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.168Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.168Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.168Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.174Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.177Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.177Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.177Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.177Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.186Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.186Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.186Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.186Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.186Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.194Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.194Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.194Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.194Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.194Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.196Z root INFO Deploy plugins list: 159.6 ms [Finished 0.375 s after backend start]
2025-04-23T10:52:28.200Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.200Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.200Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.200Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.201Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.206Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.206Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.206Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.206Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.207Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.211Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.211Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.211Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.211Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.212Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.217Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.217Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.217Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.217Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.217Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.222Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.222Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.222Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.222Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.223Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.228Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.228Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.228Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.228Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.228Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.233Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.233Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.233Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.233Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.234Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.239Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.239Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.239Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.239Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.239Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.244Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.244Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.244Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.244Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.245Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.249Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.249Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.249Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.249Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.250Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.255Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.255Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.255Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.255Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.256Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.260Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.260Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.260Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.260Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.261Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.265Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.266Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.266Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.266Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.266Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.271Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.271Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.271Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.271Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.272Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.277Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.277Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.277Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.277Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.278Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.282Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.282Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.283Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.283Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.283Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.290Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.290Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.290Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.290Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.290Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.296Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.296Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.296Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.296Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.297Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.303Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.303Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.303Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.303Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.305Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.310Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.310Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.310Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.310Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.311Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.317Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.317Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.317Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.317Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.318Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.323Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.323Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.323Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.323Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.323Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.328Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.329Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.329Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.329Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.329Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.334Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.334Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.334Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.334Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.335Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.340Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.340Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.340Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.340Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.340Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.347Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.347Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.347Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.347Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.347Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.353Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.353Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.353Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.353Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.354Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.360Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.360Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.360Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.360Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.361Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.367Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.367Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.368Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.368Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.368Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.374Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.374Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.374Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.374Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.375Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.380Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.380Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.380Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.380Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.381Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.386Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.386Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.386Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.386Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.387Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.392Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.392Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.392Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.392Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-04-23T10:52:28.393Z daemon INFO Daemon exited with exit code: 10.
2025-04-23T10:52:28.398Z daemon INFO time="2025-04-23T20:52:28+10:00" level=info msg="arduino-cli version 1.2.0"
2025-04-23T10:52:28.398Z daemon INFO Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
2025-04-23T10:52:28.398Z daemon ERROR Error: Error: invalid path creating config dir: /Users/christianabel 1/Library/Arduino15 error: mkdir /Users/christianabel 1/Library/Arduino15: permission denied
Please, to make things easier (and your post more readable), always enclose all the output in a "code" tag, like you do with sketches. Edit your latest post, and select the output and click on the "<CODE/>" button.
It looks this was caused by your macOS username changing from "christianabel 1" to "OldChrisAbel" since the time you installed Arduino IDE.
The first time you run Arduino IDE, it generates a configuration file that defines the paths to several folders used by the IDE. The default locations of these folders are under your home folder, which means the username is part of the path. When you change your username it makes the paths in the configuration file outdated. When the IDE attempts to access the old path, the operating system does not allow it, which causes the startup to hang.
I think the easiest solution will be to simply delete the configuration file. Arduino IDE will automatically generate a new file on startup with the correct paths.
I'll provide instructions you can follow to do that:
  1. Select Arduino IDE > Quit Arduino IDE from the Arduino IDE menus if it is running.
    All Arduino IDE windows will close.
  2. Delete the file at the following path:
    /Users/<username>/.arduinoIDE/arduino-cli.yaml
    (where <username> is your macOS username)
    :red_exclamation_mark: The .arduinoIDE folder is hidden by default. You can make it visible by pressing the Command+Shift+. keyboard shortcut.
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
  3. Start Arduino IDE.
Arduino IDE should now start up fully and be functional as usual.
Note that the file you deleted is used to store some of your IDE preferences. These will all have been reset to the default values. If you had customized either the "Sketchbook location" or "Additional Boards Manager URLs" preferences before, you'll need to select Arduino IDE > Settings... from the Arduino IDE menus and then set those preferences once again after performing the instructions I provided above.
thank you - that worked
You are welcome. I'm glad it is working now.
Regards, Per
