I installed Arduino IDE v1.05 2 days ago and it was working fine - I was able to create, upload and run sketches to my Nano v3.0 from my WIN 7 PC.
Now I have a problem - after attempting to import a new library, the IDE just hangs when I try to start it. I tried various things to solve this but nothing has worked. I noticed that someone had posted a similar issue a few weeks ago, but can not find his post here now. I have also searched Google and the troubleshooting section, with no success.
Here are the steps I have taken so far:
searched GOOGLE and the troubleshooting guide
remove preferences.txt file
remove and re-install ARDUINO IDE v 1.05
remove ARDUINO IDE v 1.05 and install ARDUINO IDE V1.5r2
restore my PC to before I loaded ARDUINO IDE and re-install ARDUINO IDE V1.5r2
update JAVA to v55 from v51
verified that Microchip MPLABX which also uses JAVA still works properly
started arduino_debug.exe to see what it's output is
Any ideas? I have attached screen shots of two of the messages I get.
Does anyone have any solution to my problem? I tried installing the LINUX version of the IDE on one of my other PC's but it keeps freezing the PC! It's odd all other applications run on my pc's except this Arduino IDE...
I feel like i am talking to myself as there are no replies, but here is an update to my problem.
Last night I saw that a very deep directory structure had been created by the Arduino IDE. I had thought it was about 250 folders deep, so started off by renaming all the folders to a single letter 'a' but in fact it was over 2700 folders deep! If you have ever tried removing such a structure on a windoze PC, you will know it isn't easy. (try using windows exploder to do so and you will see what I mean)
I looked around for utilities to do this, and found that there is a program called 'robocopy" in WIN7 and that it should work. I'll tell you now that in my case, robocopy just failed after running for a minute or so. I had to go look for something else....
I had to run this overnight and it also stopped about 8 times, but after 8 re-starts, it had removed the stairway to heaven created by the ARDUINO IDE.
I just attempted a re-install of ARDUINO IDE 1.05 and it actually appears to open now!
How can such a fatal flaw that took me over 8 hours to resolve actually be in this ARDUINO IDE, and it does not appear that any of the developers is actually working on a fix.
I have to wonder, is a program that creates a directly structure like this which is very hard to remove actually classified as MALWARE?
I ran into this same problem today with the 1.5.7 IDE and luckily found this thread. Used the deep remove tool linked to (worked in a single run that took about 10mins for me though), and I'm back up and running.
