Running on Windows 10. Was working this morning and suddenly when I launch the application the splash screen appears and gets to "starting" and then the splash screen disappears and nothing happens. I did an uninstall and reinstall, and still same problem. Ran the arduino_debug.exe and this is what it prints:
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
c:\Program Files (x86)\Arduino>arduino_debug.exe
Looking for library 'user32'
Adding paths from jna.library.path: null
Trying user32.dll
Found library 'user32' at user32.dll
Looking for library 'shell32'
Trying shell32.dll
Found library 'shell32' at shell32.dll
Looking for library 'Ole32'
Trying Ole32.dll
Found library 'Ole32' at Ole32.dll
Loading configuration...
Initializing packages...
Preparing boards...
Starting...
java.lang.IllegalArgumentException: Font size must be > 0
at org.fife.ui.rtextarea.RTextAreaBase.setFont(RTextAreaBase.java:986)
at org.fife.ui.rsyntaxtextarea.RSyntaxTextArea.setFont(RSyntaxTextArea.java:2510)
at processing.app.EditorTab.applyPreferences(EditorTab.java:322)
at processing.app.EditorTab.(EditorTab.java:110)
at processing.app.Editor.addTab(Editor.java:1672)
at processing.app.Editor.createTabs(Editor.java:1645)
at processing.app.Editor.handleOpenInternal(Editor.java:1944)
at processing.app.Editor.(Editor.java:340)
at processing.app.Base.handleOpen(Base.java:833)
at processing.app.Base.restoreSketches(Base.java:518)
at processing.app.Base.(Base.java:456)
at processing.app.Base.main(Base.java:140)
Any thoughts? Thanks in advance.
