IDE wont open.
This AM whenever I selected the Arduino IDE shortcut , the IDE opened as an icon on the "icons" bar
but was unable to open the IDE itself. Same applies to any previous .ino files on my computer.
Windows 10 Home edition O/S. Have also now downloaded & installed Arduino -1.8.12 three times but problem persists. No windows updates or other programs have been recently installed. Have rebooted computer several times (Including "safe mode") but makes no difference.
Can anyone help.
Thanks
Did you have a second screen connected at one time and the IDE was running on the second screen? And now Windows still thinks (in some way) that there is a second screen and puts the IDE there?
No. Only have one screen.
All other shortcuts on the taskbar are accessible. Just Arduino is problem.
Please do this:
  • Start File Explorer (AKA Windows Explorer).
  • Open the Arduino IDE's installation folder (usually C:\Program Files (x86)\Arduino)
  • In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  • Click “Open PowerShell window here” (or “Open command window here” if using Windows 7). PowerShell (or cmd if using Windows 7) will now open with the current directory set to the Arduino IDE installation folder.
  • Type ./arduino_debug
  • Press Enter. Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  • Wait for the Arduino IDE to finish starting, or failing to start.
  • Switch back to the PowerShell window if the Arduino IDE window took the focus.
  • Right click on the title bar of the PowerShell window.
  • Click Edit > Select All. This will select all the text in the PowerShell window.
  • Press Ctrl + c. This will copy the contents of the PowerShell window to the clipboard.
  • In this Arduino forum thread, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply, making it easier for us to read.
  • Press Ctrl + V. This will paste the output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Click the "Post" button.
Hopefully that will give us some information we can use to help you with the problem.
Tried Pasting but exceeded 9000 characters so hope attached Notepad document will serve.
Tx for trying to help
Debug.txt (56.2 KB)
Tx for your help but I seem to have fixed the problem accidentally.
I dropped the screen resolution down from the maximum and the problem was resolved.
Not sure why ?
