IDE won't upload to UNO, will upload to Nano
Hi Folks,
Funniest thing happened the other day. While uploading code to an UNO repeatedly as I tweeked it, it all of a sudden gave me the stk500 message.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM7
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb3
I tried a different UNO, same. Then a third. Same. I tried different USB cables. Checked port, all that, nothing.
Tried a Nano and first time it uploads without problem.
I can't figure out why it would have all of a sudden stopped uploading to the UNO.
Thanks.
Goto Tools>Board>Board Manage, you have the wrong board selected. Before you switch check which bootloader you are using for the Nano incase you want to switch back.
The board is correct. It's set to uno. I didn't oroginally do anything I can recall besides just upload the code. I don't know why it won't upload. I can't even upload a bootloader to it.
Try restarting your computer. In some rare cases, the port can get stuck in an unusable state. Restarting the computer restores the port to a usable state.
Did you try that over USB or using a programmer? The former will not work.
thats right...bootloader only through ISP. I have not tried that.
well, I am still having the same issue. I can't upload to any of my 3 Unos, I can upload to a nano.
board and port is correct, i've uploaded programs before, I am familiar with the procedure.
Running Arduino 1.8.19, Arduino AVR Boards 1.8.5. Here is what I have figured out so far. IDE is pointing to system wide configuration file "C:\Users\owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" that isn't where it should be. There is no folder under \owner\ called \AppData\ I have reinstalled Arduino IDE but that didn't help. Here is the error:
         Using Port                    : COM7
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2a
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Skipping contributed index file C:\Users\owner\AppData\Local\Arduino15\ATTinyCore, parsing error occured:
com.fasterxml.jackson.core.JsonParseException: Unexpected character ('<' (code 60)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')
 at [Source: (FileInputStream); line: 7, column: 2]
java.lang.NullPointerException
java.lang.RuntimeException: java.lang.NullPointerException
	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:150)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NullPointerException
	at cc.arduino.contributions.packages.ui.ContributionIndexTableModel.lambda$updateContributions$1(ContributionIndexTableModel.java:90)
	at java.util.TimSort.binarySort(TimSort.java:296)
	at java.util.TimSort.sort(TimSort.java:221)
	at java.util.Arrays.sort(Arrays.java:1512)
	at java.util.ArrayList.sort(ArrayList.java:1462)
	at java.util.Collections.sort(Collections.java:175)
	at cc.arduino.contributions.packages.ui.ContributionIndexTableModel.updateContributions(ContributionIndexTableModel.java:89)
	at cc.arduino.contributions.packages.ui.ContributionIndexTableModel.update(ContributionIndexTableModel.java:183)
	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:148)
	... 1 more
There is. It is just hidden by the default settings of Windows "File Explorer. You can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
Hi in0,
I found the file, it is there.
I still can't upload to my uno. I tried to reinstall. Nothing.
I know my way around windows better than average, but this is beyond me.
I just want to upload a bit of code and tweak it for my needs.
Thanks again
