Pressure transducers are usually expensive, right ?
so here is my idea:
take a cheapo pressure gauge, remove the lid/glass whatever you call it (I am not a native speaker of english, sorry :-D ), glue a small neodymium magnet to the dial, put the lid/glass back on... glue a hall sensor above the centre of the gauge...
done
obviously one'd need a hall sensor that provides analog output, not those that just turn on/off when polarity changes
CHEAP pressure sensor ? Try this one as it works really well IF you can source the stuff .
About 20 years ago , IC’s use to be shipped on a " carbonized foam rubber " . This stuff was to combat static for CMOS devides etc . ANyway , this foam is RESITIVE in nature . It changes towards a LOW value when compressed . Just apply a small metal foil pad on each side of the foam and that’s it ! It works just like a potentiometer .
ANother PLUS of using this stuff is that it can be cut up with scissors to make custom pads .
