Last month I had the idea to create a "physics.h" which is a (sub)set of different physics formulas one can use. Recall what "math.h" is for math formulas.
The rationale was that while I was making a library for the DHT (temp/humidity) sensor I thought the dewPoint() formula should not be part of the sensor library as it is useful for any temp/humid sensor combination.
So physics.h doesn't do sensors, actuators or I/O, just formulas. For now I have a simple first version with a few temperature related macro's and functions.
The architecture / structure I have in mind has 2 levels, at top is "physics.h" which just includes the more specific areas => To have multiple files one can tweak physics.h to include/exclude subsets very easily. Drawback is that some formulas will fit in multiple subsections.....
The following questions: (high level)
- What do you think of this idea? why?
- What do you think of the architecture? other ideas? why?
- other remarks? why?
(low level)
4) what subsections should exist? (mechanics, electro, radiation, ...?
5) which formulas in which subsection?
6) sources for good formulas?
Please shoot! ![]()
Rob
physics.h
// FILE: physics.h
// VERSION: 0.1.00
// PURPOSE: physics functions for Arduino
// HISTORY:
// 2011-04-17 first version rob.tillaart(at)gmail.com
#ifndef physics_h
#define physics_h
#include "temperature.h"
#endif
temperature.h
// FILE: temperature.h
// VERSION: 0.1.00
// PURPOSE: temperature functions for Arduino
// HISTORY:
#ifndef temperature_h
#define temperature_h
#include "WProgram.h"
#define TEMPERATURE_LIB_VERSION "0.1.00"
// TEMPERATURE
#define Celsius2Fahrenheit(C) ((C)*9/5+32)
#define Fahrenheit2Celsius(F) (((F)-32)*5/9)
#define Celsius2Kelvin(C) ((C)+273.15)
#define Kelvin2Celsius(K) ((K)-273.15)
// DEWPOINT
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
double A0= 373.15/(273.15 + celsius);
double SUM = -7.90298 * (A0-1);
SUM += 5.02808 * log10(A0);
SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
SUM += log10(1013.246);
double VP = pow(10, SUM-3) * humidity;
double T = log(VP/0.61078); // temp var
return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double temp = (a * celsius) / (b + celsius) + log(humidity/100);
double Td = (b * temp) / (a - temp);
return Td;
#endif
// END OF FILE
