investigating about this "too many/ too few steps" i found that its rather a problem of good sequencing then a accuracy problem of the motor itself.
I found articles like this:
"Due to their rotor inertia if high speed step pulses are applied
instantly the motor under-steps and loses position. The same is true
if at high speed the step signal is switched off again the motor will
overstep and go beyond a desired stop position. Hence stepper
motors need to be ‘stepped’ precisely and sped up and slowed down
from and to a maximum step speed. Position is accurately
determined by using the PICs counting ability to add or subtract
pulses from a nominal 200 steps to ensure exact position."
So if i programm it right, it should not be a problem, should it?
