Ideas for using those 5 sensors?
Hello,
Right now, my ideas would be to use 5 sensors: MQ5, Sound sensor, Dust Sensor, DHT11, Photocell.
Next step would be to get a better rendering of the air quality by adding sensor and add a barometric sensor
I was wondering if you got ideas on how can I make this code cleaner and may get the most of it by adding new functions.
Here is the code
#include <DHT.h>
//Dust Sensor Configuration
int measurePin = A6;
int ledPower = 12;
int samplingTime = 280;
int deltaTime = 40;
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
// Photocell Configuration
int photocellPin = A0;     // the cell and 10K pulldown are connected to a0
int photocellReading;     // the analog reading from the sensor divider
//MQ5 Sensor
int sensor=A4;
int gas_value;
//Microphone Sensor
int soundDetectedPin = A2; // Use Pin 3 as our Input
int soundDetectedVal = HIGH; // This is where we record our Sound Measurement
boolean bAlarm = false;
unsigned long lastSoundDetectTime; // Record the time that we measured a sound
int soundAlarmTime = 500; // Number of milli seconds to keep the sound alarm high
//DHT Sensor
#define DHTPIN A3
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
Serial.println("DHT11 TEST PROGRAM ");
dht.begin();
pinMode(ledPower,OUTPUT);
pinMode(sensor,INPUT);
pinMode (soundDetectedPin, INPUT) ; // input from the Sound Detection Module
Serial.println("\n");
  //Dust Sensor
  digitalWrite(ledPower,LOW); // power on the LED
  delayMicroseconds(samplingTime);
  voMeasured = analogRead(measurePin); // read the dust value
  delayMicroseconds(deltaTime);
  digitalWrite(ledPower,HIGH); // turn the LED off
  delayMicroseconds(sleepTime);
  // 0 - 3.3V mapped to 0 - 1023 integer values
  // recover voltage
  calcVoltage = voMeasured * (3.3 / 1024);
  dustDensity = 0.17 * calcVoltage - 0.1;
  Serial.print("Raw Signal Value (0-1023): ");
  Serial.print(voMeasured);
  Serial.print(" - Voltage: ");
  Serial.print(calcVoltage);
  Serial.print(" - Dust Density: ");
  Serial.println(dustDensity);
  //SoundSensor
  soundDetectedVal = analogRead (soundDetectedPin) ; // read the sound alarm time
  //Photocell
  photocellReading = analogRead(photocellPin);
  //MQ5 Sensor
  gas_value=analogRead(sensor);
  //DHT11
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  if (isnan(h) || isnan(t))
  Serial.println("Failed to read from DHT sensor!");
  return;
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" degrees Celsius Humidity: ");
  Serial.print(h);
  Serial.print("Gas Sensor Value:");
  Serial.println(gas_value);
  Serial.print("Photocell Reading = ");
  Serial.println(photocellReading);     // the raw analog reading
  Serial.print("Sound Reading = ");
  Serial.println(soundDetectedVal);     // the raw analog reading
//Microphone Sensor
If you are going to have useless comments, you MUST make then accurate, useless comments.
dht.begin();
Some
indenting
would
certainly
help.
Put the blank line BETWEEN the functions, not at the end of the function.
Stupid stuff should be commented.
Comments should explain WHY the code is the way it is, not what the code is doing. Anyone can see that you are turning a pin on and off. What is NOT clear is why you are turning an LED on and off. I suspect that there is not really an LED connected to that pin. If that is the case, the name of the variable sucks.
I really don't see what role the sound sensor plays, with the gas sensor, etc. What, exactly, are you trying to accomplish?
  return;
If the temperature sensor fails, why does that mean that you don't care about the sound level, etc.?
Thanks, I am gonna correct this. The sound sensor was supposed to be added to a PIR in order to detect sound people in the room. This could be during the day or the night.
